#1 2020-09-29 14:20:33
dev2cosmos
netinstall or dvd images
Hello
i have old hard drive i want to fill with devuan, i want to have it as archive for operating system and programs that may work 20 years from now on hardware i have that works with devuan fine. What would be the best way of getting a vast library of packages, i dont want whole debian repositories just broad spectrum of applications. Would i be better off installing from dvd sets or can netinstall do same thing?
edit: oops im sorry, i come from debian and see there is no dvd sets available that i search for, maybe in the future i hope.
I suppose slackware is better option for archival operation linux system. I have so many issues last 6 months with systemd and debuan when i find devuan it just work and keep working day after day, same with slackware.
#2 2020-09-29 16:28:53
Re: netinstall or dvd images
It's not clear whether you want to archive just your installation or if you want the whole dvd set (i.e. the whole repo).
If you choose a mirror during the install, it doesn't matter whether you use the dvd or the netinstall iso - it will pull from the repo and will be current.
If you really want ALL the packages from the repo on dvd, then take the devuan dvd for installing a fresh system and take the debian dvd set to pull any individual packages you might want that aren't on the devuan dvd. Just don't install any packages from the debian disks that need systemd.
If you really want it to still work in 20 years, you should probably install to a virtual disk, so you aren't limited by lack of hardware support in 20 years.
#3 2020-09-30 13:08:08
dev2cosmos
yep im get confused on this, sorry for posting.
The dvd sets from debian sound like a good idea. I dont want whole repo just enough of a variety of programs, the 3 dvd images debian has at 4g each seem like that would cover what i wanted.
I had planned to have time capsule of my old laptop with a few hard disks with debian, devuan and slackware on them, put them into faraday sealed suitcase and put into storage area, but then i think of battery life of the laptops so probably not a good idea, so maybe just the hard disks with cables and mounting hardware / external enclosures.
Is in your opinion the virtual disk a better method for this type of archive?
#4 2020-09-30 16:40:20
For archives you should use archival Blu-Rays or DVDs. Hard drives don't last long.
#5 2020-10-02 13:32:01
dev2cosmos
Will dvd / blue ray drives be around 20 years from now?  It might be ok to say yes archive on this medium it is future proof, but is it?
#6 2020-10-02 18:26:42
larsH
Hi
The problem 20 years from now, will be to find something that play a DVD or Bluray. Remember tapedrives (still used when reliability is important) and Floppys. Maybe a portable ssd might still be supported. And probably tapes still as well ;-). But what format ???
Have a nice day
Lars H
#7 2020-10-03 15:23:22
That is a very good question: https://www.quora.com/Will-DVDs-still-be-around-in-2037
But the point of archival DVDs & Blu-Rays is that at least they'll definitely last until the players stop being available, at which point you can transfer the data to another medium.
#8 2020-10-03 15:56:12
dev2cosmos
at which point another medium of hardware might be able to transfer the data from and archival dvd/blueray. I dont doubt this at all, will have to wait and see smile
#9 2020-10-03 19:11:21
xinomilo
Unknown
+1
after 20years, you can still move the virtual disk around.. backup it up, grow/shrink disk space... easier management, than a hdd/dvd that could suffer errors/get lost/break/etc in that time...
