#1 2020-09-12 16:26:51
openbox menu issue
I'm (slowly) installing Devuan3 on a spare drive in my ascii box so I can eventually migrate without any headaches.
One of the things I want to do is use Openbox instead of Xfce of which I have grown rather tired.
I have it on a skeleton VM installation albeint on a single screen (vis-a-vis my 3-screen ascii)  and it works well enough form the time being.
I can start gparted there via lxterminal -e su - gparted but I would like to avoid using sudo.
Same with synaptic, which I keep to use as a GUI to look for applications as I am getting used to apt or apt-get.
So I try using lxterminal -e su - gparted but I only get a flicker on the screen.
My DM is SLiM and I wonder if this is not due to its starting X as root?
If I open the terminal and try to start gparted I get this:
~$ su -
Password:
~# gparted
(gpartedbin:3660): Gtk-WARNING **: 16:23:29.432: cannot open display:
Is there a way around this or do I have to install sudo and a set up sudoers?
#2 2020-09-12 17:20:05
Re: openbox menu issue
For gparted just run the wrapper script at /usr/sbin/gparted directly from the menu entry.
For synaptic run the /usr/bin/synaptic-pkexec wrapper script from the menu entry and also install a graphical polkit authentication agent such as mate-polkit and then add this line to ~/.config/openbox/autostart:
/usr/lib/x86_64-linux-gnu/polkit-mate/polkit-mate-authentication-agent-1 &
*Do not* use su or sudo to launch graphical applications with elevated permissions, it is stupid and dangerous.
#3 2020-09-12 20:06:21
... run the wrapper script at /usr/sbin/gparted directly from the menu entry.
obmenu -> /usr/sbin/gparted in the 'Execute' box does not work.
... install a graphical polkit authentication agent ...
Looking around I found /etc/xdg/autostart/polkit-gnome-authentication-agent-1.desktop and the the executable is there.
groucho@devuan3:~$ locate gnome-authentication-agent
/usr/lib/policykit-1-gnome/polkit-gnome-authentication-agent-1
groucho@devuan3:~$
I also came upon lxpolkit on the web which in 2010 replaced gnome-polkit in LXDE.
Seems it is leaner and more suited to LXDE.
Good to know.
But it was the only way I got synaptic and gparted to run in my VM with Openbox.
I now have the same problem ...
Thanks for your input.
#4 2020-09-12 21:35:39
F_Sauce
Hello.
A bit on the side, but if you want to learn parted, from cli that is, you may find this useful: https://www.gnu.org/software/parted/manual/parted.html, it's not too hard really; neither is fdisk for that matter.
Olav
I'm on Devuan with KDE
#5 2020-09-12 21:42:17
Works for me. Do you see any error messages if you run /usr/sbin/gparted directly in a terminal?
Can we see
grep -A2 gparted ~/.config/openbox/menu.xml
But it's not being run:
/usr/lib/x86_64-linux-gnu/openbox-xdg-autostart --list
pgrep -a polkit
#6 2020-09-12 22:22:09
... any error messages if you run /usr/sbin/gparted directly in a terminal?
groucho@devuan3:~$ /usr/sbin/gparted
localuser:root being added to access control list
Error executing command as another user: No authentication agent found.
localuser:root being removed from access control list
groucho@devuan3:~$
groucho@devuan3:~$ su
Password:
root@devuan3:/home/groucho# /usr/sbin/gparted
sh: 1: dmidecode: not found
libparted : 3.2
In this last instance, via su (not su -), gparted ran.
root@devuan3:/home/groucho# su -
root@devuan3:~# /usr/sbin/gparted
(gpartedbin:2414): Gtk-WARNING **: 21:52:42.365: cannot open display:
root@devuan3:~#
Can we see
Of course ...
groucho@devuan3:~$ grep -A2 gparted ~/.config/openbox/menu.xml
		<item label="gparted">
			<action name="Execute">
				<execute>/usr/sbin/gparted</execute>
			</action>
		</item>
groucho@devuan3:~$
/usr/lib/x86_64-linux-gnu/openbox-xdg-autostart --list pgrep -a polkit
Hmm ...
groucho@devuan3:~$ /usr/lib/x86_64-linux-gnu/openbox-xdg-autostart --list pgrep -a polkit
ERROR: openbox-xdg-autostart requires PyXDG to be installed
groucho@devuan3:~$
Interesting ...
But I previously ran apt-update, apt-upgrade and apt install -f and everything seemed to be right.
Seems the Openbox package needs to add this missing package to the depends list?
root@devuan3:~# apt update && apt upgrade && apt install -f
Hit:1 http://pkgmaster.devuan.org/merged beowulf InRelease
Hit:2 http://pkgmaster.devuan.org/merged beowulf-security InRelease
Hit:3 http://pkgmaster.devuan.org/merged beowulf-updates InRelease
Hit:4 http://pkgmaster.devuan.org/merged beowulf-backports InRelease
Building dependency tree
All packages are up to date.
Calculating upgrade... Done
root@devuan3:~#
groucho@devuan3:~$ su -
Password:
root@devuan3:~# apt install python-xdg
  python-xdg
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 35.9 kB of archives.
After this operation, 169 kB of additional disk space will be used.
Get:1 http://pkgmaster.devuan.org/merged beowulf/main amd64 python-xdg all 0.25-5 [35.9 kB]
Fetched 35.9 kB in 1s (35.7 kB/s)
Selecting previously unselected package python-xdg.
(Reading database ... 64424 files and directories currently installed.)
Preparing to unpack .../python-xdg_0.25-5_all.deb ...
Unpacking python-xdg (0.25-5) ...
Setting up python-xdg (0.25-5) ...
root@devuan3:~#
Right, now that python-xdg is installed, we continue and get this:
	  File: /home/groucho/.config/autostart/xscreensaver.desktop
	* Excluded by: Missing Exec field
	  File: /home/groucho/.config/autostart/xfce4-clipman-plugin-autostart.desktop
	  Executes: xfce4-clipman
[*] User folders update
	  File: /etc/xdg/autostart/xdg-user-dirs.desktop
	  Executes: xdg-user-dirs-update
[*] Wicd Network Manager Tray
	  File: /etc/xdg/autostart/wicd-tray.desktop
	  Executes: wicd-gtk --tray
[*] PulseAudio Sound System
	  File: /etc/xdg/autostart/pulseaudio.desktop
	  Executes: start-pulseaudio-x11
[ ] PolicyKit Authentication Agent
	  File: /etc/xdg/autostart/polkit-gnome-authentication-agent-1.desktop
	  Executes: /usr/lib/policykit-1-gnome/polkit-gnome-authentication-agent-1
	* Excluded by: OnlyShowIn (XFCE, Unity, X-Cinnamon)
[*] AT-SPI D-Bus Bus
	  File: /etc/xdg/autostart/at-spi-dbus-bus.desktop
	  Executes: /usr/lib/at-spi2-core/at-spi-bus-launcher --launch-immediately
[ ] gnome-disk-utility notification plugin for GNOME Settings Daemon
	  File: /etc/xdg/autostart/org.gnome.SettingsDaemon.DiskUtilityNotify.desktop
	  Executes: /usr/lib/gnome-disk-utility/gsd-disk-utility-notify
	* Excluded by: OnlyShowIn (GNOME)
[ ] Xfsettingsd
	  File: /etc/xdg/autostart/xfsettingsd.desktop
	  Executes: xfsettingsd
	* Excluded by: OnlyShowIn (XFCE)
groucho@devuan3:~$
I removed XFCE to see if I could just use Openbox, which is probably the cause of what is happening.
Cheers,
#7 2020-09-12 22:39:02
groucho@devuan3:~$
So is the policykit-1 package installed?
That OnlyShowIn bit indicates that the program will only be autostarted for the listed desktops so you need to add this line to ~/.config/openbox/autostart:
/usr/lib/policykit-1-gnome/polkit-gnome-authentication-agent-1 &
Both the policykit-1 package and a graphical authentication agent need to be running for a graphical password prompt to be presented.
Polkit is the modern way to run graphical applications with elevated privileges and minimises the security risks in comparison to su &sudo or gksu & gksudo (the latter two have been removed from beowulf because of the inherent risks).
It is possible to get gparted running with su but I'm not telling you how tongue
#8 2020-09-12 23:48:10
The gnome version.
That OnlyShowIn bit indicates that the program will only be autostarted for the listed desktops ...
... policykit-1 package and a graphical authentication agent need to be running ...
Both gparted and synaptic are working now.
Would it be better to run lxpolkit instead of this one?
Polkit is the modern way to run graphical applications ...
... minimises the security risks in comparison to su &sudo or gksu & gksudo.
Yes, I understand.
But the 'Custom actions' I hace set up in Thunar, such as "Edit as root" or "Open root Thunar here" use gksudo.
Command: gksu -l pluma %f and Command: gksu thunar %f in 'Edit' -> 'Configure custom actions ...'
How do I get them working with polkit?
... gparted running with su but ...
Why would I want to do that?
It is stupid! 8-D!
Cheers,
#9 2020-09-13 02:06:53
Found it:  Command: pkexec -l pluma %f and Command: pkexec thunar %f in 'Edit' -> 'Configure custom actions ...'
A question remains:
Would it be better to run lxpolkit instead of gnome-polkit?
Cheers,
#10 2020-09-13 10:05:03
A better solution for the editor might be to use gedit with the GVFS admin:// backend (gedit admin://%f), which can also be used with thunar in the latest (4.14) version (thunar admin://%f, not available for the beowulf package though).
Meh. Perhaps use ps_mem to see which one uses less memory but I really don't think it's critical.
#11 2020-09-13 22:12:08
Found it:  Command: pkexec pluma %f ...
... does not work.
According to the xfce page it should work:
Edit file as root
Name: Edit as root
Command: gksu put-your-favourite-text-editor-here %f
File pattern: *
Appears if selection contains: Text files
Note: You'll need to replace put-your-favourite-text-editor-here with your favourite text editor (e.g. mousepad or geany). Also, see previous note about gksu.   -> Note: Some distributions no longer include gksu. Use pkexec instead.
https://docs.xfce.org/xfce/thunar/custo … le_as_root
What am I missing?
Thanks in advance,
#12 2020-09-14 18:26:08
What am I missing?
The pluma package doesn't supply a polkit rule so you'll have to roll your own, see /usr/share/polkit-1/actions/org.gnome.gparted.policy for an example of this.
Another alternative would be Command: x-terminal-emulator -e sudoedit %f and then add this line to ~/.config/openbox/environment:
export SUDO_EDITOR=pluma
That would open a terminal so that you could enter the user's password and then pluma would be run under sudoedit(8) which opens the GUI under the normal user and only invokes root privileges to actually save the file. This solution needs the sudo package but it is the best way (IMO).
