#1 2020-09-09 15:32:05
giorgiob
Migration ascii -> beowulf. Mate Shut Down disappeared
One week ago I migrated my work laptop from Devuan ascii to beowulf. Everything seemed to go fine but when I logged in into my mate desktop I realised that the meny entry System -> Shut Down was gone. Now I have to enter
$ sudo shutdown -h -P now
in a terminal to shutdown.
Is this a know problem and is there a solution? I haven't found anything in the forum.
#2 2020-09-09 16:04:11
Re: Migration ascii -> beowulf. Mate Shut Down disappeared
Is the elogind package installed?
Black Lives Matter
#3 2020-09-11 14:46:52
giorgiob
Thanks a lot. elogind had indeed not been installed. I do not know exactly why and I hadn't noticed any error during the dist-upgrade. I have installed it not (it had to remove consolekit, if I remember correctly) and now the shutdown function is back.
#4 2020-09-11 17:50:32
Fantastic, please prepend [SOLVED] to the thread title to help others who may encounter this issue.
Black Lives Matter
