#1 2020-08-12 17:46:44
walterbyrd
How do I install CUPS?
# apt-get install cupsys
Building dependency tree
E: Unable to locate package cupsys
System -> Administration -> Synaptic Package Manager
Indicates that CUPS is installed, but I find no trace of it.
UPDATE:
Nevermind, CUPS is installed. For some reason systemname:631 did not bring it up. Using 127.0.0.1 seems to work.
Not about to install foomatic.
# apt-get install foomatic-db, foomatic-filters-ppds, foomatic-filters, foomatic-db-hpijs hplip hpoj
E: Could not get lock /var/lib/dpkg/lock-frontend - open (11: Resource temporarily unavailable)
E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), is another process using it?
#2 2020-08-12 17:54:03
Re: How do I install CUPS?
# apt install cups
#3 2020-08-12 18:47:03
When Synaptic is open you can't install anything with apt(-get).
