#1 2020-08-10 09:46:54
Dutch_Master
GTK error after recent update
Recently I updated my Ascii system and it included some nVidia drivers as well. Most applications work as before, but this one doesn't:
$ gweled
Gtk-Message: Failed to load module "atk-bridge"
(gweled:8431): GLib-WARNING **: GError set over the top of a previous GError or uninitialized memory.
This indicates a bug in someone's code. You must ensure an error is NULL before it's set.
The overwriting error message was: Operation not supported
Segmentation fault
I ran
dpkg --configure -a
but that didn't throw up any mis- or unconfigured packages.
Any ideas?
