Pages: 1
Dont use pulseaudio
In most situations you do not need pulseaudio. Just use alsa instead. This will reduce latency and overhead.
Alsa is enabled by default. Volume and audio device can be choosen and adjusted in a terminal using the command "alsamixer".
If you want to adjust with a gui install volumeicon-alsa from a terminal with "apt install volumeicon-alsa" as root. Add it to your desktop startup (howto depend on the enviroment). But it can also be started from a terminal using the command "volumeicon" Right click the voulmeicon to configure preferences.
And that should be about it.
For those who have laptops with HDMI outputs see this guide for setting the non-HDMI output as the default:
Black Lives Matter
With 2 devices sharing the same kernel module, you can disable the one which you are not using. You use the enable parameter, where 0=disable and 1=enable. You could set the entry in /etc/modprobe.d/alsa-base.conf to :-
# Disable the HDMI card which shows up first, but enable PCH
options snd-hda-intel enable=0,1
https://dev1galaxy.org/viewtopic.php?pid=339#p339
Geoff
And if the software you use depends on PA and they don't use ALSA, try wrapping the program with apulse, which is available in Devuan since oldstable ASCII. I use it for Seamonkey, where the official build wasn't compiled with support for ALSA.
You can also use KDE without pulseaudio. Screenshots here was taken on a Beowulf 64 bits box with KDE.
I use KDE with VLC sound engine. By default, KDE try to use pulseaudio, but pure ALSA is also available in GUI configuration.
Go to K, Preferences, System Preferences, Hardware, Audio and Video. You may need to check Show advanced devices: (click to full size):
If you (like me) dont have pulseaudio installed, clicking the Test button when pulse is selected will show an error on console:
main audio output error: no suitable audio output module
main decoder error: failed to create audio output
vlcpulse audio output error: PulseAudio server connection failure: Connection refused
Dragging and dropping or with the Prefer button, put the option Default to first position:
Then, Apply Device List to all the categories (YMMV).
Now, you can listen audio even on Dolphin:
Even with pulse I ran into an Issue getting Audio out of my HDMI to the TV.
I used Alsa to push audio out the HDMI port as a test. I was able to push sound out through HDMI and it came out the Tv.
However, I was unable to get the media player to push it through the TV.
Was odd sure it is an Easy fix. Pulse wouldn't do it. I tried changing every setting possible found no sound.
I had pulse installed I maybe should try removing pulse and changing default to HDMI and rebooting.
Could you elaborate on this? I dont understand you.
Pages: 1
