#1 2020-07-27 20:56:45
Vernon
HOWTO: Beowulf - Connect the best bluetooth mouse - MX Anywhere 2
First, verify that your computer Bluetooth device supports Low Energy. If your Bluetooth device does not support Low Energy, the Logitech MX Anywhere 2 Bluetooth mouse will not pair and the instructions below will not work.
Why is the Logitech MX Anywhere 2 Bluetooth mouse the best mouse?
  • Ratcheting or free wheeling scroll wheel
  • Dedicated Middle Mouse button to easily perform X windows copy and paste
  • Easily switch between up to three paired computers.
  • Most of all, tracks on almost any hard surface - including glass tables
Enough introduction. Let's get connected!
Broadcom Bluetooth chipset instructions
Become root using the su - command. Note that the dash is required since we will be using programs residing in the sbin sub-directories. Then follow the instructions here to install the firmware manually.
Important Notes
  • Firmware for individual Broadcom chipsets can be obtained here.
  • The firmware file name must match exactly what was detected missing by your kernel from the dmesg command output.
  • The required firmware (.hcd file) must be placed in directory /lib/firmware/brcm.
  • Note that the /lib/firmware/brcm directory does not exist and you will have to create it.
  • If you don't feel comfortable installing manually, a Debian package is available here. Note that I installed manually and have not tested this package.
If you installed correctly, you should have an entry in you dmesg output that looks something like this after reboot..
bluetooth hci0: firmware: direct-loading firmware brcm/BCM20702A1-0a5c-21e8.hcd
Connect the Logitech MX Anywhere 2 Bluetooth mouse
Follow the instructions here. If you followed the instructions correctly and had success, the Logitech MX Anywhere 2 Bluetooth mouse will automagically connected to your computer every time you boot up - no initialization steps needed except to power the mouse on.
