Updated with instructions for freevpn.me, a free, no-signup vpn provider that allows all traffic.
Many VPN providers have support for openvpn. VPN providers 'usually have a separate .ovpn file for each individual server. Some frequently change their keys, passwords and certificates. As a result, it is easier to invoke openvpn from the command line rather than loading and unloading .ovpn configurations into a network manager.
Become root using the following command.
su -Note the dash at the end of the su command. This is required because we will be running tools from the sbin directories.
Install openvpn and resolvconf packages using the following command.
apt-get install openvpn resolvconfSince we want to invoke openvpn from the command line, we don't want openvpn running a daemon. To accomplish this, issue the following commands.
/etc/init.d/openvpn stopupdate-rc.d openvpn disablewget https://freevpnme.b-cdn.net/FreeVPN.me-OpenVPN-Bundle-July-2020.zipunzip FreeVPN.me-OpenVPN-Bundle-July-2020.zipcd FreeVPN.me-OpenVPN-Bundle-July-2020/FreeVPN.me\ -\ Server1-NLAdd the following lines to each .ovpn file to prevent DNS leakage.
script-security 2
up /etc/openvpn/update-resolv-conf
down /etc/openvpn/update-resolv-confInstead of adding manually, you can use the following script below.
#!/bin/bash
for i in *.ovpn
do
sed -i "/auth-user-pass/a script-security 2\\
up /etc/openvpn/update-resolv-conf\\
down /etc/openvpn/update-resolv-conf" $i
doneFor example, If you want to connect to the freevpn.me VPN server over TCP at port 443, invoke openvpn as root with the following command.
openvpn Server1-TCP443.ovpnEnter the username and password when prompted from the freevpn.me web site here
To stop openvpn, press the Ctrl+c keys simultaneously.
Go to https://www.dnsleaktest.com/
Make sure that this web page is reporting your VPN provider's IP address and not your Internet Service Provider's IP address.
Click on Standard Test
Make sure that the IP addresses reported are from your VPN provider and not from your Internet Service Provider'.
Corrections and Comments are welcome.
Have a great day, Vernon! Thank you for the instructions! They helped me a lot with setting Beowulf Connect to my VPN provider with OpenVPN.
Have a great day, Vernon! Thank you for the instructions! They helped me a lot with setting Beowulf Connect to my VPN provider with OpenVPN. By my opinion, this is one of the best no logging VPNs today. One problem I got is the unzipping of OpenVPN/free VPN packages from freevpn.me.. My antimalware program kept deleting the files even when I added the folder in exclusions; it took some time to delete it from the computer to install all required packages for https://bestvpnprovider.co. Once again, thank you, and keep providing good and detailed instructions!
