#1 2020-07-24 18:04:19
Danielsan
Devuan Chimaer as guest on Virtualbox: any known issues?
Hi guys,
I am trying to figure out if Devuan Chimaera plays nice with Virtualbox, so far I encountered some issues that Debian testing doesn't have. For example I cannot share folders from W10 host to Devuan guest while I can with Debian Testing. There are some modules missing in Devuan, I have not idea if this depends by the fact that Virtualbox is so tied to systemd right now.
That is a real shame a Virtual Linux Machine is a fundamental part of my daily workflow and it would be fantastic working again with Devuan. Actually I used to work with Devuan Ascii for one year on a MacOS host with Virtualbox and stuff like shared folders worked fine.
Are there any known issues of which I am unaware?
#2 2020-07-24 19:45:51
Re: Devuan Chimaer as guest on Virtualbox: any known issues?
No issues here with latest VB directly from Oracle on Beowulf and Chimaera as guest. No issues with systemd.
Have you installed the extension pack?
#3 2020-07-24 20:42:49
Danielsan
Yes of course, I also installed the Guest Addition but no traces of vboxdrv, and vboxsf and vboxvideo exist as modules but won't load even if I put in /etc/modules/modules.conf.
On the same HOST I have also Debian testing which works perfectly with all these features available...
#4 2020-07-26 09:42:27
I am running 6.1.10 directly from Oracle, installed with dpkg -i. Extension pack installed, and guest extensions in each of my old and new virtual machines.
Had some fun to get it working on Beowulf, see https://dev1galaxy.org/viewtopic.php?id=3641.
Maybe it helps. Good luck, rolfie
#5 2020-07-26 11:45:08
VirtualBox is a buggy pile of shite which is slower than QEMU/KVM and the developers have a tendency of covering up and ignoring security issues.
See also https://bugs.debian.org/cgi-bin/bugrepo … bug=794466
And it relies on blobs.
#6 2020-07-27 13:25:19
Danielsan
I see, but the other alternative I have on Windows is hyper-v of M$ which is even worst.
#7 2020-07-27 15:42:44
HevyDevy
So not a good alternative at all then, thread solved! LOL
#8 2020-07-27 17:12:11
QEMU is available for Windows: https://www.qemu.org/2017/11/22/haxm-usage-windows/
#9 2020-07-27 20:20:24
Maybe you're right. But for me VBox does what I expect it to do. I can pass through USB drives w/o any problem, UEFI mode is sort of crap but available. I can boot a VM from an iso, ....
Tried the same with qemu/kvm and gave up when bold promoters of qemu/kvm didn't have any advise how to solve my issues. I guess this highly promoted piece of SW still requires a lot of brains to really make it a competition for VBox.
#10 2020-07-27 20:49:19
https://wiki.archlinux.org/index.php/QE … USB_device
rolfie wrote:
UEFI mode
# apt install ovmf
kvm -m 4G -cdrom devuan.iso -bios /usr/share/ovmf/OVMF.fd
See also http://forums.debian.net/viewtopic.php?f=16&t=144775
EDIT: or just use gnome-boxes, which offers USB pass-through OOTB with no configuration required.
