#1 2020-07-20 17:45:47
Devuan ascii 2.1 - 'Kept back' packages
I was in the process of updating/upgrading a Devuan image I burn to a USB plug as an emergency recovery tool.
groucho@devuan:~$ uname -a
Linux devuan 4.9.0-12-amd64 #1 SMP Debian 4.9.210-1+deb9u1 (2020-06-07) x86_64 GNU/Linux
groucho@devuan:~$
The image was built with refracta snapshot 10.2.4 (20190713).
It is supposed to live inside the box, plugged into a USB socket on the MB but I've been sloppy lately so it is outside and not updated.
But I digress ...
On starting the process I came across this:
groucho@devuan:~$ sudo apt-get update
[sudo] password for groucho:
Get:1 http://deb.devuan.org/merged ascii InRelease [25.6 kB]
Get:2 http://deb.devuan.org/merged ascii-security InRelease [25.6 kB]
Get:3 http://deb.devuan.org/merged ascii-updates InRelease [25.6 kB]
Get:4 http://deb.devuan.org/devuan ascii-proposed InRelease [54.5 kB]
Get:5 http://deb.devuan.org/merged ascii-backports InRelease [25.6 kB]
Get:6 http://deb.devuan.org/merged ascii/main amd64 Packages [7198 kB]
Get:7 http://deb.devuan.org/merged ascii/contrib amd64 Packages [50.8 kB]
Get:8 http://deb.devuan.org/merged ascii/non-free amd64 Packages [78.8 kB]
Get:9 http://deb.devuan.org/merged ascii-updates/main amd64 Packages [3504 B]
Fetched 7488 kB in 9s (767 kB/s)
groucho@devuan:~$ sudo apt-get upgrade
Building dependency tree
Calculating upgrade... Done
  linux-headers-amd64 linux-image-amd64                           <------------ this
  glib-networking glib-networking-common glib-networking-services libcups2 libgnutls30 libneon27-gnutls libopenjp2-7 libperl5.24
  linux-compiler-gcc-6-x86 linux-kbuild-4.9 nfs-common perl perl-base perl-modules-5.24 tzdata wpasupplicant xdg-utils
17 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
Need to get 12.6 MB of archives.
After this operation, 63.5 kB of additional disk space will be used.
Makes me wonder because I have linux-headers-amd64 and linux-image-amd64 as essential.
¿Why are these packages being kept back?
¿Is there some application that would break if forced the upgrade?
If so, ¿how can I find out which one?
Thanks in advance,
#2 2020-07-20 18:03:10
Re: Devuan ascii 2.1 - 'Kept back' packages
The kernel & headers metapackages need to install new versions of their dependencies so use either
sudo apt-get dist-upgrade
or
sudo apt-get upgrade --with-new-pkgs
#3 2020-07-20 19:27:36
The kernel & headers metapackages need to install new versions of their dependencies ...
Right ...
But why has this happened with my VM Devuan ascii ...
groucho@devuan:~$
... and not with my everyday rig:
groucho@devuan:~$
ie: what difference is there between them that causes those packages to be kept back? <- which was the reason for my OP.
There's more ...
EDIT:
It seems that between running apt-get update and apt-get upgrade on my rig and then doing the same on the VM used for the USB plug, the repos were updated.
So it looked like two different update/upgrade processes were taking place.
ie: one machine did it on the repos just before they were updated and the other just after they were updated.
Just what are the chances?  8^D
Thanks a lot for your input.
Cheers,
