#1 2020-07-04 14:11:43
kuleszdl
[Solved] Kernel package held back - why?
I tried to install the unstable kernel on beowulf (not from backports) as follows:
cat <<'EOF'>>/etc/apt/sources.list.d/unstable.list
deb http://deb.devuan.org/merged unstable main
EOF
cat <<'EOF'>>/etc/apt/preferences.d/99unstable
# Never prefer packages from unstable
Package: *
Pin: release a=unstable
Pin-Priority: 1
# Allow upgrading kernel from unstable
Package: linux-image-arm64
Pin-Priority: 500
EOF
apt update
apt dist-upgrade
This used to work fine in the past, but since the new kernel 5.7 is available in unstable it tells me that packages have been held back.
When I try to install the package "linux-image-arm64" manually, it tells me that it has an unmet dependency to linux-image-5.7.0-1-arm64 that is not going to be installed. Simply installing this dependency by hand resolves the issue. However, I would like to get automatic updates when new kernels become available as well, so this is not the right solution I guess.
Any ideas how to solve this better?
#2 2020-07-04 14:45:56
Re: [Solved] Kernel package held back - why?
Use this in /etc/apt/preferences.d/99unstable:
Package: *
Pin-Priority: 100
^ That treats unstable just like backports so that packages explicitly installed from there will be kept updated.
Black Lives Matter
#3 2020-07-04 15:06:51
kuleszdl
Thank you! But I will have to install the package from unstable once for this to work, i.e. just running the dist-upgrade will not work, right?
#4 2020-07-04 15:08:39
Yes, that's right:
# apt update
# apt install -t unstable linux-image-arm64
EDIT: update the database before installing.
Black Lives Matter
#5 2020-07-04 15:22:15
kuleszdl
This seems to do the trick - thank you a lot!
