#1 2020-07-03 15:07:28
roluan17
[solved]Upgrading to Beowulf packages held back
I don't know whether my question has anything to do  with the problems described above ...
I did upgrade from ascii to beowulf.
when I do
apt-get upgrade
I get:
Die folgenden Pakete sind zurückgehalten worden:
  elogind libelogind0 libpam-elogind
meaning the following packages have been held back
Everything seems to work fine on my machine, but I'd like to know if I need to take action?
Which part of beowulf needs elogind, libelogind0 and  libpam-elogind?
How could I have found out for myself?
greetings
#2 2020-07-03 17:32:28
Re: [solved]Upgrading to Beowulf packages held back
No, it does not. Perhaps use the report button and request that this be split into it's own thread.
when I do
apt-get upgrade
I get:
Use apt full-upgrade to allow those packages to be installed.
Yes, elogind should be installed to replace systemd-logind.
mckaygerhard wrote:
your problem roluan17 are a devuan problem.. deprecated packages in repository AGAIN
Nonsense.
Black Lives Matter
#3 2020-07-04 21:13:15
roluan17
apt full-upgrade
made no difference.
So I tried
apt-get install elogind libelogind0 libpam-elogind
after update there was no
"packages held back"
message any more.
Thanks for helping.
#4 2020-07-06 02:58:30
vlax
it works for me too,
roluan17 wrote:
apt full-upgrade
made no difference.
So I tried
message any more.
Thanks for helping.
yes, thanks
satellite mestizo
