#1 2020-06-23 15:25:56
macondo
How can I install 'runit'?
The only options during install (Expert) is sysvnit and openrc.
#2 2020-06-23 15:32:28
HevyDevy
Re: How can I install 'runit'?
You would need to install it once you have a bootable system with sysvinit or openrc thus replacing the init.
see here: http://dev1galaxy.org/viewtopic.php?id=3628
#3 2020-06-23 15:59:38
macondo
Thanks, heavy.
it did not work for me, server error, purged runit and re-installed sysvinit, rebooted and got sysvinit back.
#4 2020-06-23 18:03:33
Really? Can you post the X.Org log file?
I did test my method in a VM and the Xfce desktop seems to work just fine:
antifa ftw!
