Ran into something this afternoon i thought strange, it probably because im missing something or other.
On beowulf using sysvinit, dbus disabled i installed xdm , rebooted and xdm failed to source .profile.
I have .xinitrc softlinked to .xsession
Should i be using .xprofile instead? <-- tried this, did not work copying over contents of .profile to .xprofile, not having .profile sourced means it loses some of my $PATH setup there.
In the meantime i found a decent fix whereby i just add in a file to /etc/X11/Xsession.d/75local-profile
# Source a users .profile, etc
PROFILES="/etc/profile $HOME/.profile /etc/xprofile $HOME/.xprofile"
for PROFILE in $PROFILES ; do
[ -f "$PROFILE" ] && . "$PROFILE"
done
/bin/truecredit to https://lists.debian.org/debian-user/20 … 02457.html
If you place a file at ~/.xsessionrc it will be read by any and all display managers (and also the startx command) without any need for special hacks.
https://wiki.debian.org/Xsession
And you should use ~/.xsession instead of ~/.xinitrc (rather than as well as), at least according to the startx man page.
ok Hoas, on your advice i have removed .xinitrc and .xsession (not your advice on removing those files but if just using .xsessionrc they should not be needed right?)
I only have .xsessionrc and in that file is
exec dwm
.profile is still not sourced so lets add in what it says in regards to Xsession
You may dot in some other POSIX shell configuration file: if [ -r ~/.profile ]; then . ~/.profile; fi
nope .profile is still not being sourced.
Oh really? In which case sorry for the misinformation. I've never actually tried xdm.
EDIT: hold on, did you source ~/.profile before the exec dwm line? Nothing in that file will be read after an exec statement.
And ~/.xsessionrc isn't really intended as a replacement for ~/.xsession, it is an adjunct to that file.
Devuan's display managers should automatically start whatever is set as the x-session-manager alternative with no need for further configuration, or /etc/alternatives/x-window-manager otherwise.
How did you install dwm? Is it the Devuan package or did you compile it yourself?
yes i did source before exec dwm.
. ~/.profile;
fi
exec dwmdwm is from suckless.org so, built from source.
There is definetly something im missing here, if i go back to startx and remove xdm .profile is sourced again.
What about if you have ~/.xsession with just exec dwm and then add ~/.xsessionrc to source ~/.profile?
You probably shouldn't use xdm any way because it will run X under the root user. The startx command runs X under your normal user, which is much better.
Can confirm that having ~/.xsession with just exec dwm and ~/.xsessionrc sourcing ~/.profile is the solution.
I prefer startx but even that i believe needs root rights as i have to install xserver-xorg-legacy and the modify /etc/X11/Xwrapper.config
to have..
needs_root_rights=yes
I was just interested to use xdm as it seems like the only display manager that does not need dbus as a dependency.
Anyhow thanks.
EDIT: correction looks like lxdm doesnt need dbus either.
I believe needs root rights as i have to install xserver-xorg-legacy and the modify /etc/X11/Xwrapper.config
to have..
Nope.
Devuan beowulf can now run rootless X OOTB (as long as the startx command is used) thanks to elogind ![]()
HevyDevy wrote:I believe needs root rights as i have to install xserver-xorg-legacy and the modify /etc/X11/Xwrapper.config
to have..
needs_root_rights=yesNope.
That may be true if using elogind but elogind depends on dbus and as i dont have dbus enabled and i have it pinned i have to use xserver-xorg-legacy. Thems the disadvantage of not using dbus i suppose.
