#1 2020-06-05 19:59:59
walter
Beowulf and Legion y540
Hi there,
first let me express my great thanks to the developers and maintainers of this wonderful distro. I am using ASCII since quite a while on an 11 year old laptop and it runs and runs and runs. Even with the updates from time to time the system always is stable and has no quirks at all. The appetite for more power led me to a Lenovo Legion Y540-17IRH with NVM.e 512 GB (M2 2242), spinning drive 2TB, i7-9750H, 16 GB RAM, GeForce GTX 1660Ti, IPS Full HD 17 inch display, Intel AC9560 WiFi Controller.
Since a few days I am trying to get the machine up and running with Beowulf. I tried with live first and ran into some trouble which let me check the full version. Even setting up ASCII and upgrade to Beowulf like devuan.org/os/documentation/dev1fanboy/ … to-beowulf didn‘t suceed. What I detected so far: it seems that setup with UEFI-boot is not coming up to a running system out-of-the-box, nouveau-driver is not supported (due to very new hardware), nvidia driver runs into a black screen with no reaction on keyboard keys (possibly I fucked it up during installation back/forward of graphics drivers, kernels and bumblebee). In contrast the legacy mode (BIOS) gave me a running system with just a few minor issues. There is a flickering display when choosing the iGPU in BIOS (both in UEFI and legacy mode). Strange behaviour. I think some stuff is due to new hardware not supported yet, but not all of them.
Maybe you can help me satisfying the following wishes:
    • Beowulf with XFCE
    • Possible switch between iGPU and GPU using Optimus or bumblebee for better battery uptime and less heat production
    • System uses UEFI
So far:
    • BIOS: put to the latest release (no errors during upgrade from the last one) - don't ask what a job I had with this little step
    • BIOS: its possible to decide which GPU is handling the display (noticed the item for the iGPU is called „Switchable Graphics“ - the other one „Discrete Graphics“)
    • BIOS: Secure Boot is switched off
    • BIOS: UEFI is selected
    • Used the guideline at devuan.org/os/documentation/install-gui … all-devuan.
    • dd of devuan_beowulf_3.0.0_amd64-desktop.iso to pendrive and installation with manual partition scheme, LUKS encryption and LVM all with network mirror.
    • First start run into a console logon screen. One console (I guess 7) displayed a blinking cursor with no reaction on keyboard input.
    • I logged into a console tried startx with no change and X crashes after trying to start.
    • Tried boot with rd.driver.blacklist=nouveau in grubmenu with no change (see dmesg output below).
    • Switched to use iGPU inside BIOS, which let XFCE start, but the display is terribly flickering (switched back to discrete GPU).
dmesg
[    0.000000] Linux version 4.19.0-9-amd64 (debian-kernel@lists.debian.org) (gcc version 8.3.0 (Debian 8.3.0-6)) #1 SMP Debian 4.19.118-2 (2020-04-29)
[    0.000000] Command line: BOOT_IMAGE=/vmlinuz-4.19.0-9-amd64 root=/dev/mapper/vgs-root ro quiet rd.driver.blacklist=nouveau
[    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[    0.000000] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.000000] x86/fpu: xstate_offset[3]:  832, xstate_sizes[3]:   64
[    0.000000] x86/fpu: xstate_offset[4]:  896, xstate_sizes[4]:   64
[    0.000000] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000086d86fff] usable
[    0.000000] BIOS-e820: [mem 0x0000000086d87000-0x0000000087686fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000087687000-0x000000009d89dfff] usable
[    0.000000] BIOS-e820: [mem 0x000000009d89e000-0x000000009da9dfff] type 20
[    0.000000] BIOS-e820: [mem 0x000000009da9e000-0x000000009e49dfff] reserved
[    0.000000] BIOS-e820: [mem 0x000000009e49e000-0x000000009eb8dfff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x000000009eb8e000-0x000000009ec0dfff] ACPI data
[    0.000000] BIOS-e820: [mem 0x000000009ec0e000-0x000000009ec0efff] usable
[    0.000000] BIOS-e820: [mem 0x000000009ec0f000-0x000000009fffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed10000-0x00000000fed19fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed84000-0x00000000fed84fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ff600000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000045dffffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] efi: EFI v2.60 by INSYDE Corp.
[    0.000000] efi:  ACPI=0x9ec0d000  ACPI 2.0=0x9ec0d014  SMBIOS=0x9dc50000  SMBIOS 3.0=0x9dc4e000  ESRT=0x8d75c718  MEMATTR=0x8d4d2018
[    0.000000] secureboot: Secure boot could not be determined (mode 0)
[    0.000000] SMBIOS 3.0.1 present.
[    0.000000] DMI: LENOVO 81Q4/LNVNB161216, BIOS BHCN36WW 02/10/2020
[    0.000000] tsc: Detected 2600.000 MHz processor
[    0.000009] tsc: Detected 2592.000 MHz TSC
[    0.000009] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000011] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000017] last_pfn = 0x45e000 max_arch_pfn = 0x400000000
[    0.000020] MTRR default type: write-back
[    0.000021] MTRR fixed ranges enabled:
[    0.000022]   00000-9FFFF write-back
[    0.000023]   A0000-BFFFF uncachable
[    0.000024]   C0000-FFFFF write-protect
[    0.000024] MTRR variable ranges enabled:
[    0.000026]   0 base 00C0000000 mask 7FC0000000 uncachable
[    0.000027]   1 base 00A0000000 mask 7FE0000000 uncachable
[    0.000027]   2 base 2000000000 mask 6000000000 uncachable
[    0.000028]   3 base 1000000000 mask 7000000000 uncachable
[    0.000029]   4 base 0800000000 mask 7800000000 uncachable
[    0.000029]   5 base 4000000000 mask 4000000000 uncachable
[    0.000030]   6 disabled
[    0.000030]   7 disabled
[    0.000031]   8 disabled
[    0.000031]   9 disabled
[    0.001320] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.001477] last_pfn = 0x9ec0f max_arch_pfn = 0x400000000
[    0.009745] esrt: Reserving ESRT space from 0x000000008d75c718 to 0x000000008d75c7c8.
[    0.009750] e820: update [mem 0x8d75c000-0x8d75cfff] usable ==> reserved
[    0.009773] Using GB pages for direct mapping
[    0.009775] BRK [0x381001000, 0x381001fff] PGTABLE
[    0.009777] BRK [0x381002000, 0x381002fff] PGTABLE
[    0.009777] BRK [0x381003000, 0x381003fff] PGTABLE
[    0.009816] BRK [0x381004000, 0x381004fff] PGTABLE
[    0.009818] BRK [0x381005000, 0x381005fff] PGTABLE
[    0.010032] BRK [0x381006000, 0x381006fff] PGTABLE
[    0.010080] BRK [0x381007000, 0x381007fff] PGTABLE
[    0.010136] BRK [0x381008000, 0x381008fff] PGTABLE
[    0.010231] BRK [0x381009000, 0x381009fff] PGTABLE
[    0.010296] BRK [0x38100a000, 0x38100afff] PGTABLE
[    0.010396] RAMDISK: [mem 0x3494f000-0x3649efff]
[    0.010405] ACPI: Early table checksum verification disabled
[    0.010407] ACPI: RSDP 0x000000009EC0D014 000024 (v02 LENOVO)
[    0.010410] ACPI: XSDT 0x000000009EBEE188 0000FC (v01 LENOVO CB-01    00000001      01000013)
[    0.010415] ACPI: FACP 0x000000009EBF1000 00010C (v05 LENOVO CB-01    00000001 ACPI 00040000)
[    0.010420] ACPI: DSDT 0x000000009EBBD000 02FE66 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.010422] ACPI: FACS 0x000000009EB0D000 000040
[    0.010424] ACPI: UEFI 0x000000009EC0C000 000236 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.010427] ACPI: SSDT 0x000000009EC0A000 001B1C (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.010429] ACPI: SSDT 0x000000009EC06000 0031D0 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.010431] ACPI: UEFI 0x000000009EC05000 000042 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.010433] ACPI: SSDT 0x000000009EC04000 00045A (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.010436] ACPI: SSDT 0x000000009EC03000 000046 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.010438] ACPI: TPM2 0x000000009EC02000 000034 (v03 LENOVO CB-01    00000001 ACPI 00040000)
[    0.010440] ACPI: POAT 0x000000009EC01000 000055 (v03 LENOVO CB-01    00000001 ACPI 00040000)
[    0.010442] ACPI: SSDT 0x000000009EBFC000 0044B6 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.010444] ACPI: LPIT 0x000000009EBFB000 000094 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.010446] ACPI: WSMT 0x000000009EBFA000 000028 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.010449] ACPI: SSDT 0x000000009EBF9000 000C2F (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.010451] ACPI: DBGP 0x000000009EBF8000 000034 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.010453] ACPI: DBG2 0x000000009EBF7000 000061 (v00 LENOVO CB-01    00000001 ACPI 00040000)
[    0.010455] ACPI: SSDT 0x000000009EBF6000 000896 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.010457] ACPI: SSDT 0x000000009EBF3000 002F89 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.010459] ACPI: ASF! 0x000000009EBF2000 0000A5 (v32 LENOVO CB-01    00000001 ACPI 00040000)
[    0.010462] ACPI: HPET 0x000000009EBF0000 000038 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.010464] ACPI: APIC 0x000000009EBEF000 00012C (v03 LENOVO CB-01    00000001 ACPI 00040000)
[    0.010466] ACPI: MCFG 0x000000009EBED000 00003C (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.010468] ACPI: SSDT 0x000000009EBBA000 002BBF (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.010470] ACPI: DMAR 0x000000009EBB9000 000070 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.010473] ACPI: SSDT 0x000000009EBB6000 002B68 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.010475] ACPI: SSDT 0x000000009EBB5000 00004C (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.010477] ACPI: FPDT 0x000000009EBB4000 000044 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.010479] ACPI: BGRT 0x000000009EBB3000 000038 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.010485] ACPI: Local APIC address 0xfee00000
[    0.010793] No NUMA configuration found
[    0.010793] Faking a node at [mem 0x0000000000000000-0x000000045dffffff]
[    0.010797] NODE_DATA(0) allocated [mem 0x45dffb000-0x45dffffff]
[    0.010825] Zone ranges:
[    0.010826]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.010827]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.010828]   Normal   [mem 0x0000000100000000-0x000000045dffffff]
[    0.010828]   Device   empty
[    0.010829] Movable zone start for each node
[    0.010830] Early memory node ranges
[    0.010831]   node   0: [mem 0x0000000000001000-0x000000000009efff]
[    0.010831]   node   0: [mem 0x0000000000100000-0x0000000086d86fff]
[    0.010832]   node   0: [mem 0x0000000087687000-0x000000009d89dfff]
[    0.010832]   node   0: [mem 0x000000009ec0e000-0x000000009ec0efff]
[    0.010833]   node   0: [mem 0x0000000100000000-0x000000045dffffff]
[    0.011144] Zeroed struct page in unavailable ranges: 20675 pages
[    0.011145] Initmem setup node 0 [mem 0x0000000000001000-0x000000045dffffff]
[    0.011146] On node 0 totalpages: 4173629
[    0.011147]   DMA zone: 64 pages used for memmap
[    0.011148]   DMA zone: 23 pages reserved
[    0.011149]   DMA zone: 3998 pages, LIFO batch:0
[    0.011237]   DMA32 zone: 9983 pages used for memmap
[    0.011237]   DMA32 zone: 638879 pages, LIFO batch:63
[    0.026526]   Normal zone: 55168 pages used for memmap
[    0.026527]   Normal zone: 3530752 pages, LIFO batch:63
[    0.100473] ACPI: PM-Timer IO Port: 0x1808
[    0.100474] ACPI: Local APIC address 0xfee00000
[    0.100480] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.100481] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[    0.100482] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[    0.100482] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[    0.100483] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[    0.100483] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[    0.100483] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[    0.100484] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[    0.100484] ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
[    0.100485] ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
[    0.100485] ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
[    0.100486] ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
[    0.100486] ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
[    0.100487] ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
[    0.100487] ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
[    0.100488] ACPI: LAPIC_NMI (acpi_id[0x10] high edge lint[0x1])
[    0.100550] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[    0.100552] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.100553] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.100555] ACPI: IRQ0 used by override.
[    0.100556] ACPI: IRQ9 used by override.
[    0.100557] Using ACPI (MADT) for SMP configuration information
[    0.100559] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[    0.100564] e820: update [mem 0x8d55e000-0x8d59efff] usable ==> reserved
[    0.100573] smpboot: Allowing 12 CPUs, 0 hotplug CPUs
[    0.100588] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.100590] PM: Registered nosave memory: [mem 0x0009f000-0x000fffff]
[    0.100591] PM: Registered nosave memory: [mem 0x86d87000-0x87686fff]
[    0.100592] PM: Registered nosave memory: [mem 0x8d55e000-0x8d59efff]
[    0.100593] PM: Registered nosave memory: [mem 0x8d75c000-0x8d75cfff]
[    0.100595] PM: Registered nosave memory: [mem 0x9d89e000-0x9da9dfff]
[    0.100595] PM: Registered nosave memory: [mem 0x9da9e000-0x9e49dfff]
[    0.100595] PM: Registered nosave memory: [mem 0x9e49e000-0x9eb8dfff]
[    0.100596] PM: Registered nosave memory: [mem 0x9eb8e000-0x9ec0dfff]
[    0.100597] PM: Registered nosave memory: [mem 0x9ec0f000-0x9fffffff]
[    0.100598] PM: Registered nosave memory: [mem 0xa0000000-0xdfffffff]
[    0.100598] PM: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[    0.100599] PM: Registered nosave memory: [mem 0xf0000000-0xfdffffff]
[    0.100599] PM: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
[    0.100599] PM: Registered nosave memory: [mem 0xfe011000-0xfed0ffff]
[    0.100600] PM: Registered nosave memory: [mem 0xfed10000-0xfed19fff]
[    0.100600] PM: Registered nosave memory: [mem 0xfed1a000-0xfed83fff]
[    0.100601] PM: Registered nosave memory: [mem 0xfed84000-0xfed84fff]
[    0.100601] PM: Registered nosave memory: [mem 0xfed85000-0xfedfffff]
[    0.100602] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[    0.100602] PM: Registered nosave memory: [mem 0xfee01000-0xff5fffff]
[    0.100603] PM: Registered nosave memory: [mem 0xff600000-0xffffffff]
[    0.100604] [mem 0xa0000000-0xdfffffff] available for PCI devices
[    0.100605] Booting paravirtualized kernel on bare hardware
[    0.100607] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[    0.194585] random: get_random_bytes called from start_kernel+0x93/0x52c with crng_init=0
[    0.194590] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:12 nr_node_ids:1
[    0.194876] percpu: Embedded 45 pages/cpu s144408 r8192 d31720 u262144
[    0.194882] pcpu-alloc: s144408 r8192 d31720 u262144 alloc=1*2097152
[    0.194883] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 -- -- -- --
[    0.194903] Built 1 zonelists, mobility grouping on.  Total pages: 4108391
[    0.194903] Policy zone: Normal
[    0.194905] Kernel command line: BOOT_IMAGE=/vmlinuz-4.19.0-9-amd64 root=/dev/mapper/vgs-root ro quiet rd.driver.blacklist=nouveau
[    0.198462] Calgary: detecting Calgary via BIOS EBDA area
[    0.198464] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[    0.229907] Memory: 16244316K/16694516K available (10252K kernel code, 1241K rwdata, 3316K rodata, 1588K init, 2276K bss, 450200K reserved, 0K cma-reserved)
[    0.229990] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[    0.229995] Kernel/User page tables isolation: enabled
[    0.242326] ftrace: allocating 31879 entries in 125 pages
[    0.254866] rcu: Hierarchical RCU implementation.
[    0.254867] rcu: 	RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=12.
[    0.254868] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[    0.257732] NR_IRQS: 33024, nr_irqs: 2152, preallocated irqs: 16
[    0.258252] Console: colour dummy device 80x25
[    0.258255] console [tty0] enabled
[    0.258271] ACPI: Core revision 20180810
[    0.258773] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635855245 ns
[    0.258843] hpet clockevent registered
[    0.258916] APIC: Switch to symmetric I/O mode setup
[    0.258918] DMAR: Host address width 39
[    0.258919] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[    0.258923] DMAR: dmar0: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[    0.258924] DMAR: RMRR base: 0x0000009e47d000 end: 0x0000009e49cfff
[    0.258926] DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 0
[    0.258927] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[    0.258927] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[    0.261922] DMAR-IR: Enabled IRQ remapping in x2apic mode
[    0.261924] x2apic enabled
[    0.261954] Switched APIC routing to cluster x2apic.
[    0.271247] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.290868] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x255cb6cc5db, max_idle_ns: 440795203504 ns
[    0.290879] Calibrating delay loop (skipped), value calculated using timer frequency.. 5184.00 BogoMIPS (lpj=10368000)
[    0.290881] pid_max: default: 32768 minimum: 301
[    0.292579] Security Framework initialized
[    0.292581] Yama: disabled by default; enable with sysctl kernel.yama.*
[    0.292600] AppArmor: AppArmor initialized
[    0.294244] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[    0.295103] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[    0.295138] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes)
[    0.295166] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes)
[    0.295355] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.295355] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
[    0.295370] CPU0: Thermal monitoring enabled (TM1)
[    0.295395] process: using mwait in idle threads
[    0.295397] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[    0.295398] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[    0.295399] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.295400] Spectre V2 : Mitigation: Full generic retpoline
[    0.295400] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.295401] Spectre V2 : Enabling Restricted Speculation for firmware calls
[    0.295408] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.295408] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
[    0.295409] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[    0.295432] MDS: Mitigation: Clear CPU buffers
[    0.301350] Freeing SMP alternatives memory: 24K
[    0.307191] TSC deadline timer enabled
[    0.307202] smpboot: CPU0: Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz (family: 0x6, model: 0x9e, stepping: 0xa)
[    0.307279] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[    0.307309] ... version:                4
[    0.307309] ... bit width:              48
[    0.307310] ... generic registers:      4
[    0.307310] ... value mask:             0000ffffffffffff
[    0.307311] ... max period:             00007fffffffffff
[    0.307311] ... fixed-purpose events:   3
[    0.307312] ... event mask:             000000070000000f
[    0.307350] rcu: Hierarchical SRCU implementation.
[    0.307691] random: crng done (trusting CPU's manufacturer)
[    0.308379] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.308454] smp: Bringing up secondary CPUs ...
[    0.308511] x86: Booting SMP configuration:
[    0.308512] .... node  #0, CPUs:        #1  #2  #3  #4  #5  #6
[    0.311630] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[    0.311630]   #7  #8  #9 #10 #11
[    0.315477] smp: Brought up 1 node, 12 CPUs
[    0.315477] smpboot: Max logical packages: 1
[    0.315477] smpboot: Total of 12 processors activated (62208.00 BogoMIPS)
[    0.319253] devtmpfs: initialized
[    0.319253] x86/mm: Memory block size: 128MB
[    0.320296] PM: Registering ACPI NVS region [mem 0x9e49e000-0x9eb8dfff] (7274496 bytes)
[    0.320296] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.320296] futex hash table entries: 4096 (order: 6, 262144 bytes)
[    0.320296] pinctrl core: initialized pinctrl subsystem
[    0.320296] NET: Registered protocol family 16
[    0.320296] audit: initializing netlink subsys (disabled)
[    0.320296] audit: type=2000 audit(1591369651.052:1): state=initialized audit_enabled=0 res=1
[    0.320296] cpuidle: using governor ladder
[    0.320296] cpuidle: using governor menu
[    0.320296] KVM setup pv remote TLB flush
[    0.320296] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.320296] ACPI: bus type PCI registered
[    0.320296] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.320296] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[    0.320296] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[    0.320296] PCI: Using configuration type 1 for base access
[    0.320296] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.320296] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.320296] ACPI: Added _OSI(Module Device)
[    0.320296] ACPI: Added _OSI(Processor Device)
[    0.320296] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.320296] ACPI: Added _OSI(Processor Aggregator Device)
[    0.320296] ACPI: Added _OSI(Linux-Dell-Video)
[    0.320296] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.364333] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.TPLD], AE_ALREADY_EXISTS (20180810/dswload2-316)
[    0.364341] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[    0.364344] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[    0.364389] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS01._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[    0.364394] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[    0.364396] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[    0.364399] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS01._PLD], AE_ALREADY_EXISTS (20180810/dswload2-316)
[    0.364402] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[    0.364405] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[    0.365900] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS02._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[    0.365904] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[    0.365907] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[    0.365909] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS02._PLD], AE_ALREADY_EXISTS (20180810/dswload2-316)
[    0.365913] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[    0.365916] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[    0.367406] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS03._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[    0.367410] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[    0.367413] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[    0.367416] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS03._PLD], AE_ALREADY_EXISTS (20180810/dswload2-316)
[    0.367420] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[    0.367422] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[    0.368905] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS04._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[    0.368909] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[    0.368912] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[    0.368915] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS04._PLD], AE_ALREADY_EXISTS (20180810/dswload2-316)
[    0.368918] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[    0.368921] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[    0.370405] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS05._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[    0.370409] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[    0.370412] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[    0.371900] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS06._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[    0.371905] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[    0.371907] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[    0.371910] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS06._PLD], AE_ALREADY_EXISTS (20180810/dswload2-316)
[    0.371914] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[    0.371916] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[    0.373398] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS07._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[    0.373402] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[    0.373405] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[    0.374890] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS08._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[    0.374895] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[    0.374897] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[    0.376384] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS09._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[    0.376388] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[    0.376390] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[    0.376393] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS09._PLD], AE_ALREADY_EXISTS (20180810/dswload2-316)
[    0.376397] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[    0.376399] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[    0.377883] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS10._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[    0.377887] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[    0.377890] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[    0.379378] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS11._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[    0.379382] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[    0.379385] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[    0.380869] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS12._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[    0.380873] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[    0.380875] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[    0.382359] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS13._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[    0.382364] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[    0.382366] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[    0.383854] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS14._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[    0.383859] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[    0.383861] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[    0.383864] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS14._PLD], AE_ALREADY_EXISTS (20180810/dswload2-316)
[    0.383868] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[    0.383870] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[    0.385336] ACPI BIOS Error (bug): Could not resolve [\_SB.PCI0.XHC.RHUB.USR1], AE_NOT_FOUND (20180810/dswload2-160)
[    0.385340] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20180810/psobject-221)
[    0.385343] ACPI Error: Ignore error and continue table load (20180810/psobject-604)
[    0.385345] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[    0.385349] ACPI BIOS Error (bug): Could not resolve [\_SB.PCI0.XHC.RHUB.USR2], AE_NOT_FOUND (20180810/dswload2-160)
[    0.385353] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20180810/psobject-221)
[    0.385356] ACPI Error: Ignore error and continue table load (20180810/psobject-604)
[    0.385358] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[    0.385382] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS01._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[    0.385386] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[    0.385388] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[    0.385391] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS01._PLD], AE_ALREADY_EXISTS (20180810/dswload2-316)
[    0.385395] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[    0.385397] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[    0.385427] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS02._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[    0.385431] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[    0.385433] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[    0.385436] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS02._PLD], AE_ALREADY_EXISTS (20180810/dswload2-316)
[    0.385440] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[    0.385442] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[    0.385472] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS03._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[    0.385476] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[    0.385478] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[    0.385481] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS03._PLD], AE_ALREADY_EXISTS (20180810/dswload2-316)
[    0.385485] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[    0.385487] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[    0.385516] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS04._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[    0.385520] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[    0.385523] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[    0.385525] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS04._PLD], AE_ALREADY_EXISTS (20180810/dswload2-316)
[    0.385529] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[    0.385531] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[    0.385560] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS05._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[    0.385564] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[    0.385567] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[    0.385592] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS06._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[    0.385596] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[    0.385599] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[    0.385623] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS07._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[    0.385626] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[    0.385629] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[    0.385653] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS08._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[    0.385657] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[    0.385659] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[    0.385683] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS09._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[    0.385687] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[    0.385689] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[    0.385713] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS10._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[    0.385717] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[    0.385720] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[    0.386417] ACPI BIOS Error (bug): Could not resolve [\_SB.PCI0.I2C2.TPD0], AE_NOT_FOUND (20180810/dswload2-160)
[    0.386422] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20180810/psobject-221)
[    0.386425] ACPI Error: Ignore error and continue table load (20180810/psobject-604)
[    0.386428] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[    0.386449] ACPI BIOS Error (bug): Could not resolve [\_SB.PCI0.I2C3.TPL1], AE_NOT_FOUND (20180810/dswload2-160)
[    0.386452] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20180810/psobject-221)
[    0.386455] ACPI Error: Ignore error and continue table load (20180810/psobject-604)
[    0.386457] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[    0.388416] ACPI: 12 ACPI AML tables successfully acquired and loaded
[    0.397516] ACPI: Dynamic OEM Table Load:
[    0.397528] ACPI: SSDT 0xFFFF9F150AD44500 0000F4 (v02 PmRef  Cpu0Psd  00003000 INTL 20160422)
[    0.397880] ACPI: \_SB_.PR00: _OSC native thermal LVT Acked
[    0.398600] ACPI: Dynamic OEM Table Load:
[    0.398607] ACPI: SSDT 0xFFFF9F150AD4FC00 000400 (v02 PmRef  Cpu0Cst  00003001 INTL 20160422)
[    0.399060] ACPI: Dynamic OEM Table Load:
[    0.399067] ACPI: SSDT 0xFFFF9F150B744000 000581 (v02 PmRef  Cpu0Ist  00003000 INTL 20160422)
[    0.399562] ACPI: Dynamic OEM Table Load:
[    0.399568] ACPI: SSDT 0xFFFF9F150AD42E00 00011B (v02 PmRef  Cpu0Hwp  00003000 INTL 20160422)
[    0.399929] ACPI: Dynamic OEM Table Load:
[    0.399936] ACPI: SSDT 0xFFFF9F150B741800 000724 (v02 PmRef  HwpLvt   00003000 INTL 20160422)
[    0.400535] ACPI: Dynamic OEM Table Load:
[    0.400542] ACPI: SSDT 0xFFFF9F150B740000 0005FC (v02 PmRef  ApIst    00003000 INTL 20160422)
[    0.401032] ACPI: Dynamic OEM Table Load:
[    0.401037] ACPI: SSDT 0xFFFF9F150AD4F400 000317 (v02 PmRef  ApHwp    00003000 INTL 20160422)
[    0.401539] ACPI: Dynamic OEM Table Load:
[    0.401545] ACPI: SSDT 0xFFFF9F150B78F000 000AB0 (v02 PmRef  ApPsd    00003000 INTL 20160422)
[    0.402422] ACPI: Dynamic OEM Table Load:
[    0.402428] ACPI: SSDT 0xFFFF9F150AD4BC00 00030A (v02 PmRef  ApCst    00003000 INTL 20160422)
[    0.406444] ACPI: EC: EC started
[    0.406445] ACPI: EC: interrupt blocked
[    0.419042] ACPI: \_SB_.PCI0.LPCB.EC0_: Used as first EC
[    0.419044] ACPI: \_SB_.PCI0.LPCB.EC0_: GPE=0x2, EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.419045] ACPI: \_SB_.PCI0.LPCB.EC0_: Used as boot DSDT EC to handle transactions
[    0.419045] ACPI: Interpreter enabled
[    0.419095] ACPI: (supports S0 S3 S4 S5)
[    0.419095] ACPI: Using IOAPIC for interrupt routing
[    0.419132] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.419579] ACPI: Enabled 10 GPEs in block 00 to 7F
[    0.420399] ACPI: Power Resource [PG00] (on)
[    0.423853] ACPI: Power Resource [PUBS] (on)
[    0.424612] ACPI: Power Resource [BTPR] (on)
[    0.425906] ACPI: Power Resource [USBC] (on)
[    0.426065] ACPI: Power Resource [PAUD] (on)
[    0.429399] ACPI: Power Resource [PXP] (off)
[    0.435014] ACPI: Power Resource [PXP] (off)
[    0.436423] ACPI: Power Resource [V0PR] (on)
[    0.436572] ACPI: Power Resource [V1PR] (on)
[    0.436715] ACPI: Power Resource [V2PR] (on)
[    0.438433] ACPI: Power Resource [PXTC] (on)
[    0.438809] ACPI: Power Resource [PXTC] (off)
[    0.440375] ACPI: Power Resource [WRST] (on)
[    0.442127] ACPI: Power Resource [PIN] (off)
[    0.442446] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[    0.442450] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[    0.445763] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR]
[    0.445764] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[    0.448158] PCI host bridge to bus 0000:00
[    0.448160] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.448161] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.448162] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.448163] pci_bus 0000:00: root bus resource [mem 0xa0000000-0xdfffffff window]
[    0.448164] pci_bus 0000:00: root bus resource [mem 0xfc800000-0xfe7fffff window]
[    0.448165] pci_bus 0000:00: root bus resource [bus 00-fe]
[    0.448172] pci 0000:00:00.0: [8086:3ec4] type 00 class 0x060000
[    0.449069] pci 0000:00:01.0: [8086:1901] type 01 class 0x060400
[    0.449110] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[    0.450076] pci 0000:00:04.0: [8086:1903] type 00 class 0x118000
[    0.450088] pci 0000:00:04.0: reg 0x10: [mem 0xb4510000-0xb4517fff 64bit]
[    0.451040] pci 0000:00:08.0: [8086:1911] type 00 class 0x088000
[    0.451051] pci 0000:00:08.0: reg 0x10: [mem 0xb4524000-0xb4524fff 64bit]
[    0.452046] pci 0000:00:12.0: [8086:a379] type 00 class 0x118000
[    0.452090] pci 0000:00:12.0: reg 0x10: [mem 0xb4525000-0xb4525fff 64bit]
[    0.453184] pci 0000:00:14.0: [8086:a36d] type 00 class 0x0c0330
[    0.453229] pci 0000:00:14.0: reg 0x10: [mem 0xb4500000-0xb450ffff 64bit]
[    0.453372] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    0.454318] pci 0000:00:14.2: [8086:a36f] type 00 class 0x050000
[    0.454358] pci 0000:00:14.2: reg 0x10: [mem 0xb4520000-0xb4521fff 64bit]
[    0.454382] pci 0000:00:14.2: reg 0x18: [mem 0xb4526000-0xb4526fff 64bit]
[    0.455413] pci 0000:00:14.3: [8086:a370] type 00 class 0x028000
[    0.455598] pci 0000:00:14.3: reg 0x10: [mem 0xb4518000-0xb451bfff 64bit]
[    0.456260] pci 0000:00:14.3: PME# supported from D0 D3hot D3cold
[    0.457346] pci 0000:00:15.0: [8086:a368] type 00 class 0x0c8000
[    0.457387] pci 0000:00:15.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[    0.458404] pci 0000:00:15.1: [8086:a369] type 00 class 0x0c8000
[    0.458444] pci 0000:00:15.1: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[    0.459527] pci 0000:00:16.0: [8086:a360] type 00 class 0x078000
[    0.459570] pci 0000:00:16.0: reg 0x10: [mem 0xb4529000-0xb4529fff 64bit]
[    0.459692] pci 0000:00:16.0: PME# supported from D3hot
[    0.460721] pci 0000:00:17.0: [8086:a353] type 00 class 0x010601
[    0.460759] pci 0000:00:17.0: reg 0x10: [mem 0xb4522000-0xb4523fff]
[    0.460774] pci 0000:00:17.0: reg 0x14: [mem 0xb452e000-0xb452e0ff]
[    0.460790] pci 0000:00:17.0: reg 0x18: [io  0x5040-0x5047]
[    0.460804] pci 0000:00:17.0: reg 0x1c: [io  0x5048-0x504b]
[    0.460820] pci 0000:00:17.0: reg 0x20: [io  0x5020-0x503f]
[    0.460834] pci 0000:00:17.0: reg 0x24: [mem 0xb452d000-0xb452d7ff]
[    0.460920] pci 0000:00:17.0: PME# supported from D3hot
[    0.461905] pci 0000:00:1d.0: [8086:a330] type 01 class 0x060400
[    0.462111] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    0.462152] pci 0000:00:1d.0: PTM enabled (root), 4ns granularity
[    0.463146] pci 0000:00:1d.5: [8086:a335] type 01 class 0x060400
[    0.463341] pci 0000:00:1d.5: PME# supported from D0 D3hot D3cold
[    0.463383] pci 0000:00:1d.5: PTM enabled (root), 4ns granularity
[    0.464349] pci 0000:00:1e.0: [8086:a328] type 00 class 0x078000
[    0.464389] pci 0000:00:1e.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[    0.465478] pci 0000:00:1f.0: [8086:a30d] type 00 class 0x060100
[    0.466642] pci 0000:00:1f.3: [8086:a348] type 00 class 0x040300
[    0.466720] pci 0000:00:1f.3: reg 0x10: [mem 0xb451c000-0xb451ffff 64bit]
[    0.466794] pci 0000:00:1f.3: reg 0x20: [mem 0xb4200000-0xb42fffff 64bit]
[    0.466944] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[    0.467993] pci 0000:00:1f.4: [8086:a323] type 00 class 0x0c0500
[    0.468175] pci 0000:00:1f.4: reg 0x10: [mem 0xb452b000-0xb452b0ff 64bit]
[    0.468393] pci 0000:00:1f.4: reg 0x20: [io  0x5000-0x501f]
[    0.469529] pci 0000:00:1f.5: [8086:a324] type 00 class 0x0c8000
[    0.469558] pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
[    0.470572] pci 0000:01:00.0: [10de:2191] type 00 class 0x030000
[    0.470592] pci 0000:01:00.0: reg 0x10: [mem 0xb3000000-0xb3ffffff]
[    0.470603] pci 0000:01:00.0: reg 0x14: [mem 0xa0000000-0xafffffff 64bit pref]
[    0.470613] pci 0000:01:00.0: reg 0x1c: [mem 0xb0000000-0xb1ffffff 64bit pref]
[    0.470620] pci 0000:01:00.0: reg 0x24: [io  0x4000-0x407f]
[    0.470627] pci 0000:01:00.0: reg 0x30: [mem 0xfff80000-0xffffffff pref]
[    0.470644] pci 0000:01:00.0: BAR 1: assigned to efifb
[    0.470681] pci 0000:01:00.0: PME# supported from D0 D3hot
[    0.470712] pci 0000:01:00.0: 32.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s x16 link at 0000:00:01.0 (capable of 126.016 Gb/s with 8 GT/s x16 link)
[    0.470772] pci 0000:01:00.1: [10de:1aeb] type 00 class 0x040300
[    0.470788] pci 0000:01:00.1: reg 0x10: [mem 0xb4000000-0xb4003fff]
[    0.470910] pci 0000:01:00.2: [10de:1aec] type 00 class 0x0c0330
[    0.470928] pci 0000:01:00.2: reg 0x10: [mem 0xb4100000-0xb413ffff 64bit pref]
[    0.470944] pci 0000:01:00.2: reg 0x1c: [mem 0xb4140000-0xb414ffff 64bit pref]
[    0.470997] pci 0000:01:00.2: PME# supported from D0 D3hot
[    0.471047] pci 0000:01:00.3: [10de:1aed] type 00 class 0x0c8000
[    0.471062] pci 0000:01:00.3: reg 0x10: [mem 0xb4004000-0xb4004fff]
[    0.471135] pci 0000:01:00.3: PME# supported from D0 D3hot
[    0.471207] pci 0000:00:01.0: PCI bridge to [bus 01-05]
[    0.471209] pci 0000:00:01.0:   bridge window [io  0x4000-0x4fff]
[    0.471211] pci 0000:00:01.0:   bridge window [mem 0xa0000000-0xb40fffff]
[    0.471214] pci 0000:00:01.0:   bridge window [mem 0xb4100000-0xb41fffff 64bit pref]
[    0.471453] pci 0000:06:00.0: [144d:a808] type 00 class 0x010802
[    0.471506] pci 0000:06:00.0: reg 0x10: [mem 0xb4400000-0xb4403fff 64bit]
[    0.472027] pci 0000:00:1d.0: PCI bridge to [bus 06]
[    0.472036] pci 0000:00:1d.0:   bridge window [mem 0xb4400000-0xb44fffff]
[    0.472137] pci 0000:07:00.0: [10ec:8168] type 00 class 0x020000
[    0.472180] pci 0000:07:00.0: reg 0x10: [io  0x3000-0x30ff]
[    0.472218] pci 0000:07:00.0: reg 0x18: [mem 0xb4304000-0xb4304fff 64bit]
[    0.472241] pci 0000:07:00.0: reg 0x20: [mem 0xb4300000-0xb4303fff 64bit]
[    0.472382] pci 0000:07:00.0: supports D1 D2
[    0.472383] pci 0000:07:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.472586] pci 0000:00:1d.5: PCI bridge to [bus 07]
[    0.472591] pci 0000:00:1d.5:   bridge window [io  0x3000-0x3fff]
[    0.472596] pci 0000:00:1d.5:   bridge window [mem 0xb4300000-0xb43fffff]
[    0.475622] ACPI: EC: interrupt unblocked
[    0.475654] ACPI: EC: event unblocked
[    0.475675] ACPI: \_SB_.PCI0.LPCB.EC0_: GPE=0x2, EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.475676] ACPI: \_SB_.PCI0.LPCB.EC0_: Used as boot DSDT EC to handle transactions and events
[    0.475737] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[    0.475737] pci 0000:01:00.0: vgaarb: bridge control possible
[    0.475737] pci 0000:01:00.0: vgaarb: setting as boot device
[    0.475737] vgaarb: loaded
[    0.475737] pps_core: LinuxPPS API ver. 1 registered
[    0.475737] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.475737] PTP clock support registered
[    0.475737] EDAC MC: Ver: 3.0.0
[    0.475737] Registered efivars operations
[    0.475737] PCI: Using ACPI for IRQ routing
[    0.560694] PCI: pci_cache_line_size set to 64 bytes
[    0.561103] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[    0.561104] e820: reserve RAM buffer [mem 0x86d87000-0x87ffffff]
[    0.561105] e820: reserve RAM buffer [mem 0x8d55e000-0x8fffffff]
[    0.561106] e820: reserve RAM buffer [mem 0x8d75c000-0x8fffffff]
[    0.561106] e820: reserve RAM buffer [mem 0x9d89e000-0x9fffffff]
[    0.561107] e820: reserve RAM buffer [mem 0x9ec0f000-0x9fffffff]
[    0.561108] e820: reserve RAM buffer [mem 0x45e000000-0x45fffffff]
[    0.561180] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[    0.561180] hpet0: 8 comparators, 64-bit 24.000000 MHz counter
[    0.563914] clocksource: Switched to clocksource tsc-early
[    0.570887] VFS: Disk quotas dquot_6.6.0
[    0.570899] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.570981] AppArmor: AppArmor Filesystem Enabled
[    0.570990] pnp: PnP ACPI init
[    0.571064] system 00:00: [mem 0x40000000-0x403fffff] could not be reserved
[    0.571067] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.571353] system 00:01: [io  0x1800-0x18fe] has been reserved
[    0.571355] system 00:01: [mem 0xfd000000-0xfd69ffff] has been reserved
[    0.571356] system 00:01: [mem 0xfd6c0000-0xfd6cffff] has been reserved
[    0.571357] system 00:01: [mem 0xfd6f0000-0xfdffffff] has been reserved
[    0.571358] system 00:01: [mem 0xfe000000-0xfe01ffff] could not be reserved
[    0.571359] system 00:01: [mem 0xfe200000-0xfe7fffff] has been reserved
[    0.571360] system 00:01: [mem 0xff000000-0xffffffff] could not be reserved
[    0.571363] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.571641] system 00:02: [io  0x2000-0x20fe] has been reserved
[    0.571644] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.571797] system 00:03: [io  0x0680-0x069f] has been reserved
[    0.571798] system 00:03: [io  0x164e-0x164f] has been reserved
[    0.571801] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.571904] system 00:04: [io  0x1854-0x1857] has been reserved
[    0.571907] system 00:04: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[    0.571937] pnp 00:05: Plug and Play ACPI device, IDs PNP0303 (active)
[    0.573063] system 00:06: [mem 0xfe037000-0xfe037fff] has been reserved
[    0.573064] system 00:06: [mem 0xfe036008-0xfe036fff] has been reserved
[    0.573067] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.573482] system 00:07: [mem 0xfed10000-0xfed17fff] has been reserved
[    0.573483] system 00:07: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.573484] system 00:07: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.573485] system 00:07: [mem 0xe0000000-0xefffffff] has been reserved
[    0.573487] system 00:07: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.573488] system 00:07: [mem 0xfed90000-0xfed93fff] could not be reserved
[    0.573489] system 00:07: [mem 0xfed45000-0xfed8ffff] could not be reserved
[    0.573490] system 00:07: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.573493] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.573634] pnp: PnP ACPI: found 8 devices
[    0.579092] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.579095] pci 0000:01:00.0: can't claim BAR 6 [mem 0xfff80000-0xffffffff pref]: no compatible bridge window
[    0.579138] pci 0000:00:15.0: BAR 0: assigned [mem 0xb4527000-0xb4527fff 64bit]
[    0.579166] pci 0000:00:15.1: BAR 0: assigned [mem 0xb4528000-0xb4528fff 64bit]
[    0.579182] pci 0000:00:1e.0: BAR 0: assigned [mem 0xb452a000-0xb452afff 64bit]
[    0.579199] pci 0000:01:00.0: BAR 6: assigned [mem 0xb2000000-0xb207ffff pref]
[    0.579200] pci 0000:00:01.0: PCI bridge to [bus 01-05]
[    0.579202] pci 0000:00:01.0:   bridge window [io  0x4000-0x4fff]
[    0.579204] pci 0000:00:01.0:   bridge window [mem 0xa0000000-0xb40fffff]
[    0.579206] pci 0000:00:01.0:   bridge window [mem 0xb4100000-0xb41fffff 64bit pref]
[    0.579209] pci 0000:00:1d.0: PCI bridge to [bus 06]
[    0.579219] pci 0000:00:1d.0:   bridge window [mem 0xb4400000-0xb44fffff]
[    0.579233] pci 0000:00:1d.5: PCI bridge to [bus 07]
[    0.579236] pci 0000:00:1d.5:   bridge window [io  0x3000-0x3fff]
[    0.579243] pci 0000:00:1d.5:   bridge window [mem 0xb4300000-0xb43fffff]
[    0.579257] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.579258] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.579259] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.579260] pci_bus 0000:00: resource 7 [mem 0xa0000000-0xdfffffff window]
[    0.579261] pci_bus 0000:00: resource 8 [mem 0xfc800000-0xfe7fffff window]
[    0.579262] pci_bus 0000:01: resource 0 [io  0x4000-0x4fff]
[    0.579262] pci_bus 0000:01: resource 1 [mem 0xa0000000-0xb40fffff]
[    0.579263] pci_bus 0000:01: resource 2 [mem 0xb4100000-0xb41fffff 64bit pref]
[    0.579264] pci_bus 0000:06: resource 1 [mem 0xb4400000-0xb44fffff]
[    0.579265] pci_bus 0000:07: resource 0 [io  0x3000-0x3fff]
[    0.579266] pci_bus 0000:07: resource 1 [mem 0xb4300000-0xb43fffff]
[    0.579400] NET: Registered protocol family 2
[    0.579511] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes)
[    0.579552] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.579691] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[    0.579780] TCP: Hash tables configured (established 131072 bind 65536)
[    0.579811] UDP hash table entries: 8192 (order: 6, 262144 bytes)
[    0.579846] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes)
[    0.579912] NET: Registered protocol family 1
[    0.579916] NET: Registered protocol family 44
[    0.581679] pci 0000:01:00.1: Linked as a consumer to 0000:01:00.0
[    0.582171] PCI: CLS 64 bytes, default 64
[    0.582197] Unpacking initramfs...
[    1.044064] Freeing initrd memory: 27968K
[    1.067033] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    1.067034] software IO TLB: mapped [mem 0x991c6000-0x9d1c6000] (64MB)
[    1.067063] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x255cb6cc5db, max_idle_ns: 440795203504 ns
[    1.067079] clocksource: Switched to clocksource tsc
[    1.067107] platform rtc_cmos: registered platform RTC device (no PNP device found)
[    1.067801] Initialise system trusted keyrings
[    1.067807] Key type blacklist registered
[    1.067843] workingset: timestamp_bits=40 max_order=22 bucket_order=0
[    1.068800] zbud: loaded
[    1.201884] Key type asymmetric registered
[    1.201884] Asymmetric key parser 'x509' registered
[    1.201896] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    1.201927] io scheduler noop registered
[    1.201927] io scheduler deadline registered
[    1.201957] io scheduler cfq registered (default)
[    1.201958] io scheduler mq-deadline registered
[    1.202418] pcieport 0000:00:01.0: Signaling PME with IRQ 121
[    1.202688] pcieport 0000:00:1d.0: Signaling PME with IRQ 122
[    1.202983] pcieport 0000:00:1d.5: Signaling PME with IRQ 123
[    1.203086] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    1.203100] efifb: probing for efifb
[    1.203108] efifb: framebuffer at 0xa0000000, using 8640k, total 8640k
[    1.203109] efifb: mode is 1920x1080x32, linelength=8192, pages=1
[    1.203109] efifb: scrolling: redraw
[    1.203110] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    1.206783] Console: switching to colour frame buffer device 240x67
[    1.210336] fb0: EFI VGA frame buffer device
[    1.210343] intel_idle: MWAIT substates: 0x11142120
[    1.210344] intel_idle: v0.4.1 model 0x9E
[    1.210833] intel_idle: lapic_timer_reliable_states 0xffffffff
[    1.212429] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.212946] Linux agpgart interface v0.103
[    1.212995] AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[    1.212996] AMD IOMMUv2 functionality not available on this system
[    1.213569] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[    1.213569] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[    1.220037] serio: i8042 KBD port at 0x60,0x64 irq 1
[    1.220140] mousedev: PS/2 mouse device common for all mice
[    1.220214] rtc_cmos rtc_cmos: RTC can wake from S4
[    1.221297] rtc_cmos rtc_cmos: registered as rtc0
[    1.221307] rtc_cmos rtc_cmos: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[    1.221342] intel_pstate: Intel P-state driver initializing
[    1.221384] intel_pstate: Disabling energy efficiency optimization
[    1.222141] intel_pstate: HWP enabled
[    1.222198] ledtrig-cpu: registered to indicate activity on CPUs
[    1.222520] NET: Registered protocol family 10
[    1.224599] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[    1.228738] Segment Routing with IPv6
[    1.228752] mip6: Mobile IPv6
[    1.228754] NET: Registered protocol family 17
[    1.228903] mpls_gso: MPLS GSO support
[    1.229820] mce: Using 12 MCE banks
[    1.229879] microcode: sig=0x906ea, pf=0x20, revision=0xc6
[    1.230266] microcode: Microcode Update Driver: v2.2.
[    1.230273] sched_clock: Marking stable (1221623801, 8639797)->(1242888022, -12624424)
[    1.230642] registered taskstats version 1
[    1.230642] Loading compiled-in X.509 certificates
[    1.257150] Loaded X.509 cert 'Debian Secure Boot CA: 6ccece7e4c6c0d1f6149f3dd27dfcc5cbb419ea1'
[    1.257164] Loaded X.509 cert 'Debian Secure Boot Signer: 00a7468def'
[    1.259541] Loaded UEFI:db cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53' linked to secondary sys keyring
[    1.259559] Loaded UEFI:db cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4' linked to secondary sys keyring
[    1.259561] Problem loading UEFI:db X.509 certificate (-65)
[    1.261704] zswap: loaded using pool lzo/zbud
[    1.262050] AppArmor: AppArmor sha1 policy hashing enabled
[    1.263087] rtc_cmos rtc_cmos: setting system clock to 2020-06-05 15:07:32 UTC (1591369652)
[    1.466725] CPU4: Core temperature above threshold, cpu clock throttled (total events = 1)
[    1.466726] CPU10: Core temperature above threshold, cpu clock throttled (total events = 1)
[    1.466727] CPU4: Package temperature above threshold, cpu clock throttled (total events = 1)
[    1.466727] CPU10: Package temperature above threshold, cpu clock throttled (total events = 1)
[    1.466761] CPU2: Package temperature above threshold, cpu clock throttled (total events = 1)
[    1.466762] CPU6: Package temperature above threshold, cpu clock throttled (total events = 1)
[    1.466763] CPU7: Package temperature above threshold, cpu clock throttled (total events = 1)
[    1.466764] CPU0: Package temperature above threshold, cpu clock throttled (total events = 1)
[    1.466764] CPU8: Package temperature above threshold, cpu clock throttled (total events = 1)
[    1.466765] CPU1: Package temperature above threshold, cpu clock throttled (total events = 1)
[    1.466766] CPU3: Package temperature above threshold, cpu clock throttled (total events = 1)
[    1.466767] CPU9: Package temperature above threshold, cpu clock throttled (total events = 1)
[    1.466767] CPU5: Package temperature above threshold, cpu clock throttled (total events = 1)
[    1.466768] CPU11: Package temperature above threshold, cpu clock throttled (total events = 1)
[    1.490956] Freeing unused kernel image memory: 1588K
[    1.492156] CPU4: Core temperature/speed normal
[    1.492156] CPU5: Package temperature/speed normal
[    1.492157] CPU8: Package temperature/speed normal
[    1.492158] CPU3: Package temperature/speed normal
[    1.492158] CPU2: Package temperature/speed normal
[    1.492159] CPU1: Package temperature/speed normal
[    1.492160] CPU0: Package temperature/speed normal
[    1.492160] CPU6: Package temperature/speed normal
[    1.492161] CPU7: Package temperature/speed normal
[    1.492161] CPU10: Core temperature/speed normal
[    1.492162] CPU9: Package temperature/speed normal
[    1.492162] CPU11: Package temperature/speed normal
[    1.492163] CPU10: Package temperature/speed normal
[    1.492164] CPU4: Package temperature/speed normal
[    1.575400] Write protecting the kernel read-only data: 16384k
[    1.580427] Freeing unused kernel image memory: 2028K
[    1.580702] Freeing unused kernel image memory: 780K
[    1.585050] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.585051] x86/mm: Checking user space page tables
[    1.589333] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.589334] Run /init as init process
[    1.639852] udevd[151]: starting version 3.2.7
[    1.640556] udevd[152]: starting eudev-3.2.7
[    1.656453] hidraw: raw HID events driver (C) Jiri Kosina
[    1.657963] cryptd: max_cpu_qlen set to 1000
[    1.661533] r8169 0000:07:00.0: can't disable ASPM; OS doesn't have ASPM control
[    1.663723] SCSI subsystem initialized
[    1.664728] AVX2 version of gcm_enc/dec engaged.
[    1.664729] AES CTR mode by8 optimization enabled
[    1.666146] ACPI: bus type USB registered
[    1.666162] usbcore: registered new interface driver usbfs
[    1.666168] usbcore: registered new interface driver hub
[    1.666189] usbcore: registered new device driver usb
[    1.666959] nvme nvme0: pci function 0000:06:00.0
[    1.666979] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[    1.667376] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[    1.671003] intel-lpss 0000:00:15.0: enabling device (0000 -> 0002)
[    1.673418] libata version 3.00 loaded.
[    1.675087] intel-lpss 0000:00:15.1: enabling device (0000 -> 0002)
[    1.676326] intel-lpss 0000:00:1e.0: enabling device (0000 -> 0002)
[    1.676381] ahci 0000:00:17.0: version 3.0
[    1.676590] dw-apb-uart.2: ttyS0 at MMIO 0xb452a000 (irq = 20, base_baud = 115200) is a 16550A
[    1.677505] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.677509] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[    1.678580] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x110 quirks 0x0000000000009810
[    1.678587] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[    1.678727] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    1.678728] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.678728] usb usb1: Product: xHCI Host Controller
[    1.678729] usb usb1: Manufacturer: Linux 4.19.0-9-amd64 xhci-hcd
[    1.678729] usb usb1: SerialNumber: 0000:00:14.0
[    1.678782] hub 1-0:1.0: USB hub found
[    1.678798] hub 1-0:1.0: 16 ports detected
[    1.679297] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.679298] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[    1.679300] xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
[    1.679322] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[    1.679322] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.679323] usb usb2: Product: xHCI Host Controller
[    1.679323] usb usb2: Manufacturer: Linux 4.19.0-9-amd64 xhci-hcd
[    1.679324] usb usb2: SerialNumber: 0000:00:14.0
[    1.679371] hub 2-0:1.0: USB hub found
[    1.679387] hub 2-0:1.0: 8 ports detected
[    1.679774] xhci_hcd 0000:01:00.2: xHCI Host Controller
[    1.679776] xhci_hcd 0000:01:00.2: new USB bus registered, assigned bus number 3
[    1.680383] xhci_hcd 0000:01:00.2: hcc params 0x0180ff05 hci version 0x110 quirks 0x0000000000000010
[    1.680461] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    1.680462] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.680463] usb usb3: Product: xHCI Host Controller
[    1.680463] usb usb3: Manufacturer: Linux 4.19.0-9-amd64 xhci-hcd
[    1.680464] usb usb3: SerialNumber: 0000:01:00.2
[    1.680521] hub 3-0:1.0: USB hub found
[    1.680526] hub 3-0:1.0: 2 ports detected
[    1.680705] xhci_hcd 0000:01:00.2: xHCI Host Controller
[    1.680706] xhci_hcd 0000:01:00.2: new USB bus registered, assigned bus number 4
[    1.680707] xhci_hcd 0000:01:00.2: Host supports USB 3.1 Enhanced SuperSpeed
[    1.680739] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.680748] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[    1.680749] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.680750] usb usb4: Product: xHCI Host Controller
[    1.680750] usb usb4: Manufacturer: Linux 4.19.0-9-amd64 xhci-hcd
[    1.680750] usb usb4: SerialNumber: 0000:01:00.2
[    1.680804] hub 4-0:1.0: USB hub found
[    1.680810] hub 4-0:1.0: 4 ports detected
[    1.684686] libphy: r8169: probed
[    1.684981] r8169 0000:07:00.0 eth0: RTL8168h/8111h, f8:75:a4:a2:7b:db, XID 54100800, IRQ 128
[    1.684982] r8169 0000:07:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[    1.685886] alg: No test for pcbc(aes) (pcbc-aes-aesni)
[    1.686613] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x10 impl SATA mode
[    1.686614] ahci 0000:00:17.0: flags: 64bit ncq sntf pm clo only pio slum part ems deso sadm sds apst
[    1.686923] scsi host0: ahci
[    1.687001] scsi host1: ahci
[    1.687055] scsi host2: ahci
[    1.687104] scsi host3: ahci
[    1.687156] scsi host4: ahci
[    1.687193] ata1: DUMMY
[    1.687193] ata2: DUMMY
[    1.687194] ata3: DUMMY
[    1.687194] ata4: DUMMY
[    1.687200] ata5: SATA max UDMA/133 abar m2048@0xb452d000 port 0xb452d300 irq 125
[    1.696488] i2c_hid i2c-MSFT0001:01: i2c-MSFT0001:01 supply vdd not found, using dummy regulator
[    1.696497] i2c_hid i2c-MSFT0001:01: Linked as a consumer to regulator.0
[    1.696498] i2c_hid i2c-MSFT0001:01: i2c-MSFT0001:01 supply vddl not found, using dummy regulator
[    1.721798] input: MSFT0001:01 04F3:309E Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-MSFT0001:01/0018:04F3:309E.0001/input/input1
[    1.721985] input: MSFT0001:01 04F3:309E Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-MSFT0001:01/0018:04F3:309E.0001/input/input3
[    1.722206] hid-generic 0018:04F3:309E.0001: input,hidraw0: I2C HID v1.00 Mouse [MSFT0001:01 04F3:309E] on i2c-MSFT0001:01
[    1.888886] nvme nvme0: missing or invalid SUBNQN field.
[    1.888961] nvme nvme0: Shutdown timeout set to 8 seconds
[    1.984694]  nvme0n1: p1 p2 p3
[    1.999383] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    2.015427] usb 1-2: new full-speed USB device number 2 using xhci_hcd
[    2.068022] ata5.00: ATA-10: ST2000LM015-2E8174, 0001, max UDMA/133
[    2.068026] ata5.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    2.167368] usb 1-2: New USB device found, idVendor=1bcf, idProduct=0824, bcdDevice= 5.22
[    2.167372] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.167375] usb 1-2: Product: SmartMouse
[    2.167377] usb 1-2: Manufacturer: SunplusIT
[    2.177283] input: SunplusIT SmartMouse as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.0/0003:1BCF:0824.0002/input/input4
[    2.235831] hid-generic 0003:1BCF:0824.0002: input,hidraw1: USB HID v1.00 Keyboard [SunplusIT SmartMouse] on usb-0000:00:14.0-2/input0
[    2.238137] input: SunplusIT SmartMouse Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:1BCF:0824.0003/input/input5
[    2.238433] input: SunplusIT SmartMouse Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:1BCF:0824.0003/input/input6
[    2.295432] usb 1-6: new high-speed USB device number 3 using xhci_hcd
[    2.295649] hid-generic 0003:1BCF:0824.0003: input,hidraw2: USB HID v1.00 Mouse [SunplusIT SmartMouse] on usb-0000:00:14.0-2/input1
[    2.295763] usbcore: registered new interface driver usbhid
[    2.295765] usbhid: USB HID core driver
[    2.422790] ata5.00: configured for UDMA/133
[    2.423111] scsi 4:0:0:0: Direct-Access     ATA      ST2000LM015-2E81 0001 PQ: 0 ANSI: 5
[    2.434511] sd 4:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[    2.434515] sd 4:0:0:0: [sda] 4096-byte physical blocks
[    2.434525] sd 4:0:0:0: [sda] Write Protect is off
[    2.434528] sd 4:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    2.434542] sd 4:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.454590] usb 1-6: New USB device found, idVendor=04ca, idProduct=7070, bcdDevice= 0.24
[    2.454595] usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.454597] usb 1-6: Product: Integrated Camera
[    2.454600] usb 1-6: Manufacturer: 8SSC20F27068L1GZ0197DY5
[    2.488281]  sda: sda1
[    2.488980] sd 4:0:0:0: [sda] Attached SCSI disk
[    2.494348] sd 4:0:0:0: Attached scsi generic sg0 type 0
[    2.583436] usb 1-9: new full-speed USB device number 4 using xhci_hcd
[    2.746773] usb 1-9: New USB device found, idVendor=048d, idProduct=c100, bcdDevice= 0.43
[    2.746777] usb 1-9: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.746780] usb 1-9: Product: ITE Device(8910)
[    2.746782] usb 1-9: Manufacturer: ITE Tech. Inc.
[    2.759111] input: ITE Tech. Inc. ITE Device(8910) Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/0003:048D:C100.0004/input/input7
[    2.819683] input: ITE Tech. Inc. ITE Device(8910) Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/0003:048D:C100.0004/input/input8
[    2.819742] input: ITE Tech. Inc. ITE Device(8910) Wireless Radio Control as /devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/0003:048D:C100.0004/input/input9
[    2.820160] hid-generic 0003:048D:C100.0004: input,hiddev0,hidraw3: USB HID v1.10 Keyboard [ITE Tech. Inc. ITE Device(8910)] on usb-0000:00:14.0-9/input0
[    2.947586] usb 1-14: new full-speed USB device number 5 using xhci_hcd
[    3.011125] device-mapper: uevent: version 1.0.3
[    3.011356] device-mapper: ioctl: 4.39.0-ioctl (2018-04-03) initialised: dm-devel@redhat.com
[    3.097095] usb 1-14: New USB device found, idVendor=8087, idProduct=0aaa, bcdDevice= 0.02
[    3.097100] usb 1-14: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[   12.259682] NET: Registered protocol family 38
[   12.656892] PM: Image not found (code -22)
[   12.832691] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Opts: (null)
[   12.861838] EXT4-fs (dm-2): mounted filesystem with ordered data mode. Opts: (null)
[   13.180186] udevd[658]: starting version 3.2.7
[   13.190261] udevd[658]: specified group 'kvm' unknown
[   13.211619] udevd[658]: starting eudev-3.2.7
[   13.226736] ACPI: AC Adapter [ADP0] (on-line)
[   13.230547] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input10
[   13.230554] ACPI: Lid Switch [LID0]
[   13.230589] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input11
[   13.230595] ACPI: Power Button [PWRB]
[   13.231967] acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[   13.236728] [Firmware Bug]: ACPI(PEGP) defines _DOD but not _DOS
[   13.236755] ACPI: Video Device [PEGP] (multi-head: yes  rom: yes  post: no)
[   13.237304] acpi device:01: registered as cooling_device12
[   13.237335] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input12
[   13.238170] proc_thermal 0000:00:04.0: Creating sysfs group for PROC_THERMAL_PCI
[   13.246444] idma64 idma64.0: Found Intel integrated DMA 64-bit
[   13.252453] media: Linux media interface: v0.10
[   13.253641] alg: No test for fips(ansi_cprng) (fips_ansi_cprng)
[   13.254228] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[   13.261030] videodev: Linux video capture interface: v2.00
[   13.265812] idma64 idma64.1: Found Intel integrated DMA 64-bit
[   13.282948] idma64 idma64.2: Found Intel integrated DMA 64-bit
[   13.299373] r8169 0000:07:00.0: firmware: direct-loading firmware rtl_nic/rtl8168h-2.fw
[   13.299563] Generic PHY r8169-700:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=r8169-700:00, irq=IGNORE)
[   13.319698] iTCO_vendor_support: vendor-support=0
[   13.322255] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[   13.322274] Bluetooth: Core ver 2.22
[   13.322279] NET: Registered protocol family 31
[   13.322279] Bluetooth: HCI device and connection manager initialized
[   13.322281] Bluetooth: HCI socket layer initialized
[   13.322282] Bluetooth: L2CAP socket layer initialized
[   13.322285] Bluetooth: SCO socket layer initialized
[   13.322460] iTCO_wdt iTCO_wdt: can't request region for resource [mem 0x00c5fffc-0x00c5ffff]
[   13.322486] iTCO_wdt: probe of iTCO_wdt failed with error -16
[   13.325644] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[   13.326062] snd_hda_intel 0000:01:00.1: Disabling MSI
[   13.326066] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[   13.326337] EFI Variables Facility v0.08 2004-May-17
[   13.326349] uvcvideo: Found UVC 1.00 device Integrated Camera (04ca:7070)
[   13.327587] input: PC Speaker as /devices/platform/pcspkr/input/input13
[   13.330964] usbcore: registered new interface driver btusb
[   13.331407] Bluetooth: hci0: Bootloader revision 0.1 build 42 week 52 2015
[   13.332417] Bluetooth: hci0: Device revision is 2
[   13.332418] Bluetooth: hci0: Secure boot is enabled
[   13.332419] Bluetooth: hci0: OTP lock is enabled
[   13.332419] Bluetooth: hci0: API lock is enabled
[   13.332419] Bluetooth: hci0: Debug lock is disabled
[   13.332420] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[   13.333619] bluetooth hci0: firmware: direct-loading firmware intel/ibt-17-16-1.sfi
[   13.333621] Bluetooth: hci0: Found device firmware: intel/ibt-17-16-1.sfi
[   13.339127] battery: ACPI: Battery Slot [BAT0] (battery present)
[   13.345372] uvcvideo 1-6:1.0: Entity type for entity Extension 4 was not initialized!
[   13.345373] uvcvideo 1-6:1.0: Entity type for entity Extension 3 was not initialized!
[   13.345374] uvcvideo 1-6:1.0: Entity type for entity Processing 2 was not initialized!
[   13.345374] uvcvideo 1-6:1.0: Entity type for entity Camera 1 was not initialized!
[   13.345759] input: Integrated Camera: Integrated C as /devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.0/input/input14
[   13.346320] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC257: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[   13.346323] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[   13.346324] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[   13.346324] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[   13.346325] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[   13.346326] snd_hda_codec_realtek hdaudioC0D0:      Mic=0x19
[   13.346327] snd_hda_codec_realtek hdaudioC0D0:      Internal Mic=0x12
[   13.349199] input: Ideapad extra buttons as /devices/pci0000:00/0000:00:1f.0/PNP0C09:00/VPC2004:00/input/input16
[   13.349487] RAPL PMU: API unit is 2^-32 Joules, 5 fixed counters, 655360 ms ovfl timer
[   13.349488] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[   13.349488] RAPL PMU: hw unit of domain package 2^-14 Joules
[   13.349488] RAPL PMU: hw unit of domain dram 2^-14 Joules
[   13.349489] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[   13.349489] RAPL PMU: hw unit of domain psys 2^-14 Joules
[   13.366761] pstore: Using compression: deflate
[   13.366770] pstore: Registered efi as persistent store backend
[   13.399466] usbcore: registered new interface driver uvcvideo
[   13.399467] USB Video Class driver (1.1.1)
[   13.399750] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1f.3/sound/card0/input15
[   13.399865] ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20180810/nsarguments-66)
[   13.400292] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input17
[   13.400314] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input18
[   13.402420] pci 0000:01:00.0: optimus capabilities: enabled, status dynamic power, hda bios codec supported
[   13.402426] VGA switcheroo: detected Optimus DSM method \_SB_.PCI0.PEG0.PEGP handle
[   13.402427] nouveau: detected PR support, will not use DSM
[   13.402588] nouveau 0000:01:00.0: unknown chipset (168000a1)
[   13.402611] nouveau: probe of 0000:01:00.0 failed with error -12
[   13.414202] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   13.425946] r8169 0000:07:00.0 eth0: Link is Down
[   13.437686] input: MSFT0001:01 04F3:309E Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-MSFT0001:01/0018:04F3:309E.0001/input/input21
[   13.437749] hid-multitouch 0018:04F3:309E.0001: input,hidraw0: I2C HID v1.00 Mouse [MSFT0001:01 04F3:309E] on i2c-MSFT0001:01
[   13.448863] Intel(R) Wireless WiFi driver for Linux
[   13.448863] Copyright(c) 2003- 2015 Intel Corporation
[   13.454050] iwlwifi 0000:00:14.3: firmware: direct-loading firmware iwlwifi-9000-pu-b0-jf-b0-38.ucode
[   13.454345] iwlwifi 0000:00:14.3: loaded firmware version 38.755cfdd8.0 op_mode iwlmvm
[   13.514656] iwlwifi 0000:00:14.3: Detected Intel(R) Dual Band Wireless AC 9560, REV=0x318
[   13.564173] intel_rapl: Found RAPL domain package
[   13.564173] intel_rapl: Found RAPL domain core
[   13.564174] intel_rapl: Found RAPL domain dram
[   13.565538] iwlwifi 0000:00:14.3: base HW address: 54:8d:5a:12:93:82
[   13.635625] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[   13.635766] thermal thermal_zone9: failed to read out thermal zone (-61)
[   14.051559] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input22
[   14.051597] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input23
[   14.051632] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input24
[   14.781491] Bluetooth: hci0: Waiting for firmware download to complete
[   14.782383] Bluetooth: hci0: Firmware loaded in 1417403 usecs
[   14.782408] Bluetooth: hci0: Waiting for device to boot
[   14.795467] Bluetooth: hci0: Device booted in 12757 usecs
[   14.795739] bluetooth hci0: firmware: direct-loading firmware intel/ibt-17-16-1.ddc
[   14.795741] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-17-16-1.ddc
[   14.797722] EXT4-fs (dm-1): re-mounted. Opts: errors=remount-ro
[   14.798464] Bluetooth: hci0: Applying Intel DDC parameters completed
[   17.665978] r8169 0000:07:00.0 eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[   17.665992] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   25.141794] lp: driver loaded but no devices found
[   25.165016] ppdev: user-space parallel port driver
[   26.795899] EXT4-fs (dm-2): re-mounted. Opts: (null)
[   26.800022] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
[   26.868535] EXT4-fs (dm-8): mounted filesystem with ordered data mode. Opts: (null)
[   26.876265] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null)
[   26.879888] EXT4-fs (dm-4): mounted filesystem with ordered data mode. Opts: (null)
[   26.883337] EXT4-fs (dm-3): mounted filesystem with ordered data mode. Opts: (null)
[   26.919540] Adding 15622140k swap on /dev/mapper/vgs-swap.  Priority:-2 extents:1 across:15622140k SSFS
[   27.041224] audit: type=1400 audit(1591369678.272:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-senddoc" pid=1789 comm="apparmor_parser"
[   27.041301] audit: type=1400 audit(1591369678.272:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-xpdfimport" pid=1790 comm="apparmor_parser"
[   27.041620] audit: type=1400 audit(1591369678.272:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=1792 comm="apparmor_parser"
[   27.041622] audit: type=1400 audit(1591369678.272:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=1792 comm="apparmor_parser"
[   27.041862] audit: type=1400 audit(1591369678.272:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-oopslash" pid=1788 comm="apparmor_parser"
[   27.042050] audit: type=1400 audit(1591369678.272:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=1794 comm="apparmor_parser"
[   27.042052] audit: type=1400 audit(1591369678.272:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=1794 comm="apparmor_parser"
[   27.042053] audit: type=1400 audit(1591369678.272:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=1794 comm="apparmor_parser"
[   27.042486] audit: type=1400 audit(1591369678.272:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cups-browsed" pid=1791 comm="apparmor_parser"
[   27.044292] audit: type=1400 audit(1591369678.276:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/cups/backend/cups-pdf" pid=1793 comm="apparmor_parser"
[   27.710835] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   27.710836] Bluetooth: BNEP filters: protocol multicast
[   27.710839] Bluetooth: BNEP socket layer initialized
[   27.827391] elogind-daemon[2579]: New seat seat0.
[   29.091486] NET: Registered protocol family 3
[   29.097448] NET: Registered protocol family 5
[   48.451022] elogind-daemon[2579]: New session 1 of user hamsa.
[ 2222.722790] usb usb2-port4: config error
[ 2223.172128] usb 2-4: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 2223.207123] usb 2-4: New USB device found, idVendor=18a5, idProduct=0243, bcdDevice= 1.00
[ 2223.207128] usb 2-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2223.207131] usb 2-4: Product: STORE N GO
[ 2223.207134] usb 2-4: Manufacturer: Verbatim
[ 2223.207136] usb 2-4: SerialNumber: 0707284228443603
[ 2223.230152] usb-storage 2-4:1.0: USB Mass Storage device detected
[ 2223.230551] scsi host5: usb-storage 2-4:1.0
[ 2223.230642] usbcore: registered new interface driver usb-storage
[ 2223.232367] usbcore: registered new interface driver uas
[ 2224.302617] scsi 5:0:0:0: Direct-Access     Verbatim STORE N GO       PMAP PQ: 0 ANSI: 4
[ 2224.303354] sd 5:0:0:0: Attached scsi generic sg1 type 0
[ 2225.199307] sd 5:0:0:0: [sdb] 60532992 512-byte logical blocks: (31.0 GB/28.9 GiB)
[ 2225.199506] sd 5:0:0:0: [sdb] Write Protect is off
[ 2225.199510] sd 5:0:0:0: [sdb] Mode Sense: 23 00 00 00
[ 2225.199696] sd 5:0:0:0: [sdb] No Caching mode page found
[ 2225.202988] sd 5:0:0:0: [sdb] Assuming drive cache: write through
[ 2225.228811]  sdb: sdb1
[ 2225.231219] sd 5:0:0:0: [sdb] Attached SCSI removable disk
df -Th
filesystem           type      Size    Used  Free  Verw% Mounted
udev                 devtmpfs  7,8G       0  7,8G    0% /dev
tmpfs                tmpfs     1,6G    916K  1,6G    1% /run
/dev/mapper/vgs-root ext4       37G    430M   35G    2% /
/dev/mapper/vgs-usr  ext4       55G    2,9G   50G    6% /usr
tmpfs                tmpfs     5,0M       0  5,0M    0% /run/lock
tmpfs                tmpfs     3,2G       0  3,2G    0% /dev/shm
/dev/nvme0n1p2       ext4      227M     50M  162M   24% /boot
/dev/nvme0n1p1       vfat      476M    9,0M  467M    2% /boot/efi
/dev/mapper/vgh-home ext4      1,4T     77M  1,3T    1% /home
/dev/mapper/vgs-test ext4      183G     61M  173G    1% /test
/dev/mapper/vgs-tmp  ext4      3,7G     15M  3,4G    1% /tmp
/dev/mapper/vgs-var  ext4       28G    250M   26G    1% /var
tmpfs                tmpfs     7,8G       0  7,8G    0% /sys/fs/cgroup
tmpfs                tmpfs     1,6G       0  1,6G    0% /run/user/1000
/dev/sdb1            vfat       29G    256K   29G    1% /media/stick
lsblk
NAME                MAJ:MIN RM   SIZE RO TYPE  MOUNTPOINT
sda                   8:0    0   1,8T  0 disk
└─sda1                8:1    0   1,8T  0 part
  └─sda1_crypt      254:7    0   1,8T  0 crypt
    └─vgh-home      254:8    0   1,4T  0 lvm   /home
sdb                   8:16   1  28,9G  0 disk
└─sdb1                8:17   1  28,9G  0 part  /media/stick
nvme0n1             259:0    0   477G  0 disk
├─nvme0n1p1         259:1    0   476M  0 part  /boot/efi
├─nvme0n1p2         259:2    0   238M  0 part  /boot
└─nvme0n1p3         259:3    0 476,2G  0 part
  └─nvme0n1p3_crypt 254:0    0 476,2G  0 crypt
    ├─vgs-root      254:1    0  37,3G  0 lvm   /
    ├─vgs-usr       254:2    0  55,9G  0 lvm   /usr
    ├─vgs-var       254:3    0    28G  0 lvm   /var
    ├─vgs-tmp       254:4    0   3,7G  0 lvm   /tmp
    ├─vgs-swap      254:5    0  14,9G  0 lvm   [SWAP]
    └─vgs-test      254:6    0 186,3G  0 lvm   /test
lspci -vnn
with option discrete graphics enabled in BIOS
00:00.0 Host bridge [0600]: Intel Corporation 8th Gen Core Processor Host Bridge/DRAM Registers [8086:3ec4] (rev 07)
	Subsystem: Lenovo 8th Gen Core Processor Host Bridge/DRAM Registers [17aa:3807]
	Flags: bus master, fast devsel, latency 0
	Capabilities: [e0] Vendor Specific Information: Len=10 <?>
	Kernel driver in use: skl_uncore
00:01.0 PCI bridge [0604]: Intel Corporation Skylake PCIe Controller (x16) [8086:1901] (rev 07) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 121
	Bus: primary=00, secondary=01, subordinate=05, sec-latency=0
	I/O behind bridge: 00004000-00004fff
	Memory behind bridge: a0000000-b40fffff
	Prefetchable memory behind bridge: 00000000b4100000-00000000b41fffff
	Capabilities: [88] Subsystem: Lenovo Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x16) [17aa:3812]
	Capabilities: [80] Power Management version 3
	Capabilities: [90] MSI: Enable+ Count=1/1 Maskable- 64bit-
	Capabilities: [a0] Express Root Port (Slot+), MSI 00
	Capabilities: [100] Virtual Channel
	Capabilities: [140] Root Complex Link
	Capabilities: [d94] #19
	Kernel driver in use: pcieport
00:04.0 Signal processing controller [1180]: Intel Corporation Skylake Processor Thermal Subsystem [8086:1903] (rev 07)
	Subsystem: Lenovo Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem [17aa:382f]
	Flags: bus master, fast devsel, latency 0, IRQ 16
	Memory at b4510000 (64-bit, non-prefetchable) [size=32K]
	Capabilities: [90] MSI: Enable- Count=1/1 Maskable- 64bit-
	Capabilities: [d0] Power Management version 3
	Capabilities: [e0] Vendor Specific Information: Len=0c <?>
	Kernel driver in use: proc_thermal
	Kernel modules: processor_thermal_device
00:08.0 System peripheral [0880]: Intel Corporation Skylake Gaussian Mixture Model [8086:1911]
	Subsystem: Lenovo Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th Gen Core Processor Gaussian Mixture Model [17aa:3864]
	Flags: bus master, fast devsel, latency 0, IRQ 255
	Memory at b4524000 (64-bit, non-prefetchable) [size=4K]
	Capabilities: [dc] Power Management version 2
	Capabilities: [f0] PCI Advanced Features
00:12.0 Signal processing controller [1180]: Intel Corporation Cannon Lake PCH Thermal Controller [8086:a379] (rev 10)
	Subsystem: Lenovo Cannon Lake PCH Thermal Controller [17aa:3802]
	Memory at b4525000 (64-bit, non-prefetchable) [size=4K]
	Capabilities: [50] Power Management version 3
	Capabilities: [80] MSI: Enable- Count=1/1 Maskable- 64bit-
	Kernel driver in use: intel_pch_thermal
	Kernel modules: intel_pch_thermal
00:14.0 USB controller [0c03]: Intel Corporation Cannon Lake PCH USB 3.1 xHCI Host Controller [8086:a36d] (rev 10) (prog-if 30 [XHCI])
	Subsystem: Lenovo Cannon Lake PCH USB 3.1 xHCI Host Controller [17aa:3806]
	Flags: bus master, medium devsel, latency 0, IRQ 126
	Memory at b4500000 (64-bit, non-prefetchable) [size=64K]
	Capabilities: [70] Power Management version 2
	Capabilities: [80] MSI: Enable+ Count=1/8 Maskable- 64bit+
	Capabilities: [90] Vendor Specific Information: Len=14 <?>
	Kernel driver in use: xhci_hcd
	Kernel modules: xhci_pci
00:14.2 RAM memory [0500]: Intel Corporation Cannon Lake PCH Shared SRAM [8086:a36f] (rev 10)
	Subsystem: Lenovo Cannon Lake PCH Shared SRAM [17aa:3824]
	Memory at b4520000 (64-bit, non-prefetchable) [size=8K]
	Memory at b4526000 (64-bit, non-prefetchable) [size=4K]
00:14.3 Network controller [0280]: Intel Corporation Wireless-AC 9560 [Jefferson Peak] [8086:a370] (rev 10)
	Subsystem: Intel Corporation Wireless-AC 9560 [Jefferson Peak] [8086:0034]
	Memory at b4518000 (64-bit, non-prefetchable) [size=16K]
	Capabilities: [c8] Power Management version 3
	Capabilities: [d0] MSI: Enable- Count=1/1 Maskable- 64bit+
	Capabilities: [40] Express Root Complex Integrated Endpoint, MSI 00
	Capabilities: [80] MSI-X: Enable+ Count=16 Masked-
	Capabilities: [100] #00
	Capabilities: [14c] Latency Tolerance Reporting
	Capabilities: [164] Vendor Specific Information: ID=0010 Rev=0 Len=014 <?>
	Kernel driver in use: iwlwifi
	Kernel modules: iwlwifi
00:15.0 Serial bus controller [0c80]: Intel Corporation Device [8086:a368] (rev 10)
	Subsystem: Lenovo Device [17aa:3803]
	Memory at b4527000 (64-bit, non-prefetchable) [size=4K]
	Kernel driver in use: intel-lpss
	Kernel modules: intel_lpss_pci
00:15.1 Serial bus controller [0c80]: Intel Corporation Device [8086:a369] (rev 10)
	Subsystem: Lenovo Device [17aa:3804]
	Flags: bus master, fast devsel, latency 0, IRQ 17
	Memory at b4528000 (64-bit, non-prefetchable) [size=4K]
00:16.0 Communication controller [0780]: Intel Corporation Cannon Lake PCH HECI Controller [8086:a360] (rev 10)
	Subsystem: Lenovo Cannon Lake PCH HECI Controller [17aa:3810]
	Flags: bus master, fast devsel, latency 0, IRQ 141
	Memory at b4529000 (64-bit, non-prefetchable) [size=4K]
	Capabilities: [8c] MSI: Enable+ Count=1/1 Maskable- 64bit+
	Capabilities: [a4] Vendor Specific Information: Len=14 <?>
	Kernel driver in use: mei_me
	Kernel modules: mei_me
00:17.0 SATA controller [0106]: Intel Corporation Device [8086:a353] (rev 10) (prog-if 01 [AHCI 1.0])
	Subsystem: Lenovo Device [17aa:3808]
	Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 125
	Memory at b4522000 (32-bit, non-prefetchable) [size=8K]
	Memory at b452e000 (32-bit, non-prefetchable) [size=256]
	I/O ports at 5040 [size=8]
	I/O ports at 5048 [size=4]
	I/O ports at 5020 [size=32]
	Memory at b452d000 (32-bit, non-prefetchable) [size=2K]
	Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit-
	Capabilities: [70] Power Management version 3
	Capabilities: [a8] SATA HBA v1.0
	Kernel driver in use: ahci
	Kernel modules: ahci
00:1d.0 PCI bridge [0604]: Intel Corporation Cannon Lake PCH PCI Express Root Port 9 [8086:a330] (rev f0) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 122
	Bus: primary=00, secondary=06, subordinate=06, sec-latency=0
	Memory behind bridge: b4400000-b44fffff
	Capabilities: [40] Express Root Port (Slot+), MSI 00
	Capabilities: [90] Subsystem: Lenovo Cannon Lake PCH PCI Express Root Port 9 [17aa:381e]
	Capabilities: [a0] Power Management version 3
	Capabilities: [140] Access Control Services
	Capabilities: [150] Precision Time Measurement
	Capabilities: [200] L1 PM Substates
	Capabilities: [220] #19
	Capabilities: [250] Downstream Port Containment
00:1d.5 PCI bridge [0604]: Intel Corporation Device [8086:a335] (rev f0) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 123
	Bus: primary=00, secondary=07, subordinate=07, sec-latency=0
	I/O behind bridge: 00003000-00003fff
	Memory behind bridge: b4300000-b43fffff
	Capabilities: [90] Subsystem: Lenovo Device [17aa:3823]
00:1e.0 Communication controller [0780]: Intel Corporation Device [8086:a328] (rev 10)
	Subsystem: Lenovo Device [17aa:3813]
	Flags: bus master, fast devsel, latency 0, IRQ 20
	Memory at b452a000 (64-bit, non-prefetchable) [size=4K]
00:1f.0 ISA bridge [0601]: Intel Corporation Device [8086:a30d] (rev 10)
	Subsystem: Lenovo Device [17aa:380e]
00:1f.3 Audio device [0403]: Intel Corporation Cannon Lake PCH cAVS [8086:a348] (rev 10)
	Subsystem: Lenovo Cannon Lake PCH cAVS [17aa:380f]
	Flags: bus master, fast devsel, latency 32, IRQ 142
	Memory at b451c000 (64-bit, non-prefetchable) [size=16K]
	Memory at b4200000 (64-bit, non-prefetchable) [size=1M]
	Capabilities: [80] Vendor Specific Information: Len=14 <?>
	Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
	Kernel driver in use: snd_hda_intel
	Kernel modules: snd_hda_intel
00:1f.4 SMBus [0c05]: Intel Corporation Cannon Lake PCH SMBus Controller [8086:a323] (rev 10)
	Subsystem: Lenovo Cannon Lake PCH SMBus Controller [17aa:3814]
	Flags: medium devsel, IRQ 16
	Memory at b452b000 (64-bit, non-prefetchable) [size=256]
	I/O ports at 5000 [size=32]
	Kernel driver in use: i801_smbus
	Kernel modules: i2c_i801
00:1f.5 Serial bus controller [0c80]: Intel Corporation Cannon Lake PCH SPI Controller [8086:a324] (rev 10)
	Subsystem: Lenovo Cannon Lake PCH SPI Controller [17aa:3827]
	Memory at fe010000 (32-bit, non-prefetchable) [size=4K]
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation Device [10de:2191] (rev a1) (prog-if 00 [VGA controller])
	Subsystem: Lenovo Device [17aa:3ffc]
	Flags: fast devsel, IRQ 16
	Memory at b3000000 (32-bit, non-prefetchable) [size=16M]
	Memory at a0000000 (64-bit, prefetchable) [size=256M]
	Memory at b0000000 (64-bit, prefetchable) [size=32M]
	I/O ports at 4000 [size=128]
	Expansion ROM at b2000000 [disabled] [size=512K]
	Capabilities: [60] Power Management version 3
	Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
	Capabilities: [78] Express Legacy Endpoint, MSI 00
	Capabilities: [250] Latency Tolerance Reporting
	Capabilities: [258] L1 PM Substates
	Capabilities: [128] Power Budgeting <?>
	Capabilities: [420] Advanced Error Reporting
	Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
	Capabilities: [900] #19
	Capabilities: [bb0] #15
	Kernel modules: nouveau
01:00.1 Audio device [0403]: NVIDIA Corporation Device [10de:1aeb] (rev a1)
	Memory at b4000000 (32-bit, non-prefetchable) [size=16K]
	Capabilities: [78] Express Endpoint, MSI 00
	Capabilities: [100] Advanced Error Reporting
01:00.2 USB controller [0c03]: NVIDIA Corporation Device [10de:1aec] (rev a1) (prog-if 30 [XHCI])
	Flags: bus master, fast devsel, latency 0, IRQ 127
	Memory at b4100000 (64-bit, prefetchable) [size=256K]
	Memory at b4140000 (64-bit, prefetchable) [size=64K]
	Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
	Capabilities: [b4] Power Management version 3
01:00.3 Serial bus controller [0c80]: NVIDIA Corporation Device [10de:1aed] (rev a1)
	Flags: fast devsel, IRQ 255
	Memory at b4004000 (32-bit, non-prefetchable) [size=4K]
06:00.0 Non-Volatile memory controller [0108]: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981 [144d:a808] (prog-if 02 [NVM Express])
	Subsystem: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981 [144d:a801]
	Flags: bus master, fast devsel, latency 0, IRQ 16, NUMA node 0
	Memory at b4400000 (64-bit, non-prefetchable) [size=16K]
	Capabilities: [40] Power Management version 3
	Capabilities: [50] MSI: Enable- Count=1/32 Maskable- 64bit+
	Capabilities: [70] Express Endpoint, MSI 00
	Capabilities: [b0] MSI-X: Enable+ Count=33 Masked-
	Capabilities: [148] Device Serial Number 00-00-00-00-00-00-00-00
	Capabilities: [158] Power Budgeting <?>
	Capabilities: [168] #19
	Capabilities: [188] Latency Tolerance Reporting
	Capabilities: [190] L1 PM Substates
	Kernel driver in use: nvme
	Kernel modules: nvme
07:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 15)
	Subsystem: Lenovo RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [17aa:38cd]
	I/O ports at 3000 [size=256]
	Memory at b4304000 (64-bit, non-prefetchable) [size=4K]
	Memory at b4300000 (64-bit, non-prefetchable) [size=16K]
	Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
	Capabilities: [70] Express Endpoint, MSI 01
	Capabilities: [b0] MSI-X: Enable+ Count=4 Masked-
	Capabilities: [140] Virtual Channel
	Capabilities: [160] Device Serial Number 01-00-00-00-68-4c-e0-00
	Capabilities: [170] Latency Tolerance Reporting
	Capabilities: [178] L1 PM Substates
	Kernel driver in use: r8169
	Kernel modules: r8169
Xorg.0.log
X.Org X Server 1.20.4
[    27.923] Build Operating System: Linux 4.9.0-8-amd64 x86_64 Debian
[    27.923] Current Operating System: Linux deva 4.19.0-9-amd64 #1 SMP Debian 4.19.118-2 (2020-04-29) x86_64
[    27.923] Kernel command line: BOOT_IMAGE=/vmlinuz-4.19.0-9-amd64 root=/dev/mapper/vgs-root ro quiet rd.driver.blacklist=nouveau
[    27.923] Build Date: 05 March 2019  08:11:12PM
[    27.923] xorg-server 2:1.20.4-1 (https://www.debian.org/support)
[    27.923] Current version of pixman: 0.36.0
[    27.923] 	Before reporting problems, check http://wiki.x.org
[    27.923] Markers: (--) probed, (**) from config file, (==) default setting,
[    27.924] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Jun  5 17:07:59 2020
[    27.924] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    27.925] (==) No Layout section.  Using the first Screen section.
[    27.925] (==) No screen section available. Using defaults.
[    27.925] (**) |-->Screen "Default Screen Section" (0)
[    27.925] (**) |   |-->Monitor "<default monitor>"
[    27.926] (==) No monitor specified for screen "Default Screen Section".
[    27.926] (==) Automatically adding devices
[    27.926] (==) Automatically enabling devices
[    27.926] (==) Automatically adding GPU devices
[    27.926] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    27.928] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[    27.928] 	Entry deleted from font path.
[    27.930] (==) FontPath set to:
	/usr/share/fonts/X11/misc,
	/usr/share/fonts/X11/Type1,
	/usr/share/fonts/X11/100dpi,
	/usr/share/fonts/X11/75dpi,
	built-ins
[    27.930] (==) ModulePath set to "/usr/lib/xorg/modules"
[    27.930] (II) The server relies on udev to provide the list of input devices.
[    27.930] (II) Loader magic: 0x55f4f97fde20
[    27.930] (II) Module ABI versions:
[    27.930] 	X.Org ANSI C Emulation: 0.4
[    27.930] 	X.Org Video Driver: 24.0
[    27.930] 	X.Org XInput driver : 24.1
[    27.930] 	X.Org Server Extension : 10.0
[    27.930] (++) using VT number 7
[    27.930] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[    27.933] (--) PCI:*(1@0:0:0) 10de:2191:17aa:3ffc rev 161, Mem @ 0xb3000000/16777216, 0xa0000000/268435456, 0xb0000000/33554432, I/O @ 0x00004000/128, BIOS @ 0x????????/524288
[    27.933] (II) LoadModule: "glx"
[    27.933] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    27.940] (II) Module glx: vendor="X.Org Foundation"
[    27.940] 	compiled for 1.20.4, module version = 1.0.0
[    27.940] 	ABI class: X.Org Server Extension, version 10.0
[    28.073] (==) Matched nouveau as autoconfigured driver 0
[    28.073] (==) Matched nv as autoconfigured driver 1
[    28.073] (==) Matched modesetting as autoconfigured driver 2
[    28.073] (==) Matched fbdev as autoconfigured driver 3
[    28.073] (==) Matched vesa as autoconfigured driver 4
[    28.073] (==) Assigned the driver to the xf86ConfigLayout
[    28.073] (II) LoadModule: "nouveau"
[    28.076] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[    28.078] (II) Module nouveau: vendor="X.Org Foundation"
[    28.078] 	compiled for 1.20.3, module version = 1.0.16
[    28.079] 	Module class: X.Org Video Driver
[    28.079] 	ABI class: X.Org Video Driver, version 24.0
[    28.079] (II) LoadModule: "nv"
[    28.079] (WW) Warning, couldn't open module nv
[    28.079] (EE) Failed to load module "nv" (module does not exist, 0)
[    28.079] (II) LoadModule: "modesetting"
[    28.079] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    28.081] (II) Module modesetting: vendor="X.Org Foundation"
[    28.081] 	compiled for 1.20.4, module version = 1.20.4
[    28.081] 	Module class: X.Org Video Driver
[    28.081] 	ABI class: X.Org Video Driver, version 24.0
[    28.081] (II) LoadModule: "fbdev"
[    28.081] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[    28.081] (II) Module fbdev: vendor="X.Org Foundation"
[    28.081] 	compiled for 1.20.0, module version = 0.5.0
[    28.081] (II) LoadModule: "vesa"
[    28.082] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[    28.082] (II) Module vesa: vendor="X.Org Foundation"
[    28.082] 	compiled for 1.20.1, module version = 2.4.0
[    28.082] 	Module class: X.Org Video Driver
[    28.082] 	ABI class: X.Org Video Driver, version 24.0
[    28.082] (II) NOUVEAU driver Date:   Mon Jan 28 23:25:58 2019 -0500
[    28.082] (II) NOUVEAU driver for NVIDIA chipset families :
[    28.082] 	RIVA TNT            (NV04)
[    28.082] 	RIVA TNT2           (NV05)
[    28.082] 	GeForce 256         (NV10)
[    28.083] 	GeForce 2           (NV11, NV15)
[    28.083] 	GeForce 4MX         (NV17, NV18)
[    28.083] 	GeForce 3           (NV20)
[    28.083] 	GeForce 4Ti         (NV25, NV28)
[    28.083] 	GeForce FX          (NV3x)
[    28.083] 	GeForce 6           (NV4x)
[    28.083] 	GeForce 7           (G7x)
[    28.083] 	GeForce 8           (G8x)
[    28.083] 	GeForce 9           (G9x)
[    28.083] 	GeForce GTX 2xx/3xx (GT2xx)
[    28.083] 	GeForce GTX 4xx/5xx (GFxxx)
[    28.083] 	GeForce GTX 6xx/7xx (GKxxx)
[    28.083] 	GeForce GTX 9xx     (GMxxx)
[    28.083] 	GeForce GTX 10xx    (GPxxx)
[    28.083] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    28.083] (II) FBDEV: driver for framebuffer: fbdev
[    28.083] (II) VESA: driver for VESA chipsets: vesa
[    28.233] (EE) [drm] Failed to open DRM device for pci:0000:01:00.0: -19
[    28.233] (EE) open /dev/dri/card0: No such file or directory
[    28.233] (WW) Falling back to old probe method for modesetting
[    28.233] (II) Loading sub module "fbdevhw"
[    28.233] (II) LoadModule: "fbdevhw"
[    28.233] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[    28.236] (II) Module fbdevhw: vendor="X.Org Foundation"
[    28.236] 	compiled for 1.20.4, module version = 0.0.2
[    28.237] 	ABI class: X.Org Video Driver, version 24.0
[    28.237] (EE) Unable to find a valid framebuffer device
[    28.237] (WW) Falling back to old probe method for fbdev
[    28.237] (II) Loading sub module "fbdevhw"
[    28.237] (II) LoadModule: "fbdevhw"
[    28.237] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[    28.237] (II) Module fbdevhw: vendor="X.Org Foundation"
[    28.237] 	compiled for 1.20.4, module version = 0.0.2
[    28.237] (II) FBDEV(2): using default device
[    28.237] (EE) Screen 0 deleted because of no matching config section.
[    28.237] (II) UnloadModule: "modesetting"
[    28.237] (II) UnloadModule: "fbdev"
[    28.237] (II) UnloadSubModule: "fbdevhw"
[    28.237] (EE)
Fatal server error:
[    28.237] (EE) Cannot run in framebuffer mode. Please specify busIDs        for all framebuffer devices
[    28.237] (EE)
[    28.237] (EE)
Please consult the The X.Org Foundation support
	 at http://wiki.x.org
 for help.
[    28.237] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[    28.237] (EE)
[    28.260] (EE) Server terminated with error (1). Closing log file.
Any help getting this baby up and running greatly appreciated.
Have a wonderful time - Walter
#2 2020-06-05 20:26:32
larsH
Re: Beowulf and Legion y540
Hi
The default kernel for devuan is 4.19. It is to old for your graphics card. I would suggest you to install the newest kernel for the system (linux 5.4) from devuan backports. It might not support your video card. But it will also have better drivers for other things on such a new machine. i would also suggest installing the newest nvidia drivers also from backports.
To enable backports add "deb http://deb.devuan.org/merged beowulf-backports main contrib non-free" to your /etc/apt/sources.list.
If you encounter any problems you are welcome here again
Enjoy your new machine
Have an good day
Lars H
Oh then i could see that you might nead bumblebee. Read here (and it is about buster) https://wiki.debian.org/Bumblebee
#3 2020-06-08 13:39:08
walter
Hi larsH,
thank you very much for your time and response. I had the very same idea and I did it before and got stuck at/with bumblebee. OK - let me try again.
As you suggested:
1) Installed the kernel from beowulf-backports - I installed 5.4.19 and 5.5.17 (and use 5.5.17 since then)
2) Installed the nvidia-drivers from beowulf-backports (release 440.82)
After reboot system came up with X (XFCE) and I was able to login. I noticed some minor issues: missing firmware for both network cards, X.509 certificate loading failure, eudev didn't find a group kvm and I got a delay during shutdown the system (the LVM/Luks issue).
3) Then with the installation of bumblebee-nvidia the trouble started. After that installation I got error messages from nvidia-persistenced both in Synaptic and the console during installation of any package:
nvidia-persistenced failed to initialize. Check syslog for more details.
invoke-rc.d: initsript nvidia-persistenced, action "start" failed.
dpkg: failure during maintenance of package nvidia-persistenced (--configure): (line was translated by me - ori in german)
subprocess of "installed nvidia-persistenced-script post-installation" returned failure 1 (line was translated by me - ori in german)
I checked syslog and the corresponding content is:
nvidia-persistenced: Failed to lock PID file: Resource temporarily unavailable
nvidia-persistenced: Shutdown (4909)
However after reboot its still possible to use X and login.
4) All this was done with BIOS setting "Discrete Graphics". As soon I switch over to "Switchable Graphics" the screen is mainly black and for very short moments flashes up. Its impossible to read. I took my camera and made a movie of it to check what is stated on the screen. After starting the machine came up and starts X. Login is possible to console and X. I used a console to login and copied dmesg to a pendrive (tried many times, bescause blind of no visual feedback from the black screen.
Output of dmesg (with Switchable Graphics enabled inside BIOS):
[    0.000000] Linux version 5.5.0-0.bpo.2-amd64 (debian-kernel@lists.debian.org) (gcc version 8.3.0 (Debian 8.3.0-6)) #1 SMP Debian 5.5.17-1~bpo10+1 (2020-04-23)
[    0.000000] Command line: BOOT_IMAGE=/vmlinuz-5.5.0-0.bpo.2-amd64 root=/dev/mapper/vgs-root ro quiet
[    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[    0.000000] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.000000] x86/fpu: xstate_offset[3]:  832, xstate_sizes[3]:   64
[    0.000000] x86/fpu: xstate_offset[4]:  896, xstate_sizes[4]:   64
[    0.000000] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000073d86fff] usable
[    0.000000] BIOS-e820: [mem 0x0000000073d87000-0x0000000074686fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000074687000-0x000000008a89dfff] usable
[    0.000000] BIOS-e820: [mem 0x000000008a89e000-0x000000008aa9dfff] type 20
[    0.000000] BIOS-e820: [mem 0x000000008aa9e000-0x000000008b49dfff] reserved
[    0.000000] BIOS-e820: [mem 0x000000008b49e000-0x000000008bb8dfff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x000000008bb8e000-0x000000008bc0dfff] ACPI data
[    0.000000] BIOS-e820: [mem 0x000000008bc0e000-0x000000008bc0efff] usable
[    0.000000] BIOS-e820: [mem 0x000000008bc0f000-0x000000008f7fffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed10000-0x00000000fed19fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed84000-0x00000000fed84fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ff600000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000046e7fffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] efi: EFI v2.60 by INSYDE Corp.
[    0.000000] efi:  ACPI=0x8bc0d000  ACPI 2.0=0x8bc0d014  TPMFinalLog=0x8b475000  SMBIOS=0x8ac50000  SMBIOS 3.0=0x8ac4e000  ESRT=0x7b474918  MEMATTR=0x7ac91018
[    0.000000] secureboot: Secure boot could not be determined (mode 0)
[    0.000000] SMBIOS 3.0.1 present.
[    0.000000] DMI: LENOVO 81Q4/LNVNB161216, BIOS BHCN36WW 02/10/2020
[    0.000000] tsc: Detected 2600.000 MHz processor
[    0.000009] tsc: Detected 2599.992 MHz TSC
[    0.000009] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000011] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000016] last_pfn = 0x46e800 max_arch_pfn = 0x400000000
[    0.000020] MTRR default type: write-back
[    0.000020] MTRR fixed ranges enabled:
[    0.000021]   00000-9FFFF write-back
[    0.000022]   A0000-BFFFF uncachable
[    0.000023]   C0000-FFFFF write-protect
[    0.000023] MTRR variable ranges enabled:
[    0.000025]   0 base 00C0000000 mask 7FC0000000 uncachable
[    0.000026]   1 base 00A0000000 mask 7FE0000000 uncachable
[    0.000026]   2 base 0090000000 mask 7FF0000000 uncachable
[    0.000027]   3 base 008E000000 mask 7FFE000000 uncachable
[    0.000028]   4 base 008D000000 mask 7FFF000000 uncachable
[    0.000029]   5 base 2000000000 mask 6000000000 uncachable
[    0.000029]   6 base 1000000000 mask 7000000000 uncachable
[    0.000030]   7 base 0800000000 mask 7800000000 uncachable
[    0.000031]   8 base 4000000000 mask 4000000000 uncachable
[    0.000031]   9 disabled
[    0.000477] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.000637] last_pfn = 0x8bc0f max_arch_pfn = 0x400000000
[    0.008929] esrt: Reserving ESRT space from 0x000000007b474918 to 0x000000007b4749c8.
[    0.008933] e820: update [mem 0x7b474000-0x7b474fff] usable ==> reserved
[    0.008945] Using GB pages for direct mapping
[    0.008947] BRK [0x311601000, 0x311601fff] PGTABLE
[    0.008948] BRK [0x311602000, 0x311602fff] PGTABLE
[    0.008949] BRK [0x311603000, 0x311603fff] PGTABLE
[    0.008987] BRK [0x311604000, 0x311604fff] PGTABLE
[    0.008988] BRK [0x311605000, 0x311605fff] PGTABLE
[    0.009150] BRK [0x311606000, 0x311606fff] PGTABLE
[    0.009189] BRK [0x311607000, 0x311607fff] PGTABLE
[    0.009229] BRK [0x311608000, 0x311608fff] PGTABLE
[    0.009263] BRK [0x311609000, 0x311609fff] PGTABLE
[    0.009316] BRK [0x31160a000, 0x31160afff] PGTABLE
[    0.009391] BRK [0x31160b000, 0x31160bfff] PGTABLE
[    0.009500] RAMDISK: [mem 0x34703000-0x36378fff]
[    0.009508] ACPI: Early table checksum verification disabled
[    0.009510] ACPI: RSDP 0x000000008BC0D014 000024 (v02 LENOVO)
[    0.009513] ACPI: XSDT 0x000000008BBEE188 000104 (v01 LENOVO CB-01    00000001      01000013)
[    0.009518] ACPI: FACP 0x000000008BBF1000 00010C (v05 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009522] ACPI: DSDT 0x000000008BBBD000 02FE66 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009524] ACPI: FACS 0x000000008BB0D000 000040
[    0.009526] ACPI: UEFI 0x000000008BC0C000 000236 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009529] ACPI: SSDT 0x000000008BC0A000 001B1C (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009531] ACPI: SSDT 0x000000008BC06000 0031D0 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009533] ACPI: UEFI 0x000000008BC05000 000042 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009535] ACPI: SSDT 0x000000008BC04000 00045A (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009537] ACPI: SSDT 0x000000008BC03000 000046 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009540] ACPI: TPM2 0x000000008BC02000 000034 (v03 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009542] ACPI: POAT 0x000000008BC01000 000055 (v03 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009544] ACPI: SSDT 0x000000008BBFC000 0044B6 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009546] ACPI: LPIT 0x000000008BBFB000 000094 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009548] ACPI: WSMT 0x000000008BBFA000 000028 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009550] ACPI: SSDT 0x000000008BBF9000 000C2F (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009553] ACPI: DBGP 0x000000008BBF8000 000034 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009555] ACPI: DBG2 0x000000008BBF7000 000061 (v00 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009557] ACPI: SSDT 0x000000008BBF6000 000896 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009559] ACPI: SSDT 0x000000008BBF3000 002F89 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009561] ACPI: ASF! 0x000000008BBF2000 0000A5 (v32 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009564] ACPI: HPET 0x000000008BBF0000 000038 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009566] ACPI: APIC 0x000000008BBEF000 00012C (v03 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009568] ACPI: MCFG 0x000000008BBED000 00003C (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009570] ACPI: SSDT 0x000000008BBBA000 002BBF (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009572] ACPI: DMAR 0x000000008BBB9000 0000A8 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009575] ACPI: SSDT 0x000000008BBB3000 005178 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009577] ACPI: SSDT 0x000000008BBB2000 00004C (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009579] ACPI: SSDT 0x000000008BBB1000 000123 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009582] ACPI: FPDT 0x000000008BBB0000 000044 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009585] ACPI: BGRT 0x000000008BBAF000 000038 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009591] ACPI: Local APIC address 0xfee00000
[    0.009886] No NUMA configuration found
[    0.009887] Faking a node at [mem 0x0000000000000000-0x000000046e7fffff]
[    0.009889] NODE_DATA(0) allocated [mem 0x46e7fb000-0x46e7fffff]
[    0.009916] Zone ranges:
[    0.009917]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.009918]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.009919]   Normal   [mem 0x0000000100000000-0x000000046e7fffff]
[    0.009920]   Device   empty
[    0.009920] Movable zone start for each node
[    0.009921] Early memory node ranges
[    0.009922]   node   0: [mem 0x0000000000001000-0x000000000009efff]
[    0.009923]   node   0: [mem 0x0000000000100000-0x0000000073d86fff]
[    0.009923]   node   0: [mem 0x0000000074687000-0x000000008a89dfff]
[    0.009924]   node   0: [mem 0x000000008bc0e000-0x000000008bc0efff]
[    0.009924]   node   0: [mem 0x0000000100000000-0x000000046e7fffff]
[    0.010147] Zeroed struct page in unavailable ranges: 30915 pages
[    0.010148] Initmem setup node 0 [mem 0x0000000000001000-0x000000046e7fffff]
[    0.010149] On node 0 totalpages: 4163389
[    0.010150]   DMA zone: 64 pages used for memmap
[    0.010151]   DMA zone: 23 pages reserved
[    0.010151]   DMA zone: 3998 pages, LIFO batch:0
[    0.010205]   DMA32 zone: 8767 pages used for memmap
[    0.010206]   DMA32 zone: 561055 pages, LIFO batch:63
[    0.020377]   Normal zone: 56224 pages used for memmap
[    0.020377]   Normal zone: 3598336 pages, LIFO batch:63
[    0.020838] x86/hpet: Will disable the HPET for this platform because it's not reliable
[    0.020874] Reserving Intel graphics memory at [mem 0x8d800000-0x8f7fffff]
[    0.021420] ACPI: PM-Timer IO Port: 0x1808
[    0.021421] ACPI: Local APIC address 0xfee00000
[    0.021427] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.021428] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[    0.021429] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[    0.021429] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[    0.021430] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[    0.021430] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[    0.021431] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[    0.021431] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[    0.021432] ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
[    0.021432] ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
[    0.021433] ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
[    0.021433] ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
[    0.021434] ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
[    0.021434] ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
[    0.021435] ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
[    0.021435] ACPI: LAPIC_NMI (acpi_id[0x10] high edge lint[0x1])
[    0.021495] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[    0.021498] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.021499] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.021502] ACPI: IRQ0 used by override.
[    0.021503] ACPI: IRQ9 used by override.
[    0.021504] Using ACPI (MADT) for SMP configuration information
[    0.021505] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[    0.021511] e820: update [mem 0x7ad24000-0x7ad64fff] usable ==> reserved
[    0.021518] smpboot: Allowing 12 CPUs, 0 hotplug CPUs
[    0.021533] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.021534] PM: Registered nosave memory: [mem 0x0009f000-0x000fffff]
[    0.021535] PM: Registered nosave memory: [mem 0x73d87000-0x74686fff]
[    0.021536] PM: Registered nosave memory: [mem 0x7ad24000-0x7ad64fff]
[    0.021538] PM: Registered nosave memory: [mem 0x7b474000-0x7b474fff]
[    0.021539] PM: Registered nosave memory: [mem 0x8a89e000-0x8aa9dfff]
[    0.021539] PM: Registered nosave memory: [mem 0x8aa9e000-0x8b49dfff]
[    0.021540] PM: Registered nosave memory: [mem 0x8b49e000-0x8bb8dfff]
[    0.021540] PM: Registered nosave memory: [mem 0x8bb8e000-0x8bc0dfff]
[    0.021542] PM: Registered nosave memory: [mem 0x8bc0f000-0x8f7fffff]
[    0.021542] PM: Registered nosave memory: [mem 0x8f800000-0xdfffffff]
[    0.021543] PM: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[    0.021543] PM: Registered nosave memory: [mem 0xf0000000-0xfdffffff]
[    0.021544] PM: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
[    0.021544] PM: Registered nosave memory: [mem 0xfe011000-0xfed0ffff]
[    0.021545] PM: Registered nosave memory: [mem 0xfed10000-0xfed19fff]
[    0.021545] PM: Registered nosave memory: [mem 0xfed1a000-0xfed83fff]
[    0.021545] PM: Registered nosave memory: [mem 0xfed84000-0xfed84fff]
[    0.021546] PM: Registered nosave memory: [mem 0xfed85000-0xfedfffff]
[    0.021546] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[    0.021547] PM: Registered nosave memory: [mem 0xfee01000-0xff5fffff]
[    0.021547] PM: Registered nosave memory: [mem 0xff600000-0xffffffff]
[    0.021549] [mem 0x8f800000-0xdfffffff] available for PCI devices
[    0.021549] Booting paravirtualized kernel on bare hardware
[    0.021552] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[    0.112233] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:12 nr_node_ids:1
[    0.112560] percpu: Embedded 55 pages/cpu s187800 r8192 d29288 u262144
[    0.112567] pcpu-alloc: s187800 r8192 d29288 u262144 alloc=1*2097152
[    0.112568] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 -- -- -- --
[    0.112590] Built 1 zonelists, mobility grouping on.  Total pages: 4098311
[    0.112590] Policy zone: Normal
[    0.112591] Kernel command line: BOOT_IMAGE=/vmlinuz-5.5.0-0.bpo.2-amd64 root=/dev/mapper/vgs-root ro quiet
[    0.113527] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.113969] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.114077] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.127193] Memory: 2242828K/16653556K available (10243K kernel code, 1210K rwdata, 3984K rodata, 1664K init, 1992K bss, 462932K reserved, 0K cma-reserved)
[    0.127200] random: get_random_u64 called from __kmem_cache_create+0x3e/0x520 with crng_init=0
[    0.127307] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[    0.127316] Kernel/User page tables isolation: enabled
[    0.127329] ftrace: allocating 34312 entries in 135 pages
[    0.140397] ftrace: allocated 135 pages with 4 groups
[    0.140477] rcu: Hierarchical RCU implementation.
[    0.140478] rcu: 	RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=12.
[    0.140479] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.140479] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[    0.143159] NR_IRQS: 33024, nr_irqs: 2152, preallocated irqs: 16
[    0.143705] random: crng done (trusting CPU's manufacturer)
[    0.143728] Console: colour dummy device 80x25
[    0.143732] printk: console [tty0] enabled
[    0.143747] ACPI: Core revision 20191018
[    0.144030] APIC: Switch to symmetric I/O mode setup
[    0.144032] DMAR: Host address width 39
[    0.144033] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[    0.144038] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 19e2ff0505e
[    0.144039] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[    0.144042] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[    0.144043] DMAR: RMRR base: 0x0000008b47d000 end: 0x0000008b49cfff
[    0.144044] DMAR: RMRR base: 0x0000008d000000 end: 0x0000008f7fffff
[    0.144045] DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 1
[    0.144046] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[    0.144047] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[    0.147157] DMAR-IR: Enabled IRQ remapping in x2apic mode
[    0.147158] x2apic enabled
[    0.147190] Switched APIC routing to cluster x2apic.
[    0.156195] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x257a34a6eea, max_idle_ns: 440795264358 ns
[    0.156200] Calibrating delay loop (skipped), value calculated using timer frequency.. 5199.98 BogoMIPS (lpj=10399968)
[    0.156202] pid_max: default: 32768 minimum: 301
[    0.159819] LSM: Security Framework initializing
[    0.159825] Yama: disabled by default; enable with sysctl kernel.yama.*
[    0.159848] AppArmor: AppArmor initialized
[    0.159850] TOMOYO Linux initialized
[    0.159884] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.159905] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.160141] mce: CPU0: Thermal monitoring enabled (TM1)
[    0.160168] process: using mwait in idle threads
[    0.160170] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[    0.160171] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[    0.160174] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.160175] Spectre V2 : Mitigation: Full generic retpoline
[    0.160176] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.160176] Spectre V2 : Enabling Restricted Speculation for firmware calls
[    0.160177] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.160178] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
[    0.160178] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[    0.160181] MDS: Mitigation: Clear CPU buffers
[    0.160197] Freeing SMP alternatives memory: 32K
[    0.160197] TSC deadline timer enabled
[    0.160197] smpboot: CPU0: Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz (family: 0x6, model: 0x9e, stepping: 0xa)
[    0.160197] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[    0.160197] ... version:                4
[    0.160197] ... bit width:              48
[    0.160197] ... generic registers:      4
[    0.160197] ... value mask:             0000ffffffffffff
[    0.160197] ... max period:             00007fffffffffff
[    0.160197] ... fixed-purpose events:   3
[    0.160197] ... event mask:             000000070000000f
[    0.160197] rcu: Hierarchical SRCU implementation.
[    0.160197] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.160197] smp: Bringing up secondary CPUs ...
[    0.160197] x86: Booting SMP configuration:
[    0.160197] .... node  #0, CPUs:        #1  #2  #3  #4  #5  #6
[    0.160961] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[    0.160961]   #7  #8  #9 #10 #11
[    0.164813] smp: Brought up 1 node, 12 CPUs
[    0.164813] smpboot: Max logical packages: 1
[    0.164813] smpboot: Total of 12 processors activated (62399.80 BogoMIPS)
[    0.208202] node 0 initialised, 3486949 pages in 40ms
[    0.208495] devtmpfs: initialized
[    0.208495] x86/mm: Memory block size: 128MB
[    0.209681] PM: Registering ACPI NVS region [mem 0x8b49e000-0x8bb8dfff] (7274496 bytes)
[    0.212252] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.212255] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[    0.212345] pinctrl core: initialized pinctrl subsystem
[    0.212405] thermal_sys: Registered thermal governor 'fair_share'
[    0.212406] thermal_sys: Registered thermal governor 'bang_bang'
[    0.212407] thermal_sys: Registered thermal governor 'step_wise'
[    0.212407] thermal_sys: Registered thermal governor 'user_space'
[    0.212488] NET: Registered protocol family 16
[    0.212569] audit: initializing netlink subsys (disabled)
[    0.212574] audit: type=2000 audit(1591613951.056:1): state=initialized audit_enabled=0 res=1
[    0.212574] cpuidle: using governor ladder
[    0.212574] cpuidle: using governor menu
[    0.212574] KVM setup pv remote TLB flush
[    0.212574] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.212574] ACPI: bus type PCI registered
[    0.212574] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.212574] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[    0.212574] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[    0.212574] PCI: Using configuration type 1 for base access
[    0.213265] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.213269] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.213269] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.348404] ACPI: Added _OSI(Module Device)
[    0.348404] ACPI: Added _OSI(Processor Device)
[    0.348404] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.348404] ACPI: Added _OSI(Processor Aggregator Device)
[    0.348404] ACPI: Added _OSI(Linux-Dell-Video)
[    0.348404] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.348404] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[    0.393701] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.TPLD], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.393711] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.393714] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.393759] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS01._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.393764] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.393766] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.393767] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS01._PLD], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.393771] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.393773] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.395301] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS02._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.395305] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.395307] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.395308] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS02._PLD], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.395312] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.395314] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.396837] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS03._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.396841] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.396843] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.396844] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS03._PLD], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.396848] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.396851] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.398366] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS04._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.398371] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.398373] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.398374] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS04._PLD], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.398378] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.398380] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.399894] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS05._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.399898] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.399900] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.401423] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS06._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.401427] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.401430] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.401431] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS06._PLD], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.401435] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.401437] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.402953] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS07._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.402957] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.402959] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.404482] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS08._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.404486] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.404488] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.406002] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS09._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.406006] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.406009] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.406010] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS09._PLD], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.406013] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.406016] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.407530] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS10._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.407534] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.407536] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.409051] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS11._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.409056] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.409058] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.410574] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS12._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.410578] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.410580] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.412094] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS13._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.412098] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.412101] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.413620] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS14._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.413624] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.413627] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.413628] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS14._PLD], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.413632] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.413634] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.415128] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.USR1], AE_NOT_FOUND (20191018/dswload2-160)
[    0.415133] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20191018/psobject-221)
[    0.415135] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0010)
[    0.415138] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.USR2], AE_NOT_FOUND (20191018/dswload2-160)
[    0.415141] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20191018/psobject-221)
[    0.415143] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0010)
[    0.415167] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS01._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.415171] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.415174] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.415175] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS01._PLD], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.415178] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.415181] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.415210] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS02._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.415214] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.415216] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.415217] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS02._PLD], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.415221] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.415223] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.415251] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS03._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.415255] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.415258] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.415259] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS03._PLD], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.415262] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.415265] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.415293] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS04._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.415297] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.415299] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.415300] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS04._PLD], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.415304] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.415306] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.415335] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS05._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.415339] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.415341] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.415366] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS06._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.415370] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.415372] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.415396] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS07._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.415400] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.415402] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.415426] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS08._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.415430] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.415432] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.415455] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS09._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.415459] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.415462] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.415485] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS10._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.415489] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.415491] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.416212] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.I2C2.TPD0], AE_NOT_FOUND (20191018/dswload2-160)
[    0.416217] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20191018/psobject-221)
[    0.416220] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0010)
[    0.416241] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.I2C3.TPL1], AE_NOT_FOUND (20191018/dswload2-160)
[    0.416245] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20191018/psobject-221)
[    0.416247] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0010)
[    0.419082] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.PEG0.PEGP._ON], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.419087] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.419090] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.419092] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.PEG0.PEGP._OFF], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.419096] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.419098] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.419099] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.PEG0.PEGP.SGPO], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.419103] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.419105] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.419274] ACPI: 13 ACPI AML tables successfully acquired and loaded
[    0.428415] ACPI: Dynamic OEM Table Load:
[    0.428428] ACPI: SSDT 0xFFFF951C1E50A300 0000F4 (v02 PmRef  Cpu0Psd  00003000 INTL 20160422)
[    0.429644] ACPI: \_SB_.PR00: _OSC native thermal LVT Acked
[    0.430389] ACPI: Dynamic OEM Table Load:
[    0.430396] ACPI: SSDT 0xFFFF951AD16C8800 000400 (v02 PmRef  Cpu0Cst  00003001 INTL 20160422)
[    0.431720] ACPI: Dynamic OEM Table Load:
[    0.431726] ACPI: SSDT 0xFFFF951C1C424000 000581 (v02 PmRef  Cpu0Ist  00003000 INTL 20160422)
[    0.433101] ACPI: Dynamic OEM Table Load:
[    0.433106] ACPI: SSDT 0xFFFF951AD1781800 00011B (v02 PmRef  Cpu0Hwp  00003000 INTL 20160422)
[    0.434341] ACPI: Dynamic OEM Table Load:
[    0.434347] ACPI: SSDT 0xFFFF951C1C422000 000724 (v02 PmRef  HwpLvt   00003000 INTL 20160422)
[    0.435834] ACPI: Dynamic OEM Table Load:
[    0.435841] ACPI: SSDT 0xFFFF951C1C422800 0005FC (v02 PmRef  ApIst    00003000 INTL 20160422)
[    0.437220] ACPI: Dynamic OEM Table Load:
[    0.437226] ACPI: SSDT 0xFFFF951AD16CF800 000317 (v02 PmRef  ApHwp    00003000 INTL 20160422)
[    0.438619] ACPI: Dynamic OEM Table Load:
[    0.438625] ACPI: SSDT 0xFFFF9518C7264000 000AB0 (v02 PmRef  ApPsd    00003000 INTL 20160422)
[    0.440420] ACPI: Dynamic OEM Table Load:
[    0.440426] ACPI: SSDT 0xFFFF951AD16CC400 00030A (v02 PmRef  ApCst    00003000 INTL 20160422)
[    0.445504] ACPI: EC: EC started
[    0.445505] ACPI: EC: interrupt blocked
[    0.460348] ACPI: \_SB_.PCI0.LPCB.EC0_: Used as first EC
[    0.460350] ACPI: \_SB_.PCI0.LPCB.EC0_: GPE=0x2, IRQ=-1, EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.460351] ACPI: \_SB_.PCI0.LPCB.EC0_: Boot DSDT EC used to handle transactions
[    0.460351] ACPI: Interpreter enabled
[    0.460405] ACPI: (supports S0 S3 S4 S5)
[    0.460406] ACPI: Using IOAPIC for interrupt routing
[    0.460445] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.460908] ACPI: Enabled 10 GPEs in block 00 to 7F
[    0.461758] ACPI: Power Resource [PG00] (on)
[    0.465226] ACPI: Power Resource [PUBS] (on)
[    0.466001] ACPI: Power Resource [BTPR] (on)
[    0.467357] ACPI: Power Resource [USBC] (on)
[    0.467521] ACPI: Power Resource [PAUD] (on)
[    0.471002] ACPI: Power Resource [PXP] (off)
[    0.476856] ACPI: Power Resource [PXP] (off)
[    0.478324] ACPI: Power Resource [V0PR] (on)
[    0.478478] ACPI: Power Resource [V1PR] (on)
[    0.478625] ACPI: Power Resource [V2PR] (on)
[    0.480429] ACPI: Power Resource [PXTC] (on)
[    0.480822] ACPI: Power Resource [PXTC] (off)
[    0.482452] ACPI: Power Resource [WRST] (on)
[    0.484259] ACPI: Power Resource [PIN] (off)
[    0.484594] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[    0.484599] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI HPX-Type3]
[    0.487928] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR]
[    0.487929] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[    0.490403] PCI host bridge to bus 0000:00
[    0.490405] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.490406] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.490407] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.490408] pci_bus 0000:00: root bus resource [mem 0x8f800000-0xdfffffff window]
[    0.490409] pci_bus 0000:00: root bus resource [mem 0xfc800000-0xfe7fffff window]
[    0.490410] pci_bus 0000:00: root bus resource [bus 00-fe]
[    0.490418] pci 0000:00:00.0: [8086:3ec4] type 00 class 0x060000
[    0.491353] pci 0000:00:01.0: [8086:1901] type 01 class 0x060400
[    0.491399] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[    0.492397] pci 0000:00:02.0: [8086:3e9b] type 00 class 0x030000
[    0.492407] pci 0000:00:02.0: reg 0x10: [mem 0xb5000000-0xb5ffffff 64bit]
[    0.492412] pci 0000:00:02.0: reg 0x18: [mem 0x90000000-0x9fffffff 64bit pref]
[    0.492416] pci 0000:00:02.0: reg 0x20: [io  0x5000-0x503f]
[    0.492429] pci 0000:00:02.0: BAR 2: assigned to efifb
[    0.493376] pci 0000:00:04.0: [8086:1903] type 00 class 0x118000
[    0.493388] pci 0000:00:04.0: reg 0x10: [mem 0xb4510000-0xb4517fff 64bit]
[    0.494386] pci 0000:00:08.0: [8086:1911] type 00 class 0x088000
[    0.494397] pci 0000:00:08.0: reg 0x10: [mem 0xb4524000-0xb4524fff 64bit]
[    0.495427] pci 0000:00:12.0: [8086:a379] type 00 class 0x118000
[    0.495471] pci 0000:00:12.0: reg 0x10: [mem 0xb4525000-0xb4525fff 64bit]
[    0.496608] pci 0000:00:14.0: [8086:a36d] type 00 class 0x0c0330
[    0.496654] pci 0000:00:14.0: reg 0x10: [mem 0xb4500000-0xb450ffff 64bit]
[    0.496794] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    0.497789] pci 0000:00:14.2: [8086:a36f] type 00 class 0x050000
[    0.497829] pci 0000:00:14.2: reg 0x10: [mem 0xb4520000-0xb4521fff 64bit]
[    0.497852] pci 0000:00:14.2: reg 0x18: [mem 0xb4526000-0xb4526fff 64bit]
[    0.498921] pci 0000:00:14.3: [8086:a370] type 00 class 0x028000
[    0.499112] pci 0000:00:14.3: reg 0x10: [mem 0xb4518000-0xb451bfff 64bit]
[    0.499780] pci 0000:00:14.3: PME# supported from D0 D3hot D3cold
[    0.500988] pci 0000:00:15.0: [8086:a368] type 00 class 0x0c8000
[    0.501029] pci 0000:00:15.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[    0.502101] pci 0000:00:15.1: [8086:a369] type 00 class 0x0c8000
[    0.502142] pci 0000:00:15.1: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[    0.503269] pci 0000:00:16.0: [8086:a360] type 00 class 0x078000
[    0.503312] pci 0000:00:16.0: reg 0x10: [mem 0xb4529000-0xb4529fff 64bit]
[    0.503434] pci 0000:00:16.0: PME# supported from D3hot
[    0.504521] pci 0000:00:17.0: [8086:a353] type 00 class 0x010601
[    0.504559] pci 0000:00:17.0: reg 0x10: [mem 0xb4522000-0xb4523fff]
[    0.504574] pci 0000:00:17.0: reg 0x14: [mem 0xb452e000-0xb452e0ff]
[    0.504589] pci 0000:00:17.0: reg 0x18: [io  0x5080-0x5087]
[    0.504604] pci 0000:00:17.0: reg 0x1c: [io  0x5088-0x508b]
[    0.504619] pci 0000:00:17.0: reg 0x20: [io  0x5060-0x507f]
[    0.504634] pci 0000:00:17.0: reg 0x24: [mem 0xb452d000-0xb452d7ff]
[    0.504718] pci 0000:00:17.0: PME# supported from D3hot
[    0.505754] pci 0000:00:1d.0: [8086:a330] type 01 class 0x060400
[    0.505986] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    0.506056] pci 0000:00:1d.0: PTM enabled (root), 4ns granularity
[    0.507108] pci 0000:00:1d.5: [8086:a335] type 01 class 0x060400
[    0.507323] pci 0000:00:1d.5: PME# supported from D0 D3hot D3cold
[    0.507390] pci 0000:00:1d.5: PTM enabled (root), 4ns granularity
[    0.508422] pci 0000:00:1e.0: [8086:a328] type 00 class 0x078000
[    0.508463] pci 0000:00:1e.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[    0.509602] pci 0000:00:1f.0: [8086:a30d] type 00 class 0x060100
[    0.510814] pci 0000:00:1f.3: [8086:a348] type 00 class 0x040300
[    0.510892] pci 0000:00:1f.3: reg 0x10: [mem 0xb451c000-0xb451ffff 64bit]
[    0.510965] pci 0000:00:1f.3: reg 0x20: [mem 0xb4200000-0xb42fffff 64bit]
[    0.511115] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[    0.512209] pci 0000:00:1f.4: [8086:a323] type 00 class 0x0c0500
[    0.512390] pci 0000:00:1f.4: reg 0x10: [mem 0xb452b000-0xb452b0ff 64bit]
[    0.512595] pci 0000:00:1f.4: reg 0x20: [io  0x5040-0x505f]
[    0.513775] pci 0000:00:1f.5: [8086:a324] type 00 class 0x0c8000
[    0.513803] pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
[    0.514853] pci 0000:01:00.0: [10de:2191] type 00 class 0x030000
[    0.514871] pci 0000:01:00.0: reg 0x10: [mem 0xb3000000-0xb3ffffff]
[    0.514881] pci 0000:01:00.0: reg 0x14: [mem 0xa0000000-0xafffffff 64bit pref]
[    0.514889] pci 0000:01:00.0: reg 0x1c: [mem 0xb0000000-0xb1ffffff 64bit pref]
[    0.514895] pci 0000:01:00.0: reg 0x24: [io  0x4000-0x407f]
[    0.514902] pci 0000:01:00.0: reg 0x30: [mem 0xfff80000-0xffffffff pref]
[    0.514950] pci 0000:01:00.0: PME# supported from D0 D3hot
[    0.515060] pci 0000:01:00.1: [10de:1aeb] type 00 class 0x040300
[    0.515074] pci 0000:01:00.1: reg 0x10: [mem 0xb4000000-0xb4003fff]
[    0.515188] pci 0000:01:00.2: [10de:1aec] type 00 class 0x0c0330
[    0.515204] pci 0000:01:00.2: reg 0x10: [mem 0xb4100000-0xb413ffff 64bit pref]
[    0.515218] pci 0000:01:00.2: reg 0x1c: [mem 0xb4140000-0xb414ffff 64bit pref]
[    0.515266] pci 0000:01:00.2: PME# supported from D0 D3hot
[    0.515322] pci 0000:01:00.3: [10de:1aed] type 00 class 0x0c8000
[    0.515335] pci 0000:01:00.3: reg 0x10: [mem 0xb4004000-0xb4004fff]
[    0.515404] pci 0000:01:00.3: PME# supported from D0 D3hot
[    0.515475] pci 0000:00:01.0: PCI bridge to [bus 01-05]
[    0.515477] pci 0000:00:01.0:   bridge window [io  0x4000-0x4fff]
[    0.515478] pci 0000:00:01.0:   bridge window [mem 0xa0000000-0xb40fffff]
[    0.515481] pci 0000:00:01.0:   bridge window [mem 0xb4100000-0xb41fffff 64bit pref]
[    0.515719] pci 0000:06:00.0: [144d:a808] type 00 class 0x010802
[    0.515771] pci 0000:06:00.0: reg 0x10: [mem 0xb4400000-0xb4403fff 64bit]
[    0.516266] pci 0000:00:1d.0: PCI bridge to [bus 06]
[    0.516275] pci 0000:00:1d.0:   bridge window [mem 0xb4400000-0xb44fffff]
[    0.516378] pci 0000:07:00.0: [10ec:8168] type 00 class 0x020000
[    0.516422] pci 0000:07:00.0: reg 0x10: [io  0x3000-0x30ff]
[    0.516459] pci 0000:07:00.0: reg 0x18: [mem 0xb4304000-0xb4304fff 64bit]
[    0.516482] pci 0000:07:00.0: reg 0x20: [mem 0xb4300000-0xb4303fff 64bit]
[    0.516632] pci 0000:07:00.0: supports D1 D2
[    0.516633] pci 0000:07:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.516876] pci 0000:00:1d.5: PCI bridge to [bus 07]
[    0.516881] pci 0000:00:1d.5:   bridge window [io  0x3000-0x3fff]
[    0.516886] pci 0000:00:1d.5:   bridge window [mem 0xb4300000-0xb43fffff]
[    0.520004] ACPI: EC: interrupt unblocked
[    0.520035] ACPI: EC: event unblocked
[    0.520057] ACPI: \_SB_.PCI0.LPCB.EC0_: GPE=0x2, IRQ=-1, EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.520058] ACPI: \_SB_.PCI0.LPCB.EC0_: Boot DSDT EC used to handle transactions and events
[    0.520112] iommu: Default domain type: Translated
[    0.520124] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[    0.520124] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.520124] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[    0.520124] pci 0000:00:02.0: vgaarb: no bridge control possible
[    0.520124] pci 0000:01:00.0: vgaarb: bridge control possible
[    0.520124] vgaarb: loaded
[    0.520204] EDAC MC: Ver: 3.0.0
[    0.520492] Registered efivars operations
[    0.520492] PCI: Using ACPI for IRQ routing
[    0.604856] PCI: pci_cache_line_size set to 64 bytes
[    0.605267] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[    0.605268] e820: reserve RAM buffer [mem 0x73d87000-0x73ffffff]
[    0.605269] e820: reserve RAM buffer [mem 0x7ad24000-0x7bffffff]
[    0.605270] e820: reserve RAM buffer [mem 0x7b474000-0x7bffffff]
[    0.605270] e820: reserve RAM buffer [mem 0x8a89e000-0x8bffffff]
[    0.605271] e820: reserve RAM buffer [mem 0x8bc0f000-0x8bffffff]
[    0.605272] e820: reserve RAM buffer [mem 0x46e800000-0x46fffffff]
[    0.605383] clocksource: Switched to clocksource tsc-early
[    0.612747] VFS: Disk quotas dquot_6.6.0
[    0.612762] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.612859] AppArmor: AppArmor Filesystem Enabled
[    0.612869] pnp: PnP ACPI init
[    0.612946] system 00:00: [mem 0x40000000-0x403fffff] could not be reserved
[    0.612950] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.613245] system 00:01: [io  0x1800-0x18fe] has been reserved
[    0.613247] system 00:01: [mem 0xfd000000-0xfd69ffff] has been reserved
[    0.613248] system 00:01: [mem 0xfd6c0000-0xfd6cffff] has been reserved
[    0.613249] system 00:01: [mem 0xfd6f0000-0xfdffffff] has been reserved
[    0.613250] system 00:01: [mem 0xfe000000-0xfe01ffff] could not be reserved
[    0.613251] system 00:01: [mem 0xfe200000-0xfe7fffff] has been reserved
[    0.613252] system 00:01: [mem 0xff000000-0xffffffff] could not be reserved
[    0.613255] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.613542] system 00:02: [io  0x2000-0x20fe] has been reserved
[    0.613545] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.613706] system 00:03: [io  0x0680-0x069f] has been reserved
[    0.613707] system 00:03: [io  0x164e-0x164f] has been reserved
[    0.613710] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.613818] system 00:04: [io  0x1854-0x1857] has been reserved
[    0.613821] system 00:04: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[    0.613851] pnp 00:05: Plug and Play ACPI device, IDs PNP0303 (active)
[    0.615021] system 00:06: [mem 0xfe037000-0xfe037fff] has been reserved
[    0.615022] system 00:06: [mem 0xfe036008-0xfe036fff] has been reserved
[    0.615025] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.615462] system 00:07: [mem 0xfed10000-0xfed17fff] has been reserved
[    0.615463] system 00:07: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.615464] system 00:07: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.615465] system 00:07: [mem 0xe0000000-0xefffffff] has been reserved
[    0.615466] system 00:07: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.615467] system 00:07: [mem 0xfed90000-0xfed93fff] could not be reserved
[    0.615468] system 00:07: [mem 0xfed45000-0xfed8ffff] could not be reserved
[    0.615469] system 00:07: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.615472] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.615626] pnp: PnP ACPI: found 8 devices
[    0.621115] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.621141] pci 0000:01:00.0: can't claim BAR 6 [mem 0xfff80000-0xffffffff pref]: no compatible bridge window
[    0.621154] pci 0000:00:15.0: BAR 0: assigned [mem 0x8f800000-0x8f800fff 64bit]
[    0.621175] pci 0000:00:15.1: BAR 0: assigned [mem 0x8f801000-0x8f801fff 64bit]
[    0.621192] pci 0000:00:1e.0: BAR 0: assigned [mem 0x8f802000-0x8f802fff 64bit]
[    0.621208] pci 0000:01:00.0: BAR 6: assigned [mem 0xb2000000-0xb207ffff pref]
[    0.621210] pci 0000:00:01.0: PCI bridge to [bus 01-05]
[    0.621211] pci 0000:00:01.0:   bridge window [io  0x4000-0x4fff]
[    0.621213] pci 0000:00:01.0:   bridge window [mem 0xa0000000-0xb40fffff]
[    0.621215] pci 0000:00:01.0:   bridge window [mem 0xb4100000-0xb41fffff 64bit pref]
[    0.621219] pci 0000:00:1d.0: PCI bridge to [bus 06]
[    0.621229] pci 0000:00:1d.0:   bridge window [mem 0xb4400000-0xb44fffff]
[    0.621242] pci 0000:00:1d.5: PCI bridge to [bus 07]
[    0.621245] pci 0000:00:1d.5:   bridge window [io  0x3000-0x3fff]
[    0.621251] pci 0000:00:1d.5:   bridge window [mem 0xb4300000-0xb43fffff]
[    0.621265] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.621266] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.621267] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.621268] pci_bus 0000:00: resource 7 [mem 0x8f800000-0xdfffffff window]
[    0.621269] pci_bus 0000:00: resource 8 [mem 0xfc800000-0xfe7fffff window]
[    0.621269] pci_bus 0000:01: resource 0 [io  0x4000-0x4fff]
[    0.621270] pci_bus 0000:01: resource 1 [mem 0xa0000000-0xb40fffff]
[    0.621271] pci_bus 0000:01: resource 2 [mem 0xb4100000-0xb41fffff 64bit pref]
[    0.621272] pci_bus 0000:06: resource 1 [mem 0xb4400000-0xb44fffff]
[    0.621273] pci_bus 0000:07: resource 0 [io  0x3000-0x3fff]
[    0.621274] pci_bus 0000:07: resource 1 [mem 0xb4300000-0xb43fffff]
[    0.621408] NET: Registered protocol family 2
[    0.621516] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    0.621533] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.621648] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.621740] TCP: Hash tables configured (established 131072 bind 65536)
[    0.621764] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.621791] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.621873] NET: Registered protocol family 1
[    0.621879] NET: Registered protocol family 44
[    0.621891] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.623652] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[    0.623691] pci 0000:01:00.2: D0 power state depends on 0000:01:00.0
[    0.624046] pci 0000:01:00.3: D0 power state depends on 0000:01:00.0
[    0.624197] PCI: CLS 64 bytes, default 64
[    0.624257] Trying to unpack rootfs image as initramfs...
[    1.132416] Freeing initrd memory: 29144K
[    1.132453] DMAR: No ATSR found
[    1.132504] DMAR: dmar0: Using Queued invalidation
[    1.132506] DMAR: dmar1: Using Queued invalidation
[    1.133086] pci 0000:00:00.0: Adding to iommu group 0
[    1.133150] pci 0000:00:01.0: Adding to iommu group 1
[    1.137074] pci 0000:00:02.0: Adding to iommu group 2
[    1.137514] pci 0000:00:02.0: Using iommu direct mapping
[    1.137559] pci 0000:00:04.0: Adding to iommu group 3
[    1.137615] pci 0000:00:08.0: Adding to iommu group 4
[    1.137687] pci 0000:00:12.0: Adding to iommu group 5
[    1.137797] pci 0000:00:14.0: Adding to iommu group 6
[    1.137807] pci 0000:00:14.2: Adding to iommu group 6
[    1.137841] pci 0000:00:14.3: Adding to iommu group 6
[    1.137915] pci 0000:00:15.0: Adding to iommu group 7
[    1.137926] pci 0000:00:15.1: Adding to iommu group 7
[    1.137990] pci 0000:00:16.0: Adding to iommu group 8
[    1.138044] pci 0000:00:17.0: Adding to iommu group 9
[    1.138121] pci 0000:00:1d.0: Adding to iommu group 10
[    1.138187] pci 0000:00:1d.5: Adding to iommu group 11
[    1.138260] pci 0000:00:1e.0: Adding to iommu group 12
[    1.139861] pci 0000:00:1f.0: Adding to iommu group 13
[    1.139873] pci 0000:00:1f.3: Adding to iommu group 13
[    1.139883] pci 0000:00:1f.4: Adding to iommu group 13
[    1.139895] pci 0000:00:1f.5: Adding to iommu group 13
[    1.139903] pci 0000:01:00.0: Adding to iommu group 1
[    1.139908] pci 0000:01:00.1: Adding to iommu group 1
[    1.139913] pci 0000:01:00.2: Adding to iommu group 1
[    1.139918] pci 0000:01:00.3: Adding to iommu group 1
[    1.139994] pci 0000:06:00.0: Adding to iommu group 14
[    1.140063] pci 0000:07:00.0: Adding to iommu group 15
[    1.140384] DMAR: Intel(R) Virtualization Technology for Directed I/O
[    1.142324] platform rtc_cmos: registered platform RTC device (no PNP device found)
[    1.142784] Initialise system trusted keyrings
[    1.142791] Key type blacklist registered
[    1.142820] workingset: timestamp_bits=40 max_order=22 bucket_order=0
[    1.143832] zbud: loaded
[    1.143971] Platform Keyring initialized
[    1.143973] Key type asymmetric registered
[    1.143974] Asymmetric key parser 'x509' registered
[    1.143979] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[    1.144020] io scheduler mq-deadline registered
[    1.148085] pcieport 0000:00:01.0: PME: Signaling with IRQ 122
[    1.148380] pcieport 0000:00:1d.0: PME: Signaling with IRQ 123
[    1.148687] pcieport 0000:00:1d.5: PME: Signaling with IRQ 124
[    1.148829] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    1.148843] efifb: probing for efifb
[    1.148853] efifb: framebuffer at 0x90000000, using 8128k, total 8128k
[    1.148854] efifb: mode is 1920x1080x32, linelength=7680, pages=1
[    1.148854] efifb: scrolling: redraw
[    1.148855] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    1.148919] Console: switching to colour frame buffer device 240x67
[    1.152483] fb0: EFI VGA frame buffer device
[    1.152490] intel_idle: MWAIT substates: 0x11142120
[    1.152491] intel_idle: v0.4.1 model 0x9E
[    1.153058] intel_idle: lapic_timer_reliable_states 0xffffffff
[    1.155155] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.155814] hpet_acpi_add: no address or irqs in _CRS
[    1.155841] Linux agpgart interface v0.103
[    1.155897] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[    1.155898] AMD-Vi: AMD IOMMUv2 functionality not available on this system
[    1.156631] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[    1.156631] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[    1.159078] serio: i8042 KBD port at 0x60,0x64 irq 1
[    1.159190] mousedev: PS/2 mouse device common for all mice
[    1.159266] rtc_cmos rtc_cmos: RTC can wake from S4
[    1.160459] rtc_cmos rtc_cmos: registered as rtc0
[    1.160470] rtc_cmos rtc_cmos: alarms up to one month, y3k, 114 bytes nvram
[    1.160477] intel_pstate: Intel P-state driver initializing
[    1.160490] intel_pstate: Disabling energy efficiency optimization
[    1.161416] intel_pstate: HWP enabled
[    1.161614] ledtrig-cpu: registered to indicate activity on CPUs
[    1.161824] drop_monitor: Initializing network drop monitor service
[    1.161946] NET: Registered protocol family 10
[    1.164064] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[    1.170806] Segment Routing with IPv6
[    1.170821] mip6: Mobile IPv6
[    1.170822] NET: Registered protocol family 17
[    1.170942] mpls_gso: MPLS GSO support
[    1.171998] microcode: sig=0x906ea, pf=0x20, revision=0xc6
[    1.172176] microcode: Microcode Update Driver: v2.2.
[    1.172178] IPI shorthand broadcast: enabled
[    1.172181] sched_clock: Marking stable (1159388912, 12538530)->(1182697132, -10769690)
[    1.172304] registered taskstats version 1
[    1.172305] Loading compiled-in X.509 certificates
[    1.192194] Loaded X.509 cert 'Debian Secure Boot CA: 6ccece7e4c6c0d1f6149f3dd27dfcc5cbb419ea1'
[    1.192207] Loaded X.509 cert 'Debian Secure Boot Signer: 00a7468def'
[    1.192218] zswap: loaded using pool lzo/zbud
[    1.192602] Key type ._fscrypt registered
[    1.192603] Key type .fscrypt registered
[    1.192629] AppArmor: AppArmor sha1 policy hashing enabled
[    1.194815] integrity: Loading X.509 certificate: UEFI:db
[    1.194855] integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
[    1.194855] integrity: Loading X.509 certificate: UEFI:db
[    1.194868] integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
[    1.194868] integrity: Loading X.509 certificate: UEFI:db
[    1.194869] integrity: Problem loading X.509 certificate -65
[    1.194882] Error adding keys to platform keyring UEFI:db
[    1.197939] rtc_cmos rtc_cmos: setting system clock to 2020-06-08T10:59:12 UTC (1591613952)
[    1.198626] Freeing unused kernel image (initmem) memory: 1664K
[    1.272703] Write protecting the kernel read-only data: 16384k
[    1.273847] Freeing unused kernel image (text/rodata gap) memory: 2044K
[    1.274179] Freeing unused kernel image (rodata/data gap) memory: 112K
[    1.280919] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.280920] x86/mm: Checking user space page tables
[    1.284797] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.284798] Run /init as init process
[    1.335385] udevd[184]: starting version 3.2.7
[    1.336128] udevd[185]: starting eudev-3.2.7
[    1.347418] wmi_bus wmi_bus-PNP0C14:00: WQ data block query control method not found
[    1.347420] wmi_bus wmi_bus-PNP0C14:00: WQ data block query control method not found
[    1.347421] wmi_bus wmi_bus-PNP0C14:00: WQ data block query control method not found
[    1.347422] wmi_bus wmi_bus-PNP0C14:00: WQ data block query control method not found
[    1.347591] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
[    1.353480] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[    1.353596] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[    1.354449] hid: raw HID events driver (C) Jiri Kosina
[    1.356886] intel-lpss 0000:00:15.0: enabling device (0000 -> 0002)
[    1.357146] cryptd: max_cpu_qlen set to 1000
[    1.361188] SCSI subsystem initialized
[    1.361794] nvme nvme0: pci function 0000:06:00.0
[    1.362100] idma64 idma64.0: Found Intel integrated DMA 64-bit
[    1.362128] r8169 0000:07:00.0: can't disable ASPM; OS doesn't have ASPM control
[    1.364639] AVX2 version of gcm_enc/dec engaged.
[    1.364640] AES CTR mode by8 optimization enabled
[    1.364658] ACPI: bus type USB registered
[    1.364676] usbcore: registered new interface driver usbfs
[    1.364683] usbcore: registered new interface driver hub
[    1.364709] usbcore: registered new device driver usb
[    1.366345] intel-lpss 0000:00:15.1: enabling device (0000 -> 0002)
[    1.366734] idma64 idma64.1: Found Intel integrated DMA 64-bit
[    1.370084] intel-lpss 0000:00:1e.0: enabling device (0000 -> 0002)
[    1.370351] idma64 idma64.2: Found Intel integrated DMA 64-bit
[    1.370491] dw-apb-uart.2: ttyS0 at MMIO 0x8f802000 (irq = 20, base_baud = 115200) is a 16550A
[    1.371112] libata version 3.00 loaded.
[    1.373579] libphy: r8169: probed
[    1.373692] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.373695] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[    1.373750] r8169 0000:07:00.0 eth0: RTL8168h/8111h, f8:75:a4:a2:7b:db, XID 541, IRQ 126
[    1.373751] r8169 0000:07:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[    1.374063] ahci 0000:00:17.0: version 3.0
[    1.374796] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x110 quirks 0x0000000000009810
[    1.374802] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[    1.374953] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
[    1.374954] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.374955] usb usb1: Product: xHCI Host Controller
[    1.374955] usb usb1: Manufacturer: Linux 5.5.0-0.bpo.2-amd64 xhci-hcd
[    1.374956] usb usb1: SerialNumber: 0000:00:14.0
[    1.375014] hub 1-0:1.0: USB hub found
[    1.375031] hub 1-0:1.0: 16 ports detected
[    1.375569] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.375571] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[    1.375572] xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
[    1.375593] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05
[    1.375594] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.375594] usb usb2: Product: xHCI Host Controller
[    1.375595] usb usb2: Manufacturer: Linux 5.5.0-0.bpo.2-amd64 xhci-hcd
[    1.375595] usb usb2: SerialNumber: 0000:00:14.0
[    1.375647] hub 2-0:1.0: USB hub found
[    1.375662] hub 2-0:1.0: 8 ports detected
[    1.376094] xhci_hcd 0000:01:00.2: xHCI Host Controller
[    1.376096] xhci_hcd 0000:01:00.2: new USB bus registered, assigned bus number 3
[    1.376727] xhci_hcd 0000:01:00.2: hcc params 0x0180ff05 hci version 0x110 quirks 0x0000000000000010
[    1.376807] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
[    1.376807] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.376808] usb usb3: Product: xHCI Host Controller
[    1.376808] usb usb3: Manufacturer: Linux 5.5.0-0.bpo.2-amd64 xhci-hcd
[    1.376809] usb usb3: SerialNumber: 0000:01:00.2
[    1.376939] hub 3-0:1.0: USB hub found
[    1.376944] hub 3-0:1.0: 2 ports detected
[    1.377162] xhci_hcd 0000:01:00.2: xHCI Host Controller
[    1.377163] xhci_hcd 0000:01:00.2: new USB bus registered, assigned bus number 4
[    1.377165] xhci_hcd 0000:01:00.2: Host supports USB 3.1 Enhanced SuperSpeed
[    1.377181] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.377191] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05
[    1.377191] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.377192] usb usb4: Product: xHCI Host Controller
[    1.377192] usb usb4: Manufacturer: Linux 5.5.0-0.bpo.2-amd64 xhci-hcd
[    1.377193] usb usb4: SerialNumber: 0000:01:00.2
[    1.377239] hub 4-0:1.0: USB hub found
[    1.377261] hub 4-0:1.0: 4 ports detected
[    1.384308] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x10 impl SATA mode
[    1.384310] ahci 0000:00:17.0: flags: 64bit ncq sntf pm clo only pio slum part ems deso sadm sds apst
[    1.386107] scsi host0: ahci
[    1.386337] scsi host1: ahci
[    1.386573] scsi host2: ahci
[    1.386787] scsi host3: ahci
[    1.386958] scsi host4: ahci
[    1.386988] ata1: DUMMY
[    1.386988] ata2: DUMMY
[    1.386988] ata3: DUMMY
[    1.386989] ata4: DUMMY
[    1.386994] ata5: SATA max UDMA/133 abar m2048@0xb452d000 port 0xb452d300 irq 127
[    1.444983] battery: ACPI: Battery Slot [BAT0] (battery present)
[    1.451002] i2c_hid i2c-MSFT0001:01: i2c-MSFT0001:01 supply vdd not found, using dummy regulator
[    1.451012] i2c_hid i2c-MSFT0001:01: i2c-MSFT0001:01 supply vddl not found, using dummy regulator
[    1.573756] input: MSFT0001:01 04F3:309E Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-MSFT0001:01/0018:04F3:309E.0001/input/input1
[    1.573941] input: MSFT0001:01 04F3:309E Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-MSFT0001:01/0018:04F3:309E.0001/input/input3
[    1.574109] hid-generic 0018:04F3:309E.0001: input,hidraw0: I2C HID v1.00 Mouse [MSFT0001:01 04F3:309E] on i2c-MSFT0001:01
[    1.586156] nvme nvme0: missing or invalid SUBNQN field.
[    1.586241] nvme nvme0: Shutdown timeout set to 8 seconds
[    1.657241] nvme nvme0: 12/0/0 default/read/poll queues
[    1.678297]  nvme0n1: p1 p2 p3
[    1.700722] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    1.708683] usb 1-2: new full-speed USB device number 2 using xhci_hcd
[    1.790412] ata5.00: ATA-10: ST2000LM015-2E8174, 0001, max UDMA/133
[    1.790417] ata5.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    1.841168] ata5.00: configured for UDMA/133
[    1.841430] scsi 4:0:0:0: Direct-Access     ATA      ST2000LM015-2E81 0001 PQ: 0 ANSI: 5
[    1.851769] sd 4:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[    1.851770] sd 4:0:0:0: [sda] 4096-byte physical blocks
[    1.851773] sd 4:0:0:0: [sda] Write Protect is off
[    1.851773] sd 4:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    1.851777] sd 4:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.859386] usb 1-2: New USB device found, idVendor=1bcf, idProduct=0824, bcdDevice= 5.22
[    1.859387] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.859388] usb 1-2: Product: SmartMouse
[    1.859389] usb 1-2: Manufacturer: SunplusIT
[    1.864470] input: SunplusIT SmartMouse as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.0/0003:1BCF:0824.0002/input/input4
[    1.925106] hid-generic 0003:1BCF:0824.0002: input,hidraw1: USB HID v1.00 Keyboard [SunplusIT SmartMouse] on usb-0000:00:14.0-2/input0
[    1.927364] input: SunplusIT SmartMouse as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:1BCF:0824.0003/input/input5
[    1.927658] input: SunplusIT SmartMouse Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:1BCF:0824.0003/input/input6
[    1.972241]  sda: sda1
[    1.972930] sd 4:0:0:0: [sda] Attached SCSI disk
[    1.977789] sd 4:0:0:0: Attached scsi generic sg0 type 0
[    1.984507] hid-generic 0003:1BCF:0824.0003: input,hidraw2: USB HID v1.00 Mouse [SunplusIT SmartMouse] on usb-0000:00:14.0-2/input1
[    1.984568] usbcore: registered new interface driver usbhid
[    1.984570] usbhid: USB HID core driver
[    1.988316] usb 1-6: new high-speed USB device number 3 using xhci_hcd
[    2.022032] usb 1-6: New USB device found, idVendor=04ca, idProduct=7070, bcdDevice= 0.24
[    2.022037] usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.022040] usb 1-6: Product: Integrated Camera
[    2.022042] usb 1-6: Manufacturer: 8SSC20F27068L1GZ0197DY5
[    2.152771] usb 1-9: new full-speed USB device number 4 using xhci_hcd
[    2.172686] tsc: Refined TSC clocksource calibration: 2592.005 MHz
[    2.172704] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x255cbb91cef, max_idle_ns: 440795297256 ns
[    2.172780] clocksource: Switched to clocksource tsc
[    2.314515] usb 1-9: New USB device found, idVendor=048d, idProduct=c100, bcdDevice= 0.43
[    2.314520] usb 1-9: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.314523] usb 1-9: Product: ITE Device(8910)
[    2.314525] usb 1-9: Manufacturer: ITE Tech. Inc.
[    2.327328] input: ITE Tech. Inc. ITE Device(8910) Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/0003:048D:C100.0004/input/input7
[    2.384589] input: ITE Tech. Inc. ITE Device(8910) Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/0003:048D:C100.0004/input/input8
[    2.384641] input: ITE Tech. Inc. ITE Device(8910) Wireless Radio Control as /devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/0003:048D:C100.0004/input/input9
[    2.384797] hid-generic 0003:048D:C100.0004: input,hiddev0,hidraw3: USB HID v1.10 Keyboard [ITE Tech. Inc. ITE Device(8910)] on usb-0000:00:14.0-9/input0
[    2.389791] device-mapper: uevent: version 1.0.3
[    2.390028] device-mapper: ioctl: 4.41.0-ioctl (2019-09-16) initialised: dm-devel@redhat.com
[    2.512678] usb 1-14: new full-speed USB device number 5 using xhci_hcd
[    2.664397] usb 1-14: New USB device found, idVendor=8087, idProduct=0aaa, bcdDevice= 0.02
[    2.664401] usb 1-14: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[   52.866393] NET: Registered protocol family 38
[   53.380323] PM: Image not found (code -22)
[   53.503451] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Opts: (null)
[   53.528962] EXT4-fs (dm-2): mounted filesystem with ordered data mode. Opts: (null)
[   53.608776] Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist.
[   53.922344] udevd[701]: starting version 3.2.7
[   53.937001] udevd[701]: specified group 'kvm' unknown
[   53.954537] udevd[701]: starting eudev-3.2.7
[   54.057202] ACPI: AC Adapter [ADP0] (on-line)
[   54.137019] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input10
[   54.137059] ACPI: Lid Switch [LID0]
[   54.137099] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input11
[   54.137119] ACPI: Power Button [PWRB]
[   54.144486] mc: Linux media interface: v0.10
[   54.145439] input: Ideapad extra buttons as /devices/pci0000:00/0000:00:1f.0/PNP0C09:00/VPC2004:00/input/input12
[   54.147176] intel_rapl_common: Found RAPL domain package
[   54.147177] intel_rapl_common: Found RAPL domain dram
[   54.154785] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[   54.155168] videodev: Linux video capture interface: v2.00
[   54.156069] proc_thermal 0000:00:04.0: Creating sysfs group for PROC_THERMAL_PCI
[   54.160238] alg: No test for fips(ansi_cprng) (fips_ansi_cprng)
[   54.189405] r8169 0000:07:00.0: firmware: direct-loading firmware rtl_nic/rtl8168h-2.fw
[   54.189492] Generic FE-GE Realtek PHY r8169-700:00: attached PHY driver [Generic FE-GE Realtek PHY] (mii_bus:phy_addr=r8169-700:00, irq=IGNORE)
[   54.209216] EFI Variables Facility v0.08 2004-May-17
[   54.213064] iTCO_vendor_support: vendor-support=0
[   54.213114] input: PC Speaker as /devices/platform/pcspkr/input/input13
[   54.224664] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[   54.224918] iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
[   54.225762] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[   54.227250] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[   54.227637] snd_hda_intel 0000:01:00.1: Disabling MSI
[   54.227642] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[   54.230872] uvcvideo: Found UVC 1.00 device Integrated Camera (04ca:7070)
[   54.248649] uvcvideo 1-6:1.0: Entity type for entity Extension 4 was not initialized!
[   54.248651] uvcvideo 1-6:1.0: Entity type for entity Extension 3 was not initialized!
[   54.248652] uvcvideo 1-6:1.0: Entity type for entity Processing 2 was not initialized!
[   54.248654] uvcvideo 1-6:1.0: Entity type for entity Camera 1 was not initialized!
[   54.248801] input: Integrated Camera: Integrated C as /devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.0/input/input14
[   54.254125] pstore: Using crash dump compression: deflate
[   54.254135] pstore: Registered efi as persistent store backend
[   54.255718] Bluetooth: Core ver 2.22
[   54.255724] NET: Registered protocol family 31
[   54.255724] Bluetooth: HCI device and connection manager initialized
[   54.255726] Bluetooth: HCI socket layer initialized
[   54.255727] Bluetooth: L2CAP socket layer initialized
[   54.255730] Bluetooth: SCO socket layer initialized
[   54.261127] usbcore: registered new interface driver btusb
[   54.261989] Bluetooth: hci0: Bootloader revision 0.1 build 42 week 52 2015
[   54.262989] Bluetooth: hci0: Device revision is 2
[   54.262989] Bluetooth: hci0: Secure boot is enabled
[   54.262990] Bluetooth: hci0: OTP lock is enabled
[   54.262990] Bluetooth: hci0: API lock is enabled
[   54.262990] Bluetooth: hci0: Debug lock is disabled
[   54.262991] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[   54.263933] bluetooth hci0: firmware: direct-loading firmware intel/ibt-17-16-1.sfi
[   54.263934] Bluetooth: hci0: Found device firmware: intel/ibt-17-16-1.sfi
[   54.270612] RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
[   54.270612] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[   54.270613] RAPL PMU: hw unit of domain package 2^-14 Joules
[   54.270613] RAPL PMU: hw unit of domain dram 2^-14 Joules
[   54.270613] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[   54.314056] r8169 0000:07:00.0 eth0: Link is Down
[   54.314563] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   54.314701] cfg80211: Loaded X.509 cert 'benh@debian.org: 577e021cb980e0e820821ba7b54b4961b8b4fadf'
[   54.314830] cfg80211: Loaded X.509 cert 'romain.perier@gmail.com: 3abbc6ec146e09d1b6016ab9d6cf71dd233f0328'
[   54.314953] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   54.315086] platform regulatory.0: firmware: direct-loading firmware regulatory.db
[   54.315185] platform regulatory.0: firmware: direct-loading firmware regulatory.db.p7s
[   54.340474] usbcore: registered new interface driver uvcvideo
[   54.340475] USB Video Class driver (1.1.1)
[   54.350545] input: MSFT0001:01 04F3:309E Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-MSFT0001:01/0018:04F3:309E.0001/input/input15
[   54.350593] input: MSFT0001:01 04F3:309E Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-MSFT0001:01/0018:04F3:309E.0001/input/input17
[   54.350629] hid-multitouch 0018:04F3:309E.0001: input,hidraw0: I2C HID v1.00 Mouse [MSFT0001:01 04F3:309E] on i2c-MSFT0001:01
[   54.365948] i915 0000:00:02.0: VT-d active for gfx access
[   54.365950] checking generic (90000000 7f0000) vs hw (b5000000 1000000)
[   54.365951] checking generic (90000000 7f0000) vs hw (90000000 10000000)
[   54.365952] fb0: switching to inteldrmfb from EFI VGA
[   54.366009] Console: switching to colour dummy device 80x25
[   54.366039] i915 0000:00:02.0: vgaarb: deactivate vga console
[   54.367565] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[   54.367566] [drm] Driver supports precise vblank timestamp query.
[   54.368316] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[   54.369178] i915 0000:00:02.0: firmware: direct-loading firmware i915/kbl_dmc_ver1_04.bin
[   54.369232] [drm:csr_load_work_fn [i915]] *ERROR* DMC firmware has wrong CSS header length (1097158924 bytes)
[   54.369239] i915 0000:00:02.0: Failed to load DMC firmware i915/kbl_dmc_ver1_04.bin. Disabling runtime power management.
[   54.369239] i915 0000:00:02.0: DMC firmware homepage: https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/tree/i915
[   54.380103] Intel(R) Wireless WiFi driver for Linux
[   54.380104] Copyright(c) 2003- 2015 Intel Corporation
[   54.409435] iwlwifi 0000:00:14.3: firmware: direct-loading firmware iwlwifi-9000-pu-b0-jf-b0-46.ucode
[   54.409449] iwlwifi 0000:00:14.3: Found debug destination: EXTERNAL_DRAM
[   54.409450] iwlwifi 0000:00:14.3: Found debug configuration: 0
[   54.409654] iwlwifi 0000:00:14.3: loaded firmware version 46.8902351f.0 op_mode iwlmvm
[   54.424137] [drm] Initialized i915 1.6.0 20191101 for 0000:00:02.0 on minor 0
[   54.424869] [Firmware Bug]: ACPI(PEGP) defines _DOD but not _DOS
[   54.424876] ACPI: Video Device [PEGP] (multi-head: yes  rom: yes  post: no)
[   54.424899] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input18
[   54.431831] ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[   54.431954] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input19
[   54.432072] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[   54.433042] fbcon: i915drmfb (fb0) is primary device
[   54.496637] iwlwifi 0000:00:14.3: Detected Intel(R) Dual Band Wireless AC 9560, REV=0x318
[   54.504798] iwlwifi 0000:00:14.3: Applying debug destination EXTERNAL_DRAM
[   54.504935] iwlwifi 0000:00:14.3: Allocated 0x00400000 bytes for firmware monitor.
[   54.549920] iwlwifi 0000:00:14.3: base HW address: 54:8d:5a:12:93:82
[   54.616551] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[   54.616657] thermal thermal_zone9: failed to read out thermal zone (-61)
[   54.718026] intel_rapl_common: Found RAPL domain package
[   54.718027] intel_rapl_common: Found RAPL domain core
[   54.718028] intel_rapl_common: Found RAPL domain uncore
[   54.718028] intel_rapl_common: Found RAPL domain dram
[   55.701626] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input20
[   55.701746] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input21
[   55.701864] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input22
[   55.701967] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input23
[   55.702068] input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input24
[   55.702171] input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input25
[   55.742217] Console: switching to colour frame buffer device 240x67
[   55.755625] i915 0000:00:02.0: fb0: i915drmfb frame buffer device
[   55.809650] Bluetooth: hci0: Waiting for firmware download to complete
[   55.810048] Bluetooth: hci0: Firmware loaded in 1512592 usecs
[   55.810221] Bluetooth: hci0: Waiting for device to boot
[   55.823291] Bluetooth: hci0: Device booted in 12869 usecs
[   55.823615] bluetooth hci0: firmware: direct-loading firmware intel/ibt-17-16-1.ddc
[   55.823621] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-17-16-1.ddc
[   55.826153] Bluetooth: hci0: Applying Intel DDC parameters completed
[   55.828149] Bluetooth: hci0: Firmware revision 0.1 build 130 week 44 2018
[   55.913887] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC257: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[   55.913891] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[   55.913895] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[   55.913897] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[   55.913899] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[   55.913902] snd_hda_codec_realtek hdaudioC0D0:      Mic=0x19
[   55.913905] snd_hda_codec_realtek hdaudioC0D0:      Internal Mic=0x12
[   56.014280] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1f.3/sound/card0/input26
[   56.015584] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input27
[   56.015738] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input28
[   56.015875] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input29
[   56.016004] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input30
[   56.016127] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input31
[   56.016275] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input32
[   56.016409] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input33
[   56.479562] EXT4-fs (dm-1): re-mounted. Opts: errors=remount-ro
[   57.985177] r8169 0000:07:00.0 eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[   57.985192] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   78.219871] lp: driver loaded but no devices found
[   78.238231] ppdev: user-space parallel port driver
[   78.816355] EXT4-fs (dm-2): re-mounted. Opts: (null)
[   78.822880] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
[   78.822891] ext4 filesystem being mounted at /boot supports timestamps until 2038 (0x7fffffff)
[   78.924421] EXT4-fs (dm-8): mounted filesystem with ordered data mode. Opts: (null)
[   78.933113] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null)
[   78.936578] EXT4-fs (dm-4): mounted filesystem with ordered data mode. Opts: (null)
[   78.940498] EXT4-fs (dm-3): mounted filesystem with ordered data mode. Opts: (null)
[   79.028704] Adding 15622140k swap on /dev/mapper/vgs-swap.  Priority:-2 extents:1 across:15622140k SSFS
[   79.224177] audit: type=1400 audit(1591614030.444:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-xpdfimport" pid=1867 comm="apparmor_parser"
[   79.224220] audit: type=1400 audit(1591614030.448:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-senddoc" pid=1866 comm="apparmor_parser"
[   79.224769] audit: type=1400 audit(1591614030.448:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-oopslash" pid=1865 comm="apparmor_parser"
[   79.224831] audit: type=1400 audit(1591614030.448:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=1869 comm="apparmor_parser"
[   79.224832] audit: type=1400 audit(1591614030.448:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=1869 comm="apparmor_parser"
[   79.225347] audit: type=1400 audit(1591614030.448:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=1871 comm="apparmor_parser"
[   79.225348] audit: type=1400 audit(1591614030.448:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=1871 comm="apparmor_parser"
[   79.225349] audit: type=1400 audit(1591614030.448:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=1871 comm="apparmor_parser"
[   79.225475] audit: type=1400 audit(1591614030.448:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cups-browsed" pid=1868 comm="apparmor_parser"
[   79.228944] audit: type=1400 audit(1591614030.452:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/cups/backend/cups-pdf" pid=1870 comm="apparmor_parser"
[   80.026523] IPMI message handler: version 39.2
[   80.027727] ipmi device interface
[   80.052737] nvidia: loading out-of-tree module taints kernel.
[   80.052746] nvidia: module license 'NVIDIA' taints kernel.
[   80.052746] Disabling lock debugging due to kernel taint
[   80.057141] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[   80.066148] nvidia-nvlink: Nvlink Core is being initialized, major device number 241
[   80.066481] nvidia 0000:01:00.0: enabling device (0006 -> 0007)
[   80.066599] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[   80.117503] NVRM: loading NVIDIA UNIX x86_64 Kernel Module  440.82  Wed Apr  1 20:04:33 UTC 2020
[   80.140081] ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20191018/nsarguments-66)
[   80.793975] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  440.82  Wed Apr  1 19:41:29 UTC 2020
[   80.858232] bbswitch: version 0.8
[   80.858235] bbswitch: Found integrated VGA device 0000:00:02.0: \_SB_.PCI0.GFX0
[   80.858239] bbswitch: Found discrete VGA device 0000:01:00.0: \_SB_.PCI0.PEG0.PEGP
[   80.858289] bbswitch: detected an Optimus _DSM function
[   80.858293] bbswitch: Succesfully loaded. Discrete card 0000:01:00.0 is on
[   80.954229] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   80.954230] Bluetooth: BNEP filters: protocol multicast
[   80.954232] Bluetooth: BNEP socket layer initialized
[   81.045975] elogind-daemon[2689]: New seat seat0.
[   81.301321] broken atomic modeset userspace detected, disabling atomic
[   82.328668] NET: Registered protocol family 5
[   82.468682] NET: Unregistered protocol family 5
[   82.536624] NET: Registered protocol family 5
[   82.652663] NET: Unregistered protocol family 5
[   82.708393] NET: Registered protocol family 5
[   82.804665] NET: Unregistered protocol family 5
[  119.337314] usb 2-4: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[  119.372041] usb 2-4: New USB device found, idVendor=18a5, idProduct=0243, bcdDevice= 1.00
[  119.372046] usb 2-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  119.372049] usb 2-4: Product: STORE N GO
[  119.372052] usb 2-4: Manufacturer: Verbatim
[  119.372054] usb 2-4: SerialNumber: 0707284228443603
[  119.394814] usb-storage 2-4:1.0: USB Mass Storage device detected
[  119.394993] scsi host5: usb-storage 2-4:1.0
[  119.395050] usbcore: registered new interface driver usb-storage
[  119.396746] usbcore: registered new interface driver uas
[  120.479732] scsi 5:0:0:0: Direct-Access     Verbatim STORE N GO       PMAP PQ: 0 ANSI: 4
[  120.480292] sd 5:0:0:0: Attached scsi generic sg1 type 0
[  121.380689] sd 5:0:0:0: [sdb] 60532992 512-byte logical blocks: (31.0 GB/28.9 GiB)
[  121.380927] sd 5:0:0:0: [sdb] Write Protect is off
[  121.380931] sd 5:0:0:0: [sdb] Mode Sense: 23 00 00 00
[  121.381161] sd 5:0:0:0: [sdb] No Caching mode page found
[  121.381169] sd 5:0:0:0: [sdb] Assuming drive cache: write through
[  121.413860]  sdb: sdb1
[  121.417432] sd 5:0:0:0: [sdb] Attached SCSI removable disk
[  132.281289] elogind-daemon[2689]: New session 1 of user hamsa.
5) In between I worked off the issues mentioned above, just to make sure they are not making some trouble besides the message for i915.
a) Installation of latest firmware drivers:
b) for WiFi-card (iwlwifi-9000-pu-b0-jf-b0-46.ucode)
c) for Ethernet-card (rtl8125a-3.fw and rtl8168fp-3.fw)
d) for i915 (kbl_dmc_ver1_04.bin)
all drivers from git.kernel.org/pub/scm/linux/kernel/git … .git/tree/
e) copy of  git.devuan.org/devuan-packages/cryptset … -functions to /lib/cryptsetup/
f) helped eudev by adding a system group: addgroup --system kvm
h) made sure, I had not choosen Secure Boot and corresponding entries in BIOS
All worked well. Although I noticed messages for the i915-driver:
dmesg | grep i915
I suspect that disabling of the runtime power management is not crucial, because i915 was initialized. Am I right?
Bumblebee seems to work and switches to the discrete graphics card, but the screen is black and sometimes flahes up. If I change BIOS setting to "Discrete Graphics" then all works as expected, but I cannot use the iGPU. Its even not recognized by the kernel (see lspci in my initial post). This seems to be correct and bumblebeed stops.
I think my problem is:
Using "switchable graphics" in BIOS and getting a display. Display stays black and flashes up sometimes.
Could be in correspondence to nvidia-persistenced error.
How to fix this?
BIOS Upgrade of the GPU?
Any ideas?
thanks for your help
Walter
#4 2020-06-08 13:53:59
larsH
Re: Beowulf and Legion y540
Hi
Now I do not have a similar configuration to test. But according to https://wiki.archlinux.org/index.php/Bumblebee you will have to disable nvidia-persistenced.service so the nvidia card can be turned off and on when needed (the whole idea behind bumblebee). If  it works then you were indeed right yourself about what was the problem ;-))
Have a nice day
Lars H
#5 2020-06-08 19:08:52
walter
Thank you larsH,
I need to digest all the information at wiki.archlinux.org/index.php/Bumblebee before I get on. I know the bumblebee project site, but the one you suggested has some more information.
There its stated that the installation of bumblebee should be done with Option "Switchable Graphics" enabled in BIOS. Although I can follow the idea its not that easy, because my display is black and I have to use keyboard without possibility of checking keyed failures or messages on display.
Anyway I disabled nvidia-persistenced and detected that installation of packets is without any remarks about it.
Let me check the Bumblebee Archwiki page and I get back.
Thanks so far and please buy a Legion ;-)
Happy day
Walter
EDIT:
After taking steps from wiki.archlinux.org/index.php/Bumblebee I got a messed up system. Impossible X in any of the installed kernel releases and in both BIOS settings "Switchable Graphics" and "Discrete Graphics". Thats more or less the state I came in here. I cannot see how I get out of this situation. Complete reinstall needed. Takes two days since I don't have that much time.
#6 2020-06-09 19:20:57
Can you ssh onto the new system from your old system? That would enable you to read dmesg, /var/log/messages, etc to see if they say anything useful without having to enter commands blind. And to update files on the new system if necessary.
Chris
#7 2020-06-09 20:34:49
larsH
Hi
Sorry to hear things messed up. You can off course also chroot into the system to see what is happening. But sometimes the a reinstall of the whole thing is the fastest and simplest solution. And in the process I am sure you will know much more.
Hopefully you will get things up and running. But I have seen that bumblebee often causes trouble. And with a new machine it is even more so.
Best wishes
Lars H
#8 2020-06-09 22:38:14
walter
Hi there,
Chris
Yes, I had the same idea. But I need to understand SSH, since that is not used in my daily work. I'm out of that administrator business since quite long time now. But yes I will consider that.
larsH wrote:
Hi
Best wishes
Lars H
No trouble here. I was very clear with that when I decided to buy this machine. I know the driver/kernel development is always a bit behind hardware market. Anyway I had already a setup with a running system without UEFI and without bumblebee/Optimus, but maybe you know that "little competition", when you sit in front of a machine and that device present its reluctant character? Not with me :-) I am currently trying some different setups even chimaera (looks good by the way).
Walter
#9 2020-06-10 22:01:32
walter
Here we go,
current status:
    1) followed the guideline at devuan.org/os/documentation/install-gui … all-devuan
    2) dd devuan_beowulf_3.0.0_amd64-desktop.iso to pendrive and installation of manual partition scheme with LUKS/LVM
    3) installation with UEFI (no secure mode), „Switchable Graphics“ enabled (means iGPU is serving the display). No errors
    4) First start: Recognized the flickering starts after I entered password phrase for LUKS, so the flickering of the display is very likely due to a driver issue. X came up and login was successful (XFCE). Flickering display. Shutdown and restart with setting „Discrete Graphics“ in BIOS. After reboot X does not start.
    5) Installation of openssh-server. Reboot with „Switchable Graphics“ → flickering screen. From now on with SSH.
dmesg | grep nouveau
[   17.253077] nouveau: detected PR support, will not use DSM
[   17.253100] nouveau 0000:01:00.0: enabling device (0006 -> 0007)
[   17.253264] nouveau 0000:01:00.0: unknown chipset (168000a1)
[   17.253269] nouveau: probe of 0000:01:00.0 failed with error -12
dmesg | grep i915
[   17.213742] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[   17.214924] i915 0000:00:02.0: firmware: failed to load i915/kbl_dmc_ver1_04.bin (-2)
[   17.214930] i915 0000:00:02.0: Direct firmware load for i915/kbl_dmc_ver1_04.bin failed with error -2
[   17.214931] i915 0000:00:02.0: Failed to load DMC firmware i915/kbl_dmc_ver1_04.bin. Disabling runtime power management.
[   17.214932] i915 0000:00:02.0: DMC firmware homepage: https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/tree/i915
[   17.223144] [drm] Initialized i915 1.6.0 20180719 for 0000:00:02.0 on minor 0
[   17.377785] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[   18.679160] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
Performed tasks:
1) in case of nouveau – nothing; nouveau does not support the GPU yet (buhuhuuuuuu….)
2) in case of i915: copy of kbl_dmc_ver1_04.bin into /lib/firmware/i915 (driver from  https://git.kernel.org/pub/scm/linux/ke … tree/i915)
3) treating the delay when deactivating of LVM inside crypted disks: copy of http://git.devuan.org/devuan-packages/c … -functions to /lib/cryptsetup
    6) per SSH: Installation of linux-image-5.5.0-0.bpo.2-amd64 (signed) from beowulf-backports
    7) per SSH: Installation of nvidia-driver (Rel. 418.113) from beowulf-backports with errors:
Starting NVIDIA Persistence Daemon
nvidia-persistenced failed to initialize. Check syslog for more details.
invoke-rc.d: initscript nvidia-persistenced, action "start" failed.
dpkg: Fehler beim Bearbeiten des Paketes nvidia-persistenced (--configure):
»installiertes nvidia-persistenced-Skript des Paketes post-installation«-Unterprozess gab den Fehlerwert 1 zurück
    8) Reboot into Kernel 5.5.17. Flickering screen, but X came up. Login per SSH.
dmesg
[    0.000000] Linux version 5.5.0-0.bpo.2-amd64 (debian-kernel@lists.debian.org) (gcc version 8.3.0 (Debian 8.3.0-6)) #1 SMP Debian 5.5.17-1~bpo10+1 (2020-04-23)
[    0.000000] Command line: BOOT_IMAGE=/vmlinuz-5.5.0-0.bpo.2-amd64 root=/dev/mapper/vgs-root ro quiet
[    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[    0.000000] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.000000] x86/fpu: xstate_offset[3]:  832, xstate_sizes[3]:   64
[    0.000000] x86/fpu: xstate_offset[4]:  896, xstate_sizes[4]:   64
[    0.000000] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000073d86fff] usable
[    0.000000] BIOS-e820: [mem 0x0000000073d87000-0x0000000074686fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000074687000-0x000000008a89dfff] usable
[    0.000000] BIOS-e820: [mem 0x000000008a89e000-0x000000008aa9dfff] type 20
[    0.000000] BIOS-e820: [mem 0x000000008aa9e000-0x000000008b49dfff] reserved
[    0.000000] BIOS-e820: [mem 0x000000008b49e000-0x000000008bb8dfff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x000000008bb8e000-0x000000008bc0dfff] ACPI data
[    0.000000] BIOS-e820: [mem 0x000000008bc0e000-0x000000008bc0efff] usable
[    0.000000] BIOS-e820: [mem 0x000000008bc0f000-0x000000008f7fffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed10000-0x00000000fed19fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed84000-0x00000000fed84fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ff600000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000046e7fffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] efi: EFI v2.60 by INSYDE Corp.
[    0.000000] efi:  ACPI=0x8bc0d000  ACPI 2.0=0x8bc0d014  TPMFinalLog=0x8b475000  SMBIOS=0x8ac50000  SMBIOS 3.0=0x8ac4e000  ESRT=0x7af43518  MEMATTR=0x7a833018
[    0.000000] secureboot: Secure boot could not be determined (mode 0)
[    0.000000] SMBIOS 3.0.1 present.
[    0.000000] DMI: LENOVO 81Q4/LNVNB161216, BIOS BHCN36WW 02/10/2020
[    0.000000] tsc: Detected 2600.000 MHz processor
[    0.000010] tsc: Detected 2599.992 MHz TSC
[    0.000010] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000011] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000017] last_pfn = 0x46e800 max_arch_pfn = 0x400000000
[    0.000020] MTRR default type: write-back
[    0.000020] MTRR fixed ranges enabled:
[    0.000022]   00000-9FFFF write-back
[    0.000022]   A0000-BFFFF uncachable
[    0.000023]   C0000-FFFFF write-protect
[    0.000024] MTRR variable ranges enabled:
[    0.000025]   0 base 00C0000000 mask 7FC0000000 uncachable
[    0.000026]   1 base 00A0000000 mask 7FE0000000 uncachable
[    0.000026]   2 base 0090000000 mask 7FF0000000 uncachable
[    0.000027]   3 base 008E000000 mask 7FFE000000 uncachable
[    0.000028]   4 base 008D000000 mask 7FFF000000 uncachable
[    0.000029]   5 base 2000000000 mask 6000000000 uncachable
[    0.000029]   6 base 1000000000 mask 7000000000 uncachable
[    0.000030]   7 base 0800000000 mask 7800000000 uncachable
[    0.000031]   8 base 4000000000 mask 4000000000 uncachable
[    0.000031]   9 disabled
[    0.000477] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.000638] last_pfn = 0x8bc0f max_arch_pfn = 0x400000000
[    0.009075] esrt: Reserving ESRT space from 0x000000007af43518 to 0x000000007af435c8.
[    0.009079] e820: update [mem 0x7af43000-0x7af43fff] usable ==> reserved
[    0.009091] Using GB pages for direct mapping
[    0.009092] BRK [0x1dae01000, 0x1dae01fff] PGTABLE
[    0.009094] BRK [0x1dae02000, 0x1dae02fff] PGTABLE
[    0.009095] BRK [0x1dae03000, 0x1dae03fff] PGTABLE
[    0.009137] BRK [0x1dae04000, 0x1dae04fff] PGTABLE
[    0.009138] BRK [0x1dae05000, 0x1dae05fff] PGTABLE
[    0.009311] BRK [0x1dae06000, 0x1dae06fff] PGTABLE
[    0.009352] BRK [0x1dae07000, 0x1dae07fff] PGTABLE
[    0.009395] BRK [0x1dae08000, 0x1dae08fff] PGTABLE
[    0.009431] BRK [0x1dae09000, 0x1dae09fff] PGTABLE
[    0.009487] BRK [0x1dae0a000, 0x1dae0afff] PGTABLE
[    0.009565] BRK [0x1dae0b000, 0x1dae0bfff] PGTABLE
[    0.009678] RAMDISK: [mem 0x34705000-0x36379fff]
[    0.009685] ACPI: Early table checksum verification disabled
[    0.009687] ACPI: RSDP 0x000000008BC0D014 000024 (v02 LENOVO)
[    0.009690] ACPI: XSDT 0x000000008BBEE188 000104 (v01 LENOVO CB-01    00000001      01000013)
[    0.009694] ACPI: FACP 0x000000008BBF1000 00010C (v05 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009699] ACPI: DSDT 0x000000008BBBD000 02FE66 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009701] ACPI: FACS 0x000000008BB0D000 000040
[    0.009703] ACPI: UEFI 0x000000008BC0C000 000236 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009706] ACPI: SSDT 0x000000008BC0A000 001B1C (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009708] ACPI: SSDT 0x000000008BC06000 0031D0 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009710] ACPI: UEFI 0x000000008BC05000 000042 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009712] ACPI: SSDT 0x000000008BC04000 00045A (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009714] ACPI: SSDT 0x000000008BC03000 000046 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009716] ACPI: TPM2 0x000000008BC02000 000034 (v03 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009719] ACPI: POAT 0x000000008BC01000 000055 (v03 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009721] ACPI: SSDT 0x000000008BBFC000 0044B6 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009723] ACPI: LPIT 0x000000008BBFB000 000094 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009725] ACPI: WSMT 0x000000008BBFA000 000028 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009727] ACPI: SSDT 0x000000008BBF9000 000C2F (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009729] ACPI: DBGP 0x000000008BBF8000 000034 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009732] ACPI: DBG2 0x000000008BBF7000 000061 (v00 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009734] ACPI: SSDT 0x000000008BBF6000 000896 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009736] ACPI: SSDT 0x000000008BBF3000 002F89 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009738] ACPI: ASF! 0x000000008BBF2000 0000A5 (v32 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009740] ACPI: HPET 0x000000008BBF0000 000038 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009742] ACPI: APIC 0x000000008BBEF000 00012C (v03 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009745] ACPI: MCFG 0x000000008BBED000 00003C (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009747] ACPI: SSDT 0x000000008BBBA000 002BBF (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009749] ACPI: DMAR 0x000000008BBB9000 0000A8 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009751] ACPI: SSDT 0x000000008BBB3000 005178 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009753] ACPI: SSDT 0x000000008BBB2000 00004C (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009755] ACPI: SSDT 0x000000008BBB1000 000123 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009758] ACPI: FPDT 0x000000008BBB0000 000044 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009760] ACPI: BGRT 0x000000008BBAF000 000038 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009765] ACPI: Local APIC address 0xfee00000
[    0.010060] No NUMA configuration found
[    0.010061] Faking a node at [mem 0x0000000000000000-0x000000046e7fffff]
[    0.010064] NODE_DATA(0) allocated [mem 0x46e7fb000-0x46e7fffff]
[    0.010091] Zone ranges:
[    0.010091]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.010092]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.010093]   Normal   [mem 0x0000000100000000-0x000000046e7fffff]
[    0.010094]   Device   empty
[    0.010095] Movable zone start for each node
[    0.010095] Early memory node ranges
[    0.010096]   node   0: [mem 0x0000000000001000-0x000000000009efff]
[    0.010097]   node   0: [mem 0x0000000000100000-0x0000000073d86fff]
[    0.010098]   node   0: [mem 0x0000000074687000-0x000000008a89dfff]
[    0.010098]   node   0: [mem 0x000000008bc0e000-0x000000008bc0efff]
[    0.010099]   node   0: [mem 0x0000000100000000-0x000000046e7fffff]
[    0.010315] Zeroed struct page in unavailable ranges: 30915 pages
[    0.010316] Initmem setup node 0 [mem 0x0000000000001000-0x000000046e7fffff]
[    0.010317] On node 0 totalpages: 4163389
[    0.010318]   DMA zone: 64 pages used for memmap
[    0.010319]   DMA zone: 23 pages reserved
[    0.010320]   DMA zone: 3998 pages, LIFO batch:0
[    0.010377]   DMA32 zone: 8767 pages used for memmap
[    0.010377]   DMA32 zone: 561055 pages, LIFO batch:63
[    0.019957]   Normal zone: 56224 pages used for memmap
[    0.019958]   Normal zone: 3598336 pages, LIFO batch:63
[    0.020410] x86/hpet: Will disable the HPET for this platform because it's not reliable
[    0.020446] Reserving Intel graphics memory at [mem 0x8d800000-0x8f7fffff]
[    0.020992] ACPI: PM-Timer IO Port: 0x1808
[    0.020994] ACPI: Local APIC address 0xfee00000
[    0.021000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.021000] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[    0.021001] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[    0.021001] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[    0.021002] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[    0.021002] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[    0.021003] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[    0.021003] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[    0.021004] ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
[    0.021004] ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
[    0.021005] ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
[    0.021005] ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
[    0.021006] ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
[    0.021006] ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
[    0.021007] ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
[    0.021007] ACPI: LAPIC_NMI (acpi_id[0x10] high edge lint[0x1])
[    0.021067] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[    0.021068] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.021069] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.021071] ACPI: IRQ0 used by override.
[    0.021072] ACPI: IRQ9 used by override.
[    0.021073] Using ACPI (MADT) for SMP configuration information
[    0.021074] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[    0.021080] e820: update [mem 0x7a8c7000-0x7a907fff] usable ==> reserved
[    0.021087] smpboot: Allowing 12 CPUs, 0 hotplug CPUs
[    0.021102] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.021103] PM: Registered nosave memory: [mem 0x0009f000-0x000fffff]
[    0.021104] PM: Registered nosave memory: [mem 0x73d87000-0x74686fff]
[    0.021106] PM: Registered nosave memory: [mem 0x7a8c7000-0x7a907fff]
[    0.021107] PM: Registered nosave memory: [mem 0x7af43000-0x7af43fff]
[    0.021108] PM: Registered nosave memory: [mem 0x8a89e000-0x8aa9dfff]
[    0.021109] PM: Registered nosave memory: [mem 0x8aa9e000-0x8b49dfff]
[    0.021109] PM: Registered nosave memory: [mem 0x8b49e000-0x8bb8dfff]
[    0.021109] PM: Registered nosave memory: [mem 0x8bb8e000-0x8bc0dfff]
[    0.021111] PM: Registered nosave memory: [mem 0x8bc0f000-0x8f7fffff]
[    0.021111] PM: Registered nosave memory: [mem 0x8f800000-0xdfffffff]
[    0.021112] PM: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[    0.021112] PM: Registered nosave memory: [mem 0xf0000000-0xfdffffff]
[    0.021113] PM: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
[    0.021113] PM: Registered nosave memory: [mem 0xfe011000-0xfed0ffff]
[    0.021114] PM: Registered nosave memory: [mem 0xfed10000-0xfed19fff]
[    0.021114] PM: Registered nosave memory: [mem 0xfed1a000-0xfed83fff]
[    0.021114] PM: Registered nosave memory: [mem 0xfed84000-0xfed84fff]
[    0.021115] PM: Registered nosave memory: [mem 0xfed85000-0xfedfffff]
[    0.021115] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[    0.021116] PM: Registered nosave memory: [mem 0xfee01000-0xff5fffff]
[    0.021116] PM: Registered nosave memory: [mem 0xff600000-0xffffffff]
[    0.021118] [mem 0x8f800000-0xdfffffff] available for PCI devices
[    0.021118] Booting paravirtualized kernel on bare hardware
[    0.021121] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[    0.113034] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:12 nr_node_ids:1
[    0.113358] percpu: Embedded 55 pages/cpu s187800 r8192 d29288 u262144
[    0.113364] pcpu-alloc: s187800 r8192 d29288 u262144 alloc=1*2097152
[    0.113365] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 -- -- -- --
[    0.113386] Built 1 zonelists, mobility grouping on.  Total pages: 4098311
[    0.113387] Policy zone: Normal
[    0.113388] Kernel command line: BOOT_IMAGE=/vmlinuz-5.5.0-0.bpo.2-amd64 root=/dev/mapper/vgs-root ro quiet
[    0.114307] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.114757] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.114864] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.128170] Memory: 2237516K/16653556K available (10243K kernel code, 1210K rwdata, 3984K rodata, 1664K init, 1992K bss, 468244K reserved, 0K cma-reserved)
[    0.128177] random: get_random_u64 called from __kmem_cache_create+0x3e/0x520 with crng_init=0
[    0.128283] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[    0.128292] Kernel/User page tables isolation: enabled
[    0.128305] ftrace: allocating 34312 entries in 135 pages
[    0.142277] ftrace: allocated 135 pages with 4 groups
[    0.142361] rcu: Hierarchical RCU implementation.
[    0.142362] rcu: 	RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=12.
[    0.142363] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.142363] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[    0.145187] NR_IRQS: 33024, nr_irqs: 2152, preallocated irqs: 16
[    0.145728] random: crng done (trusting CPU's manufacturer)
[    0.145751] Console: colour dummy device 80x25
[    0.145755] printk: console [tty0] enabled
[    0.145770] ACPI: Core revision 20191018
[    0.146053] APIC: Switch to symmetric I/O mode setup
[    0.146055] DMAR: Host address width 39
[    0.146056] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[    0.146060] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 19e2ff0505e
[    0.146061] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[    0.146064] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[    0.146065] DMAR: RMRR base: 0x0000008b47d000 end: 0x0000008b49cfff
[    0.146066] DMAR: RMRR base: 0x0000008d000000 end: 0x0000008f7fffff
[    0.146068] DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 1
[    0.146068] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[    0.146069] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[    0.149186] DMAR-IR: Enabled IRQ remapping in x2apic mode
[    0.149187] x2apic enabled
[    0.149219] Switched APIC routing to cluster x2apic.
[    0.158525] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x257a34a6eea, max_idle_ns: 440795264358 ns
[    0.158530] Calibrating delay loop (skipped), value calculated using timer frequency.. 5199.98 BogoMIPS (lpj=10399968)
[    0.158532] pid_max: default: 32768 minimum: 301
[    0.162448] LSM: Security Framework initializing
[    0.162455] Yama: disabled by default; enable with sysctl kernel.yama.*
[    0.162482] AppArmor: AppArmor initialized
[    0.162483] TOMOYO Linux initialized
[    0.162517] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.162527] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.162527] mce: CPU0: Thermal monitoring enabled (TM1)
[    0.162527] process: using mwait in idle threads
[    0.162527] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[    0.162527] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[    0.162527] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.162527] Spectre V2 : Mitigation: Full generic retpoline
[    0.162527] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.162527] Spectre V2 : Enabling Restricted Speculation for firmware calls
[    0.162527] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.162527] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
[    0.162527] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[    0.162527] MDS: Mitigation: Clear CPU buffers
[    0.162527] Freeing SMP alternatives memory: 32K
[    0.162527] TSC deadline timer enabled
[    0.162527] smpboot: CPU0: Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz (family: 0x6, model: 0x9e, stepping: 0xa)
[    0.162527] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[    0.162527] ... version:                4
[    0.162527] ... bit width:              48
[    0.162527] ... generic registers:      4
[    0.162527] ... value mask:             0000ffffffffffff
[    0.162527] ... max period:             00007fffffffffff
[    0.162527] ... fixed-purpose events:   3
[    0.162527] ... event mask:             000000070000000f
[    0.162527] rcu: Hierarchical SRCU implementation.
[    0.162527] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.162527] smp: Bringing up secondary CPUs ...
[    0.162527] x86: Booting SMP configuration:
[    0.162527] .... node  #0, CPUs:        #1  #2  #3  #4  #5  #6
[    0.163318] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[    0.163318]   #7  #8  #9 #10 #11
[    0.167320] smp: Brought up 1 node, 12 CPUs
[    0.167320] smpboot: Max logical packages: 1
[    0.167320] smpboot: Total of 12 processors activated (62399.80 BogoMIPS)
[    0.210532] node 0 initialised, 3486949 pages in 40ms
[    0.210832] devtmpfs: initialized
[    0.210832] x86/mm: Memory block size: 128MB
[    0.214942] PM: Registering ACPI NVS region [mem 0x8b49e000-0x8bb8dfff] (7274496 bytes)
[    0.214942] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.214942] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[    0.214942] pinctrl core: initialized pinctrl subsystem
[    0.214942] thermal_sys: Registered thermal governor 'fair_share'
[    0.214942] thermal_sys: Registered thermal governor 'bang_bang'
[    0.214942] thermal_sys: Registered thermal governor 'step_wise'
[    0.214942] thermal_sys: Registered thermal governor 'user_space'
[    0.214942] NET: Registered protocol family 16
[    0.214999] audit: initializing netlink subsys (disabled)
[    0.215004] audit: type=2000 audit(1591789197.056:1): state=initialized audit_enabled=0 res=1
[    0.215004] cpuidle: using governor ladder
[    0.215004] cpuidle: using governor menu
[    0.215004] KVM setup pv remote TLB flush
[    0.215004] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.215004] ACPI: bus type PCI registered
[    0.215004] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.215004] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[    0.215004] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[    0.215004] PCI: Using configuration type 1 for base access
[    0.215592] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.215597] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.215597] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.350832] ACPI: Added _OSI(Module Device)
[    0.350832] ACPI: Added _OSI(Processor Device)
[    0.350832] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.350832] ACPI: Added _OSI(Processor Aggregator Device)
[    0.350832] ACPI: Added _OSI(Linux-Dell-Video)
[    0.350832] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.350832] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[    0.399832] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.TPLD], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.399841] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.399844] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.399892] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS01._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.399896] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.399898] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.399900] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS01._PLD], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.399903] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.399905] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.401587] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS02._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.401592] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.401594] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.401595] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS02._PLD], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.401599] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.401601] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.403385] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS03._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.403390] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.403392] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.403393] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS03._PLD], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.403397] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.403400] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.404925] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS04._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.404929] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.404931] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.404932] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS04._PLD], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.404936] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.404938] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.406460] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS05._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.406464] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.406466] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.407994] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS06._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.407999] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.408001] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.408002] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS06._PLD], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.408006] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.408008] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.409685] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS07._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.409689] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.409692] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.411220] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS08._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.411225] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.411227] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.412894] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS09._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.412899] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.412901] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.412902] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS09._PLD], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.412906] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.412908] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.414432] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS10._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.414436] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.414439] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.416108] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS11._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.416113] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.416115] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.417794] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS12._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.417798] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.417801] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.419385] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS13._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.419389] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.419392] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.420916] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS14._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.420920] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.420923] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.420924] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS14._PLD], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.420927] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.420930] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.422580] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.USR1], AE_NOT_FOUND (20191018/dswload2-160)
[    0.422585] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20191018/psobject-221)
[    0.422587] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0010)
[    0.422589] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.USR2], AE_NOT_FOUND (20191018/dswload2-160)
[    0.422593] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20191018/psobject-221)
[    0.422595] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0010)
[    0.422621] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS01._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.422625] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.422627] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.422628] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS01._PLD], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.422632] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.422634] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.422666] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS02._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.422669] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.422672] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.422673] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS02._PLD], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.422676] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.422679] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.422709] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS03._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.422713] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.422715] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.422717] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS03._PLD], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.422720] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.422722] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.422753] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS04._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.422757] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.422759] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.422760] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS04._PLD], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.422764] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.422766] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.422796] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS05._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.422800] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.422802] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.422828] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS06._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.422832] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.422835] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.422859] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS07._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.422864] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.422866] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.422891] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS08._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.422895] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.422897] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.422922] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS09._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.422925] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.422928] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.422952] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS10._UPC], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.422956] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.422958] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.423828] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.I2C2.TPD0], AE_NOT_FOUND (20191018/dswload2-160)
[    0.423833] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20191018/psobject-221)
[    0.423836] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0010)
[    0.423857] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.I2C3.TPL1], AE_NOT_FOUND (20191018/dswload2-160)
[    0.423861] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20191018/psobject-221)
[    0.423863] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0010)
[    0.426731] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.PEG0.PEGP._ON], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.426738] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.426740] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.426742] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.PEG0.PEGP._OFF], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.426746] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.426748] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.426750] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.PEG0.PEGP.SGPO], AE_ALREADY_EXISTS (20191018/dswload2-324)
[    0.426753] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20191018/psobject-221)
[    0.426756] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.426925] ACPI: 13 ACPI AML tables successfully acquired and loaded
[    0.436459] ACPI: Dynamic OEM Table Load:
[    0.436471] ACPI: SSDT 0xFFFF99119E50BC00 0000F4 (v02 PmRef  Cpu0Psd  00003000 INTL 20160422)
[    0.437697] ACPI: \_SB_.PR00: _OSC native thermal LVT Acked
[    0.438454] ACPI: Dynamic OEM Table Load:
[    0.438461] ACPI: SSDT 0xFFFF990F1AECD800 000400 (v02 PmRef  Cpu0Cst  00003001 INTL 20160422)
[    0.439797] ACPI: Dynamic OEM Table Load:
[    0.439804] ACPI: SSDT 0xFFFF99119C491000 000581 (v02 PmRef  Cpu0Ist  00003000 INTL 20160422)
[    0.441483] ACPI: Dynamic OEM Table Load:
[    0.441488] ACPI: SSDT 0xFFFF99119E580600 00011B (v02 PmRef  Cpu0Hwp  00003000 INTL 20160422)
[    0.442876] ACPI: Dynamic OEM Table Load:
[    0.442882] ACPI: SSDT 0xFFFF99119C493000 000724 (v02 PmRef  HwpLvt   00003000 INTL 20160422)
[    0.444386] ACPI: Dynamic OEM Table Load:
[    0.444392] ACPI: SSDT 0xFFFF99119C497000 0005FC (v02 PmRef  ApIst    00003000 INTL 20160422)
[    0.445777] ACPI: Dynamic OEM Table Load:
[    0.445782] ACPI: SSDT 0xFFFF990F1AECB000 000317 (v02 PmRef  ApHwp    00003000 INTL 20160422)
[    0.447185] ACPI: Dynamic OEM Table Load:
[    0.447192] ACPI: SSDT 0xFFFF990E47261000 000AB0 (v02 PmRef  ApPsd    00003000 INTL 20160422)
[    0.449010] ACPI: Dynamic OEM Table Load:
[    0.449015] ACPI: SSDT 0xFFFF990F1AECF800 00030A (v02 PmRef  ApCst    00003000 INTL 20160422)
[    0.454733] ACPI: EC: EC started
[    0.454734] ACPI: EC: interrupt blocked
[    0.470619] ACPI: \_SB_.PCI0.LPCB.EC0_: Used as first EC
[    0.470621] ACPI: \_SB_.PCI0.LPCB.EC0_: GPE=0x2, IRQ=-1, EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.470622] ACPI: \_SB_.PCI0.LPCB.EC0_: Boot DSDT EC used to handle transactions
[    0.470622] ACPI: Interpreter enabled
[    0.470678] ACPI: (supports S0 S3 S4 S5)
[    0.470679] ACPI: Using IOAPIC for interrupt routing
[    0.470720] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.471186] ACPI: Enabled 10 GPEs in block 00 to 7F
[    0.472045] ACPI: Power Resource [PG00] (on)
[    0.475848] ACPI: Power Resource [PUBS] (on)
[    0.476623] ACPI: Power Resource [BTPR] (on)
[    0.478141] ACPI: Power Resource [USBC] (on)
[    0.478310] ACPI: Power Resource [PAUD] (on)
[    0.482009] ACPI: Power Resource [PXP] (off)
[    0.488275] ACPI: Power Resource [PXP] (off)
[    0.489919] ACPI: Power Resource [V0PR] (on)
[    0.490074] ACPI: Power Resource [V1PR] (on)
[    0.490222] ACPI: Power Resource [V2PR] (on)
[    0.492194] ACPI: Power Resource [PXTC] (on)
[    0.492591] ACPI: Power Resource [PXTC] (off)
[    0.494241] ACPI: Power Resource [WRST] (on)
[    0.496050] ACPI: Power Resource [PIN] (off)
[    0.496385] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[    0.496390] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI HPX-Type3]
[    0.499887] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR]
[    0.499888] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[    0.502503] PCI host bridge to bus 0000:00
[    0.502505] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.502506] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.502507] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.502508] pci_bus 0000:00: root bus resource [mem 0x8f800000-0xdfffffff window]
[    0.502509] pci_bus 0000:00: root bus resource [mem 0xfc800000-0xfe7fffff window]
[    0.502510] pci_bus 0000:00: root bus resource [bus 00-fe]
[    0.502519] pci 0000:00:00.0: [8086:3ec4] type 00 class 0x060000
[    0.503457] pci 0000:00:01.0: [8086:1901] type 01 class 0x060400
[    0.503502] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[    0.504653] pci 0000:00:02.0: [8086:3e9b] type 00 class 0x030000
[    0.504663] pci 0000:00:02.0: reg 0x10: [mem 0xb5000000-0xb5ffffff 64bit]
[    0.504668] pci 0000:00:02.0: reg 0x18: [mem 0x90000000-0x9fffffff 64bit pref]
[    0.504672] pci 0000:00:02.0: reg 0x20: [io  0x5000-0x503f]
[    0.504685] pci 0000:00:02.0: BAR 2: assigned to efifb
[    0.505785] pci 0000:00:04.0: [8086:1903] type 00 class 0x118000
[    0.505796] pci 0000:00:04.0: reg 0x10: [mem 0xb4510000-0xb4517fff 64bit]
[    0.506805] pci 0000:00:08.0: [8086:1911] type 00 class 0x088000
[    0.506816] pci 0000:00:08.0: reg 0x10: [mem 0xb4524000-0xb4524fff 64bit]
[    0.507851] pci 0000:00:12.0: [8086:a379] type 00 class 0x118000
[    0.507895] pci 0000:00:12.0: reg 0x10: [mem 0xb4525000-0xb4525fff 64bit]
[    0.509024] pci 0000:00:14.0: [8086:a36d] type 00 class 0x0c0330
[    0.509070] pci 0000:00:14.0: reg 0x10: [mem 0xb4500000-0xb450ffff 64bit]
[    0.509210] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    0.510204] pci 0000:00:14.2: [8086:a36f] type 00 class 0x050000
[    0.510245] pci 0000:00:14.2: reg 0x10: [mem 0xb4520000-0xb4521fff 64bit]
[    0.510268] pci 0000:00:14.2: reg 0x18: [mem 0xb4526000-0xb4526fff 64bit]
[    0.511340] pci 0000:00:14.3: [8086:a370] type 00 class 0x028000
[    0.511530] pci 0000:00:14.3: reg 0x10: [mem 0xb4518000-0xb451bfff 64bit]
[    0.512206] pci 0000:00:14.3: PME# supported from D0 D3hot D3cold
[    0.513411] pci 0000:00:15.0: [8086:a368] type 00 class 0x0c8000
[    0.513452] pci 0000:00:15.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[    0.514521] pci 0000:00:15.1: [8086:a369] type 00 class 0x0c8000
[    0.514560] pci 0000:00:15.1: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[    0.515690] pci 0000:00:16.0: [8086:a360] type 00 class 0x078000
[    0.515732] pci 0000:00:16.0: reg 0x10: [mem 0xb4529000-0xb4529fff 64bit]
[    0.515853] pci 0000:00:16.0: PME# supported from D3hot
[    0.517088] pci 0000:00:17.0: [8086:a353] type 00 class 0x010601
[    0.517126] pci 0000:00:17.0: reg 0x10: [mem 0xb4522000-0xb4523fff]
[    0.517141] pci 0000:00:17.0: reg 0x14: [mem 0xb452e000-0xb452e0ff]
[    0.517156] pci 0000:00:17.0: reg 0x18: [io  0x5080-0x5087]
[    0.517171] pci 0000:00:17.0: reg 0x1c: [io  0x5088-0x508b]
[    0.517186] pci 0000:00:17.0: reg 0x20: [io  0x5060-0x507f]
[    0.517201] pci 0000:00:17.0: reg 0x24: [mem 0xb452d000-0xb452d7ff]
[    0.517285] pci 0000:00:17.0: PME# supported from D3hot
[    0.518322] pci 0000:00:1d.0: [8086:a330] type 01 class 0x060400
[    0.518577] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    0.518648] pci 0000:00:1d.0: PTM enabled (root), 4ns granularity
[    0.519704] pci 0000:00:1d.5: [8086:a335] type 01 class 0x060400
[    0.519920] pci 0000:00:1d.5: PME# supported from D0 D3hot D3cold
[    0.519984] pci 0000:00:1d.5: PTM enabled (root), 4ns granularity
[    0.521011] pci 0000:00:1e.0: [8086:a328] type 00 class 0x078000
[    0.521051] pci 0000:00:1e.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[    0.522189] pci 0000:00:1f.0: [8086:a30d] type 00 class 0x060100
[    0.523711] pci 0000:00:1f.3: [8086:a348] type 00 class 0x040300
[    0.523789] pci 0000:00:1f.3: reg 0x10: [mem 0xb451c000-0xb451ffff 64bit]
[    0.523862] pci 0000:00:1f.3: reg 0x20: [mem 0xb4200000-0xb42fffff 64bit]
[    0.524012] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[    0.525116] pci 0000:00:1f.4: [8086:a323] type 00 class 0x0c0500
[    0.525307] pci 0000:00:1f.4: reg 0x10: [mem 0xb452b000-0xb452b0ff 64bit]
[    0.525681] pci 0000:00:1f.4: reg 0x20: [io  0x5040-0x505f]
[    0.526942] pci 0000:00:1f.5: [8086:a324] type 00 class 0x0c8000
[    0.526970] pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
[    0.528020] pci 0000:01:00.0: [10de:2191] type 00 class 0x030000
[    0.528039] pci 0000:01:00.0: reg 0x10: [mem 0xb3000000-0xb3ffffff]
[    0.528048] pci 0000:01:00.0: reg 0x14: [mem 0xa0000000-0xafffffff 64bit pref]
[    0.528057] pci 0000:01:00.0: reg 0x1c: [mem 0xb0000000-0xb1ffffff 64bit pref]
[    0.528063] pci 0000:01:00.0: reg 0x24: [io  0x4000-0x407f]
[    0.528069] pci 0000:01:00.0: reg 0x30: [mem 0xfff80000-0xffffffff pref]
[    0.528117] pci 0000:01:00.0: PME# supported from D0 D3hot
[    0.528227] pci 0000:01:00.1: [10de:1aeb] type 00 class 0x040300
[    0.528240] pci 0000:01:00.1: reg 0x10: [mem 0xb4000000-0xb4003fff]
[    0.528509] pci 0000:01:00.2: [10de:1aec] type 00 class 0x0c0330
[    0.528525] pci 0000:01:00.2: reg 0x10: [mem 0xb4100000-0xb413ffff 64bit pref]
[    0.528539] pci 0000:01:00.2: reg 0x1c: [mem 0xb4140000-0xb414ffff 64bit pref]
[    0.528587] pci 0000:01:00.2: PME# supported from D0 D3hot
[    0.528644] pci 0000:01:00.3: [10de:1aed] type 00 class 0x0c8000
[    0.528657] pci 0000:01:00.3: reg 0x10: [mem 0xb4004000-0xb4004fff]
[    0.528725] pci 0000:01:00.3: PME# supported from D0 D3hot
[    0.528797] pci 0000:00:01.0: PCI bridge to [bus 01-05]
[    0.528798] pci 0000:00:01.0:   bridge window [io  0x4000-0x4fff]
[    0.528800] pci 0000:00:01.0:   bridge window [mem 0xa0000000-0xb40fffff]
[    0.528803] pci 0000:00:01.0:   bridge window [mem 0xb4100000-0xb41fffff 64bit pref]
[    0.529042] pci 0000:06:00.0: [144d:a808] type 00 class 0x010802
[    0.529093] pci 0000:06:00.0: reg 0x10: [mem 0xb4400000-0xb4403fff 64bit]
[    0.529668] pci 0000:00:1d.0: PCI bridge to [bus 06]
[    0.529677] pci 0000:00:1d.0:   bridge window [mem 0xb4400000-0xb44fffff]
[    0.529779] pci 0000:07:00.0: [10ec:8168] type 00 class 0x020000
[    0.529823] pci 0000:07:00.0: reg 0x10: [io  0x3000-0x30ff]
[    0.529862] pci 0000:07:00.0: reg 0x18: [mem 0xb4304000-0xb4304fff 64bit]
[    0.529885] pci 0000:07:00.0: reg 0x20: [mem 0xb4300000-0xb4303fff 64bit]
[    0.530034] pci 0000:07:00.0: supports D1 D2
[    0.530035] pci 0000:07:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.530432] pci 0000:00:1d.5: PCI bridge to [bus 07]
[    0.530437] pci 0000:00:1d.5:   bridge window [io  0x3000-0x3fff]
[    0.530442] pci 0000:00:1d.5:   bridge window [mem 0xb4300000-0xb43fffff]
[    0.533741] ACPI: EC: interrupt unblocked
[    0.533773] ACPI: EC: event unblocked
[    0.533795] ACPI: \_SB_.PCI0.LPCB.EC0_: GPE=0x2, IRQ=-1, EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.533796] ACPI: \_SB_.PCI0.LPCB.EC0_: Boot DSDT EC used to handle transactions and events
[    0.533849] iommu: Default domain type: Translated
[    0.533862] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[    0.533862] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.533862] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[    0.533862] pci 0000:00:02.0: vgaarb: no bridge control possible
[    0.533862] pci 0000:01:00.0: vgaarb: bridge control possible
[    0.533862] vgaarb: loaded
[    0.533862] EDAC MC: Ver: 3.0.0
[    0.533862] Registered efivars operations
[    0.533862] PCI: Using ACPI for IRQ routing
[    0.621705] PCI: pci_cache_line_size set to 64 bytes
[    0.622112] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[    0.622113] e820: reserve RAM buffer [mem 0x73d87000-0x73ffffff]
[    0.622114] e820: reserve RAM buffer [mem 0x7a8c7000-0x7bffffff]
[    0.622114] e820: reserve RAM buffer [mem 0x7af43000-0x7bffffff]
[    0.622115] e820: reserve RAM buffer [mem 0x8a89e000-0x8bffffff]
[    0.622116] e820: reserve RAM buffer [mem 0x8bc0f000-0x8bffffff]
[    0.622117] e820: reserve RAM buffer [mem 0x46e800000-0x46fffffff]
[    0.622233] clocksource: Switched to clocksource tsc-early
[    0.627215] VFS: Disk quotas dquot_6.6.0
[    0.627228] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.627321] AppArmor: AppArmor Filesystem Enabled
[    0.627331] pnp: PnP ACPI init
[    0.627408] system 00:00: [mem 0x40000000-0x403fffff] could not be reserved
[    0.627412] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.627708] system 00:01: [io  0x1800-0x18fe] has been reserved
[    0.627710] system 00:01: [mem 0xfd000000-0xfd69ffff] has been reserved
[    0.627711] system 00:01: [mem 0xfd6c0000-0xfd6cffff] has been reserved
[    0.627712] system 00:01: [mem 0xfd6f0000-0xfdffffff] has been reserved
[    0.627713] system 00:01: [mem 0xfe000000-0xfe01ffff] could not be reserved
[    0.627714] system 00:01: [mem 0xfe200000-0xfe7fffff] has been reserved
[    0.627715] system 00:01: [mem 0xff000000-0xffffffff] could not be reserved
[    0.627718] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.628007] system 00:02: [io  0x2000-0x20fe] has been reserved
[    0.628010] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.628170] system 00:03: [io  0x0680-0x069f] has been reserved
[    0.628172] system 00:03: [io  0x164e-0x164f] has been reserved
[    0.628174] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.628284] system 00:04: [io  0x1854-0x1857] has been reserved
[    0.628287] system 00:04: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[    0.628317] pnp 00:05: Plug and Play ACPI device, IDs PNP0303 (active)
[    0.629498] system 00:06: [mem 0xfe037000-0xfe037fff] has been reserved
[    0.629499] system 00:06: [mem 0xfe036008-0xfe036fff] has been reserved
[    0.629502] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.629945] system 00:07: [mem 0xfed10000-0xfed17fff] has been reserved
[    0.629947] system 00:07: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.629948] system 00:07: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.629949] system 00:07: [mem 0xe0000000-0xefffffff] has been reserved
[    0.629950] system 00:07: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.629951] system 00:07: [mem 0xfed90000-0xfed93fff] could not be reserved
[    0.629952] system 00:07: [mem 0xfed45000-0xfed8ffff] could not be reserved
[    0.629953] system 00:07: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.629956] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.630109] pnp: PnP ACPI: found 8 devices
[    0.635695] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.635721] pci 0000:01:00.0: can't claim BAR 6 [mem 0xfff80000-0xffffffff pref]: no compatible bridge window
[    0.635732] pci 0000:00:15.0: BAR 0: assigned [mem 0x8f800000-0x8f800fff 64bit]
[    0.635753] pci 0000:00:15.1: BAR 0: assigned [mem 0x8f801000-0x8f801fff 64bit]
[    0.635769] pci 0000:00:1e.0: BAR 0: assigned [mem 0x8f802000-0x8f802fff 64bit]
[    0.635786] pci 0000:01:00.0: BAR 6: assigned [mem 0xb2000000-0xb207ffff pref]
[    0.635787] pci 0000:00:01.0: PCI bridge to [bus 01-05]
[    0.635789] pci 0000:00:01.0:   bridge window [io  0x4000-0x4fff]
[    0.635791] pci 0000:00:01.0:   bridge window [mem 0xa0000000-0xb40fffff]
[    0.635793] pci 0000:00:01.0:   bridge window [mem 0xb4100000-0xb41fffff 64bit pref]
[    0.635796] pci 0000:00:1d.0: PCI bridge to [bus 06]
[    0.635807] pci 0000:00:1d.0:   bridge window [mem 0xb4400000-0xb44fffff]
[    0.635821] pci 0000:00:1d.5: PCI bridge to [bus 07]
[    0.635823] pci 0000:00:1d.5:   bridge window [io  0x3000-0x3fff]
[    0.635830] pci 0000:00:1d.5:   bridge window [mem 0xb4300000-0xb43fffff]
[    0.635844] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.635845] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.635846] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.635847] pci_bus 0000:00: resource 7 [mem 0x8f800000-0xdfffffff window]
[    0.635848] pci_bus 0000:00: resource 8 [mem 0xfc800000-0xfe7fffff window]
[    0.635849] pci_bus 0000:01: resource 0 [io  0x4000-0x4fff]
[    0.635850] pci_bus 0000:01: resource 1 [mem 0xa0000000-0xb40fffff]
[    0.635850] pci_bus 0000:01: resource 2 [mem 0xb4100000-0xb41fffff 64bit pref]
[    0.635851] pci_bus 0000:06: resource 1 [mem 0xb4400000-0xb44fffff]
[    0.635852] pci_bus 0000:07: resource 0 [io  0x3000-0x3fff]
[    0.635853] pci_bus 0000:07: resource 1 [mem 0xb4300000-0xb43fffff]
[    0.635987] NET: Registered protocol family 2
[    0.636245] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    0.636262] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.636384] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.636467] TCP: Hash tables configured (established 131072 bind 65536)
[    0.636497] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.636525] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.636606] NET: Registered protocol family 1
[    0.636610] NET: Registered protocol family 44
[    0.636620] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.638416] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[    0.638455] pci 0000:01:00.2: D0 power state depends on 0000:01:00.0
[    0.638822] pci 0000:01:00.3: D0 power state depends on 0000:01:00.0
[    0.638974] PCI: CLS 64 bytes, default 64
[    0.639027] Trying to unpack rootfs image as initramfs...
[    1.147364] Freeing initrd memory: 29140K
[    1.147395] DMAR: No ATSR found
[    1.147445] DMAR: dmar0: Using Queued invalidation
[    1.147448] DMAR: dmar1: Using Queued invalidation
[    1.148033] pci 0000:00:00.0: Adding to iommu group 0
[    1.148102] pci 0000:00:01.0: Adding to iommu group 1
[    1.152014] pci 0000:00:02.0: Adding to iommu group 2
[    1.152451] pci 0000:00:02.0: Using iommu direct mapping
[    1.152497] pci 0000:00:04.0: Adding to iommu group 3
[    1.152553] pci 0000:00:08.0: Adding to iommu group 4
[    1.152625] pci 0000:00:12.0: Adding to iommu group 5
[    1.152737] pci 0000:00:14.0: Adding to iommu group 6
[    1.152748] pci 0000:00:14.2: Adding to iommu group 6
[    1.152782] pci 0000:00:14.3: Adding to iommu group 6
[    1.152850] pci 0000:00:15.0: Adding to iommu group 7
[    1.152860] pci 0000:00:15.1: Adding to iommu group 7
[    1.152925] pci 0000:00:16.0: Adding to iommu group 8
[    1.152983] pci 0000:00:17.0: Adding to iommu group 9
[    1.153057] pci 0000:00:1d.0: Adding to iommu group 10
[    1.153121] pci 0000:00:1d.5: Adding to iommu group 11
[    1.153193] pci 0000:00:1e.0: Adding to iommu group 12
[    1.154890] pci 0000:00:1f.0: Adding to iommu group 13
[    1.154902] pci 0000:00:1f.3: Adding to iommu group 13
[    1.154913] pci 0000:00:1f.4: Adding to iommu group 13
[    1.154926] pci 0000:00:1f.5: Adding to iommu group 13
[    1.154933] pci 0000:01:00.0: Adding to iommu group 1
[    1.154939] pci 0000:01:00.1: Adding to iommu group 1
[    1.154944] pci 0000:01:00.2: Adding to iommu group 1
[    1.154948] pci 0000:01:00.3: Adding to iommu group 1
[    1.155029] pci 0000:06:00.0: Adding to iommu group 14
[    1.155098] pci 0000:07:00.0: Adding to iommu group 15
[    1.155404] DMAR: Intel(R) Virtualization Technology for Directed I/O
[    1.157274] platform rtc_cmos: registered platform RTC device (no PNP device found)
[    1.157730] Initialise system trusted keyrings
[    1.157743] Key type blacklist registered
[    1.157776] workingset: timestamp_bits=40 max_order=22 bucket_order=0
[    1.158796] zbud: loaded
[    1.158935] Platform Keyring initialized
[    1.158936] Key type asymmetric registered
[    1.158937] Asymmetric key parser 'x509' registered
[    1.158942] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[    1.158979] io scheduler mq-deadline registered
[    1.163044] pcieport 0000:00:01.0: PME: Signaling with IRQ 122
[    1.163330] pcieport 0000:00:1d.0: PME: Signaling with IRQ 123
[    1.163637] pcieport 0000:00:1d.5: PME: Signaling with IRQ 124
[    1.163775] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    1.163789] efifb: probing for efifb
[    1.163799] efifb: framebuffer at 0x90000000, using 8128k, total 8128k
[    1.163800] efifb: mode is 1920x1080x32, linelength=7680, pages=1
[    1.163800] efifb: scrolling: redraw
[    1.163801] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    1.163866] Console: switching to colour frame buffer device 240x67
[    1.167415] fb0: EFI VGA frame buffer device
[    1.167422] intel_idle: MWAIT substates: 0x11142120
[    1.167423] intel_idle: v0.4.1 model 0x9E
[    1.167992] intel_idle: lapic_timer_reliable_states 0xffffffff
[    1.170089] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.170723] hpet_acpi_add: no address or irqs in _CRS
[    1.170752] Linux agpgart interface v0.103
[    1.170807] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[    1.170807] AMD-Vi: AMD IOMMUv2 functionality not available on this system
[    1.171626] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[    1.171627] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[    1.174519] serio: i8042 KBD port at 0x60,0x64 irq 1
[    1.174680] mousedev: PS/2 mouse device common for all mice
[    1.174720] rtc_cmos rtc_cmos: RTC can wake from S4
[    1.175781] rtc_cmos rtc_cmos: registered as rtc0
[    1.175791] rtc_cmos rtc_cmos: alarms up to one month, y3k, 114 bytes nvram
[    1.175796] intel_pstate: Intel P-state driver initializing
[    1.175812] intel_pstate: Disabling energy efficiency optimization
[    1.176752] intel_pstate: HWP enabled
[    1.177106] ledtrig-cpu: registered to indicate activity on CPUs
[    1.177310] drop_monitor: Initializing network drop monitor service
[    1.177431] NET: Registered protocol family 10
[    1.182319] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[    1.186003] Segment Routing with IPv6
[    1.186014] mip6: Mobile IPv6
[    1.186015] NET: Registered protocol family 17
[    1.186180] mpls_gso: MPLS GSO support
[    1.187137] microcode: sig=0x906ea, pf=0x20, revision=0xc6
[    1.187564] microcode: Microcode Update Driver: v2.2.
[    1.187565] IPI shorthand broadcast: enabled
[    1.187569] sched_clock: Marking stable (1174204728, 12840261)->(1201787889, -14742900)
[    1.187820] registered taskstats version 1
[    1.187821] Loading compiled-in X.509 certificates
[    1.207140] Loaded X.509 cert 'Debian Secure Boot CA: 6ccece7e4c6c0d1f6149f3dd27dfcc5cbb419ea1'
[    1.207148] Loaded X.509 cert 'Debian Secure Boot Signer: 00a7468def'
[    1.207159] zswap: loaded using pool lzo/zbud
[    1.207373] Key type ._fscrypt registered
[    1.207373] Key type .fscrypt registered
[    1.207393] AppArmor: AppArmor sha1 policy hashing enabled
[    1.209375] integrity: Loading X.509 certificate: UEFI:db
[    1.209400] integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
[    1.209400] integrity: Loading X.509 certificate: UEFI:db
[    1.209415] integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
[    1.209415] integrity: Loading X.509 certificate: UEFI:db
[    1.209417] integrity: Problem loading X.509 certificate -65
[    1.209435] Error adding keys to platform keyring UEFI:db
[    1.212269] rtc_cmos rtc_cmos: setting system clock to 2020-06-10T11:39:58 UTC (1591789198)
[    1.212992] Freeing unused kernel image (initmem) memory: 1664K
[    1.251047] Write protecting the kernel read-only data: 16384k
[    1.252090] Freeing unused kernel image (text/rodata gap) memory: 2044K
[    1.252388] Freeing unused kernel image (rodata/data gap) memory: 112K
[    1.259257] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.259258] x86/mm: Checking user space page tables
[    1.263196] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.263197] Run /init as init process
[    1.308670] udevd[182]: starting version 3.2.7
[    1.309410] udevd[183]: starting eudev-3.2.7
[    1.319977] wmi_bus wmi_bus-PNP0C14:00: WQ data block query control method not found
[    1.319978] wmi_bus wmi_bus-PNP0C14:00: WQ data block query control method not found
[    1.319979] wmi_bus wmi_bus-PNP0C14:00: WQ data block query control method not found
[    1.319980] wmi_bus wmi_bus-PNP0C14:00: WQ data block query control method not found
[    1.320093] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
[    1.325984] udevd[185]: Error running install command for nvidia
[    1.326601] hid: raw HID events driver (C) Jiri Kosina
[    1.329040] intel-lpss 0000:00:15.0: enabling device (0000 -> 0002)
[    1.329155] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[    1.329260] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[    1.329366] idma64 idma64.0: Found Intel integrated DMA 64-bit
[    1.331032] cryptd: max_cpu_qlen set to 1000
[    1.332721] SCSI subsystem initialized
[    1.333692] r8169 0000:07:00.0: can't disable ASPM; OS doesn't have ASPM control
[    1.335428] nvme nvme0: pci function 0000:06:00.0
[    1.336122] ACPI: bus type USB registered
[    1.336136] usbcore: registered new interface driver usbfs
[    1.336142] usbcore: registered new interface driver hub
[    1.336166] usbcore: registered new device driver usb
[    1.339188] AVX2 version of gcm_enc/dec engaged.
[    1.339188] AES CTR mode by8 optimization enabled
[    1.344478] intel-lpss 0000:00:15.1: enabling device (0000 -> 0002)
[    1.345126] idma64 idma64.1: Found Intel integrated DMA 64-bit
[    1.345225] libata version 3.00 loaded.
[    1.347358] intel-lpss 0000:00:1e.0: enabling device (0000 -> 0002)
[    1.347406] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.347410] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[    1.348509] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x110 quirks 0x0000000000009810
[    1.348516] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[    1.348680] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
[    1.348682] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.348683] usb usb1: Product: xHCI Host Controller
[    1.348684] usb usb1: Manufacturer: Linux 5.5.0-0.bpo.2-amd64 xhci-hcd
[    1.348685] usb usb1: SerialNumber: 0000:00:14.0
[    1.349102] ahci 0000:00:17.0: version 3.0
[    1.350249] hub 1-0:1.0: USB hub found
[    1.350287] hub 1-0:1.0: 16 ports detected
[    1.350437] idma64 idma64.2: Found Intel integrated DMA 64-bit
[    1.350741] dw-apb-uart.2: ttyS0 at MMIO 0x8f802000 (irq = 20, base_baud = 115200) is a 16550A
[    1.352531] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.352533] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[    1.352535] xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
[    1.352596] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05
[    1.352597] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.352598] usb usb2: Product: xHCI Host Controller
[    1.352599] usb usb2: Manufacturer: Linux 5.5.0-0.bpo.2-amd64 xhci-hcd
[    1.352600] usb usb2: SerialNumber: 0000:00:14.0
[    1.352794] hub 2-0:1.0: USB hub found
[    1.352873] hub 2-0:1.0: 8 ports detected
[    1.353615] xhci_hcd 0000:01:00.2: xHCI Host Controller
[    1.353619] xhci_hcd 0000:01:00.2: new USB bus registered, assigned bus number 3
[    1.354279] xhci_hcd 0000:01:00.2: hcc params 0x0180ff05 hci version 0x110 quirks 0x0000000000000010
[    1.354364] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
[    1.354364] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.354365] usb usb3: Product: xHCI Host Controller
[    1.354365] usb usb3: Manufacturer: Linux 5.5.0-0.bpo.2-amd64 xhci-hcd
[    1.354366] usb usb3: SerialNumber: 0000:01:00.2
[    1.354513] hub 3-0:1.0: USB hub found
[    1.354518] hub 3-0:1.0: 2 ports detected
[    1.355289] xhci_hcd 0000:01:00.2: xHCI Host Controller
[    1.355291] xhci_hcd 0000:01:00.2: new USB bus registered, assigned bus number 4
[    1.355292] xhci_hcd 0000:01:00.2: Host supports USB 3.1 Enhanced SuperSpeed
[    1.355309] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.355318] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05
[    1.355319] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.355319] usb usb4: Product: xHCI Host Controller
[    1.355320] usb usb4: Manufacturer: Linux 5.5.0-0.bpo.2-amd64 xhci-hcd
[    1.355320] usb usb4: SerialNumber: 0000:01:00.2
[    1.355392] hub 4-0:1.0: USB hub found
[    1.355412] hub 4-0:1.0: 4 ports detected
[    1.356127] libphy: r8169: probed
[    1.356270] r8169 0000:07:00.0 eth0: RTL8168h/8111h, f8:75:a4:a2:7b:db, XID 541, IRQ 129
[    1.356271] r8169 0000:07:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[    1.360457] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x10 impl SATA mode
[    1.360459] ahci 0000:00:17.0: flags: 64bit ncq sntf pm clo only pio slum part ems deso sadm sds apst
[    1.360915] scsi host0: ahci
[    1.361057] scsi host1: ahci
[    1.361160] scsi host2: ahci
[    1.361212] scsi host3: ahci
[    1.361262] scsi host4: ahci
[    1.361293] ata1: DUMMY
[    1.361293] ata2: DUMMY
[    1.361294] ata3: DUMMY
[    1.361294] ata4: DUMMY
[    1.361300] ata5: SATA max UDMA/133 abar m2048@0xb452d000 port 0xb452d300 irq 127
[    1.423277] battery: ACPI: Battery Slot [BAT0] (battery present)
[    1.430233] i2c_hid i2c-MSFT0001:01: i2c-MSFT0001:01 supply vdd not found, using dummy regulator
[    1.430244] i2c_hid i2c-MSFT0001:01: i2c-MSFT0001:01 supply vddl not found, using dummy regulator
[    1.499427] input: MSFT0001:01 04F3:309E Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-MSFT0001:01/0018:04F3:309E.0001/input/input1
[    1.499574] input: MSFT0001:01 04F3:309E Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-MSFT0001:01/0018:04F3:309E.0001/input/input3
[    1.499686] hid-generic 0018:04F3:309E.0001: input,hidraw0: I2C HID v1.00 Mouse [MSFT0001:01 04F3:309E] on i2c-MSFT0001:01
[    1.564285] nvme nvme0: missing or invalid SUBNQN field.
[    1.564366] nvme nvme0: Shutdown timeout set to 8 seconds
[    1.635160] nvme nvme0: 12/0/0 default/read/poll queues
[    1.656124]  nvme0n1: p1 p2 < p5 p6 >
[    1.686995] usb 1-1: new full-speed USB device number 2 using xhci_hcd
[    1.839433] usb 1-1: New USB device found, idVendor=1bcf, idProduct=0824, bcdDevice= 5.22
[    1.839437] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.839440] usb 1-1: Product: SmartMouse
[    1.839442] usb 1-1: Manufacturer: SunplusIT
[    1.849812] input: SunplusIT SmartMouse as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/0003:1BCF:0824.0002/input/input4
[    1.907466] hid-generic 0003:1BCF:0824.0002: input,hidraw1: USB HID v1.00 Keyboard [SunplusIT SmartMouse] on usb-0000:00:14.0-1/input0
[    1.909821] input: SunplusIT SmartMouse as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.1/0003:1BCF:0824.0003/input/input5
[    1.910133] input: SunplusIT SmartMouse Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.1/0003:1BCF:0824.0003/input/input6
[    1.963260] usb 2-3: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[    1.967307] hid-generic 0003:1BCF:0824.0003: input,hidraw2: USB HID v1.00 Mouse [SunplusIT SmartMouse] on usb-0000:00:14.0-1/input1
[    1.967398] usbcore: registered new interface driver usbhid
[    1.967400] usbhid: USB HID core driver
[    1.986621] usb 2-3: New USB device found, idVendor=18a5, idProduct=0243, bcdDevice= 1.00
[    1.986626] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    1.986629] usb 2-3: Product: STORE N GO
[    1.986631] usb 2-3: Manufacturer: Verbatim
[    1.986633] usb 2-3: SerialNumber: 0707284228443603
[    1.999233] usb-storage 2-3:1.0: USB Mass Storage device detected
[    1.999875] scsi host5: usb-storage 2-3:1.0
[    2.000030] usbcore: registered new interface driver usb-storage
[    2.003328] usbcore: registered new interface driver uas
[    2.099026] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    2.111103] usb 1-6: new high-speed USB device number 3 using xhci_hcd
[    2.144545] usb 1-6: New USB device found, idVendor=04ca, idProduct=7070, bcdDevice= 0.24
[    2.144549] usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.144552] usb 1-6: Product: Integrated Camera
[    2.144554] usb 1-6: Manufacturer: 8SSC20F27068L1GZ0197DY5
[    2.171029] tsc: Refined TSC clocksource calibration: 2592.005 MHz
[    2.171046] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x255cbb91cef, max_idle_ns: 440795297256 ns
[    2.171123] clocksource: Switched to clocksource tsc
[    2.275000] usb 1-9: new full-speed USB device number 4 using xhci_hcd
[    2.390723] ata5.00: ATA-10: ST2000LM015-2E8174, 0001, max UDMA/133
[    2.390727] ata5.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    2.437837] usb 1-9: New USB device found, idVendor=048d, idProduct=c100, bcdDevice= 0.43
[    2.437845] usb 1-9: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.437847] usb 1-9: Product: ITE Device(8910)
[    2.437850] usb 1-9: Manufacturer: ITE Tech. Inc.
[    2.442136] ata5.00: configured for UDMA/133
[    2.442549] scsi 4:0:0:0: Direct-Access     ATA      ST2000LM015-2E81 0001 PQ: 0 ANSI: 5
[    2.450603] input: ITE Tech. Inc. ITE Device(8910) Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/0003:048D:C100.0004/input/input7
[    2.511344] input: ITE Tech. Inc. ITE Device(8910) Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/0003:048D:C100.0004/input/input8
[    2.511403] input: ITE Tech. Inc. ITE Device(8910) Wireless Radio Control as /devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/0003:048D:C100.0004/input/input9
[    2.511778] hid-generic 0003:048D:C100.0004: input,hiddev0,hidraw3: USB HID v1.10 Keyboard [ITE Tech. Inc. ITE Device(8910)] on usb-0000:00:14.0-9/input0
[    2.545924] sd 4:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[    2.545925] sd 4:0:0:0: [sda] 4096-byte physical blocks
[    2.545930] sd 4:0:0:0: [sda] Write Protect is off
[    2.545931] sd 4:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    2.545939] sd 4:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.638705] usb 1-14: new full-speed USB device number 5 using xhci_hcd
[    2.649800]  sda: sda1
[    2.651250] sd 4:0:0:0: [sda] Attached SCSI disk
[    2.656310] sd 4:0:0:0: Attached scsi generic sg0 type 0
[    2.788324] usb 1-14: New USB device found, idVendor=8087, idProduct=0aaa, bcdDevice= 0.02
[    2.788328] usb 1-14: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.004540] scsi 5:0:0:0: Direct-Access     Verbatim STORE N GO       PMAP PQ: 0 ANSI: 4
[    3.005193] sd 5:0:0:0: Attached scsi generic sg1 type 0
[    3.005919] sd 5:0:0:0: [sdb] 60532992 512-byte logical blocks: (31.0 GB/28.9 GiB)
[    3.006169] sd 5:0:0:0: [sdb] Write Protect is off
[    3.006174] sd 5:0:0:0: [sdb] Mode Sense: 23 00 00 00
[    3.006422] sd 5:0:0:0: [sdb] No Caching mode page found
[    3.006476] sd 5:0:0:0: [sdb] Assuming drive cache: write through
[    3.039291] device-mapper: uevent: version 1.0.3
[    3.039868] device-mapper: ioctl: 4.41.0-ioctl (2019-09-16) initialised: dm-devel@redhat.com
[    3.048962]  sdb: sdb1
[    3.050073] sd 5:0:0:0: [sdb] Attached SCSI removable disk
[   98.913707] NET: Registered protocol family 38
[   99.480585] PM: Image not found (code -22)
[   99.559777] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Opts: (null)
[   99.594417] EXT4-fs (dm-2): mounted filesystem with ordered data mode. Opts: (null)
[   99.668788] Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist.
[   99.943643] udevd[708]: starting version 3.2.7
[   99.955862] udevd[708]: specified group 'kvm' unknown
[   99.979248] udevd[708]: starting eudev-3.2.7
[  100.083114] ACPI: AC Adapter [ADP0] (on-line)
[  100.126094] udevd[732]: Error running install command for nvidia
[  100.191262] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input10
[  100.191276] ACPI: Lid Switch [LID0]
[  100.191328] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input11
[  100.191342] ACPI: Power Button [PWRB]
[  100.193757] input: Ideapad extra buttons as /devices/pci0000:00/0000:00:1f.0/PNP0C09:00/VPC2004:00/input/input12
[  100.244290] mc: Linux media interface: v0.10
[  100.252220] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[  100.252429] cfg80211: Loaded X.509 cert 'benh@debian.org: 577e021cb980e0e820821ba7b54b4961b8b4fadf'
[  100.252575] cfg80211: Loaded X.509 cert 'romain.perier@gmail.com: 3abbc6ec146e09d1b6016ab9d6cf71dd233f0328'
[  100.252714] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[  100.253075] platform regulatory.0: firmware: failed to load regulatory.db (-2)
[  100.253098] firmware_class: See https://wiki.debian.org/Firmware for information about missing firmware
[  100.253123] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[  100.253124] cfg80211: failed to load regulatory.db
[  100.259152] videodev: Linux video capture interface: v2.00
[  100.259791] intel_rapl_common: Found RAPL domain package
[  100.259792] intel_rapl_common: Found RAPL domain dram
[  100.261742] alg: No test for fips(ansi_cprng) (fips_ansi_cprng)
[  100.264166] Intel(R) Wireless WiFi driver for Linux
[  100.264166] Copyright(c) 2003- 2015 Intel Corporation
[  100.264216] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[  100.265779] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-9000-pu-b0-jf-b0-46.ucode (-2)
[  100.265814] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-9000-pu-b0-jf-b0-46.ucode failed with error -2
[  100.265822] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-9000-pu-b0-jf-b0-45.ucode (-2)
[  100.265843] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-9000-pu-b0-jf-b0-45.ucode failed with error -2
[  100.265848] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-9000-pu-b0-jf-b0-44.ucode (-2)
[  100.265875] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-9000-pu-b0-jf-b0-44.ucode failed with error -2
[  100.265882] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-9000-pu-b0-jf-b0-43.ucode (-2)
[  100.265906] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-9000-pu-b0-jf-b0-43.ucode failed with error -2
[  100.265912] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-9000-pu-b0-jf-b0-42.ucode (-2)
[  100.265934] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-9000-pu-b0-jf-b0-42.ucode failed with error -2
[  100.266151] proc_thermal 0000:00:04.0: Creating sysfs group for PROC_THERMAL_PCI
[  100.270069] iwlwifi 0000:00:14.3: firmware: direct-loading firmware iwlwifi-9000-pu-b0-jf-b0-41.ucode
[  100.270495] iwlwifi 0000:00:14.3: loaded firmware version 41.fc1a7aea.0 op_mode iwlmvm
[  100.273041] uvcvideo: Found UVC 1.00 device Integrated Camera (04ca:7070)
[  100.274087] iTCO_vendor_support: vendor-support=0
[  100.276022] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[  100.276131] iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
[  100.276207] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[  100.281357] EFI Variables Facility v0.08 2004-May-17
[  100.291728] uvcvideo 1-6:1.0: Entity type for entity Extension 4 was not initialized!
[  100.291730] uvcvideo 1-6:1.0: Entity type for entity Extension 3 was not initialized!
[  100.291731] uvcvideo 1-6:1.0: Entity type for entity Processing 2 was not initialized!
[  100.291732] uvcvideo 1-6:1.0: Entity type for entity Camera 1 was not initialized!
[  100.291794] input: Integrated Camera: Integrated C as /devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.0/input/input13
[  100.292385] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[  100.292723] snd_hda_intel 0000:01:00.1: Disabling MSI
[  100.292730] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[  100.294565] input: PC Speaker as /devices/platform/pcspkr/input/input14
[  100.310426] r8169 0000:07:00.0: firmware: direct-loading firmware rtl_nic/rtl8168h-2.fw
[  100.310500] Generic FE-GE Realtek PHY r8169-700:00: attached PHY driver [Generic FE-GE Realtek PHY] (mii_bus:phy_addr=r8169-700:00, irq=IGNORE)
[  100.338677] usbcore: registered new interface driver uvcvideo
[  100.338677] USB Video Class driver (1.1.1)
[  100.352804] pstore: Using crash dump compression: deflate
[  100.352816] pstore: Registered efi as persistent store backend
[  100.353140] Bluetooth: Core ver 2.22
[  100.353146] NET: Registered protocol family 31
[  100.353147] Bluetooth: HCI device and connection manager initialized
[  100.353152] Bluetooth: HCI socket layer initialized
[  100.353157] Bluetooth: L2CAP socket layer initialized
[  100.353158] Bluetooth: SCO socket layer initialized
[  100.357334] RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
[  100.357334] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[  100.357335] RAPL PMU: hw unit of domain package 2^-14 Joules
[  100.357335] RAPL PMU: hw unit of domain dram 2^-14 Joules
[  100.357335] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[  100.380395] i915 0000:00:02.0: VT-d active for gfx access
[  100.380397] checking generic (90000000 7f0000) vs hw (b5000000 1000000)
[  100.380397] checking generic (90000000 7f0000) vs hw (90000000 10000000)
[  100.380398] fb0: switching to inteldrmfb from EFI VGA
[  100.380479] Console: switching to colour dummy device 80x25
[  100.380646] i915 0000:00:02.0: vgaarb: deactivate vga console
[  100.383809] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[  100.383810] [drm] Driver supports precise vblank timestamp query.
[  100.383823] usbcore: registered new interface driver btusb
[  100.384234] Bluetooth: hci0: Firmware revision 0.1 build 130 week 44 2018
[  100.384573] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[  100.386196] i915 0000:00:02.0: firmware: direct-loading firmware i915/kbl_dmc_ver1_04.bin
[  100.386265] [drm:csr_load_work_fn [i915]] *ERROR* DMC firmware has wrong CSS header length (1097158924 bytes)
[  100.386271] i915 0000:00:02.0: Failed to load DMC firmware i915/kbl_dmc_ver1_04.bin. Disabling runtime power management.
[  100.386272] i915 0000:00:02.0: DMC firmware homepage: https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/tree/i915
[  100.424867] [drm] Initialized i915 1.6.0 20191101 for 0000:00:02.0 on minor 0
[  100.425502] [Firmware Bug]: ACPI(PEGP) defines _DOD but not _DOS
[  100.425509] ACPI: Video Device [PEGP] (multi-head: yes  rom: yes  post: no)
[  100.425531] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input15
[  100.436470] ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[  100.436580] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input16
[  100.436743] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[  100.437740] fbcon: i915drmfb (fb0) is primary device
[  100.439923] r8169 0000:07:00.0 eth0: Link is Down
[  100.445313] input: MSFT0001:01 04F3:309E Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-MSFT0001:01/0018:04F3:309E.0001/input/input17
[  100.445572] input: MSFT0001:01 04F3:309E Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-MSFT0001:01/0018:04F3:309E.0001/input/input19
[  100.445729] hid-multitouch 0018:04F3:309E.0001: input,hidraw0: I2C HID v1.00 Mouse [MSFT0001:01 04F3:309E] on i2c-MSFT0001:01
[  100.518681] iwlwifi 0000:00:14.3: Detected Intel(R) Dual Band Wireless AC 9560, REV=0x318
[  100.532585] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC257: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[  100.532586] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[  100.532586] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[  100.532587] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[  100.532587] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[  100.532588] snd_hda_codec_realtek hdaudioC0D0:      Mic=0x19
[  100.532588] snd_hda_codec_realtek hdaudioC0D0:      Internal Mic=0x12
[  100.575840] iwlwifi 0000:00:14.3: base HW address: 54:8d:5a:12:93:82
[  100.639015] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1f.3/sound/card0/input20
[  100.639040] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input21
[  100.639062] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input22
[  100.639083] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input23
[  100.639106] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input24
[  100.639126] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input25
[  100.639147] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input26
[  100.639168] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input27
[  100.644657] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[  100.644797] thermal thermal_zone9: failed to read out thermal zone (-61)
[  100.803235] intel_rapl_common: Found RAPL domain package
[  100.803236] intel_rapl_common: Found RAPL domain core
[  100.803236] intel_rapl_common: Found RAPL domain uncore
[  100.803237] intel_rapl_common: Found RAPL domain dram
[  101.707789] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input28
[  101.707936] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input29
[  101.708038] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input30
[  101.708170] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input31
[  101.708280] input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input32
[  101.708387] input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input33
[  101.732760] Console: switching to colour frame buffer device 240x67
[  101.743597] i915 0000:00:02.0: fb0: i915drmfb frame buffer device
[  102.558763] EXT4-fs (dm-1): re-mounted. Opts: errors=remount-ro
[  104.098789] r8169 0000:07:00.0 eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[  104.098803] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[  118.899641] lp: driver loaded but no devices found
[  118.917577] ppdev: user-space parallel port driver
[  119.769087] EXT4-fs (dm-2): re-mounted. Opts: (null)
[  119.774059] EXT4-fs (nvme0n1p5): mounted filesystem with ordered data mode. Opts: (null)
[  119.774066] ext4 filesystem being mounted at /boot supports timestamps until 2038 (0x7fffffff)
[  119.874338] EXT4-fs (dm-8): mounted filesystem with ordered data mode. Opts: (null)
[  119.910267] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null)
[  119.914276] EXT4-fs (dm-4): mounted filesystem with ordered data mode. Opts: (null)
[  119.918435] EXT4-fs (dm-3): mounted filesystem with ordered data mode. Opts: (null)
[  120.014894] Adding 15622140k swap on /dev/mapper/vgs-swap.  Priority:-2 extents:1 across:15622140k SSFS
[  120.216743] audit: type=1400 audit(1591789317.744:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-senddoc" pid=1901 comm="apparmor_parser"
[  120.216821] audit: type=1400 audit(1591789317.744:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-xpdfimport" pid=1902 comm="apparmor_parser"
[  120.217271] audit: type=1400 audit(1591789317.744:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-oopslash" pid=1905 comm="apparmor_parser"
[  120.217397] audit: type=1400 audit(1591789317.744:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=1899 comm="apparmor_parser"
[  120.217398] audit: type=1400 audit(1591789317.744:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=1899 comm="apparmor_parser"
[  120.217399] audit: type=1400 audit(1591789317.744:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=1899 comm="apparmor_parser"
[  120.217503] audit: type=1400 audit(1591789317.744:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=1900 comm="apparmor_parser"
[  120.217503] audit: type=1400 audit(1591789317.744:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=1900 comm="apparmor_parser"
[  120.218337] audit: type=1400 audit(1591789317.744:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cups-browsed" pid=1904 comm="apparmor_parser"
[  120.221352] audit: type=1400 audit(1591789317.748:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/cups/backend/cups-pdf" pid=1903 comm="apparmor_parser"
[  121.080361] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[  121.080362] Bluetooth: BNEP filters: protocol multicast
[  121.080364] Bluetooth: BNEP socket layer initialized
[  121.144844] elogind-daemon[2703]: New seat seat0.
[  121.373047] broken atomic modeset userspace detected, disabling atomic
[  122.400784] NET: Registered protocol family 5
[  122.578989] NET: Unregistered protocol family 5
[  122.642713] NET: Registered protocol family 5
[  122.762702] NET: Unregistered protocol family 5
[  122.814975] NET: Registered protocol family 5
[  122.934877] NET: Unregistered protocol family 5
[  165.806522] elogind-daemon[2703]: New session 1 of user hamsa.
Checking if daemon nvidia-persistenced is up
service –status-all
[ ? ]  alsa-utils
 [ - ]  anacron
 [ + ]  apparmor
 [ + ]  avahi-daemon
 [ + ]  bluetooth
 [ - ]  bootlogd
 [ - ]  bootlogs
 [ - ]  bootmisc.sh
 [ + ]  brightness
 [ - ]  checkfs.sh
 [ - ]  checkroot-bootclean.sh
 [ - ]  checkroot.sh
 [ - ]  console-setup.sh
 [ + ]  cron
 [ ? ]  cryptdisks
 [ ? ]  cryptdisks-early
 [ + ]  cups
 [ + ]  cups-browsed
 [ + ]  dbus
 [ + ]  elogind
 [ + ]  eudev
 [ - ]  hddtemp
 [ - ]  hostname.sh
 [ ? ]  hwclock.sh
 [ - ]  keyboard-setup.sh
 [ - ]  killprocs
 [ ? ]  kmod
 [ - ]  lm-sensors
 [ - ]  lvm2
 [ - ]  lvm2-lvmpolld
 [ - ]  mountall-bootclean.sh
 [ - ]  mountall.sh
 [ - ]  mountdevsubfs.sh
 [ - ]  mountkernfs.sh
 [ - ]  mountnfs-bootclean.sh
 [ - ]  mountnfs.sh
 [ ? ]  networking
 [ ? ]  nvidia-persistenced
 [ - ]  procps
 [ - ]  rc.local
 [ - ]  rmnologin
 [ + ]  rsyslog
 [ + ]  saned
 [ - ]  sendsigs
 [ + ]  slim
 [ ? ]  speech-dispatcher
 [ + ]  ssh
 [ - ]  stop-bootlogd
 [ - ]  stop-bootlogd-single
 [ - ]  sudo
 [ - ]  umountfs
 [ - ]  umountnfs.sh
 [ - ]  umountroot
 [ - ]  urandom
 [ + ]  wicd
 [ - ]  x11-common
trying to start nvidia-persistenced (sysvinit):
/etc/init.d/nvidia-persistenced start
Starting NVIDIA Persistence Daemon
nvidia-persistenced failed to initialize. Check syslog for more details.
cat /var/log/syslog | grep nvidia-persistenced
Jun 10 20:05:30 deva nvidia-persistenced: Started (6680)
Jun 10 20:05:30 deva nvidia-persistenced: Failed to query NVIDIA devices. Please ensure that the NVIDIA device files (/dev/nvidia*) exist, and that user 112 has read and write permissions for those files.
Jun 10 20:05:30 deva nvidia-persistenced: Shutdown (6680)
User-ID is used by User nvpd – the „Nvidia“-User
awk -F":" '{ print "UserID " $3" is used by: " $1}' /etc/passwd | grep 112
UserID 112 is used by: nvpd
there are no Nvidia-Device files in /dev
ls /dev/nvidia*
ls: access to '/dev/nvidia*' not possible: file or directory not found
However, both GPUs are correctly connected to the instances
lshw -numeric -C display
*-display UNCLAIMED
       description: VGA compatible controller
       product: NVIDIA Corporation [10DE:2191]
       vendor: NVIDIA Corporation [10DE]
       physical id: 0
       bus info: pci@0000:01:00.0
       version: a1
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress vga_controller bus_master cap_list
       configuration: latency=0
       resources: memory:b3000000-b3ffffff memory:a0000000-afffffff memory:b0000000-b1ffffff ioport:4000(size=128) memory:b2000000-b207ffff
  *-display
       product: Intel Corporation [8086:3E9B]
       vendor: Intel Corporation [8086]
       physical id: 2
       bus info: pci@0000:00:02.0
       version: 00
       width: 64 bits
       clock: 33MHz
       capabilities: pciexpress msi pm vga_controller bus_master cap_list rom
       configuration: driver=i915 latency=0
       resources: irq:157 memory:b5000000-b5ffffff memory:90000000-9fffffff ioport:5000(size=64) memory:c0000-dffff
Both GPUs are registerd
lspci | grep VGA
00:02.0 VGA compatible controller: Intel Corporation Device 3e9b
01:00.0 VGA compatible controller: NVIDIA Corporation Device 2191 (rev a1)
Intel Dev. 3E9b → Intel Graphics UHD 630 (Mobile)
Nvidia Dev. 2191 → GeForce GTX 1660 Ti Mobile
At this moment it came to my mind to use the very latest releases from chimaera. Change of sources.list:
deb http://deb.devuan.org/merged chimaera main contrib non-free
deb http://deb.devuan.org/merged chimaera-updates main contrib non-free
Performed apt-get update
Performed installation of linux-image-5.6.0.2-amd64 (signed) with aptitude which upgrades the Nvidia drivers to rel. 440.82. (loads were upgraded)
Performed apt-get autoremove –purge and apt-get autoclean
After reboot system came up and login to X is possible but display is still flickering.
last status
dmesg
[    0.000000] Linux version 5.6.0-2-amd64 (debian-kernel@lists.debian.org) (gcc version 9.3.0 (Debian 9.3.0-13)) #1 SMP Debian 5.6.14-1 (2020-05-23)
[    0.000000] Command line: BOOT_IMAGE=/vmlinuz-5.6.0-2-amd64 root=/dev/mapper/vgs-root ro quiet
[    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[    0.000000] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.000000] x86/fpu: xstate_offset[3]:  832, xstate_sizes[3]:   64
[    0.000000] x86/fpu: xstate_offset[4]:  896, xstate_sizes[4]:   64
[    0.000000] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000073d86fff] usable
[    0.000000] BIOS-e820: [mem 0x0000000073d87000-0x0000000074686fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000074687000-0x000000008a89dfff] usable
[    0.000000] BIOS-e820: [mem 0x000000008a89e000-0x000000008aa9dfff] type 20
[    0.000000] BIOS-e820: [mem 0x000000008aa9e000-0x000000008b49dfff] reserved
[    0.000000] BIOS-e820: [mem 0x000000008b49e000-0x000000008bb8dfff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x000000008bb8e000-0x000000008bc0dfff] ACPI data
[    0.000000] BIOS-e820: [mem 0x000000008bc0e000-0x000000008bc0efff] usable
[    0.000000] BIOS-e820: [mem 0x000000008bc0f000-0x000000008f7fffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed10000-0x00000000fed19fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed84000-0x00000000fed84fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ff600000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000046e7fffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] efi: EFI v2.60 by INSYDE Corp.
[    0.000000] efi:  ACPI=0x8bc0d000  ACPI 2.0=0x8bc0d014  TPMFinalLog=0x8b475000  SMBIOS=0x8ac50000  SMBIOS 3.0=0x8ac4e000  ESRT=0x7af67718  MEMATTR=0x7acd0018
[    0.000000] secureboot: Secure boot could not be determined (mode 0)
[    0.000000] SMBIOS 3.0.1 present.
[    0.000000] DMI: LENOVO 81Q4/LNVNB161216, BIOS BHCN36WW 02/10/2020
[    0.000000] tsc: Detected 2600.000 MHz processor
[    0.000009] tsc: Detected 2599.992 MHz TSC
[    0.000009] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000011] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000017] last_pfn = 0x46e800 max_arch_pfn = 0x400000000
[    0.000020] MTRR default type: write-back
[    0.000021] MTRR fixed ranges enabled:
[    0.000022]   00000-9FFFF write-back
[    0.000023]   A0000-BFFFF uncachable
[    0.000024]   C0000-FFFFF write-protect
[    0.000024] MTRR variable ranges enabled:
[    0.000025]   0 base 00C0000000 mask 7FC0000000 uncachable
[    0.000026]   1 base 00A0000000 mask 7FE0000000 uncachable
[    0.000027]   2 base 0090000000 mask 7FF0000000 uncachable
[    0.000028]   3 base 008E000000 mask 7FFE000000 uncachable
[    0.000028]   4 base 008D000000 mask 7FFF000000 uncachable
[    0.000029]   5 base 2000000000 mask 6000000000 uncachable
[    0.000030]   6 base 1000000000 mask 7000000000 uncachable
[    0.000030]   7 base 0800000000 mask 7800000000 uncachable
[    0.000031]   8 base 4000000000 mask 4000000000 uncachable
[    0.000032]   9 disabled
[    0.000491] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.000646] last_pfn = 0x8bc0f max_arch_pfn = 0x400000000
[    0.008883] esrt: Reserving ESRT space from 0x000000007af67718 to 0x000000007af677c8.
[    0.008887] e820: update [mem 0x7af67000-0x7af67fff] usable ==> reserved
[    0.008899] Using GB pages for direct mapping
[    0.008900] BRK [0x10ce01000, 0x10ce01fff] PGTABLE
[    0.008901] BRK [0x10ce02000, 0x10ce02fff] PGTABLE
[    0.008902] BRK [0x10ce03000, 0x10ce03fff] PGTABLE
[    0.008933] BRK [0x10ce04000, 0x10ce04fff] PGTABLE
[    0.008935] BRK [0x10ce05000, 0x10ce05fff] PGTABLE
[    0.009063] BRK [0x10ce06000, 0x10ce06fff] PGTABLE
[    0.009092] BRK [0x10ce07000, 0x10ce07fff] PGTABLE
[    0.009124] BRK [0x10ce08000, 0x10ce08fff] PGTABLE
[    0.009150] BRK [0x10ce09000, 0x10ce09fff] PGTABLE
[    0.009197] BRK [0x10ce0a000, 0x10ce0afff] PGTABLE
[    0.009264] BRK [0x10ce0b000, 0x10ce0bfff] PGTABLE
[    0.009358] RAMDISK: [mem 0x34721000-0x36387fff]
[    0.009366] ACPI: Early table checksum verification disabled
[    0.009367] ACPI: RSDP 0x000000008BC0D014 000024 (v02 LENOVO)
[    0.009371] ACPI: XSDT 0x000000008BBEE188 000104 (v01 LENOVO CB-01    00000001      01000013)
[    0.009379] ACPI: FACP 0x000000008BBF1000 00010C (v05 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009383] ACPI: DSDT 0x000000008BBBD000 02FE66 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009385] ACPI: FACS 0x000000008BB0D000 000040
[    0.009388] ACPI: UEFI 0x000000008BC0C000 000236 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009390] ACPI: SSDT 0x000000008BC0A000 001B1C (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009392] ACPI: SSDT 0x000000008BC06000 0031D0 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009394] ACPI: UEFI 0x000000008BC05000 000042 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009397] ACPI: SSDT 0x000000008BC04000 00045A (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009399] ACPI: SSDT 0x000000008BC03000 000046 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009401] ACPI: TPM2 0x000000008BC02000 000034 (v03 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009403] ACPI: POAT 0x000000008BC01000 000055 (v03 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009406] ACPI: SSDT 0x000000008BBFC000 0044B6 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009408] ACPI: LPIT 0x000000008BBFB000 000094 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009410] ACPI: WSMT 0x000000008BBFA000 000028 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009412] ACPI: SSDT 0x000000008BBF9000 000C2F (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009415] ACPI: DBGP 0x000000008BBF8000 000034 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009417] ACPI: DBG2 0x000000008BBF7000 000061 (v00 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009419] ACPI: SSDT 0x000000008BBF6000 000896 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009421] ACPI: SSDT 0x000000008BBF3000 002F89 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009424] ACPI: ASF! 0x000000008BBF2000 0000A5 (v32 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009426] ACPI: HPET 0x000000008BBF0000 000038 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009428] ACPI: APIC 0x000000008BBEF000 00012C (v03 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009430] ACPI: MCFG 0x000000008BBED000 00003C (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009433] ACPI: SSDT 0x000000008BBBA000 002BBF (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009435] ACPI: DMAR 0x000000008BBB9000 0000A8 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009437] ACPI: SSDT 0x000000008BBB3000 005178 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009440] ACPI: SSDT 0x000000008BBB2000 00004C (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009442] ACPI: SSDT 0x000000008BBB1000 000123 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009444] ACPI: FPDT 0x000000008BBB0000 000044 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009446] ACPI: BGRT 0x000000008BBAF000 000038 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009452] ACPI: Local APIC address 0xfee00000
[    0.009747] No NUMA configuration found
[    0.009748] Faking a node at [mem 0x0000000000000000-0x000000046e7fffff]
[    0.009751] NODE_DATA(0) allocated [mem 0x46e7fb000-0x46e7fffff]
[    0.009779] Zone ranges:
[    0.009779]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.009780]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.009781]   Normal   [mem 0x0000000100000000-0x000000046e7fffff]
[    0.009782]   Device   empty
[    0.009782] Movable zone start for each node
[    0.009783] Early memory node ranges
[    0.009784]   node   0: [mem 0x0000000000001000-0x000000000009efff]
[    0.009785]   node   0: [mem 0x0000000000100000-0x0000000073d86fff]
[    0.009785]   node   0: [mem 0x0000000074687000-0x000000008a89dfff]
[    0.009786]   node   0: [mem 0x000000008bc0e000-0x000000008bc0efff]
[    0.009787]   node   0: [mem 0x0000000100000000-0x000000046e7fffff]
[    0.010053] Zeroed struct page in unavailable ranges: 30915 pages
[    0.010054] Initmem setup node 0 [mem 0x0000000000001000-0x000000046e7fffff]
[    0.010056] On node 0 totalpages: 4163389
[    0.010056]   DMA zone: 64 pages used for memmap
[    0.010057]   DMA zone: 23 pages reserved
[    0.010058]   DMA zone: 3998 pages, LIFO batch:0
[    0.010119]   DMA32 zone: 8767 pages used for memmap
[    0.010120]   DMA32 zone: 561055 pages, LIFO batch:63
[    0.018447]   Normal zone: 56224 pages used for memmap
[    0.018447]   Normal zone: 3598336 pages, LIFO batch:63
[    0.018942] x86/hpet: Will disable the HPET for this platform because it's not reliable
[    0.018978] Reserving Intel graphics memory at [mem 0x8d800000-0x8f7fffff]
[    0.019527] ACPI: PM-Timer IO Port: 0x1808
[    0.019529] ACPI: Local APIC address 0xfee00000
[    0.019536] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.019537] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[    0.019537] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[    0.019538] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[    0.019538] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[    0.019539] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[    0.019539] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[    0.019540] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[    0.019540] ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
[    0.019541] ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
[    0.019541] ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
[    0.019542] ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
[    0.019542] ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
[    0.019543] ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
[    0.019543] ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
[    0.019544] ACPI: LAPIC_NMI (acpi_id[0x10] high edge lint[0x1])
[    0.019605] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[    0.019607] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.019608] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.019609] ACPI: IRQ0 used by override.
[    0.019610] ACPI: IRQ9 used by override.
[    0.019611] Using ACPI (MADT) for SMP configuration information
[    0.019613] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[    0.019618] e820: update [mem 0x7ad64000-0x7ada4fff] usable ==> reserved
[    0.019626] smpboot: Allowing 12 CPUs, 0 hotplug CPUs
[    0.019641] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.019642] PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x000fffff]
[    0.019643] PM: hibernation: Registered nosave memory: [mem 0x73d87000-0x74686fff]
[    0.019645] PM: hibernation: Registered nosave memory: [mem 0x7ad64000-0x7ada4fff]
[    0.019646] PM: hibernation: Registered nosave memory: [mem 0x7af67000-0x7af67fff]
[    0.019647] PM: hibernation: Registered nosave memory: [mem 0x8a89e000-0x8aa9dfff]
[    0.019648] PM: hibernation: Registered nosave memory: [mem 0x8aa9e000-0x8b49dfff]
[    0.019648] PM: hibernation: Registered nosave memory: [mem 0x8b49e000-0x8bb8dfff]
[    0.019648] PM: hibernation: Registered nosave memory: [mem 0x8bb8e000-0x8bc0dfff]
[    0.019650] PM: hibernation: Registered nosave memory: [mem 0x8bc0f000-0x8f7fffff]
[    0.019650] PM: hibernation: Registered nosave memory: [mem 0x8f800000-0xdfffffff]
[    0.019651] PM: hibernation: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[    0.019651] PM: hibernation: Registered nosave memory: [mem 0xf0000000-0xfdffffff]
[    0.019652] PM: hibernation: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
[    0.019652] PM: hibernation: Registered nosave memory: [mem 0xfe011000-0xfed0ffff]
[    0.019653] PM: hibernation: Registered nosave memory: [mem 0xfed10000-0xfed19fff]
[    0.019653] PM: hibernation: Registered nosave memory: [mem 0xfed1a000-0xfed83fff]
[    0.019654] PM: hibernation: Registered nosave memory: [mem 0xfed84000-0xfed84fff]
[    0.019654] PM: hibernation: Registered nosave memory: [mem 0xfed85000-0xfedfffff]
[    0.019655] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[    0.019655] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xff5fffff]
[    0.019655] PM: hibernation: Registered nosave memory: [mem 0xff600000-0xffffffff]
[    0.019657] [mem 0x8f800000-0xdfffffff] available for PCI devices
[    0.019658] Booting paravirtualized kernel on bare hardware
[    0.019660] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[    0.023344] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:12 nr_node_ids:1
[    0.023661] percpu: Embedded 55 pages/cpu s188120 r8192 d28968 u262144
[    0.023668] pcpu-alloc: s188120 r8192 d28968 u262144 alloc=1*2097152
[    0.023668] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 -- -- -- --
[    0.023690] Built 1 zonelists, mobility grouping on.  Total pages: 4098311
[    0.023690] Policy zone: Normal
[    0.023691] Kernel command line: BOOT_IMAGE=/vmlinuz-5.6.0-2-amd64 root=/dev/mapper/vgs-root ro quiet
[    0.024618] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.025064] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.025176] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.038139] Memory: 2237720K/16653556K available (10243K kernel code, 1285K rwdata, 3976K rodata, 1612K init, 1976K bss, 468040K reserved, 0K cma-reserved)
[    0.038146] random: get_random_u64 called from __kmem_cache_create+0x3e/0x530 with crng_init=0
[    0.038254] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[    0.038264] Kernel/User page tables isolation: enabled
[    0.038276] ftrace: allocating 34646 entries in 136 pages
[    0.051290] ftrace: allocated 136 pages with 2 groups
[    0.051371] rcu: Hierarchical RCU implementation.
[    0.051372] rcu: 	RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=12.
[    0.051373] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.051373] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[    0.054016] NR_IRQS: 33024, nr_irqs: 2152, preallocated irqs: 16
[    0.054557] random: crng done (trusting CPU's manufacturer)
[    0.054579] Console: colour dummy device 80x25
[    0.054583] printk: console [tty0] enabled
[    0.054598] ACPI: Core revision 20200110
[    0.054875] APIC: Switch to symmetric I/O mode setup
[    0.054876] DMAR: Host address width 39
[    0.054878] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[    0.054882] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 19e2ff0505e
[    0.054883] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[    0.054887] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[    0.054888] DMAR: RMRR base: 0x0000008b47d000 end: 0x0000008b49cfff
[    0.054891] DMAR: RMRR base: 0x0000008d000000 end: 0x0000008f7fffff
[    0.054893] DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 1
[    0.054893] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[    0.054894] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[    0.058024] DMAR-IR: Enabled IRQ remapping in x2apic mode
[    0.058025] x2apic enabled
[    0.058056] Switched APIC routing to cluster x2apic.
[    0.067068] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x257a34a6eea, max_idle_ns: 440795264358 ns
[    0.067073] Calibrating delay loop (skipped), value calculated using timer frequency.. 5199.98 BogoMIPS (lpj=10399968)
[    0.067075] pid_max: default: 32768 minimum: 301
[    0.070853] LSM: Security Framework initializing
[    0.070859] Yama: disabled by default; enable with sysctl kernel.yama.*
[    0.070880] AppArmor: AppArmor initialized
[    0.070881] TOMOYO Linux initialized
[    0.070916] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.070937] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.071070] mce: CPU0: Thermal monitoring enabled (TM1)
[    0.071070] process: using mwait in idle threads
[    0.071070] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[    0.071070] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[    0.071070] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.071070] Spectre V2 : Mitigation: Full generic retpoline
[    0.071070] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.071070] Spectre V2 : Enabling Restricted Speculation for firmware calls
[    0.071070] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.071070] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
[    0.071070] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[    0.071070] MDS: Mitigation: Clear CPU buffers
[    0.071070] Freeing SMP alternatives memory: 32K
[    0.071070] TSC deadline timer enabled
[    0.071070] smpboot: CPU0: Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz (family: 0x6, model: 0x9e, stepping: 0xa)
[    0.071070] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[    0.071070] ... version:                4
[    0.071070] ... bit width:              48
[    0.071070] ... generic registers:      4
[    0.071070] ... value mask:             0000ffffffffffff
[    0.071070] ... max period:             00007fffffffffff
[    0.071070] ... fixed-purpose events:   3
[    0.071070] ... event mask:             000000070000000f
[    0.071070] rcu: Hierarchical SRCU implementation.
[    0.071070] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.071070] smp: Bringing up secondary CPUs ...
[    0.071070] x86: Booting SMP configuration:
[    0.071070] .... node  #0, CPUs:        #1  #2  #3  #4  #5  #6
[    0.071869] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[    0.071869]   #7  #8  #9 #10 #11
[    0.075702] smp: Brought up 1 node, 12 CPUs
[    0.075702] smpboot: Max logical packages: 1
[    0.075702] smpboot: Total of 12 processors activated (62399.80 BogoMIPS)
[    0.119075] node 0 initialised, 3486949 pages in 40ms
[    0.119377] devtmpfs: initialized
[    0.119377] x86/mm: Memory block size: 128MB
[    0.120569] PM: Registering ACPI NVS region [mem 0x8b49e000-0x8bb8dfff] (7274496 bytes)
[    0.120569] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.120569] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[    0.120569] pinctrl core: initialized pinctrl subsystem
[    0.120569] thermal_sys: Registered thermal governor 'fair_share'
[    0.120569] thermal_sys: Registered thermal governor 'bang_bang'
[    0.120569] thermal_sys: Registered thermal governor 'step_wise'
[    0.120569] thermal_sys: Registered thermal governor 'user_space'
[    0.120569] NET: Registered protocol family 16
[    0.120569] audit: initializing netlink subsys (disabled)
[    0.120569] audit: type=2000 audit(1591822462.052:1): state=initialized audit_enabled=0 res=1
[    0.120569] cpuidle: using governor ladder
[    0.120569] cpuidle: using governor menu
[    0.120569] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.120569] ACPI: bus type PCI registered
[    0.120569] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.120569] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[    0.120569] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[    0.120569] PCI: Using configuration type 1 for base access
[    0.120569] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.123869] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.123869] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.255372] ACPI: Added _OSI(Module Device)
[    0.255372] ACPI: Added _OSI(Processor Device)
[    0.255372] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.255372] ACPI: Added _OSI(Processor Aggregator Device)
[    0.255372] ACPI: Added _OSI(Linux-Dell-Video)
[    0.255372] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.255372] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[    0.301397] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.TPLD], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.301405] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.301408] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.301451] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS01._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.301456] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.301458] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.301460] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS01._PLD], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.301464] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.301466] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.302991] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS02._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.302995] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.302998] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.302999] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS02._PLD], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.303003] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.303005] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.304526] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS03._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.304530] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.304533] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.304534] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS03._PLD], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.304538] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.304541] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.306053] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS04._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.306058] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.306061] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.306062] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS04._PLD], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.306066] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.306068] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.307588] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS05._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.307593] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.307596] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.309112] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS06._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.309116] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.309119] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.309120] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS06._PLD], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.309124] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.309127] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.310640] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS07._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.310645] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.310647] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.312169] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS08._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.312174] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.312177] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.313692] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS09._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.313697] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.313699] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.313701] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS09._PLD], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.313705] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.313707] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.315224] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS10._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.315229] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.315232] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.316748] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS11._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.316752] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.316755] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.318268] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS12._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.318272] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.318275] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.319795] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS13._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.319799] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.319802] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.321316] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS14._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.321321] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.321323] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.321324] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS14._PLD], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.321328] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.321331] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.322826] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.USR1], AE_NOT_FOUND (20200110/dswload2-162)
[    0.322831] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20200110/psobject-220)
[    0.322833] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0010)
[    0.322836] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.USR2], AE_NOT_FOUND (20200110/dswload2-162)
[    0.322840] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20200110/psobject-220)
[    0.322842] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0010)
[    0.322865] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS01._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.322869] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.322872] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.322873] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS01._PLD], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.322877] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.322880] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.322908] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS02._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.322912] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.322914] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.322916] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS02._PLD], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.322920] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.322922] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.322950] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS03._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.322954] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.322957] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.322958] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS03._PLD], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.322962] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.322964] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.322992] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS04._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.322996] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.322999] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.323000] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS04._PLD], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.323004] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.323006] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.323034] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS05._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.323038] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.323040] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.323064] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS06._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.323069] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.323072] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.323097] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS07._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.323101] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.323104] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.323126] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS08._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.323130] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.323133] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.323155] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS09._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.323159] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.323162] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.323184] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS10._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.323188] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.323191] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.323905] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.I2C2.TPD0], AE_NOT_FOUND (20200110/dswload2-162)
[    0.323910] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20200110/psobject-220)
[    0.323913] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0010)
[    0.323933] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.I2C3.TPL1], AE_NOT_FOUND (20200110/dswload2-162)
[    0.323937] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20200110/psobject-220)
[    0.323939] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0010)
[    0.326715] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.PEG0.PEGP._ON], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.326721] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.326724] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.326726] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.PEG0.PEGP._OFF], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.326730] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.326733] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.326734] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.PEG0.PEGP.SGPO], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.326738] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.326741] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.326907] ACPI: 13 ACPI AML tables successfully acquired and loaded
[    0.335932] ACPI: Dynamic OEM Table Load:
[    0.335945] ACPI: SSDT 0xFFFF94B21E520400 0000F4 (v02 PmRef  Cpu0Psd  00003000 INTL 20160422)
[    0.337133] ACPI: \_SB_.PR00: _OSC native thermal LVT Acked
[    0.337878] ACPI: Dynamic OEM Table Load:
[    0.337885] ACPI: SSDT 0xFFFF94B21E50E000 000400 (v02 PmRef  Cpu0Cst  00003001 INTL 20160422)
[    0.339195] ACPI: Dynamic OEM Table Load:
[    0.339201] ACPI: SSDT 0xFFFF94AECCFEF800 000581 (v02 PmRef  Cpu0Ist  00003000 INTL 20160422)
[    0.340552] ACPI: Dynamic OEM Table Load:
[    0.340557] ACPI: SSDT 0xFFFF94B21C4C1400 00011B (v02 PmRef  Cpu0Hwp  00003000 INTL 20160422)
[    0.341773] ACPI: Dynamic OEM Table Load:
[    0.341780] ACPI: SSDT 0xFFFF94AECCFEC800 000724 (v02 PmRef  HwpLvt   00003000 INTL 20160422)
[    0.343252] ACPI: Dynamic OEM Table Load:
[    0.343259] ACPI: SSDT 0xFFFF94AECCFEC000 0005FC (v02 PmRef  ApIst    00003000 INTL 20160422)
[    0.344608] ACPI: Dynamic OEM Table Load:
[    0.344613] ACPI: SSDT 0xFFFF94B21E50A400 000317 (v02 PmRef  ApHwp    00003000 INTL 20160422)
[    0.345987] ACPI: Dynamic OEM Table Load:
[    0.345993] ACPI: SSDT 0xFFFF94AEC7262000 000AB0 (v02 PmRef  ApPsd    00003000 INTL 20160422)
[    0.347757] ACPI: Dynamic OEM Table Load:
[    0.347763] ACPI: SSDT 0xFFFF94B21E50F800 00030A (v02 PmRef  ApCst    00003000 INTL 20160422)
[    0.352769] ACPI: EC: EC started
[    0.352770] ACPI: EC: interrupt blocked
[    0.367223] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.367225] ACPI: \_SB_.PCI0.LPCB.EC0_: Boot DSDT EC used to handle transactions
[    0.367225] ACPI: Interpreter enabled
[    0.367277] ACPI: (supports S0 S3 S4 S5)
[    0.367278] ACPI: Using IOAPIC for interrupt routing
[    0.367316] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.367782] ACPI: Enabled 10 GPEs in block 00 to 7F
[    0.368615] ACPI: Power Resource [PG00] (on)
[    0.372087] ACPI: Power Resource [PUBS] (on)
[    0.372864] ACPI: Power Resource [BTPR] (on)
[    0.374206] ACPI: Power Resource [USBC] (on)
[    0.374370] ACPI: Power Resource [PAUD] (on)
[    0.377817] ACPI: Power Resource [PXP] (off)
[    0.383600] ACPI: Power Resource [PXP] (off)
[    0.385050] ACPI: Power Resource [V0PR] (on)
[    0.385204] ACPI: Power Resource [V1PR] (on)
[    0.385353] ACPI: Power Resource [V2PR] (on)
[    0.387145] ACPI: Power Resource [PXTC] (on)
[    0.387539] ACPI: Power Resource [PXTC] (off)
[    0.389167] ACPI: Power Resource [WRST] (on)
[    0.390967] ACPI: Power Resource [PIN] (off)
[    0.391303] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[    0.391308] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI HPX-Type3]
[    0.394635] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR]
[    0.394636] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[    0.397076] PCI host bridge to bus 0000:00
[    0.397078] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.397079] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.397080] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.397081] pci_bus 0000:00: root bus resource [mem 0x8f800000-0xdfffffff window]
[    0.397082] pci_bus 0000:00: root bus resource [mem 0xfc800000-0xfe7fffff window]
[    0.397084] pci_bus 0000:00: root bus resource [bus 00-fe]
[    0.397092] pci 0000:00:00.0: [8086:3ec4] type 00 class 0x060000
[    0.398016] pci 0000:00:01.0: [8086:1901] type 01 class 0x060400
[    0.398061] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[    0.399039] pci 0000:00:02.0: [8086:3e9b] type 00 class 0x030000
[    0.399049] pci 0000:00:02.0: reg 0x10: [mem 0xb5000000-0xb5ffffff 64bit]
[    0.399054] pci 0000:00:02.0: reg 0x18: [mem 0x90000000-0x9fffffff 64bit pref]
[    0.399058] pci 0000:00:02.0: reg 0x20: [io  0x5000-0x503f]
[    0.399070] pci 0000:00:02.0: BAR 2: assigned to efifb
[    0.400006] pci 0000:00:04.0: [8086:1903] type 00 class 0x118000
[    0.400017] pci 0000:00:04.0: reg 0x10: [mem 0xb4510000-0xb4517fff 64bit]
[    0.401000] pci 0000:00:08.0: [8086:1911] type 00 class 0x088000
[    0.401012] pci 0000:00:08.0: reg 0x10: [mem 0xb4524000-0xb4524fff 64bit]
[    0.402027] pci 0000:00:12.0: [8086:a379] type 00 class 0x118000
[    0.402072] pci 0000:00:12.0: reg 0x10: [mem 0xb4525000-0xb4525fff 64bit]
[    0.403192] pci 0000:00:14.0: [8086:a36d] type 00 class 0x0c0330
[    0.403237] pci 0000:00:14.0: reg 0x10: [mem 0xb4500000-0xb450ffff 64bit]
[    0.403377] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    0.404357] pci 0000:00:14.2: [8086:a36f] type 00 class 0x050000
[    0.404398] pci 0000:00:14.2: reg 0x10: [mem 0xb4520000-0xb4521fff 64bit]
[    0.404421] pci 0000:00:14.2: reg 0x18: [mem 0xb4526000-0xb4526fff 64bit]
[    0.405474] pci 0000:00:14.3: [8086:a370] type 00 class 0x028000
[    0.405665] pci 0000:00:14.3: reg 0x10: [mem 0xb4518000-0xb451bfff 64bit]
[    0.406340] pci 0000:00:14.3: PME# supported from D0 D3hot D3cold
[    0.407534] pci 0000:00:15.0: [8086:a368] type 00 class 0x0c8000
[    0.407575] pci 0000:00:15.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[    0.408626] pci 0000:00:15.1: [8086:a369] type 00 class 0x0c8000
[    0.408668] pci 0000:00:15.1: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[    0.409777] pci 0000:00:16.0: [8086:a360] type 00 class 0x078000
[    0.409820] pci 0000:00:16.0: reg 0x10: [mem 0xb4529000-0xb4529fff 64bit]
[    0.409942] pci 0000:00:16.0: PME# supported from D3hot
[    0.411002] pci 0000:00:17.0: [8086:a353] type 00 class 0x010601
[    0.411040] pci 0000:00:17.0: reg 0x10: [mem 0xb4522000-0xb4523fff]
[    0.411056] pci 0000:00:17.0: reg 0x14: [mem 0xb452e000-0xb452e0ff]
[    0.411070] pci 0000:00:17.0: reg 0x18: [io  0x5080-0x5087]
[    0.411087] pci 0000:00:17.0: reg 0x1c: [io  0x5088-0x508b]
[    0.411102] pci 0000:00:17.0: reg 0x20: [io  0x5060-0x507f]
[    0.411117] pci 0000:00:17.0: reg 0x24: [mem 0xb452d000-0xb452d7ff]
[    0.411202] pci 0000:00:17.0: PME# supported from D3hot
[    0.412224] pci 0000:00:1d.0: [8086:a330] type 01 class 0x060400
[    0.412460] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    0.412531] pci 0000:00:1d.0: PTM enabled (root), 4ns granularity
[    0.413572] pci 0000:00:1d.5: [8086:a335] type 01 class 0x060400
[    0.413792] pci 0000:00:1d.5: PME# supported from D0 D3hot D3cold
[    0.413860] pci 0000:00:1d.5: PTM enabled (root), 4ns granularity
[    0.414864] pci 0000:00:1e.0: [8086:a328] type 00 class 0x078000
[    0.414905] pci 0000:00:1e.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[    0.416031] pci 0000:00:1f.0: [8086:a30d] type 00 class 0x060100
[    0.417225] pci 0000:00:1f.3: [8086:a348] type 00 class 0x040300
[    0.417303] pci 0000:00:1f.3: reg 0x10: [mem 0xb451c000-0xb451ffff 64bit]
[    0.417377] pci 0000:00:1f.3: reg 0x20: [mem 0xb4200000-0xb42fffff 64bit]
[    0.417528] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[    0.418611] pci 0000:00:1f.4: [8086:a323] type 00 class 0x0c0500
[    0.418796] pci 0000:00:1f.4: reg 0x10: [mem 0xb452b000-0xb452b0ff 64bit]
[    0.419010] pci 0000:00:1f.4: reg 0x20: [io  0x5040-0x505f]
[    0.420162] pci 0000:00:1f.5: [8086:a324] type 00 class 0x0c8000
[    0.420190] pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
[    0.421225] pci 0000:01:00.0: [10de:2191] type 00 class 0x030000
[    0.421243] pci 0000:01:00.0: reg 0x10: [mem 0xb3000000-0xb3ffffff]
[    0.421253] pci 0000:01:00.0: reg 0x14: [mem 0xa0000000-0xafffffff 64bit pref]
[    0.421261] pci 0000:01:00.0: reg 0x1c: [mem 0xb0000000-0xb1ffffff 64bit pref]
[    0.421268] pci 0000:01:00.0: reg 0x24: [io  0x4000-0x407f]
[    0.421274] pci 0000:01:00.0: reg 0x30: [mem 0xfff80000-0xffffffff pref]
[    0.421322] pci 0000:01:00.0: PME# supported from D0 D3hot
[    0.421433] pci 0000:01:00.1: [10de:1aeb] type 00 class 0x040300
[    0.421447] pci 0000:01:00.1: reg 0x10: [mem 0xb4000000-0xb4003fff]
[    0.421559] pci 0000:01:00.2: [10de:1aec] type 00 class 0x0c0330
[    0.421575] pci 0000:01:00.2: reg 0x10: [mem 0xb4100000-0xb413ffff 64bit pref]
[    0.421589] pci 0000:01:00.2: reg 0x1c: [mem 0xb4140000-0xb414ffff 64bit pref]
[    0.421637] pci 0000:01:00.2: PME# supported from D0 D3hot
[    0.421695] pci 0000:01:00.3: [10de:1aed] type 00 class 0x0c8000
[    0.421708] pci 0000:01:00.3: reg 0x10: [mem 0xb4004000-0xb4004fff]
[    0.421776] pci 0000:01:00.3: PME# supported from D0 D3hot
[    0.421848] pci 0000:00:01.0: PCI bridge to [bus 01-05]
[    0.421850] pci 0000:00:01.0:   bridge window [io  0x4000-0x4fff]
[    0.421851] pci 0000:00:01.0:   bridge window [mem 0xa0000000-0xb40fffff]
[    0.421854] pci 0000:00:01.0:   bridge window [mem 0xb4100000-0xb41fffff 64bit pref]
[    0.422092] pci 0000:06:00.0: [144d:a808] type 00 class 0x010802
[    0.422144] pci 0000:06:00.0: reg 0x10: [mem 0xb4400000-0xb4403fff 64bit]
[    0.422720] pci 0000:00:1d.0: PCI bridge to [bus 06]
[    0.422729] pci 0000:00:1d.0:   bridge window [mem 0xb4400000-0xb44fffff]
[    0.422833] pci 0000:07:00.0: [10ec:8168] type 00 class 0x020000
[    0.422876] pci 0000:07:00.0: reg 0x10: [io  0x3000-0x30ff]
[    0.422914] pci 0000:07:00.0: reg 0x18: [mem 0xb4304000-0xb4304fff 64bit]
[    0.422938] pci 0000:07:00.0: reg 0x20: [mem 0xb4300000-0xb4303fff 64bit]
[    0.423088] pci 0000:07:00.0: supports D1 D2
[    0.423089] pci 0000:07:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.423333] pci 0000:00:1d.5: PCI bridge to [bus 07]
[    0.423338] pci 0000:00:1d.5:   bridge window [io  0x3000-0x3fff]
[    0.423343] pci 0000:00:1d.5:   bridge window [mem 0xb4300000-0xb43fffff]
[    0.426469] ACPI: EC: interrupt unblocked
[    0.426500] ACPI: EC: event unblocked
[    0.426521] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.426521] ACPI: EC: GPE=0x2
[    0.426523] ACPI: \_SB_.PCI0.LPCB.EC0_: Boot DSDT EC used to handle transactions and events
[    0.426579] iommu: Default domain type: Translated
[    0.426592] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[    0.426592] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.426592] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[    0.426592] pci 0000:00:02.0: vgaarb: no bridge control possible
[    0.426592] pci 0000:01:00.0: vgaarb: bridge control possible
[    0.426592] vgaarb: loaded
[    0.426592] EDAC MC: Ver: 3.0.0
[    0.426592] Registered efivars operations
[    0.426592] PCI: Using ACPI for IRQ routing
[    0.511315] PCI: pci_cache_line_size set to 64 bytes
[    0.511723] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[    0.511724] e820: reserve RAM buffer [mem 0x73d87000-0x73ffffff]
[    0.511724] e820: reserve RAM buffer [mem 0x7ad64000-0x7bffffff]
[    0.511725] e820: reserve RAM buffer [mem 0x7af67000-0x7bffffff]
[    0.511726] e820: reserve RAM buffer [mem 0x8a89e000-0x8bffffff]
[    0.511727] e820: reserve RAM buffer [mem 0x8bc0f000-0x8bffffff]
[    0.511728] e820: reserve RAM buffer [mem 0x46e800000-0x46fffffff]
[    0.511809] NetLabel: Initializing
[    0.511810] NetLabel:  domain hash size = 128
[    0.511810] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.511822] NetLabel:  unlabeled traffic allowed by default
[    0.511856] clocksource: Switched to clocksource tsc-early
[    0.520066] VFS: Disk quotas dquot_6.6.0
[    0.520079] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.520170] AppArmor: AppArmor Filesystem Enabled
[    0.520184] pnp: PnP ACPI init
[    0.520259] system 00:00: [mem 0x40000000-0x403fffff] could not be reserved
[    0.520263] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.520556] system 00:01: [io  0x1800-0x18fe] has been reserved
[    0.520557] system 00:01: [mem 0xfd000000-0xfd69ffff] has been reserved
[    0.520559] system 00:01: [mem 0xfd6c0000-0xfd6cffff] has been reserved
[    0.520560] system 00:01: [mem 0xfd6f0000-0xfdffffff] has been reserved
[    0.520561] system 00:01: [mem 0xfe000000-0xfe01ffff] could not be reserved
[    0.520562] system 00:01: [mem 0xfe200000-0xfe7fffff] has been reserved
[    0.520563] system 00:01: [mem 0xff000000-0xffffffff] could not be reserved
[    0.520566] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.520848] system 00:02: [io  0x2000-0x20fe] has been reserved
[    0.520850] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.521012] system 00:03: [io  0x0680-0x069f] has been reserved
[    0.521013] system 00:03: [io  0x164e-0x164f] has been reserved
[    0.521016] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.521123] system 00:04: [io  0x1854-0x1857] has been reserved
[    0.521125] system 00:04: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[    0.521158] pnp 00:05: Plug and Play ACPI device, IDs PNP0303 (active)
[    0.522315] system 00:06: [mem 0xfe037000-0xfe037fff] has been reserved
[    0.522317] system 00:06: [mem 0xfe036008-0xfe036fff] has been reserved
[    0.522319] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.522754] system 00:07: [mem 0xfed10000-0xfed17fff] has been reserved
[    0.522755] system 00:07: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.522756] system 00:07: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.522757] system 00:07: [mem 0xe0000000-0xefffffff] has been reserved
[    0.522758] system 00:07: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.522760] system 00:07: [mem 0xfed90000-0xfed93fff] could not be reserved
[    0.522761] system 00:07: [mem 0xfed45000-0xfed8ffff] could not be reserved
[    0.522762] system 00:07: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.522765] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.522919] pnp: PnP ACPI: found 8 devices
[    0.528421] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.528448] pci 0000:01:00.0: can't claim BAR 6 [mem 0xfff80000-0xffffffff pref]: no compatible bridge window
[    0.528459] pci 0000:00:15.0: BAR 0: assigned [mem 0x8f800000-0x8f800fff 64bit]
[    0.528479] pci 0000:00:15.1: BAR 0: assigned [mem 0x8f801000-0x8f801fff 64bit]
[    0.528496] pci 0000:00:1e.0: BAR 0: assigned [mem 0x8f802000-0x8f802fff 64bit]
[    0.528512] pci 0000:01:00.0: BAR 6: assigned [mem 0xb2000000-0xb207ffff pref]
[    0.528514] pci 0000:00:01.0: PCI bridge to [bus 01-05]
[    0.528515] pci 0000:00:01.0:   bridge window [io  0x4000-0x4fff]
[    0.528517] pci 0000:00:01.0:   bridge window [mem 0xa0000000-0xb40fffff]
[    0.528519] pci 0000:00:01.0:   bridge window [mem 0xb4100000-0xb41fffff 64bit pref]
[    0.528523] pci 0000:00:1d.0: PCI bridge to [bus 06]
[    0.528534] pci 0000:00:1d.0:   bridge window [mem 0xb4400000-0xb44fffff]
[    0.528547] pci 0000:00:1d.5: PCI bridge to [bus 07]
[    0.528550] pci 0000:00:1d.5:   bridge window [io  0x3000-0x3fff]
[    0.528557] pci 0000:00:1d.5:   bridge window [mem 0xb4300000-0xb43fffff]
[    0.528571] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.528572] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.528573] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.528574] pci_bus 0000:00: resource 7 [mem 0x8f800000-0xdfffffff window]
[    0.528575] pci_bus 0000:00: resource 8 [mem 0xfc800000-0xfe7fffff window]
[    0.528576] pci_bus 0000:01: resource 0 [io  0x4000-0x4fff]
[    0.528577] pci_bus 0000:01: resource 1 [mem 0xa0000000-0xb40fffff]
[    0.528578] pci_bus 0000:01: resource 2 [mem 0xb4100000-0xb41fffff 64bit pref]
[    0.528579] pci_bus 0000:06: resource 1 [mem 0xb4400000-0xb44fffff]
[    0.528580] pci_bus 0000:07: resource 0 [io  0x3000-0x3fff]
[    0.528581] pci_bus 0000:07: resource 1 [mem 0xb4300000-0xb43fffff]
[    0.528717] NET: Registered protocol family 2
[    0.528825] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    0.528841] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.528963] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.529081] TCP: Hash tables configured (established 131072 bind 65536)
[    0.529105] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.529133] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.529213] NET: Registered protocol family 1
[    0.529216] NET: Registered protocol family 44
[    0.529226] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.530962] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[    0.531001] pci 0000:01:00.2: D0 power state depends on 0000:01:00.0
[    0.531366] pci 0000:01:00.3: D0 power state depends on 0000:01:00.0
[    0.531518] PCI: CLS 64 bytes, default 64
[    0.531570] Trying to unpack rootfs image as initramfs...
[    1.040531] Freeing initrd memory: 29084K
[    1.040566] DMAR: No ATSR found
[    1.040623] DMAR: dmar0: Using Queued invalidation
[    1.040630] DMAR: dmar1: Using Queued invalidation
[    1.041214] pci 0000:00:00.0: Adding to iommu group 0
[    1.041279] pci 0000:00:01.0: Adding to iommu group 1
[    1.045171] pci 0000:00:02.0: Adding to iommu group 2
[    1.045610] pci 0000:00:02.0: Using iommu direct mapping
[    1.045654] pci 0000:00:04.0: Adding to iommu group 3
[    1.045708] pci 0000:00:08.0: Adding to iommu group 4
[    1.045779] pci 0000:00:12.0: Adding to iommu group 5
[    1.045899] pci 0000:00:14.0: Adding to iommu group 6
[    1.045909] pci 0000:00:14.2: Adding to iommu group 6
[    1.045943] pci 0000:00:14.3: Adding to iommu group 6
[    1.046009] pci 0000:00:15.0: Adding to iommu group 7
[    1.046020] pci 0000:00:15.1: Adding to iommu group 7
[    1.046086] pci 0000:00:16.0: Adding to iommu group 8
[    1.046137] pci 0000:00:17.0: Adding to iommu group 9
[    1.046212] pci 0000:00:1d.0: Adding to iommu group 10
[    1.046279] pci 0000:00:1d.5: Adding to iommu group 11
[    1.046348] pci 0000:00:1e.0: Adding to iommu group 12
[    1.047933] pci 0000:00:1f.0: Adding to iommu group 13
[    1.047945] pci 0000:00:1f.3: Adding to iommu group 13
[    1.047957] pci 0000:00:1f.4: Adding to iommu group 13
[    1.047968] pci 0000:00:1f.5: Adding to iommu group 13
[    1.047975] pci 0000:01:00.0: Adding to iommu group 1
[    1.047981] pci 0000:01:00.1: Adding to iommu group 1
[    1.047985] pci 0000:01:00.2: Adding to iommu group 1
[    1.047990] pci 0000:01:00.3: Adding to iommu group 1
[    1.048068] pci 0000:06:00.0: Adding to iommu group 14
[    1.048138] pci 0000:07:00.0: Adding to iommu group 15
[    1.048447] DMAR: Intel(R) Virtualization Technology for Directed I/O
[    1.050297] platform rtc_cmos: registered platform RTC device (no PNP device found)
[    1.050759] Initialise system trusted keyrings
[    1.050768] Key type blacklist registered
[    1.050800] workingset: timestamp_bits=40 max_order=22 bucket_order=0
[    1.051854] zbud: loaded
[    1.052000] Platform Keyring initialized
[    1.052001] Key type asymmetric registered
[    1.052002] Asymmetric key parser 'x509' registered
[    1.052008] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[    1.052044] io scheduler mq-deadline registered
[    1.056106] pcieport 0000:00:01.0: PME: Signaling with IRQ 122
[    1.056397] pcieport 0000:00:1d.0: PME: Signaling with IRQ 123
[    1.056703] pcieport 0000:00:1d.5: PME: Signaling with IRQ 124
[    1.056842] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    1.056859] efifb: probing for efifb
[    1.056868] efifb: framebuffer at 0x90000000, using 8128k, total 8128k
[    1.056869] efifb: mode is 1920x1080x32, linelength=7680, pages=1
[    1.056869] efifb: scrolling: redraw
[    1.056870] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    1.056938] Console: switching to colour frame buffer device 240x67
[    1.060640] fb0: EFI VGA frame buffer device
[    1.060648] intel_idle: MWAIT substates: 0x11142120
[    1.060649] intel_idle: v0.4.1 model 0x9E
[    1.061341] intel_idle: lapic_timer_reliable_states 0xffffffff
[    1.063579] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.064250] hpet_acpi_add: no address or irqs in _CRS
[    1.064279] Linux agpgart interface v0.103
[    1.064339] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[    1.064339] AMD-Vi: AMD IOMMUv2 functionality not available on this system
[    1.065072] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[    1.065073] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[    1.067264] serio: i8042 KBD port at 0x60,0x64 irq 1
[    1.067415] mousedev: PS/2 mouse device common for all mice
[    1.067463] rtc_cmos rtc_cmos: RTC can wake from S4
[    1.068586] rtc_cmos rtc_cmos: registered as rtc0
[    1.068598] rtc_cmos rtc_cmos: alarms up to one month, y3k, 114 bytes nvram
[    1.068604] intel_pstate: Intel P-state driver initializing
[    1.068649] intel_pstate: Disabling energy efficiency optimization
[    1.069560] intel_pstate: HWP enabled
[    1.069886] ledtrig-cpu: registered to indicate activity on CPUs
[    1.070094] drop_monitor: Initializing network drop monitor service
[    1.070204] NET: Registered protocol family 10
[    1.078586] Segment Routing with IPv6
[    1.078599] mip6: Mobile IPv6
[    1.078600] NET: Registered protocol family 17
[    1.078766] mpls_gso: MPLS GSO support
[    1.079752] microcode: sig=0x906ea, pf=0x20, revision=0xc6
[    1.080288] microcode: Microcode Update Driver: v2.2.
[    1.080290] IPI shorthand broadcast: enabled
[    1.080293] sched_clock: Marking stable (1067136559, 12553360)->(1090683221, -10993302)
[    1.080668] registered taskstats version 1
[    1.080669] Loading compiled-in X.509 certificates
[    1.084608] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[    1.100134] Loaded X.509 cert 'Debian Secure Boot CA: 6ccece7e4c6c0d1f6149f3dd27dfcc5cbb419ea1'
[    1.100143] Loaded X.509 cert 'Debian Secure Boot Signer: 00a7468def'
[    1.100155] zswap: loaded using pool lzo/zbud
[    1.100529] Key type ._fscrypt registered
[    1.100530] Key type .fscrypt registered
[    1.100530] Key type fscrypt-provisioning registered
[    1.100561] AppArmor: AppArmor sha1 policy hashing enabled
[    1.102704] integrity: Loading X.509 certificate: UEFI:db
[    1.102726] integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
[    1.102726] integrity: Loading X.509 certificate: UEFI:db
[    1.102740] integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
[    1.102740] integrity: Loading X.509 certificate: UEFI:db
[    1.102741] integrity: Problem loading X.509 certificate -65
[    1.102755] Error adding keys to platform keyring UEFI:db
[    1.105512] rtc_cmos rtc_cmos: setting system clock to 2020-06-10T20:54:23 UTC (1591822463)
[    1.106291] Freeing unused kernel image (initmem) memory: 1612K
[    1.171608] Write protecting the kernel read-only data: 16384k
[    1.172432] Freeing unused kernel image (text/rodata gap) memory: 2044K
[    1.172608] Freeing unused kernel image (rodata/data gap) memory: 120K
[    1.199414] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.199415] x86/mm: Checking user space page tables
[    1.222956] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.222957] Run /init as init process
[    1.222957]   with arguments:
[    1.222958]     /init
[    1.222958]   with environment:
[    1.222958]     HOME=/
[    1.222958]     TERM=linux
[    1.222959]     BOOT_IMAGE=/vmlinuz-5.6.0-2-amd64
[    1.267204] udevd[175]: starting version 3.2.7
[    1.267910] udevd[176]: starting eudev-3.2.7
[    1.278557] wmi_bus wmi_bus-PNP0C14:00: WQ data block query control method not found
[    1.278558] wmi_bus wmi_bus-PNP0C14:00: WQ data block query control method not found
[    1.278559] wmi_bus wmi_bus-PNP0C14:00: WQ data block query control method not found
[    1.278678] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
[    1.285094] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[    1.285190] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[    1.286109] hid: raw HID events driver (C) Jiri Kosina
[    1.286244] udevd[198]: Error running install command for nvidia
[    1.289224] intel-lpss 0000:00:15.0: enabling device (0000 -> 0002)
[    1.289480] idma64 idma64.0: Found Intel integrated DMA 64-bit
[    1.290609] cryptd: max_cpu_qlen set to 1000
[    1.293184] SCSI subsystem initialized
[    1.296514] ACPI: bus type USB registered
[    1.296529] usbcore: registered new interface driver usbfs
[    1.296534] usbcore: registered new interface driver hub
[    1.296555] usbcore: registered new device driver usb
[    1.300482] AVX2 version of gcm_enc/dec engaged.
[    1.300482] AES CTR mode by8 optimization enabled
[    1.301538] intel-lpss 0000:00:15.1: enabling device (0000 -> 0002)
[    1.301809] idma64 idma64.1: Found Intel integrated DMA 64-bit
[    1.302005] r8169 0000:07:00.0: can't disable ASPM; OS doesn't have ASPM control
[    1.304797] nvme nvme0: pci function 0000:06:00.0
[    1.304827] libata version 3.00 loaded.
[    1.308049] intel-lpss 0000:00:1e.0: enabling device (0000 -> 0002)
[    1.308566] ahci 0000:00:17.0: version 3.0
[    1.310198] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.310202] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[    1.310278] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x10 impl SATA mode
[    1.310280] ahci 0000:00:17.0: flags: 64bit ncq sntf pm clo only pio slum part ems deso sadm sds apst
[    1.310306] idma64 idma64.2: Found Intel integrated DMA 64-bit
[    1.310445] dw-apb-uart.2: ttyS0 at MMIO 0x8f802000 (irq = 20, base_baud = 115200) is a 16550A
[    1.311460] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x110 quirks 0x0000000000009810
[    1.311483] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[    1.311699] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.06
[    1.311699] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.311700] usb usb1: Product: xHCI Host Controller
[    1.311701] usb usb1: Manufacturer: Linux 5.6.0-2-amd64 xhci-hcd
[    1.311701] usb usb1: SerialNumber: 0000:00:14.0
[    1.311914] scsi host0: ahci
[    1.311922] hub 1-0:1.0: USB hub found
[    1.311960] hub 1-0:1.0: 16 ports detected
[    1.312223] scsi host1: ahci
[    1.312313] scsi host2: ahci
[    1.312403] scsi host3: ahci
[    1.312484] scsi host4: ahci
[    1.312527] ata1: DUMMY
[    1.312528] ata2: DUMMY
[    1.312528] ata3: DUMMY
[    1.312529] ata4: DUMMY
[    1.312531] ata5: SATA max UDMA/133 abar m2048@0xb452d000 port 0xb452d300 irq 126
[    1.312699] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.312701] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[    1.312702] xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
[    1.312729] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.06
[    1.312730] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.312730] usb usb2: Product: xHCI Host Controller
[    1.312731] usb usb2: Manufacturer: Linux 5.6.0-2-amd64 xhci-hcd
[    1.312731] usb usb2: SerialNumber: 0000:00:14.0
[    1.312790] hub 2-0:1.0: USB hub found
[    1.312818] hub 2-0:1.0: 8 ports detected
[    1.312830] libphy: r8169: probed
[    1.313011] r8169 0000:07:00.0 eth0: RTL8168h/8111h, f8:75:a4:a2:7b:db, XID 541, IRQ 127
[    1.313013] r8169 0000:07:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[    1.313310] xhci_hcd 0000:01:00.2: xHCI Host Controller
[    1.313313] xhci_hcd 0000:01:00.2: new USB bus registered, assigned bus number 3
[    1.313985] xhci_hcd 0000:01:00.2: hcc params 0x0180ff05 hci version 0x110 quirks 0x0000000000000010
[    1.314069] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.06
[    1.314070] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.314070] usb usb3: Product: xHCI Host Controller
[    1.314071] usb usb3: Manufacturer: Linux 5.6.0-2-amd64 xhci-hcd
[    1.314071] usb usb3: SerialNumber: 0000:01:00.2
[    1.314212] hub 3-0:1.0: USB hub found
[    1.314217] hub 3-0:1.0: 2 ports detected
[    1.314745] xhci_hcd 0000:01:00.2: xHCI Host Controller
[    1.314747] xhci_hcd 0000:01:00.2: new USB bus registered, assigned bus number 4
[    1.314748] xhci_hcd 0000:01:00.2: Host supports USB 3.1 Enhanced SuperSpeed
[    1.314764] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.314773] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.06
[    1.314774] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.314774] usb usb4: Product: xHCI Host Controller
[    1.314775] usb usb4: Manufacturer: Linux 5.6.0-2-amd64 xhci-hcd
[    1.314775] usb usb4: SerialNumber: 0000:01:00.2
[    1.314817] hub 4-0:1.0: USB hub found
[    1.314824] hub 4-0:1.0: 4 ports detected
[    1.375865] battery: ACPI: Battery Slot [BAT0] (battery present)
[    1.381813] i2c_hid i2c-MSFT0001:01: i2c-MSFT0001:01 supply vdd not found, using dummy regulator
[    1.381821] i2c_hid i2c-MSFT0001:01: i2c-MSFT0001:01 supply vddl not found, using dummy regulator
[    1.524743] nvme nvme0: missing or invalid SUBNQN field.
[    1.524822] nvme nvme0: Shutdown timeout set to 8 seconds
[    1.598913] nvme nvme0: 12/0/0 default/read/poll queues
[    1.620775]  nvme0n1: p1 p2 < p5 p6 >
[    1.623826] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    1.647537] usb 1-1: new low-speed USB device number 2 using xhci_hcd
[    1.738762] ata5.00: ATA-10: ST2000LM015-2E8174, 0001, max UDMA/133
[    1.738766] ata5.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    1.789780] ata5.00: configured for UDMA/133
[    1.790042] scsi 4:0:0:0: Direct-Access     ATA      ST2000LM015-2E81 0001 PQ: 0 ANSI: 5
[    1.796678] input: MSFT0001:01 04F3:309E Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-MSFT0001:01/0018:04F3:309E.0001/input/input1
[    1.796956] input: MSFT0001:01 04F3:309E Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-MSFT0001:01/0018:04F3:309E.0001/input/input3
[    1.797275] hid-generic 0018:04F3:309E.0001: input,hidraw0: I2C HID v1.00 Mouse [MSFT0001:01 04F3:309E] on i2c-MSFT0001:01
[    1.800834] sd 4:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[    1.800835] sd 4:0:0:0: [sda] 4096-byte physical blocks
[    1.800860] sd 4:0:0:0: [sda] Write Protect is off
[    1.800860] sd 4:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    1.800866] sd 4:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.804240] usb 1-1: New USB device found, idVendor=0b05, idProduct=17a9, bcdDevice= 1.00
[    1.804241] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.804242] usb 1-1: Product: Asus USB Optical Mouse
[    1.804242] usb 1-1: Manufacturer: PixArt
[    1.808386] input: PixArt Asus USB Optical Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/0003:0B05:17A9.0002/input/input4
[    1.808504] hid-generic 0003:0B05:17A9.0002: input,hidraw1: USB HID v1.11 Mouse [PixArt Asus USB Optical Mouse] on usb-0000:00:14.0-1/input0
[    1.808522] usbcore: registered new interface driver usbhid
[    1.808523] usbhid: USB HID core driver
[    1.912151]  sda: sda1
[    1.912999] sd 4:0:0:0: [sda] Attached SCSI disk
[    1.918087] sd 4:0:0:0: Attached scsi generic sg0 type 0
[    1.931855] usb 1-6: new high-speed USB device number 3 using xhci_hcd
[    2.051181] tsc: Refined TSC clocksource calibration: 2592.005 MHz
[    2.051199] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x255cbb91cef, max_idle_ns: 440795297256 ns
[    2.051289] clocksource: Switched to clocksource tsc
[    2.092836] usb 1-6: New USB device found, idVendor=04ca, idProduct=7070, bcdDevice= 0.24
[    2.092841] usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.092845] usb 1-6: Product: Integrated Camera
[    2.092847] usb 1-6: Manufacturer: 8SSC20F27068L1GZ0197DY5
[    2.223574] usb 1-9: new full-speed USB device number 4 using xhci_hcd
[    2.340632] device-mapper: uevent: version 1.0.3
[    2.340872] device-mapper: ioctl: 4.42.0-ioctl (2020-02-27) initialised: dm-devel@redhat.com
[    2.385749] usb 1-9: New USB device found, idVendor=048d, idProduct=c100, bcdDevice= 0.43
[    2.385750] usb 1-9: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.385751] usb 1-9: Product: ITE Device(8910)
[    2.385751] usb 1-9: Manufacturer: ITE Tech. Inc.
[    2.398477] input: ITE Tech. Inc. ITE Device(8910) Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/0003:048D:C100.0003/input/input5
[    2.455902] input: ITE Tech. Inc. ITE Device(8910) Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/0003:048D:C100.0003/input/input6
[    2.455965] input: ITE Tech. Inc. ITE Device(8910) Wireless Radio Control as /devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/0003:048D:C100.0003/input/input7
[    2.456385] hid-generic 0003:048D:C100.0003: input,hiddev0,hidraw2: USB HID v1.10 Keyboard [ITE Tech. Inc. ITE Device(8910)] on usb-0000:00:14.0-9/input0
[    2.583638] usb 1-14: new full-speed USB device number 5 using xhci_hcd
[    2.733820] usb 1-14: New USB device found, idVendor=8087, idProduct=0aaa, bcdDevice= 0.02
[    2.733825] usb 1-14: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[   12.682428] NET: Registered protocol family 38
[   23.838723] process '/usr/bin/fstype' started with executable stack
[   24.252692] PM: Image not found (code -22)
[   24.348856] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Opts: (null)
[   24.383327] EXT4-fs (dm-2): mounted filesystem with ordered data mode. Opts: (null)
[   24.445732] Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist.
[   24.630064] udevd[767]: starting version 3.2.7
[   24.638996] udevd[767]: specified group 'kvm' unknown
[   24.656583] udevd[767]: starting eudev-3.2.7
[   24.763757] ACPI: AC Adapter [ADP0] (on-line)
[   24.860420] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input8
[   24.860441] ACPI: Lid Switch [LID0]
[   24.860474] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input9
[   24.860495] ACPI: Power Button [PWRB]
[   24.861776] IPMI message handler: version 39.2
[   24.861842] mc: Linux media interface: v0.10
[   24.867846] input: Ideapad extra buttons as /devices/pci0000:00/0000:00:1f.0/PNP0C09:00/VPC2004:00/input/input10
[   24.868507] ipmi device interface
[   24.868614] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   24.868735] cfg80211: Loaded X.509 cert 'benh@debian.org: 577e021cb980e0e820821ba7b54b4961b8b4fadf'
[   24.868857] cfg80211: Loaded X.509 cert 'romain.perier@gmail.com: 3abbc6ec146e09d1b6016ab9d6cf71dd233f0328'
[   24.868975] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   24.869284] platform regulatory.0: firmware: failed to load regulatory.db (-2)
[   24.869314] firmware_class: See https://wiki.debian.org/Firmware for information about missing firmware
[   24.869324] intel_rapl_common: Found RAPL domain package
[   24.869349] intel_rapl_common: Found RAPL domain dram
[   24.869349] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[   24.869351] cfg80211: failed to load regulatory.db
[   24.873434] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[   24.873758] videodev: Linux video capture interface: v2.00
[   24.875067] alg: No test for fips(ansi_cprng) (fips_ansi_cprng)
[   24.875800] proc_thermal 0000:00:04.0: Creating sysfs group for PROC_THERMAL_PCI
[   24.884561] Intel(R) Wireless WiFi driver for Linux
[   24.884562] Copyright(c) 2003- 2015 Intel Corporation
[   24.889042] iwlwifi 0000:00:14.3: firmware: direct-loading firmware iwlwifi-9000-pu-b0-jf-b0-46.ucode
[   24.889055] iwlwifi 0000:00:14.3: Found debug destination: EXTERNAL_DRAM
[   24.889056] iwlwifi 0000:00:14.3: Found debug configuration: 0
[   24.889286] iwlwifi 0000:00:14.3: loaded firmware version 46.8902351f.0 9000-pu-b0-jf-b0-46.ucode op_mode iwlmvm
[   24.891253] nvidia: loading out-of-tree module taints kernel.
[   24.891259] nvidia: module license 'NVIDIA' taints kernel.
[   24.891261] Disabling lock debugging due to kernel taint
[   24.893190] uvcvideo: Found UVC 1.00 device Integrated Camera (04ca:7070)
[   24.898173] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[   24.911023] uvcvideo 1-6:1.0: Entity type for entity Extension 4 was not initialized!
[   24.911025] uvcvideo 1-6:1.0: Entity type for entity Extension 3 was not initialized!
[   24.911026] uvcvideo 1-6:1.0: Entity type for entity Processing 2 was not initialized!
[   24.911027] uvcvideo 1-6:1.0: Entity type for entity Camera 1 was not initialized!
[   24.911081] input: Integrated Camera: Integrated C as /devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.0/input/input11
[   24.930818] r8169 0000:07:00.0: firmware: direct-loading firmware rtl_nic/rtl8168h-2.fw
[   24.930890] Generic FE-GE Realtek PHY r8169-700:00: attached PHY driver [Generic FE-GE Realtek PHY] (mii_bus:phy_addr=r8169-700:00, irq=IGNORE)
[   24.971924] nvidia-nvlink: Nvlink Core is being initialized, major device number 242
[   24.972373] nvidia 0000:01:00.0: enabling device (0006 -> 0007)
[   24.972502] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[   24.972665] EFI Variables Facility v0.08 2004-May-17
[   24.972786] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[   24.973202] snd_hda_intel 0000:01:00.1: Disabling MSI
[   24.973208] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[   24.973766] input: PC Speaker as /devices/platform/pcspkr/input/input12
[   24.974332] iTCO_vendor_support: vendor-support=0
[   24.980444] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[   24.980701] iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
[   24.980916] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[   24.984624] Bluetooth: Core ver 2.22
[   24.984668] NET: Registered protocol family 31
[   24.984668] Bluetooth: HCI device and connection manager initialized
[   24.984690] Bluetooth: HCI socket layer initialized
[   24.984699] Bluetooth: L2CAP socket layer initialized
[   24.984710] Bluetooth: SCO socket layer initialized
[   25.017681] i915 0000:00:02.0: VT-d active for gfx access
[   25.017684] checking generic (90000000 7f0000) vs hw (b5000000 1000000)
[   25.017686] checking generic (90000000 7f0000) vs hw (90000000 10000000)
[   25.017686] fb0: switching to inteldrmfb from EFI VGA
[   25.017772] Console: switching to colour dummy device 80x25
[   25.017774] pstore: Using crash dump compression: deflate
[   25.017784] pstore: Registered efi as persistent store backend
[   25.017799] i915 0000:00:02.0: vgaarb: deactivate vga console
[   25.019669] NVRM: loading NVIDIA UNIX x86_64 Kernel Module  440.82  Wed Apr  1 20:04:33 UTC 2020
[   25.020361] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[   25.020361] [drm] Driver supports precise vblank timestamp query.
[   25.021353] RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
[   25.021353] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[   25.021354] RAPL PMU: hw unit of domain package 2^-14 Joules
[   25.021354] RAPL PMU: hw unit of domain dram 2^-14 Joules
[   25.021355] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[   25.022336] i915 0000:00:02.0: firmware: direct-loading firmware i915/kbl_dmc_ver1_04.bin
[   25.022384] [drm:csr_load_work_fn [i915]] *ERROR* DMC firmware has wrong CSS header length (1097158924 bytes)
[   25.022388] i915 0000:00:02.0: Failed to load DMC firmware i915/kbl_dmc_ver1_04.bin. Disabling runtime power management.
[   25.022390] i915 0000:00:02.0: DMC firmware homepage: https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/tree/i915
[   25.022819] usbcore: registered new interface driver btusb
[   25.027722] Bluetooth: hci0: Firmware revision 0.1 build 130 week 44 2018
[   25.038927] [drm] Initialized i915 1.6.0 20200114 for 0000:00:02.0 on minor 0
[   25.039093] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input13
[   25.039642] [Firmware Bug]: ACPI(PEGP) defines _DOD but not _DOS
[   25.039652] ACPI: Video Device [PEGP] (multi-head: yes  rom: yes  post: no)
[   25.039674] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input19
[   25.055170] usbcore: registered new interface driver uvcvideo
[   25.055171] USB Video Class driver (1.1.1)
[   25.063984] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input14
[   25.064812] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input15
[   25.064865] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input16
[   25.064937] r8169 0000:07:00.0 eth0: Link is Down
[   25.064938] input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input17
[   25.064992] input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input18
[   25.071521] ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[   25.071632] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input20
[   25.071829] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[   25.072839] fbcon: i915drmfb (fb0) is primary device
[   25.074792] input: MSFT0001:01 04F3:309E Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-MSFT0001:01/0018:04F3:309E.0001/input/input21
[   25.074889] input: MSFT0001:01 04F3:309E Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-MSFT0001:01/0018:04F3:309E.0001/input/input23
[   25.074924] hid-multitouch 0018:04F3:309E.0001: input,hidraw0: I2C HID v1.00 Mouse [MSFT0001:01 04F3:309E] on i2c-MSFT0001:01
[   25.115635] iwlwifi 0000:00:14.3: Detected Intel(R) Dual Band Wireless AC 9560, REV=0x318
[   25.125407] iwlwifi 0000:00:14.3: Applying debug destination EXTERNAL_DRAM
[   25.125546] iwlwifi 0000:00:14.3: Allocated 0x00400000 bytes for firmware monitor.
[   25.129870] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC257: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[   25.129871] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[   25.129872] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[   25.129872] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[   25.129873] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[   25.129874] snd_hda_codec_realtek hdaudioC0D0:      Mic=0x19
[   25.129874] snd_hda_codec_realtek hdaudioC0D0:      Internal Mic=0x12
[   25.169872] iwlwifi 0000:00:14.3: base HW address: 54:8d:5a:12:93:82
[   25.209529] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1f.3/sound/card0/input24
[   25.209563] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input25
[   25.209584] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input26
[   25.209604] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input27
[   25.209629] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input28
[   25.209648] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input29
[   25.209666] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input30
[   25.209702] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input31
[   25.228849] intel_rapl_common: Found RAPL domain package
[   25.228850] intel_rapl_common: Found RAPL domain core
[   25.228850] intel_rapl_common: Found RAPL domain uncore
[   25.228851] intel_rapl_common: Found RAPL domain dram
[   25.237380] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[   25.237522] thermal thermal_zone9: failed to read out thermal zone (-61)
[   26.373245] Console: switching to colour frame buffer device 240x67
[   26.389299] i915 0000:00:02.0: fb0: i915drmfb frame buffer device
[   27.244083] EXT4-fs (dm-1): re-mounted. Opts: errors=remount-ro
[   28.852858] r8169 0000:07:00.0 eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[   28.852873] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   43.187928] lp: driver loaded but no devices found
[   43.207788] ppdev: user-space parallel port driver
[   43.284033] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  440.82  Wed Apr  1 19:41:29 UTC 2020
[   43.302455] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[   43.302457] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 1
[   43.841814] EXT4-fs (dm-2): re-mounted. Opts: (null)
[   43.848409] EXT4-fs (nvme0n1p5): mounted filesystem with ordered data mode. Opts: (null)
[   43.848424] ext4 filesystem being mounted at /boot supports timestamps until 2038 (0x7fffffff)
[   43.950787] EXT4-fs (dm-8): mounted filesystem with ordered data mode. Opts: (null)
[   43.989534] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null)
[   43.993886] EXT4-fs (dm-4): mounted filesystem with ordered data mode. Opts: (null)
[   43.998786] EXT4-fs (dm-3): mounted filesystem with ordered data mode. Opts: (null)
[   44.095564] Adding 15622140k swap on /dev/mapper/vgs-swap.  Priority:-2 extents:1 across:15622140k SSFS
[   44.332896] audit: type=1400 audit(1591822506.580:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-senddoc" pid=1951 comm="apparmor_parser"
[   44.333319] audit: type=1400 audit(1591822506.580:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-xpdfimport" pid=1952 comm="apparmor_parser"
[   44.333686] audit: type=1400 audit(1591822506.580:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-oopslash" pid=1955 comm="apparmor_parser"
[   44.334761] audit: type=1400 audit(1591822506.580:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=1950 comm="apparmor_parser"
[   44.334763] audit: type=1400 audit(1591822506.580:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=1950 comm="apparmor_parser"
[   44.334772] audit: type=1400 audit(1591822506.580:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=1949 comm="apparmor_parser"
[   44.334774] audit: type=1400 audit(1591822506.580:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=1949 comm="apparmor_parser"
[   44.334779] audit: type=1400 audit(1591822506.580:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=1949 comm="apparmor_parser"
[   44.335537] audit: type=1400 audit(1591822506.584:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cups-browsed" pid=1954 comm="apparmor_parser"
[   44.340711] audit: type=1400 audit(1591822506.588:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/cups/backend/cups-pdf" pid=1953 comm="apparmor_parser"
[   44.975866] ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20200110/nsarguments-59)
[   45.840183] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   45.840184] Bluetooth: BNEP filters: protocol multicast
[   45.840186] Bluetooth: BNEP socket layer initialized
[   45.894221] elogind-daemon[2530]: New seat seat0.
[   46.291696] broken atomic modeset userspace detected, disabling atomic
[   47.140537] NET: Registered protocol family 5
[   47.275079] NET: Unregistered protocol family 5
[   47.329030] NET: Registered protocol family 5
[   47.431538] NET: Unregistered protocol family 5
[   47.494125] NET: Registered protocol family 5
[   47.595536] NET: Unregistered protocol family 5
[   85.960363] elogind-daemon[2530]: New session 1 of user hamsa.
I did not install Bumblebee so far, since I think that could cause the trouble to restart again.
Any ideas of how to get the display into a non-flickering mode?
Do you think its a driver problem for the iGPU? If so, which one could I use?
happy hacking
Walter
#10 2020-06-12 16:47:36
Re: Beowulf and Legion y540
Bumblebee is for when you want the Intel iGPU to run the display most of the time but use the NVIDIA card for graphically-intensive programs (with the optirun command), this will give the best battery life and is the intended mode of operation for Optimus devices.
Another alternative would be PRIME, which can be used for display offloading and suchlike.
In both cases "switchable graphics" will need to be selected in your machine's firmware ("BIOS") options.
Try either disabling the desktop compositor or switching from the xserver-xorg-video-intel DDX driver to X's builtin modesetting version. Check the X.Org log to see which is being used at the moment.
Also check the log to see if any X.Org configuration files are being read — the NVIDIA proprietary drivers now integrate with X automatically and a configuration file may be breaking things for you.
#11 2020-06-14 01:09:55
walter
I put the system up to chimaera as a whole. Worked well all in all. I had to solve some package dependency warnings inside aptitude. At the end I have the same situation.
Display is flickering when booted with "switchable graphics" - both X and console screen. Now the screen has some moments of stability and then the flickering or to be more precise the on/off phases gets shorter and its getting more to a flashing display with main time black. But sometimes its coming back and the process restarts. It seems that moving the mouse and clicking changes the behaviour and suddenly there is a stable display for a moment and then it starts to flicker again. Very strange. Could this be a misconfigured display or wrong sync entries????
Yes, thats what I suppose Bumblebee is doing. I use it on my old machine and it works amazing well. Nvidia uses Optimus and I think its pretty much the same with some more sophisticated ways of automatic switching between the GPUs.
Here I need a bit more detailed information about what you are suggesting.
cat /var/log/Xorg.0.log
[    40.884]
X.Org X Server 1.20.8
[    40.884] Build Operating System: Linux 4.19.0-8-amd64 x86_64 Debian
[    40.884] Current Operating System: Linux deva 5.6.0-2-amd64 #1 SMP Debian 5.6.14-1 (2020-05-23) x86_64
[    40.885] Kernel command line: BOOT_IMAGE=/vmlinuz-5.6.0-2-amd64 root=/dev/mapper/vgs-root ro quiet
[    40.885] Build Date: 31 March 2020  10:14:40AM
[    40.885] xorg-server 2:1.20.8-2 (https://www.debian.org/support)
[    40.885] Current version of pixman: 0.36.0
[    40.885] 	Before reporting problems, check http://wiki.x.org
[    40.885] Markers: (--) probed, (**) from config file, (==) default setting,
[    40.885] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Jun 14 01:16:36 2020
[    40.887] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    40.889] (==) No Layout section.  Using the first Screen section.
[    40.889] (==) No screen section available. Using defaults.
[    40.889] (**) |-->Screen "Default Screen Section" (0)
[    40.889] (**) |   |-->Monitor "<default monitor>"
[    40.891] (==) No monitor specified for screen "Default Screen Section".
[    40.891] (==) Automatically adding devices
[    40.891] (==) Automatically enabling devices
[    40.891] (==) Automatically adding GPU devices
[    40.891] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    40.893] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[    40.893] 	Entry deleted from font path.
[    40.894] (==) FontPath set to:
	/usr/share/fonts/X11/misc,
	/usr/share/fonts/X11/Type1,
	/usr/share/fonts/X11/100dpi,
	/usr/share/fonts/X11/75dpi,
	built-ins
[    40.895] (==) ModulePath set to "/usr/lib/xorg/modules"
[    40.895] (II) The server relies on udev to provide the list of input devices.
[    40.895] (II) Loader magic: 0x556c484afe20
[    40.895] (II) Module ABI versions:
[    40.895] 	X.Org ANSI C Emulation: 0.4
[    40.895] 	X.Org Video Driver: 24.1
[    40.895] 	X.Org XInput driver : 24.1
[    40.895] 	X.Org Server Extension : 10.0
[    40.895] (++) using VT number 7
[    40.895] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[    40.896] (II) xfree86: Adding drm device (/dev/dri/card1)
[    40.896] (II) xfree86: Adding drm device (/dev/dri/card0)
[    40.904] (--) PCI:*(0@0:2:0) 8086:3e9b:17aa:3ffc rev 0, Mem @ 0xb5000000/16777216, 0x90000000/268435456, I/O @ 0x00005000/64, BIOS @ 0x????????/131072
[    40.904] (--) PCI: (1@0:0:0) 10de:2191:17aa:3ffc rev 161, Mem @ 0xb3000000/16777216, 0xa0000000/268435456, 0xb0000000/33554432, I/O @ 0x00004000/128, BIOS @ 0x????????/524288
[    40.904] (II) LoadModule: "glx"
[    40.904] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    40.912] (II) Module glx: vendor="X.Org Foundation"
[    40.912] 	compiled for 1.20.8, module version = 1.0.0
[    40.912] 	ABI class: X.Org Server Extension, version 10.0
[    40.912] (II) Applying OutputClass "nvidia" to /dev/dri/card1
[    40.912] 	loading driver: nvidia
[    41.031] (==) Matched nvidia as autoconfigured driver 0
[    41.031] (==) Matched nouveau as autoconfigured driver 1
[    41.031] (==) Matched nv as autoconfigured driver 2
[    41.031] (==) Matched modesetting as autoconfigured driver 3
[    41.031] (==) Matched fbdev as autoconfigured driver 4
[    41.031] (==) Matched vesa as autoconfigured driver 5
[    41.031] (==) Assigned the driver to the xf86ConfigLayout
[    41.031] (II) LoadModule: "nvidia"
[    41.032] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[    41.040] (II) Module nvidia: vendor="NVIDIA Corporation"
[    41.040] 	compiled for 1.6.99.901, module version = 1.0.0
[    41.040] 	Module class: X.Org Video Driver
[    41.041] (II) LoadModule: "nouveau"
[    41.041] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[    41.043] (II) Module nouveau: vendor="X.Org Foundation"
[    41.043] 	compiled for 1.20.3, module version = 1.0.16
[    41.043] 	Module class: X.Org Video Driver
[    41.043] 	ABI class: X.Org Video Driver, version 24.0
[    41.043] (II) LoadModule: "nv"
[    41.043] (WW) Warning, couldn't open module nv
[    41.043] (EE) Failed to load module "nv" (module does not exist, 0)
[    41.043] (II) LoadModule: "modesetting"
[    41.043] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    41.044] (II) Module modesetting: vendor="X.Org Foundation"
[    41.044] 	compiled for 1.20.8, module version = 1.20.8
[    41.044] 	Module class: X.Org Video Driver
[    41.044] 	ABI class: X.Org Video Driver, version 24.1
[    41.044] (II) LoadModule: "fbdev"
[    41.044] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[    41.045] (II) Module fbdev: vendor="X.Org Foundation"
[    41.045] 	compiled for 1.20.0, module version = 0.5.0
[    41.045] 	Module class: X.Org Video Driver
[    41.045] 	ABI class: X.Org Video Driver, version 24.0
[    41.045] (II) LoadModule: "vesa"
[    41.045] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[    41.045] (II) Module vesa: vendor="X.Org Foundation"
[    41.045] 	compiled for 1.20.4, module version = 2.4.0
[    41.045] (II) NVIDIA dlloader X Driver  440.82  Wed Apr  1 19:50:17 UTC 2020
[    41.045] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    41.046] (II) NOUVEAU driver Date:   Mon Jan 28 23:25:58 2019 -0500
[    41.046] (II) NOUVEAU driver for NVIDIA chipset families :
[    41.046] 	RIVA TNT            (NV04)
[    41.046] 	RIVA TNT2           (NV05)
[    41.046] 	GeForce 256         (NV10)
[    41.046] 	GeForce 2           (NV11, NV15)
[    41.046] 	GeForce 4MX         (NV17, NV18)
[    41.046] 	GeForce 3           (NV20)
[    41.046] 	GeForce 4Ti         (NV25, NV28)
[    41.046] 	GeForce FX          (NV3x)
[    41.046] 	GeForce 6           (NV4x)
[    41.046] 	GeForce 7           (G7x)
[    41.046] 	GeForce 8           (G8x)
[    41.046] 	GeForce 9           (G9x)
[    41.046] 	GeForce GTX 2xx/3xx (GT2xx)
[    41.046] 	GeForce GTX 4xx/5xx (GFxxx)
[    41.046] 	GeForce GTX 6xx/7xx (GKxxx)
[    41.046] 	GeForce GTX 9xx     (GMxxx)
[    41.046] 	GeForce GTX 10xx    (GPxxx)
[    41.046] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    41.046] (II) FBDEV: driver for framebuffer: fbdev
[    41.046] (II) VESA: driver for VESA chipsets: vesa
[    41.511] (II) modeset(0): using drv /dev/dri/card0
[    41.511] (WW) Falling back to old probe method for fbdev
[    41.511] (II) Loading sub module "fbdevhw"
[    41.511] (II) LoadModule: "fbdevhw"
[    41.511] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[    41.512] (II) Module fbdevhw: vendor="X.Org Foundation"
[    41.512] 	compiled for 1.20.8, module version = 0.0.2
[    41.512] 	ABI class: X.Org Video Driver, version 24.1
[    41.513] (II) Loading sub module "fb"
[    41.513] (II) LoadModule: "fb"
[    41.514] (II) Loading /usr/lib/xorg/modules/libfb.so
[    41.515] (II) Module fb: vendor="X.Org Foundation"
[    41.515] 	compiled for 1.20.8, module version = 1.0.0
[    41.515] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    41.515] (II) Loading sub module "wfb"
[    41.515] (II) LoadModule: "wfb"
[    41.515] (II) Loading /usr/lib/xorg/modules/libwfb.so
[    41.516] (II) Module wfb: vendor="X.Org Foundation"
[    41.516] 	compiled for 1.20.8, module version = 1.0.0
[    41.516] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    41.516] (II) Loading sub module "ramdac"
[    41.516] (II) LoadModule: "ramdac"
[    41.516] (II) Module "ramdac" already built-in
[    41.578] (II) modeset(0): Creating default Display subsection in Screen section
[    41.578] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[    41.578] (==) modeset(0): RGB weight 888
[    41.578] (==) modeset(0): Default visual is TrueColor
[    41.578] (II) Loading sub module "glamoregl"
[    41.578] (II) LoadModule: "glamoregl"
[    41.578] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[    41.586] (II) Module glamoregl: vendor="X.Org Foundation"
[    41.586] 	compiled for 1.20.8, module version = 1.0.1
[    41.586] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    41.801] (II) modeset(0): glamor X acceleration enabled on Mesa Intel(R) UHD Graphics 630 (CFL GT2)
[    41.801] (II) modeset(0): glamor initialized
[    41.803] (II) modeset(0): Output eDP-1 has no monitor section
[    41.804] (II) modeset(0): EDID for output eDP-1
[    41.804] (II) modeset(0): Manufacturer: CMN  Model: 175c  Serial#: 0
[    41.804] (II) modeset(0): Year: 2018  Week: 22
[    41.804] (II) modeset(0): EDID Version: 1.4
[    41.804] (II) modeset(0): Digital Display Input
[    41.804] (II) modeset(0): 8 bits per channel
[    41.804] (II) modeset(0): Digital interface is DisplayPort
[    41.804] (II) modeset(0): Max Image Size [cm]: horiz.: 38  vert.: 21
[    41.804] (II) modeset(0): Gamma: 2.20
[    41.804] (II) modeset(0): No DPMS capabilities specified
[    41.804] (II) modeset(0): Supported color encodings: RGB 4:4:4
[    41.804] (II) modeset(0): First detailed timing is preferred mode
[    41.804] (II) modeset(0): Preferred mode is native pixel format and refresh rate
[    41.804] (II) modeset(0): redX: 0.640 redY: 0.330   greenX: 0.300 greenY: 0.600
[    41.804] (II) modeset(0): blueX: 0.150 blueY: 0.060   whiteX: 0.313 whiteY: 0.329
[    41.804] (II) modeset(0): Manufacturer's mask: 0
[    41.804] (II) modeset(0): Supported detailed timing:
[    41.804] (II) modeset(0): clock: 342.1 MHz   Image Size:  381 x 214 mm
[    41.804] (II) modeset(0): h_active: 1920  h_sync: 1968  h_sync_end 2000 h_blank_end 2080 h_border: 0
[    41.804] (II) modeset(0): v_active: 1080  v_sync: 1090  v_sync_end 1095 v_blanking: 1142 v_border: 0
[    41.804] (II) modeset(0):  N173HCE-G33
[    41.804] (II) modeset(0):  CMN
[    41.804] (II) modeset(0): EDID (in hex):
[    41.804] (II) modeset(0): 	00ffffffffffff000dae5c1700000000
[    41.804] (II) modeset(0): 	161c0104a526157802ee95a3544c9926
[    41.804] (II) modeset(0): 	0f505400000001010101010101010101
[    41.804] (II) modeset(0): 	0101010101019e8580a070383e403020
[    41.804] (II) modeset(0): 	a5007dd610000018000000fe004e3137
[    41.804] (II) modeset(0): 	334843452d4733330a20000000fe0043
[    41.804] (II) modeset(0): 	4d4e0a202020202020202020000000fe
[    41.804] (II) modeset(0): 	004e3137334843452d4733330a2000aa
[    41.804] (II) modeset(0): Printing probed modes for output eDP-1
[    41.804] (II) modeset(0): Modeline "1920x1080"x144.0  342.06  1920 1968 2000 2080  1080 1090 1095 1142 -hsync -vsync (164.5 kHz eP)
[    41.804] (II) modeset(0): Modeline "1920x1080"x120.0  356.38  1920 2080 2288 2656  1080 1081 1084 1118 doublescan -hsync +vsync (134.2 kHz d)
[    41.804] (II) modeset(0): Modeline "1920x1080"x119.9  266.50  1920 1944 1960 2000  1080 1081 1084 1111 doublescan +hsync -vsync (133.2 kHz d)
[    41.804] (II) modeset(0): Modeline "1920x1080"x60.0  173.00  1920 2048 2248 2576  1080 1083 1088 1120 -hsync +vsync (67.2 kHz d)
[    41.804] (II) modeset(0): Modeline "1920x1080"x59.9  138.50  1920 1968 2000 2080  1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[    41.804] (II) modeset(0): Modeline "1680x1050"x84.9  214.75  1680 1808 1984 2288  1050 1053 1059 1105 -hsync +vsync (93.9 kHz d)
[    41.804] (II) modeset(0): Modeline "1680x1050"x74.9  187.00  1680 1800 1976 2272  1050 1053 1059 1099 -hsync +vsync (82.3 kHz d)
[    41.804] (II) modeset(0): Modeline "1680x1050"x69.9  174.00  1680 1800 1976 2272  1050 1053 1059 1096 -hsync +vsync (76.6 kHz d)
[    41.804] (II) modeset(0): Modeline "1680x1050"x60.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
[    41.804] (II) modeset(0): Modeline "1680x1050"x59.9  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
[    41.804] (II) modeset(0): Modeline "1600x1024"x60.2  103.12  1600 1600 1656 1664  1024 1024 1029 1030 +hsync +vsync (62.0 kHz d)
[    41.804] (II) modeset(0): Modeline "1400x1050"x85.0  179.26  1400 1504 1656 1912  1050 1051 1054 1103 -hsync +vsync (93.8 kHz d)
[    41.804] (II) modeset(0): Modeline "1400x1050"x74.8  155.80  1400 1464 1784 1912  1050 1052 1064 1090 +hsync +vsync (81.5 kHz d)
[    41.804] (II) modeset(0): Modeline "1400x1050"x70.0  145.06  1400 1496 1648 1896  1050 1051 1054 1093 -hsync +vsync (76.5 kHz d)
[    41.804] (II) modeset(0): Modeline "1400x1050"x60.0  122.00  1400 1488 1640 1880  1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[    41.804] (II) modeset(0): Modeline "1600x900"x120.0  246.00  1600 1728 1900 2200  900 901 904 932 doublescan -hsync +vsync (111.8 kHz d)
[    41.804] (II) modeset(0): Modeline "1600x900"x119.9  186.50  1600 1624 1640 1680  900 901 904 926 doublescan +hsync -vsync (111.0 kHz d)
[    41.804] (II) modeset(0): Modeline "1600x900"x59.9  118.25  1600 1696 1856 2112  900 903 908 934 -hsync +vsync (56.0 kHz d)
[    41.804] (II) modeset(0): Modeline "1600x900"x59.8   97.50  1600 1648 1680 1760  900 903 908 926 +hsync -vsync (55.4 kHz d)
[    41.804] (II) modeset(0): Modeline "1280x1024"x85.0  157.50  1280 1344 1504 1728  1024 1025 1028 1072 +hsync +vsync (91.1 kHz d)
[    41.804] (II) modeset(0): Modeline "1280x1024"x75.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz d)
[    41.804] (II) modeset(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
[    41.804] (II) modeset(0): Modeline "1440x900"x59.9  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz d)
[    41.804] (II) modeset(0): Modeline "1400x900"x60.0  103.50  1400 1480 1624 1848  900 903 913 934 -hsync +vsync (56.0 kHz d)
[    41.804] (II) modeset(0): Modeline "1400x900"x59.9   86.50  1400 1448 1480 1560  900 903 913 926 +hsync -vsync (55.4 kHz d)
[    41.804] (II) modeset(0): Modeline "1280x960"x85.0  148.50  1280 1344 1504 1728  960 961 964 1011 +hsync +vsync (85.9 kHz d)
[    41.804] (II) modeset(0): Modeline "1280x960"x60.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz d)
[    41.804] (II) modeset(0): Modeline "1440x810"x120.0  198.12  1440 1548 1704 1968  810 811 814 839 doublescan -hsync +vsync (100.7 kHz d)
[    41.804] (II) modeset(0): Modeline "1440x810"x119.9  151.88  1440 1464 1480 1520  810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
[    41.804] (II) modeset(0): Modeline "1368x768"x59.9   85.25  1368 1440 1576 1784  768 771 781 798 -hsync +vsync (47.8 kHz d)
[    41.804] (II) modeset(0): Modeline "1368x768"x59.9   72.25  1368 1416 1448 1528  768 771 781 790 +hsync -vsync (47.3 kHz d)
[    41.804] (II) modeset(0): Modeline "1360x768"x59.8   84.75  1360 1432 1568 1776  768 771 781 798 -hsync +vsync (47.7 kHz d)
[    41.804] (II) modeset(0): Modeline "1360x768"x60.0   72.00  1360 1408 1440 1520  768 771 781 790 +hsync -vsync (47.4 kHz d)
[    41.804] (II) modeset(0): Modeline "1280x800"x120.0  174.25  1280 1380 1516 1752  800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
[    41.804] (II) modeset(0): Modeline "1280x800"x119.9  134.25  1280 1304 1320 1360  800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
[    41.804] (II) modeset(0): Modeline "1280x800"x59.8   83.50  1280 1352 1480 1680  800 803 809 831 -hsync +vsync (49.7 kHz d)
[    41.804] (II) modeset(0): Modeline "1280x800"x59.9   71.00  1280 1328 1360 1440  800 803 809 823 +hsync -vsync (49.3 kHz d)
[    41.804] (II) modeset(0): Modeline "1152x864"x100.0  143.47  1152 1232 1360 1568  864 865 868 915 -hsync +vsync (91.5 kHz d)
[    41.804] (II) modeset(0): Modeline "1152x864"x85.1  121.50  1152 1216 1344 1568  864 865 868 911 +hsync -vsync (77.5 kHz d)
[    41.804] (II) modeset(0): Modeline "1152x864"x85.0  119.65  1152 1224 1352 1552  864 865 868 907 -hsync +vsync (77.1 kHz d)
[    41.804] (II) modeset(0): Modeline "1152x864"x75.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz d)
[    41.804] (II) modeset(0): Modeline "1152x864"x75.0  104.99  1152 1224 1352 1552  864 865 868 902 -hsync +vsync (67.6 kHz d)
[    41.804] (II) modeset(0): Modeline "1152x864"x70.0   96.77  1152 1224 1344 1536  864 865 868 900 -hsync +vsync (63.0 kHz d)
[    41.804] (II) modeset(0): Modeline "1152x864"x60.0   81.62  1152 1216 1336 1520  864 865 868 895 -hsync +vsync (53.7 kHz d)
[    41.804] (II) modeset(0): Modeline "1280x720"x120.0  156.12  1280 1376 1512 1744  720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[    41.804] (II) modeset(0): Modeline "1280x720"x120.0  120.75  1280 1304 1320 1360  720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[    41.804] (II) modeset(0): Modeline "1280x720"x59.9   74.50  1280 1344 1472 1664  720 723 728 748 -hsync +vsync (44.8 kHz d)
[    41.804] (II) modeset(0): Modeline "1280x720"x59.7   63.75  1280 1328 1360 1440  720 723 728 741 +hsync -vsync (44.3 kHz d)
[    41.804] (II) modeset(0): Modeline "1024x768"x170.0  194.02  1024 1108 1220 1416  768 768 770 806 doublescan -hsync +vsync (137.0 kHz d)
[    41.804] (II) modeset(0): Modeline "1024x768"x150.1  170.24  1024 1108 1220 1416  768 768 770 801 doublescan -hsync +vsync (120.2 kHz d)
[    41.804] (II) modeset(0): Modeline "1024x768"x120.1  133.47  1024 1100 1212 1400  768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[    41.804] (II) modeset(0): Modeline "1024x768"x85.0   94.50  1024 1072 1168 1376  768 769 772 808 +hsync +vsync (68.7 kHz d)
[    41.804] (II) modeset(0): Modeline "1024x768"x75.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz d)
[    41.804] (II) modeset(0): Modeline "1024x768"x70.1   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz d)
[    41.804] (II) modeset(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz d)
[    41.804] (II) modeset(0): Modeline "1024x768i"x43.5   44.90  1024 1032 1208 1264  768 768 776 817 interlace +hsync +vsync (35.5 kHz d)
[    41.804] (II) modeset(0): Modeline "960x720"x170.0  170.68  960 1036 1144 1328  720 720 722 756 doublescan -hsync +vsync (128.5 kHz d)
[    41.804] (II) modeset(0): Modeline "960x720"x150.0  148.50  960 1032 1144 1320  720 720 722 750 doublescan -hsync +vsync (112.5 kHz d)
[    41.804] (II) modeset(0): Modeline "960x720"x120.0  117.00  960 1024 1128 1300  720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[    41.804] (II) modeset(0): Modeline "928x696"x150.0  144.00  928 992 1104 1280  696 696 698 750 doublescan -hsync +vsync (112.5 kHz d)
[    41.804] (II) modeset(0): Modeline "928x696"x120.1  109.15  928 976 1088 1264  696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[    41.804] (II) modeset(0): Modeline "896x672"x150.1  130.50  896 944 1052 1228  672 672 674 708 doublescan -hsync +vsync (106.3 kHz d)
[    41.804] (II) modeset(0): Modeline "896x672"x120.0  102.40  896 960 1060 1224  672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[    41.804] (II) modeset(0): Modeline "1024x576"x119.9   98.50  1024 1092 1200 1376  576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[    41.804] (II) modeset(0): Modeline "1024x576"x119.9   78.38  1024 1048 1064 1104  576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[    41.804] (II) modeset(0): Modeline "1024x576"x59.9   46.50  1024 1064 1160 1296  576 579 584 599 -hsync +vsync (35.9 kHz d)
[    41.804] (II) modeset(0): Modeline "1024x576"x59.8   42.00  1024 1072 1104 1184  576 579 584 593 +hsync -vsync (35.5 kHz d)
[    41.804] (II) modeset(0): Modeline "960x600"x119.9   96.62  960 1028 1128 1296  600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[    41.804] (II) modeset(0): Modeline "960x600"x120.0   77.00  960 984 1000 1040  600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[    41.804] (II) modeset(0): Modeline "832x624"x74.6   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz d)
[    41.804] (II) modeset(0): Modeline "960x540"x119.9   86.50  960 1024 1124 1288  540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[    41.804] (II) modeset(0): Modeline "960x540"x120.0   69.25  960 984 1000 1040  540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[    41.804] (II) modeset(0): Modeline "960x540"x59.6   40.75  960 992 1088 1216  540 543 548 562 -hsync +vsync (33.5 kHz d)
[    41.804] (II) modeset(0): Modeline "960x540"x59.8   37.25  960 1008 1040 1120  540 543 548 556 +hsync -vsync (33.3 kHz d)
[    41.804] (II) modeset(0): Modeline "800x600"x170.0  114.75  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (106.2 kHz d)
[    41.804] (II) modeset(0): Modeline "800x600"x150.0  101.25  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (93.8 kHz d)
[    41.804] (II) modeset(0): Modeline "800x600"x140.0   94.50  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (87.5 kHz d)
[    41.804] (II) modeset(0): Modeline "800x600"x130.0   87.75  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (81.2 kHz d)
[    41.804] (II) modeset(0): Modeline "800x600"x120.0   81.00  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[    41.804] (II) modeset(0): Modeline "800x600"x85.1   56.30  800 832 896 1048  600 601 604 631 +hsync +vsync (53.7 kHz d)
[    41.804] (II) modeset(0): Modeline "800x600"x72.2   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz d)
[    41.805] (II) modeset(0): Modeline "800x600"x75.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz d)
[    41.805] (II) modeset(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz d)
[    41.805] (II) modeset(0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz d)
[    41.805] (II) modeset(0): Modeline "840x525"x170.0  107.38  840 904 992 1144  525 526 529 552 doublescan -hsync +vsync (93.9 kHz d)
[    41.805] (II) modeset(0): Modeline "840x525"x149.9   93.50  840 900 988 1136  525 526 529 549 doublescan -hsync +vsync (82.3 kHz d)
[    41.805] (II) modeset(0): Modeline "840x525"x139.8   87.00  840 900 988 1136  525 526 529 548 doublescan -hsync +vsync (76.6 kHz d)
[    41.805] (II) modeset(0): Modeline "840x525"x120.0   73.12  840 892 980 1120  525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[    41.805] (II) modeset(0): Modeline "840x525"x119.8   59.50  840 864 880 920  525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[    41.805] (II) modeset(0): Modeline "864x486"x59.9   32.50  864 888 968 1072  486 489 494 506 -hsync +vsync (30.3 kHz d)
[    41.805] (II) modeset(0): Modeline "864x486"x59.6   30.50  864 912 944 1024  486 489 494 500 +hsync -vsync (29.8 kHz d)
[    41.805] (II) modeset(0): Modeline "800x512"x120.3   51.56  800 800 828 832  512 512 514 515 doublescan +hsync +vsync (62.0 kHz d)
[    41.805] (II) modeset(0): Modeline "700x525"x170.2   89.63  700 752 828 956  525 525 527 551 doublescan -hsync +vsync (93.8 kHz d)
[    41.805] (II) modeset(0): Modeline "700x525"x149.5   77.90  700 732 892 956  525 526 532 545 doublescan +hsync +vsync (81.5 kHz d)
[    41.805] (II) modeset(0): Modeline "700x525"x140.1   72.53  700 748 824 948  525 525 527 546 doublescan -hsync +vsync (76.5 kHz d)
[    41.805] (II) modeset(0): Modeline "700x525"x120.0   61.00  700 744 820 940  525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[    41.805] (II) modeset(0): Modeline "800x450"x119.9   59.12  800 848 928 1056  450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[    41.805] (II) modeset(0): Modeline "800x450"x119.6   48.75  800 824 840 880  450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[    41.805] (II) modeset(0): Modeline "640x512"x170.0   78.75  640 672 752 864  512 512 514 536 doublescan +hsync +vsync (91.1 kHz d)
[    41.805] (II) modeset(0): Modeline "640x512"x150.0   67.50  640 648 720 844  512 512 514 533 doublescan +hsync +vsync (80.0 kHz d)
[    41.805] (II) modeset(0): Modeline "640x512"x120.0   54.00  640 664 720 844  512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[    41.805] (II) modeset(0): Modeline "720x450"x119.8   53.25  720 760 836 952  450 451 454 467 doublescan -hsync +vsync (55.9 kHz d)
[    41.805] (II) modeset(0): Modeline "700x450"x119.9   51.75  700 740 812 924  450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[    41.805] (II) modeset(0): Modeline "700x450"x119.8   43.25  700 724 740 780  450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[    41.805] (II) modeset(0): Modeline "640x480"x170.2   74.25  640 672 752 864  480 480 482 505 doublescan +hsync +vsync (85.9 kHz d)
[    41.805] (II) modeset(0): Modeline "640x480"x120.0   54.00  640 688 744 900  480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[    41.805] (II) modeset(0): Modeline "640x480"x85.0   36.00  640 696 752 832  480 481 484 509 -hsync -vsync (43.3 kHz d)
[    41.805] (II) modeset(0): Modeline "640x480"x72.8   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz d)
[    41.805] (II) modeset(0): Modeline "640x480"x75.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz d)
[    41.805] (II) modeset(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz d)
[    41.805] (II) modeset(0): Modeline "720x405"x59.5   22.50  720 744 808 896  405 408 413 422 -hsync +vsync (25.1 kHz d)
[    41.805] (II) modeset(0): Modeline "720x405"x59.0   21.75  720 768 800 880  405 408 413 419 +hsync -vsync (24.7 kHz d)
[    41.805] (II) modeset(0): Modeline "720x400"x85.0   35.50  720 756 828 936  400 401 404 446 -hsync +vsync (37.9 kHz d)
[    41.805] (II) modeset(0): Modeline "684x384"x119.8   42.62  684 720 788 892  384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[    41.805] (II) modeset(0): Modeline "684x384"x119.7   36.12  684 708 724 764  384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[    41.805] (II) modeset(0): Modeline "680x384"x119.6   42.38  680 716 784 888  384 385 390 399 doublescan -hsync +vsync (47.7 kHz d)
[    41.805] (II) modeset(0): Modeline "680x384"x119.9   36.00  680 704 720 760  384 385 390 395 doublescan +hsync -vsync (47.4 kHz d)
[    41.805] (II) modeset(0): Modeline "640x400"x119.8   41.75  640 676 740 840  400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[    41.805] (II) modeset(0): Modeline "640x400"x120.0   35.50  640 664 680 720  400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[    41.805] (II) modeset(0): Modeline "640x400"x85.1   31.50  640 672 736 832  400 401 404 445 -hsync +vsync (37.9 kHz d)
[    41.805] (II) modeset(0): Modeline "576x432"x200.2   71.73  576 616 680 784  432 432 434 457 doublescan -hsync +vsync (91.5 kHz d)
[    41.805] (II) modeset(0): Modeline "576x432"x170.3   60.75  576 608 672 784  432 432 434 455 doublescan +hsync -vsync (77.5 kHz d)
[    41.805] (II) modeset(0): Modeline "576x432"x170.2   59.83  576 612 676 776  432 432 434 453 doublescan -hsync +vsync (77.1 kHz d)
[    41.805] (II) modeset(0): Modeline "576x432"x150.0   54.00  576 608 672 800  432 432 434 450 doublescan +hsync +vsync (67.5 kHz d)
[    41.805] (II) modeset(0): Modeline "576x432"x150.0   52.49  576 612 676 776  432 432 434 451 doublescan -hsync +vsync (67.6 kHz d)
[    41.805] (II) modeset(0): Modeline "576x432"x140.0   48.38  576 612 672 768  432 432 434 450 doublescan -hsync +vsync (63.0 kHz d)
[    41.805] (II) modeset(0): Modeline "576x432"x120.1   40.81  576 608 668 760  432 432 434 447 doublescan -hsync +vsync (53.7 kHz d)
[    41.805] (II) modeset(0): Modeline "640x360"x119.7   37.25  640 672 736 832  360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[    41.805] (II) modeset(0): Modeline "640x360"x119.7   31.88  640 664 680 720  360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[    41.805] (II) modeset(0): Modeline "640x360"x59.8   18.00  640 664 720 800  360 363 368 376 -hsync +vsync (22.5 kHz d)
[    41.805] (II) modeset(0): Modeline "640x360"x59.3   17.75  640 688 720 800  360 363 368 374 +hsync -vsync (22.2 kHz d)
[    41.805] (II) modeset(0): Modeline "640x350"x85.1   31.50  640 672 736 832  350 382 385 445 +hsync -vsync (37.9 kHz d)
[    41.805] (II) modeset(0): Modeline "512x384"x170.0   47.25  512 536 584 688  384 384 386 404 doublescan +hsync +vsync (68.7 kHz d)
[    41.805] (II) modeset(0): Modeline "512x384"x150.1   39.38  512 520 568 656  384 384 386 400 doublescan +hsync +vsync (60.0 kHz d)
[    41.805] (II) modeset(0): Modeline "512x384"x140.1   37.50  512 524 592 664  384 385 388 403 doublescan -hsync -vsync (56.5 kHz d)
[    41.805] (II) modeset(0): Modeline "512x384"x120.0   32.50  512 524 592 672  384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[    41.805] (II) modeset(0): Modeline "512x384i"x87.1   22.45  512 516 604 632  384 384 388 408 interlace doublescan +hsync +vsync (35.5 kHz d)
[    41.805] (II) modeset(0): Modeline "512x288"x120.0   23.25  512 532 580 648  288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[    41.805] (II) modeset(0): Modeline "512x288"x119.8   21.00  512 536 552 592  288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[    41.805] (II) modeset(0): Modeline "416x312"x149.3   28.64  416 432 464 576  312 312 314 333 doublescan -hsync -vsync (49.7 kHz d)
[    41.805] (II) modeset(0): Modeline "480x270"x119.3   20.38  480 496 544 608  270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[    41.805] (II) modeset(0): Modeline "480x270"x119.6   18.62  480 504 520 560  270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[    41.805] (II) modeset(0): Modeline "400x300"x170.5   28.15  400 416 448 524  300 300 302 315 doublescan +hsync +vsync (53.7 kHz d)
[    41.805] (II) modeset(0): Modeline "400x300"x144.4   25.00  400 428 488 520  300 318 321 333 doublescan +hsync +vsync (48.1 kHz d)
[    41.805] (II) modeset(0): Modeline "400x300"x150.2   24.75  400 408 448 528  300 300 302 312 doublescan +hsync +vsync (46.9 kHz d)
[    41.805] (II) modeset(0): Modeline "400x300"x120.6   20.00  400 420 484 528  300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[    41.805] (II) modeset(0): Modeline "400x300"x112.7   18.00  400 412 448 512  300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[    41.805] (II) modeset(0): Modeline "432x243"x119.8   16.25  432 444 484 536  243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[    41.805] (II) modeset(0): Modeline "432x243"x119.1   15.25  432 456 472 512  243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[    41.805] (II) modeset(0): Modeline "320x240"x170.4   18.00  320 348 376 416  240 240 242 254 doublescan -hsync -vsync (43.3 kHz d)
[    41.805] (II) modeset(0): Modeline "320x240"x145.6   15.75  320 332 352 416  240 244 246 260 doublescan -hsync -vsync (37.9 kHz d)
[    41.805] (II) modeset(0): Modeline "320x240"x150.0   15.75  320 328 360 420  240 240 242 250 doublescan -hsync -vsync (37.5 kHz d)
[    41.805] (II) modeset(0): Modeline "320x240"x120.1   12.59  320 328 376 400  240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[    41.805] (II) modeset(0): Modeline "360x202"x119.0   11.25  360 372 404 448  202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[    41.805] (II) modeset(0): Modeline "360x202"x118.3   10.88  360 384 400 440  202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[    41.805] (II) modeset(0): Modeline "360x200"x170.1   17.75  360 378 414 468  200 200 202 223 doublescan -hsync +vsync (37.9 kHz d)
[    41.805] (II) modeset(0): Modeline "320x200"x170.5   15.75  320 336 368 416  200 200 202 222 doublescan -hsync +vsync (37.9 kHz d)
[    41.805] (II) modeset(0): Modeline "320x180"x119.7    9.00  320 332 360 400  180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[    41.805] (II) modeset(0): Modeline "320x180"x118.6    8.88  320 344 360 400  180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[    41.805] (II) modeset(0): Modeline "320x175"x170.5   15.75  320 336 368 416  175 191 192 222 doublescan +hsync -vsync (37.9 kHz d)
[    41.805] (II) modeset(0): Output eDP-1 connected
[    41.805] (II) modeset(0): Using exact sizes for initial modes
[    41.805] (II) modeset(0): Output eDP-1 using initial mode 1920x1080 +0+0
[    41.805] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[    41.805] (==) modeset(0): DPI set to (96, 96)
[    41.805] (II) Loading sub module "fb"
[    41.805] (II) LoadModule: "fb"
[    41.805] (II) Loading /usr/lib/xorg/modules/libfb.so
[    41.805] (II) Module fb: vendor="X.Org Foundation"
[    41.805] 	compiled for 1.20.8, module version = 1.0.0
[    41.805] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    41.805] (==) NVIDIA(G0): Depth 24, (==) framebuffer bpp 32
[    41.805] (==) NVIDIA(G0): RGB weight 888
[    41.805] (==) NVIDIA(G0): Default visual is TrueColor
[    41.805] (==) NVIDIA(G0): Using gamma correction (1.0, 1.0, 1.0)
[    41.806] (**) NVIDIA(G0): Enabling 2D acceleration
[    41.806] (EE) NVIDIA(G0): GPU screens are not yet supported by the NVIDIA driver
[    41.806] (EE) NVIDIA(G0): Failing initialization of X screen
[    41.806] (II) UnloadModule: "nvidia"
[    41.806] (II) UnloadSubModule: "wfb"
[    41.806] (II) UnloadSubModule: "fb"
[    41.806] (II) UnloadModule: "nouveau"
[    41.806] (II) Unloading nouveau
[    41.806] (II) UnloadModule: "fbdev"
[    41.806] (II) Unloading fbdev
[    41.806] (II) UnloadSubModule: "fbdevhw"
[    41.806] (II) Unloading fbdevhw
[    41.806] (II) UnloadModule: "vesa"
[    41.806] (II) Unloading vesa
[    41.820] (==) modeset(0): Backing store enabled
[    41.820] (==) modeset(0): Silken mouse enabled
[    41.851] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[    41.852] (==) modeset(0): DPMS enabled
[    41.852] (II) modeset(0): [DRI2] Setup complete
[    41.852] (II) modeset(0): [DRI2]   DRI driver: iris
[    41.852] (II) modeset(0): [DRI2]   VDPAU driver: va_gl
[    41.852] (II) Initializing extension Generic Event Extension
[    41.852] (II) Initializing extension SHAPE
[    41.852] (II) Initializing extension MIT-SHM
[    41.852] (II) Initializing extension XInputExtension
[    41.853] (II) Initializing extension XTEST
[    41.853] (II) Initializing extension BIG-REQUESTS
[    41.853] (II) Initializing extension SYNC
[    41.853] (II) Initializing extension XKEYBOARD
[    41.853] (II) Initializing extension XC-MISC
[    41.854] (II) Initializing extension SECURITY
[    41.854] (II) Initializing extension XFIXES
[    41.854] (II) Initializing extension RENDER
[    41.854] (II) Initializing extension RANDR
[    41.854] (II) Initializing extension COMPOSITE
[    41.854] (II) Initializing extension DAMAGE
[    41.855] (II) Initializing extension MIT-SCREEN-SAVER
[    41.855] (II) Initializing extension DOUBLE-BUFFER
[    41.855] (II) Initializing extension RECORD
[    41.855] (II) Initializing extension DPMS
[    41.855] (II) Initializing extension Present
[    41.855] (II) Initializing extension DRI3
[    41.856] (II) Initializing extension X-Resource
[    41.856] (II) Initializing extension XVideo
[    41.856] (II) Initializing extension XVideo-MotionCompensation
[    41.856] (II) Initializing extension SELinux
[    41.856] (II) SELinux: Disabled on system
[    41.856] (II) Initializing extension GLX
[    41.869] (II) AIGLX: Loaded and initialized iris
[    41.869] (II) GLX: Initialized DRI2 GL provider for screen 0
[    41.869] (II) Initializing extension XFree86-VidModeExtension
[    41.869] (II) Initializing extension XFree86-DGA
[    41.869] (II) Initializing extension XFree86-DRI
[    41.869] (II) Initializing extension DRI2
[    41.875] (II) modeset(0): Damage tracking initialized
[    41.875] (II) modeset(0): Setting screen physical size to 508 x 285
[    41.930] (II) config/udev: Adding input device Video Bus (/dev/input/event21)
[    41.930] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[    41.930] (II) LoadModule: "libinput"
[    41.930] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    41.933] (II) Module libinput: vendor="X.Org Foundation"
[    41.933] 	compiled for 1.20.4, module version = 0.29.0
[    41.933] 	Module class: X.Org XInput Driver
[    41.933] 	ABI class: X.Org XInput driver, version 24.1
[    41.933] (II) Using input driver 'libinput' for 'Video Bus'
[    41.933] (**) Video Bus: always reports core events
[    41.933] (**) Option "Device" "/dev/input/event21"
[    41.933] (**) Option "_source" "server/udev"
[    41.938] (II) event21 - Video Bus: is tagged by udev as: Keyboard
[    41.938] (II) event21 - Video Bus: device is a keyboard
[    41.938] (II) event21 - Video Bus: device removed
[    42.023] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input25/event21"
[    42.023] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 6)
[    42.023] (**) Option "xkb_model" "pc105"
[    42.024] (**) Option "xkb_layout" "de"
[    42.070] (II) event21 - Video Bus: is tagged by udev as: Keyboard
[    42.070] (II) event21 - Video Bus: device is a keyboard
[    42.070] (II) config/udev: Adding input device Video Bus (/dev/input/event20)
[    42.070] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[    42.070] (II) Using input driver 'libinput' for 'Video Bus'
[    42.070] (**) Video Bus: always reports core events
[    42.070] (**) Option "Device" "/dev/input/event20"
[    42.070] (**) Option "_source" "server/udev"
[    42.071] (II) event20 - Video Bus: is tagged by udev as: Keyboard
[    42.071] (II) event20 - Video Bus: device is a keyboard
[    42.072] (II) event20 - Video Bus: device removed
[    42.127] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input24/event20"
[    42.127] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[    42.127] (**) Option "xkb_model" "pc105"
[    42.127] (**) Option "xkb_layout" "de"
[    42.129] (II) event20 - Video Bus: is tagged by udev as: Keyboard
[    42.129] (II) event20 - Video Bus: device is a keyboard
[    42.129] (II) config/udev: Adding input device Power Button (/dev/input/event9)
[    42.129] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    42.129] (II) Using input driver 'libinput' for 'Power Button'
[    42.129] (**) Power Button: always reports core events
[    42.129] (**) Option "Device" "/dev/input/event9"
[    42.129] (**) Option "_source" "server/udev"
[    42.130] (II) event9  - Power Button: is tagged by udev as: Keyboard
[    42.130] (II) event9  - Power Button: device is a keyboard
[    42.130] (II) event9  - Power Button: device removed
[    42.143] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input12/event9"
[    42.143] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[    42.143] (**) Option "xkb_model" "pc105"
[    42.143] (**) Option "xkb_layout" "de"
[    42.145] (II) event9  - Power Button: is tagged by udev as: Keyboard
[    42.145] (II) event9  - Power Button: device is a keyboard
[    42.145] (II) config/udev: Adding input device Lid Switch (/dev/input/event8)
[    42.145] (II) No input driver specified, ignoring this device.
[    42.145] (II) This device may have been added with another device file.
[    42.146] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event14)
[    42.146] (II) No input driver specified, ignoring this device.
[    42.146] (II) This device may have been added with another device file.
[    42.146] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event15)
[    42.147] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event16)
[    42.147] (II) No input driver specified, ignoring this device.
[    42.147] (II) This device may have been added with another device file.
[    42.147] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event17)
[    42.148] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event18)
[    42.148] (II) No input driver specified, ignoring this device.
[    42.148] (II) This device may have been added with another device file.
[    42.148] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event19)
[    42.149] (II) config/udev: Adding input device SunplusIT SmartMouse (/dev/input/event1)
[    42.149] (**) SunplusIT SmartMouse: Applying InputClass "libinput keyboard catchall"
[    42.149] (II) Using input driver 'libinput' for 'SunplusIT SmartMouse'
[    42.149] (**) SunplusIT SmartMouse: always reports core events
[    42.149] (**) Option "Device" "/dev/input/event1"
[    42.149] (**) Option "_source" "server/udev"
[    42.151] (II) event1  - SunplusIT SmartMouse: is tagged by udev as: Keyboard
[    42.151] (II) event1  - SunplusIT SmartMouse: device is a keyboard
[    42.151] (II) event1  - SunplusIT SmartMouse: device removed
[    42.195] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.0/0003:1BCF:0824.0002/input/input4/event1"
[    42.195] (II) XINPUT: Adding extended input device "SunplusIT SmartMouse" (type: KEYBOARD, id 9)
[    42.195] (**) Option "xkb_model" "pc105"
[    42.195] (**) Option "xkb_layout" "de"
[    42.198] (II) event1  - SunplusIT SmartMouse: is tagged by udev as: Keyboard
[    42.198] (II) event1  - SunplusIT SmartMouse: device is a keyboard
[    42.199] (II) config/udev: Adding input device SunplusIT SmartMouse (/dev/input/event2)
[    42.199] (**) SunplusIT SmartMouse: Applying InputClass "libinput pointer catchall"
[    42.199] (II) Using input driver 'libinput' for 'SunplusIT SmartMouse'
[    42.199] (**) SunplusIT SmartMouse: always reports core events
[    42.199] (**) Option "Device" "/dev/input/event2"
[    42.199] (**) Option "_source" "server/udev"
[    42.201] (II) event2  - SunplusIT SmartMouse: is tagged by udev as: Mouse
[    42.201] (II) event2  - SunplusIT SmartMouse: device is a pointer
[    42.202] (II) event2  - SunplusIT SmartMouse: device removed
[    42.251] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:1BCF:0824.0003/input/input5/event2"
[    42.251] (II) XINPUT: Adding extended input device "SunplusIT SmartMouse" (type: MOUSE, id 10)
[    42.252] (**) Option "AccelerationScheme" "none"
[    42.252] (**) SunplusIT SmartMouse: (accel) selected scheme none/0
[    42.252] (**) SunplusIT SmartMouse: (accel) acceleration factor: 2.000
[    42.252] (**) SunplusIT SmartMouse: (accel) acceleration threshold: 4
[    42.254] (II) event2  - SunplusIT SmartMouse: is tagged by udev as: Mouse
[    42.254] (II) event2  - SunplusIT SmartMouse: device is a pointer
[    42.255] (II) config/udev: Adding input device SunplusIT SmartMouse (/dev/input/mouse2)
[    42.255] (II) No input driver specified, ignoring this device.
[    42.255] (II) This device may have been added with another device file.
[    42.256] (II) config/udev: Adding input device SunplusIT SmartMouse Consumer Control (/dev/input/event3)
[    42.256] (**) SunplusIT SmartMouse Consumer Control: Applying InputClass "libinput keyboard catchall"
[    42.256] (II) Using input driver 'libinput' for 'SunplusIT SmartMouse Consumer Control'
[    42.256] (**) SunplusIT SmartMouse Consumer Control: always reports core events
[    42.256] (**) Option "Device" "/dev/input/event3"
[    42.256] (**) Option "_source" "server/udev"
[    42.258] (II) event3  - SunplusIT SmartMouse Consumer Control: is tagged by udev as: Keyboard
[    42.258] (II) event3  - SunplusIT SmartMouse Consumer Control: device is a keyboard
[    42.258] (II) event3  - SunplusIT SmartMouse Consumer Control: device removed
[    42.287] (II) libinput: SunplusIT SmartMouse Consumer Control: needs a virtual subdevice
[    42.287] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:1BCF:0824.0003/input/input6/event3"
[    42.287] (II) XINPUT: Adding extended input device "SunplusIT SmartMouse Consumer Control" (type: MOUSE, id 11)
[    42.288] (**) Option "AccelerationScheme" "none"
[    42.288] (**) SunplusIT SmartMouse Consumer Control: (accel) selected scheme none/0
[    42.288] (**) SunplusIT SmartMouse Consumer Control: (accel) acceleration factor: 2.000
[    42.288] (**) SunplusIT SmartMouse Consumer Control: (accel) acceleration threshold: 4
[    42.290] (II) event3  - SunplusIT SmartMouse Consumer Control: is tagged by udev as: Keyboard
[    42.290] (II) event3  - SunplusIT SmartMouse Consumer Control: device is a keyboard
[    42.291] (II) config/udev: Adding input device Integrated Camera: Integrated C (/dev/input/event13)
[    42.291] (**) Integrated Camera: Integrated C: Applying InputClass "libinput keyboard catchall"
[    42.291] (II) Using input driver 'libinput' for 'Integrated Camera: Integrated C'
[    42.291] (**) Integrated Camera: Integrated C: always reports core events
[    42.291] (**) Option "Device" "/dev/input/event13"
[    42.291] (**) Option "_source" "server/udev"
[    42.293] (II) event13 - Integrated Camera: Integrated C: is tagged by udev as: Keyboard
[    42.293] (II) event13 - Integrated Camera: Integrated C: device is a keyboard
[    42.293] (II) event13 - Integrated Camera: Integrated C: device removed
[    42.335] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.0/input/input17/event13"
[    42.335] (II) XINPUT: Adding extended input device "Integrated Camera: Integrated C" (type: KEYBOARD, id 12)
[    42.335] (**) Option "xkb_model" "pc105"
[    42.335] (**) Option "xkb_layout" "de"
[    42.338] (II) event13 - Integrated Camera: Integrated C: is tagged by udev as: Keyboard
[    42.338] (II) event13 - Integrated Camera: Integrated C: device is a keyboard
[    42.339] (II) config/udev: Adding input device ITE Tech. Inc. ITE Device(8910) Keyboard (/dev/input/event4)
[    42.339] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: Applying InputClass "libinput keyboard catchall"
[    42.339] (II) Using input driver 'libinput' for 'ITE Tech. Inc. ITE Device(8910) Keyboard'
[    42.339] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: always reports core events
[    42.339] (**) Option "Device" "/dev/input/event4"
[    42.339] (**) Option "_source" "server/udev"
[    42.341] (II) event4  - ITE Tech. Inc. ITE Device(8910) Keyboard: is tagged by udev as: Keyboard
[    42.341] (II) event4  - ITE Tech. Inc. ITE Device(8910) Keyboard: device is a keyboard
[    42.341] (II) event4  - ITE Tech. Inc. ITE Device(8910) Keyboard: device removed
[    42.363] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/0003:048D:C100.0004/input/input7/event4"
[    42.363] (II) XINPUT: Adding extended input device "ITE Tech. Inc. ITE Device(8910) Keyboard" (type: KEYBOARD, id 13)
[    42.363] (**) Option "xkb_model" "pc105"
[    42.363] (**) Option "xkb_layout" "de"
[    42.366] (II) event4  - ITE Tech. Inc. ITE Device(8910) Keyboard: is tagged by udev as: Keyboard
[    42.366] (II) event4  - ITE Tech. Inc. ITE Device(8910) Keyboard: device is a keyboard
[    42.367] (II) config/udev: Adding input device ITE Tech. Inc. ITE Device(8910) Consumer Control (/dev/input/event5)
[    42.367] (**) ITE Tech. Inc. ITE Device(8910) Consumer Control: Applying InputClass "libinput keyboard catchall"
[    42.367] (II) Using input driver 'libinput' for 'ITE Tech. Inc. ITE Device(8910) Consumer Control'
[    42.367] (**) ITE Tech. Inc. ITE Device(8910) Consumer Control: always reports core events
[    42.367] (**) Option "Device" "/dev/input/event5"
[    42.367] (**) Option "_source" "server/udev"
[    42.369] (II) event5  - ITE Tech. Inc. ITE Device(8910) Consumer Control: is tagged by udev as: Keyboard
[    42.370] (II) event5  - ITE Tech. Inc. ITE Device(8910) Consumer Control: device is a keyboard
[    42.370] (II) event5  - ITE Tech. Inc. ITE Device(8910) Consumer Control: device removed
[    42.391] (II) libinput: ITE Tech. Inc. ITE Device(8910) Consumer Control: needs a virtual subdevice
[    42.391] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/0003:048D:C100.0004/input/input8/event5"
[    42.391] (II) XINPUT: Adding extended input device "ITE Tech. Inc. ITE Device(8910) Consumer Control" (type: MOUSE, id 14)
[    42.392] (**) Option "AccelerationScheme" "none"
[    42.392] (**) ITE Tech. Inc. ITE Device(8910) Consumer Control: (accel) selected scheme none/0
[    42.392] (**) ITE Tech. Inc. ITE Device(8910) Consumer Control: (accel) acceleration factor: 2.000
[    42.392] (**) ITE Tech. Inc. ITE Device(8910) Consumer Control: (accel) acceleration threshold: 4
[    42.394] (II) event5  - ITE Tech. Inc. ITE Device(8910) Consumer Control: is tagged by udev as: Keyboard
[    42.394] (II) event5  - ITE Tech. Inc. ITE Device(8910) Consumer Control: device is a keyboard
[    42.395] (II) config/udev: Adding input device ITE Tech. Inc. ITE Device(8910) Wireless Radio Control (/dev/input/event6)
[    42.395] (**) ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: Applying InputClass "libinput keyboard catchall"
[    42.395] (II) Using input driver 'libinput' for 'ITE Tech. Inc. ITE Device(8910) Wireless Radio Control'
[    42.395] (**) ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: always reports core events
[    42.395] (**) Option "Device" "/dev/input/event6"
[    42.395] (**) Option "_source" "server/udev"
[    42.397] (II) event6  - ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: is tagged by udev as: Keyboard
[    42.397] (II) event6  - ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: device is a keyboard
[    42.397] (II) event6  - ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: device removed
[    42.443] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/0003:048D:C100.0004/input/input9/event6"
[    42.443] (II) XINPUT: Adding extended input device "ITE Tech. Inc. ITE Device(8910) Wireless Radio Control" (type: KEYBOARD, id 15)
[    42.443] (**) Option "xkb_model" "pc105"
[    42.443] (**) Option "xkb_layout" "de"
[    42.446] (II) event6  - ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: is tagged by udev as: Keyboard
[    42.446] (II) event6  - ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: device is a keyboard
[    42.447] (II) config/udev: Adding input device MSFT0001:01 04F3:309E Mouse (/dev/input/event10)
[    42.447] (**) MSFT0001:01 04F3:309E Mouse: Applying InputClass "libinput pointer catchall"
[    42.447] (II) Using input driver 'libinput' for 'MSFT0001:01 04F3:309E Mouse'
[    42.447] (**) MSFT0001:01 04F3:309E Mouse: always reports core events
[    42.447] (**) Option "Device" "/dev/input/event10"
[    42.447] (**) Option "_source" "server/udev"
[    42.449] (II) event10 - MSFT0001:01 04F3:309E Mouse: is tagged by udev as: Mouse
[    42.449] (II) event10 - MSFT0001:01 04F3:309E Mouse: device is a pointer
[    42.449] (II) event10 - MSFT0001:01 04F3:309E Mouse: device removed
[    42.487] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-MSFT0001:01/0018:04F3:309E.0001/input/input13/event10"
[    42.487] (II) XINPUT: Adding extended input device "MSFT0001:01 04F3:309E Mouse" (type: MOUSE, id 16)
[    42.488] (**) Option "AccelerationScheme" "none"
[    42.488] (**) MSFT0001:01 04F3:309E Mouse: (accel) selected scheme none/0
[    42.488] (**) MSFT0001:01 04F3:309E Mouse: (accel) acceleration factor: 2.000
[    42.488] (**) MSFT0001:01 04F3:309E Mouse: (accel) acceleration threshold: 4
[    42.490] (II) event10 - MSFT0001:01 04F3:309E Mouse: is tagged by udev as: Mouse
[    42.490] (II) event10 - MSFT0001:01 04F3:309E Mouse: device is a pointer
[    42.491] (II) config/udev: Adding input device MSFT0001:01 04F3:309E Mouse (/dev/input/mouse0)
[    42.491] (II) No input driver specified, ignoring this device.
[    42.491] (II) This device may have been added with another device file.
[    42.491] (II) config/udev: Adding input device MSFT0001:01 04F3:309E Touchpad (/dev/input/event11)
[    42.491] (**) MSFT0001:01 04F3:309E Touchpad: Applying InputClass "libinput touchpad catchall"
[    42.491] (II) Using input driver 'libinput' for 'MSFT0001:01 04F3:309E Touchpad'
[    42.491] (**) MSFT0001:01 04F3:309E Touchpad: always reports core events
[    42.491] (**) Option "Device" "/dev/input/event11"
[    42.491] (**) Option "_source" "server/udev"
[    42.493] (II) event11 - MSFT0001:01 04F3:309E Touchpad: is tagged by udev as: Touchpad
[    42.495] (II) event11 - MSFT0001:01 04F3:309E Touchpad: device is a touchpad
[    42.495] (II) event11 - MSFT0001:01 04F3:309E Touchpad: device removed
[    42.540] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-MSFT0001:01/0018:04F3:309E.0001/input/input15/event11"
[    42.540] (II) XINPUT: Adding extended input device "MSFT0001:01 04F3:309E Touchpad" (type: TOUCHPAD, id 17)
[    42.541] (**) Option "AccelerationScheme" "none"
[    42.541] (**) MSFT0001:01 04F3:309E Touchpad: (accel) selected scheme none/0
[    42.541] (**) MSFT0001:01 04F3:309E Touchpad: (accel) acceleration factor: 2.000
[    42.541] (**) MSFT0001:01 04F3:309E Touchpad: (accel) acceleration threshold: 4
[    42.543] (II) event11 - MSFT0001:01 04F3:309E Touchpad: is tagged by udev as: Touchpad
[    42.544] (II) event11 - MSFT0001:01 04F3:309E Touchpad: device is a touchpad
[    42.545] (II) config/udev: Adding input device MSFT0001:01 04F3:309E Touchpad (/dev/input/mouse1)
[    42.545] (II) No input driver specified, ignoring this device.
[    42.545] (II) This device may have been added with another device file.
[    42.546] (II) config/udev: Adding input device Ideapad extra buttons (/dev/input/event7)
[    42.546] (**) Ideapad extra buttons: Applying InputClass "libinput keyboard catchall"
[    42.546] (II) Using input driver 'libinput' for 'Ideapad extra buttons'
[    42.546] (**) Ideapad extra buttons: always reports core events
[    42.546] (**) Option "Device" "/dev/input/event7"
[    42.546] (**) Option "_source" "server/udev"
[    42.547] (II) event7  - Ideapad extra buttons: is tagged by udev as: Keyboard
[    42.547] (II) event7  - Ideapad extra buttons: device is a keyboard
[    42.548] (II) event7  - Ideapad extra buttons: device removed
[    42.579] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1f.0/PNP0C09:00/VPC2004:00/input/input10/event7"
[    42.579] (II) XINPUT: Adding extended input device "Ideapad extra buttons" (type: KEYBOARD, id 18)
[    42.579] (**) Option "xkb_model" "pc105"
[    42.579] (**) Option "xkb_layout" "de"
[    42.581] (II) event7  - Ideapad extra buttons: is tagged by udev as: Keyboard
[    42.582] (II) event7  - Ideapad extra buttons: device is a keyboard
[    42.582] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event22)
[    42.582] (II) No input driver specified, ignoring this device.
[    42.582] (II) This device may have been added with another device file.
[    42.583] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event23)
[    42.583] (II) No input driver specified, ignoring this device.
[    42.583] (II) This device may have been added with another device file.
[    42.583] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event24)
[    42.584] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event25)
[    42.584] (II) No input driver specified, ignoring this device.
[    42.584] (II) This device may have been added with another device file.
[    42.584] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event26)
[    42.585] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event27)
[    42.585] (II) No input driver specified, ignoring this device.
[    42.585] (II) This device may have been added with another device file.
[    42.585] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event28)
[    42.585] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event29)
[    42.586] (II) This device may have been added with another device file.
[    42.586] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event0)
[    42.586] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[    42.586] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[    42.586] (**) AT Translated Set 2 keyboard: always reports core events
[    42.586] (**) Option "Device" "/dev/input/event0"
[    42.586] (**) Option "_source" "server/udev"
[    42.588] (II) event0  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[    42.588] (II) event0  - AT Translated Set 2 keyboard: device is a keyboard
[    42.590] (II) event0  - AT Translated Set 2 keyboard: device removed
[    42.603] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input0/event0"
[    42.603] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 19)
[    42.603] (**) Option "xkb_model" "pc105"
[    42.603] (**) Option "xkb_layout" "de"
[    42.605] (II) event0  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[    42.606] (II) event0  - AT Translated Set 2 keyboard: device is a keyboard
[    42.608] (II) config/udev: Adding input device PC Speaker (/dev/input/event12)
[    42.608] (II) No input driver specified, ignoring this device.
[    42.608] (II) This device may have been added with another device file.
[    42.616] (**) SunplusIT SmartMouse Consumer Control: Applying InputClass "libinput keyboard catchall"
[    42.616] (II) Using input driver 'libinput' for 'SunplusIT SmartMouse Consumer Control'
[    42.616] (**) SunplusIT SmartMouse Consumer Control: always reports core events
[    42.616] (**) Option "Device" "/dev/input/event3"
[    42.616] (**) Option "_source" "_driver/libinput"
[    42.616] (II) libinput: SunplusIT SmartMouse Consumer Control: is a virtual subdevice
[    42.616] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:1BCF:0824.0003/input/input6/event3"
[    42.616] (II) XINPUT: Adding extended input device "SunplusIT SmartMouse Consumer Control" (type: KEYBOARD, id 20)
[    42.616] (**) Option "xkb_model" "pc105"
[    42.616] (**) Option "xkb_layout" "de"
[    42.617] (**) ITE Tech. Inc. ITE Device(8910) Consumer Control: Applying InputClass "libinput keyboard catchall"
[    42.617] (II) Using input driver 'libinput' for 'ITE Tech. Inc. ITE Device(8910) Consumer Control'
[    42.617] (**) ITE Tech. Inc. ITE Device(8910) Consumer Control: always reports core events
[    42.617] (**) Option "Device" "/dev/input/event5"
[    42.617] (**) Option "_source" "_driver/libinput"
[    42.617] (II) libinput: ITE Tech. Inc. ITE Device(8910) Consumer Control: is a virtual subdevice
[    42.617] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/0003:048D:C100.0004/input/input8/event5"
[    42.617] (II) XINPUT: Adding extended input device "ITE Tech. Inc. ITE Device(8910) Consumer Control" (type: KEYBOARD, id 21)
[    42.617] (**) Option "xkb_model" "pc105"
[    42.617] (**) Option "xkb_layout" "de"
There are errors and warnings in the Xorg.0.log:
and
I think especially this last message is important, but I have no idea of how to go on with that. I checked the nvidia developer forum, but this is huge and I didn't found a matching description/content. Still I feel this installation should run and there is just a minor alteration required.
And there is this daemon not correct established/running: nvidia-persistenced.
Any more ideas?
thanks for your help
Walter
#12 2020-06-14 10:47:11
If you're also experiencing the flicker in the console then it's nothing to do with the compositor or the DDX driver.
FWIW your X.Org log shows that X.Org's builtin modesetting driver is being used for your Intel iGPU.
I really don't know anything about NVIDIA (I would never give money to that company) so I can't help with that, sorry.
#13 2020-06-14 19:33:36
walter
I really appreciate that you are willing to help.
There is a another message in dmesg from udev: udevd[189]: Error running install command 'modprobe -i nvidia-current ' for module nvidia: retcode 1
cat dmesg
[    0.000000] microcode: microcode updated early to revision 0xd6, date = 2020-04-27
[    0.000000] Linux version 5.6.0-2-amd64 (debian-kernel@lists.debian.org) (gcc version 9.3.0 (Debian 9.3.0-13)) #1 SMP Debian 5.6.14-1 (2020-05-23)
[    0.000000] Command line: BOOT_IMAGE=/vmlinuz-5.6.0-2-amd64 root=/dev/mapper/vgs-root ro quiet
[    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[    0.000000] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.000000] x86/fpu: xstate_offset[3]:  832, xstate_sizes[3]:   64
[    0.000000] x86/fpu: xstate_offset[4]:  896, xstate_sizes[4]:   64
[    0.000000] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000073d86fff] usable
[    0.000000] BIOS-e820: [mem 0x0000000073d87000-0x0000000074686fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000074687000-0x000000008a89dfff] usable
[    0.000000] BIOS-e820: [mem 0x000000008a89e000-0x000000008aa9dfff] type 20
[    0.000000] BIOS-e820: [mem 0x000000008aa9e000-0x000000008b49dfff] reserved
[    0.000000] BIOS-e820: [mem 0x000000008b49e000-0x000000008bb8dfff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x000000008bb8e000-0x000000008bc0dfff] ACPI data
[    0.000000] BIOS-e820: [mem 0x000000008bc0e000-0x000000008bc0efff] usable
[    0.000000] BIOS-e820: [mem 0x000000008bc0f000-0x000000008f7fffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed10000-0x00000000fed19fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed84000-0x00000000fed84fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ff600000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000046e7fffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] efi: EFI v2.60 by INSYDE Corp.
[    0.000000] efi:  ACPI=0x8bc0d000  ACPI 2.0=0x8bc0d014  TPMFinalLog=0x8b475000  SMBIOS=0x8ac50000  SMBIOS 3.0=0x8ac4e000  ESRT=0x7b474918  MEMATTR=0x7ac88018
[    0.000000] secureboot: Secure boot could not be determined (mode 0)
[    0.000000] SMBIOS 3.0.1 present.
[    0.000000] DMI: LENOVO 81Q4/LNVNB161216, BIOS BHCN36WW 02/10/2020
[    0.000000] tsc: Detected 2600.000 MHz processor
[    0.000010] tsc: Detected 2599.992 MHz TSC
[    0.000010] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000011] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000017] last_pfn = 0x46e800 max_arch_pfn = 0x400000000
[    0.000020] MTRR default type: write-back
[    0.000021] MTRR fixed ranges enabled:
[    0.000022]   00000-9FFFF write-back
[    0.000023]   A0000-BFFFF uncachable
[    0.000024]   C0000-FFFFF write-protect
[    0.000024] MTRR variable ranges enabled:
[    0.000026]   0 base 00C0000000 mask 7FC0000000 uncachable
[    0.000027]   1 base 00A0000000 mask 7FE0000000 uncachable
[    0.000027]   2 base 0090000000 mask 7FF0000000 uncachable
[    0.000028]   3 base 008E000000 mask 7FFE000000 uncachable
[    0.000029]   4 base 008D000000 mask 7FFF000000 uncachable
[    0.000029]   5 base 2000000000 mask 6000000000 uncachable
[    0.000030]   6 base 1000000000 mask 7000000000 uncachable
[    0.000031]   7 base 0800000000 mask 7800000000 uncachable
[    0.000031]   8 base 4000000000 mask 4000000000 uncachable
[    0.000032]   9 disabled
[    0.000492] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.000650] last_pfn = 0x8bc0f max_arch_pfn = 0x400000000
[    0.008890] esrt: Reserving ESRT space from 0x000000007b474918 to 0x000000007b4749c8.
[    0.008894] e820: update [mem 0x7b474000-0x7b474fff] usable ==> reserved
[    0.008906] Using GB pages for direct mapping
[    0.008908] BRK [0x2dde01000, 0x2dde01fff] PGTABLE
[    0.008909] BRK [0x2dde02000, 0x2dde02fff] PGTABLE
[    0.008910] BRK [0x2dde03000, 0x2dde03fff] PGTABLE
[    0.008940] BRK [0x2dde04000, 0x2dde04fff] PGTABLE
[    0.008941] BRK [0x2dde05000, 0x2dde05fff] PGTABLE
[    0.009065] BRK [0x2dde06000, 0x2dde06fff] PGTABLE
[    0.009092] BRK [0x2dde07000, 0x2dde07fff] PGTABLE
[    0.009123] BRK [0x2dde08000, 0x2dde08fff] PGTABLE
[    0.009147] BRK [0x2dde09000, 0x2dde09fff] PGTABLE
[    0.009192] BRK [0x2dde0a000, 0x2dde0afff] PGTABLE
[    0.009255] BRK [0x2dde0b000, 0x2dde0bfff] PGTABLE
[    0.009342] RAMDISK: [mem 0x340d9000-0x36063fff]
[    0.009352] ACPI: Early table checksum verification disabled
[    0.009355] ACPI: RSDP 0x000000008BC0D014 000024 (v02 LENOVO)
[    0.009358] ACPI: XSDT 0x000000008BBEE188 000104 (v01 LENOVO CB-01    00000001      01000013)
[    0.009363] ACPI: FACP 0x000000008BBF1000 00010C (v05 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009367] ACPI: DSDT 0x000000008BBBD000 02FE66 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009369] ACPI: FACS 0x000000008BB0D000 000040
[    0.009371] ACPI: UEFI 0x000000008BC0C000 000236 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009374] ACPI: SSDT 0x000000008BC0A000 001B1C (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009377] ACPI: SSDT 0x000000008BC06000 0031D0 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009379] ACPI: UEFI 0x000000008BC05000 000042 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009382] ACPI: SSDT 0x000000008BC04000 00045A (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009384] ACPI: SSDT 0x000000008BC03000 000046 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009387] ACPI: TPM2 0x000000008BC02000 000034 (v03 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009389] ACPI: POAT 0x000000008BC01000 000055 (v03 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009391] ACPI: SSDT 0x000000008BBFC000 0044B6 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009393] ACPI: LPIT 0x000000008BBFB000 000094 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009396] ACPI: WSMT 0x000000008BBFA000 000028 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009398] ACPI: SSDT 0x000000008BBF9000 000C2F (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009400] ACPI: DBGP 0x000000008BBF8000 000034 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009402] ACPI: DBG2 0x000000008BBF7000 000061 (v00 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009405] ACPI: SSDT 0x000000008BBF6000 000896 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009407] ACPI: SSDT 0x000000008BBF3000 002F89 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009409] ACPI: ASF! 0x000000008BBF2000 0000A5 (v32 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009411] ACPI: HPET 0x000000008BBF0000 000038 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009414] ACPI: APIC 0x000000008BBEF000 00012C (v03 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009416] ACPI: MCFG 0x000000008BBED000 00003C (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009418] ACPI: SSDT 0x000000008BBBA000 002BBF (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009421] ACPI: DMAR 0x000000008BBB9000 0000A8 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009423] ACPI: SSDT 0x000000008BBB3000 005178 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009425] ACPI: SSDT 0x000000008BBB2000 00004C (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009427] ACPI: SSDT 0x000000008BBB1000 000123 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009430] ACPI: FPDT 0x000000008BBB0000 000044 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009432] ACPI: BGRT 0x000000008BBAF000 000038 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.009438] ACPI: Local APIC address 0xfee00000
[    0.009735] No NUMA configuration found
[    0.009736] Faking a node at [mem 0x0000000000000000-0x000000046e7fffff]
[    0.009739] NODE_DATA(0) allocated [mem 0x46e7fb000-0x46e7fffff]
[    0.009771] Zone ranges:
[    0.009772]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.009773]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.009774]   Normal   [mem 0x0000000100000000-0x000000046e7fffff]
[    0.009775]   Device   empty
[    0.009775] Movable zone start for each node
[    0.009776] Early memory node ranges
[    0.009777]   node   0: [mem 0x0000000000001000-0x000000000009efff]
[    0.009778]   node   0: [mem 0x0000000000100000-0x0000000073d86fff]
[    0.009779]   node   0: [mem 0x0000000074687000-0x000000008a89dfff]
[    0.009779]   node   0: [mem 0x000000008bc0e000-0x000000008bc0efff]
[    0.009780]   node   0: [mem 0x0000000100000000-0x000000046e7fffff]
[    0.010062] Zeroed struct page in unavailable ranges: 30915 pages
[    0.010063] Initmem setup node 0 [mem 0x0000000000001000-0x000000046e7fffff]
[    0.010064] On node 0 totalpages: 4163389
[    0.010065]   DMA zone: 64 pages used for memmap
[    0.010066]   DMA zone: 23 pages reserved
[    0.010067]   DMA zone: 3998 pages, LIFO batch:0
[    0.010126]   DMA32 zone: 8767 pages used for memmap
[    0.010127]   DMA32 zone: 561055 pages, LIFO batch:63
[    0.018435]   Normal zone: 56224 pages used for memmap
[    0.018436]   Normal zone: 3598336 pages, LIFO batch:63
[    0.018948] x86/hpet: Will disable the HPET for this platform because it's not reliable
[    0.018984] Reserving Intel graphics memory at [mem 0x8d800000-0x8f7fffff]
[    0.019531] ACPI: PM-Timer IO Port: 0x1808
[    0.019533] ACPI: Local APIC address 0xfee00000
[    0.019539] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.019540] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[    0.019540] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[    0.019541] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[    0.019541] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[    0.019542] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[    0.019542] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[    0.019543] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[    0.019543] ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
[    0.019544] ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
[    0.019544] ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
[    0.019545] ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
[    0.019545] ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
[    0.019546] ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
[    0.019546] ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
[    0.019547] ACPI: LAPIC_NMI (acpi_id[0x10] high edge lint[0x1])
[    0.019610] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[    0.019612] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.019613] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.019614] ACPI: IRQ0 used by override.
[    0.019615] ACPI: IRQ9 used by override.
[    0.019617] Using ACPI (MADT) for SMP configuration information
[    0.019618] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[    0.019624] e820: update [mem 0x7ad1b000-0x7ad5bfff] usable ==> reserved
[    0.019632] smpboot: Allowing 12 CPUs, 0 hotplug CPUs
[    0.019647] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.019648] PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x000fffff]
[    0.019650] PM: hibernation: Registered nosave memory: [mem 0x73d87000-0x74686fff]
[    0.019651] PM: hibernation: Registered nosave memory: [mem 0x7ad1b000-0x7ad5bfff]
[    0.019652] PM: hibernation: Registered nosave memory: [mem 0x7b474000-0x7b474fff]
[    0.019653] PM: hibernation: Registered nosave memory: [mem 0x8a89e000-0x8aa9dfff]
[    0.019654] PM: hibernation: Registered nosave memory: [mem 0x8aa9e000-0x8b49dfff]
[    0.019654] PM: hibernation: Registered nosave memory: [mem 0x8b49e000-0x8bb8dfff]
[    0.019655] PM: hibernation: Registered nosave memory: [mem 0x8bb8e000-0x8bc0dfff]
[    0.019656] PM: hibernation: Registered nosave memory: [mem 0x8bc0f000-0x8f7fffff]
[    0.019657] PM: hibernation: Registered nosave memory: [mem 0x8f800000-0xdfffffff]
[    0.019657] PM: hibernation: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[    0.019658] PM: hibernation: Registered nosave memory: [mem 0xf0000000-0xfdffffff]
[    0.019658] PM: hibernation: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
[    0.019658] PM: hibernation: Registered nosave memory: [mem 0xfe011000-0xfed0ffff]
[    0.019659] PM: hibernation: Registered nosave memory: [mem 0xfed10000-0xfed19fff]
[    0.019659] PM: hibernation: Registered nosave memory: [mem 0xfed1a000-0xfed83fff]
[    0.019660] PM: hibernation: Registered nosave memory: [mem 0xfed84000-0xfed84fff]
[    0.019660] PM: hibernation: Registered nosave memory: [mem 0xfed85000-0xfedfffff]
[    0.019661] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[    0.019661] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xff5fffff]
[    0.019662] PM: hibernation: Registered nosave memory: [mem 0xff600000-0xffffffff]
[    0.019663] [mem 0x8f800000-0xdfffffff] available for PCI devices
[    0.019664] Booting paravirtualized kernel on bare hardware
[    0.019666] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[    0.023439] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:12 nr_node_ids:1
[    0.023757] percpu: Embedded 55 pages/cpu s188120 r8192 d28968 u262144
[    0.023763] pcpu-alloc: s188120 r8192 d28968 u262144 alloc=1*2097152
[    0.023764] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 -- -- -- --
[    0.023789] Built 1 zonelists, mobility grouping on.  Total pages: 4098311
[    0.023790] Policy zone: Normal
[    0.023793] Kernel command line: BOOT_IMAGE=/vmlinuz-5.6.0-2-amd64 root=/dev/mapper/vgs-root ro quiet
[    0.024695] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.025135] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.025242] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.038408] Memory: 2239676K/16653556K available (10243K kernel code, 1285K rwdata, 3976K rodata, 1612K init, 1976K bss, 466084K reserved, 0K cma-reserved)
[    0.038414] random: get_random_u64 called from __kmem_cache_create+0x3e/0x530 with crng_init=0
[    0.038545] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[    0.038558] Kernel/User page tables isolation: enabled
[    0.038570] ftrace: allocating 34646 entries in 136 pages
[    0.051600] ftrace: allocated 136 pages with 2 groups
[    0.051686] rcu: Hierarchical RCU implementation.
[    0.051687] rcu: 	RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=12.
[    0.051688] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.051688] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[    0.054395] NR_IRQS: 33024, nr_irqs: 2152, preallocated irqs: 16
[    0.055096] random: crng done (trusting CPU's manufacturer)
[    0.055120] Console: colour dummy device 80x25
[    0.055124] printk: console [tty0] enabled
[    0.055143] ACPI: Core revision 20200110
[    0.055428] APIC: Switch to symmetric I/O mode setup
[    0.055430] DMAR: Host address width 39
[    0.055431] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[    0.055436] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 19e2ff0505e
[    0.055437] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[    0.055440] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[    0.055441] DMAR: RMRR base: 0x0000008b47d000 end: 0x0000008b49cfff
[    0.055442] DMAR: RMRR base: 0x0000008d000000 end: 0x0000008f7fffff
[    0.055446] DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 1
[    0.055447] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[    0.055448] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[    0.058598] DMAR-IR: Enabled IRQ remapping in x2apic mode
[    0.058599] x2apic enabled
[    0.058631] Switched APIC routing to cluster x2apic.
[    0.067582] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x257a34a6eea, max_idle_ns: 440795264358 ns
[    0.067587] Calibrating delay loop (skipped), value calculated using timer frequency.. 5199.98 BogoMIPS (lpj=10399968)
[    0.067589] pid_max: default: 32768 minimum: 301
[    0.071205] LSM: Security Framework initializing
[    0.071211] Yama: disabled by default; enable with sysctl kernel.yama.*
[    0.071235] AppArmor: AppArmor initialized
[    0.071236] TOMOYO Linux initialized
[    0.071273] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.071294] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.071565] mce: CPU0: Thermal monitoring enabled (TM1)
[    0.071584] process: using mwait in idle threads
[    0.071584] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[    0.071584] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[    0.071584] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.071584] Spectre V2 : Mitigation: Full generic retpoline
[    0.071584] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.071584] Spectre V2 : Enabling Restricted Speculation for firmware calls
[    0.071584] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.071584] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
[    0.071584] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[    0.071584] MDS: Mitigation: Clear CPU buffers
[    0.071584] Freeing SMP alternatives memory: 32K
[    0.071584] TSC deadline timer enabled
[    0.071584] smpboot: CPU0: Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz (family: 0x6, model: 0x9e, stepping: 0xa)
[    0.071584] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[    0.071584] ... version:                4
[    0.071584] ... bit width:              48
[    0.071584] ... generic registers:      4
[    0.071584] ... value mask:             0000ffffffffffff
[    0.071584] ... max period:             00007fffffffffff
[    0.071584] ... fixed-purpose events:   3
[    0.071584] ... event mask:             000000070000000f
[    0.071584] rcu: Hierarchical SRCU implementation.
[    0.071584] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.071584] smp: Bringing up secondary CPUs ...
[    0.071584] x86: Booting SMP configuration:
[    0.071584] .... node  #0, CPUs:        #1  #2  #3  #4  #5  #6
[    0.081879] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[    0.081879]   #7  #8  #9 #10 #11
[    0.084243] smp: Brought up 1 node, 12 CPUs
[    0.084243] smpboot: Max logical packages: 1
[    0.084243] smpboot: Total of 12 processors activated (62399.80 BogoMIPS)
[    0.127589] node 0 initialised, 3486949 pages in 40ms
[    0.127893] devtmpfs: initialized
[    0.127893] x86/mm: Memory block size: 128MB
[    0.129095] PM: Registering ACPI NVS region [mem 0x8b49e000-0x8bb8dfff] (7274496 bytes)
[    0.129095] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.129095] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[    0.129095] pinctrl core: initialized pinctrl subsystem
[    0.129095] thermal_sys: Registered thermal governor 'fair_share'
[    0.129095] thermal_sys: Registered thermal governor 'bang_bang'
[    0.129095] thermal_sys: Registered thermal governor 'step_wise'
[    0.129095] thermal_sys: Registered thermal governor 'user_space'
[    0.129095] NET: Registered protocol family 16
[    0.129095] audit: initializing netlink subsys (disabled)
[    0.129095] audit: type=2000 audit(1592159259.060:1): state=initialized audit_enabled=0 res=1
[    0.129095] cpuidle: using governor ladder
[    0.129095] cpuidle: using governor menu
[    0.129095] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.129095] ACPI: bus type PCI registered
[    0.129095] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.129095] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[    0.129095] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[    0.129095] PCI: Using configuration type 1 for base access
[    0.129095] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.132400] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.132400] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.263886] ACPI: Added _OSI(Module Device)
[    0.263886] ACPI: Added _OSI(Processor Device)
[    0.263886] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.263886] ACPI: Added _OSI(Processor Aggregator Device)
[    0.263886] ACPI: Added _OSI(Linux-Dell-Video)
[    0.263886] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.263886] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[    0.310059] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.TPLD], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.310068] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.310071] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.310115] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS01._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.310120] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.310123] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.310124] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS01._PLD], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.310128] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.310131] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.311670] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS02._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.311675] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.311678] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.311679] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS02._PLD], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.311683] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.311685] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.313211] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS03._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.313216] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.313219] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.313220] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS03._PLD], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.313224] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.313227] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.314751] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS04._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.314756] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.314759] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.314760] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS04._PLD], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.314764] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.314767] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.316296] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS05._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.316301] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.316303] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.317829] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS06._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.317834] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.317837] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.317838] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS06._PLD], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.317842] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.317845] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.319370] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS07._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.319375] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.319378] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.320909] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS08._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.320914] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.320917] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.322443] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS09._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.322447] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.322450] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.322451] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS09._PLD], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.322455] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.322458] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.323988] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS10._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.323993] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.323996] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.325522] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS11._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.325527] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.325529] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.327058] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS12._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.327063] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.327065] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.328597] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS13._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.328602] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.328604] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.330131] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS14._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.330136] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.330139] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.330140] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS14._PLD], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.330144] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.330147] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.331660] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.USR1], AE_NOT_FOUND (20200110/dswload2-162)
[    0.331665] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20200110/psobject-220)
[    0.331668] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0010)
[    0.331670] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.USR2], AE_NOT_FOUND (20200110/dswload2-162)
[    0.331674] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20200110/psobject-220)
[    0.331677] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0010)
[    0.331700] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS01._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.331705] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.331707] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.331709] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS01._PLD], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.331713] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.331715] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.331745] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS02._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.331749] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.331752] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.331753] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS02._PLD], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.331757] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.331760] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.331790] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS03._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.331794] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.331796] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.331798] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS03._PLD], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.331802] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.331804] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.331834] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS04._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.331838] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.331841] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.331842] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS04._PLD], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.331846] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.331849] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.331878] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS05._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.331882] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.331885] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.331910] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS06._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.331915] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.331917] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.331940] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS07._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.331945] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.331947] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.331971] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS08._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.331975] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.331978] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.332001] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS09._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.332005] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.332008] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.332031] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS10._UPC], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.332035] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.332038] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.332756] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.I2C2.TPD0], AE_NOT_FOUND (20200110/dswload2-162)
[    0.332761] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20200110/psobject-220)
[    0.332764] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0010)
[    0.332784] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.I2C3.TPL1], AE_NOT_FOUND (20200110/dswload2-162)
[    0.332788] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20200110/psobject-220)
[    0.332791] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0010)
[    0.335580] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.PEG0.PEGP._ON], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.335589] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.335593] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.335595] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.PEG0.PEGP._OFF], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.335599] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.335602] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.335603] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.PEG0.PEGP.SGPO], AE_ALREADY_EXISTS (20200110/dswload2-326)
[    0.335607] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
[    0.335610] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[    0.335776] ACPI: 13 ACPI AML tables successfully acquired and loaded
[    0.344915] ACPI: Dynamic OEM Table Load:
[    0.344928] ACPI: SSDT 0xFFFF903B5E520100 0000F4 (v02 PmRef  Cpu0Psd  00003000 INTL 20160422)
[    0.346122] ACPI: \_SB_.PR00: _OSC native thermal LVT Acked
[    0.346878] ACPI: Dynamic OEM Table Load:
[    0.346886] ACPI: SSDT 0xFFFF903B5E50A000 000400 (v02 PmRef  Cpu0Cst  00003001 INTL 20160422)
[    0.348192] ACPI: Dynamic OEM Table Load:
[    0.348199] ACPI: SSDT 0xFFFF90380739C000 000581 (v02 PmRef  Cpu0Ist  00003000 INTL 20160422)
[    0.349550] ACPI: Dynamic OEM Table Load:
[    0.349555] ACPI: SSDT 0xFFFF903B5C4C1E00 00011B (v02 PmRef  Cpu0Hwp  00003000 INTL 20160422)
[    0.350763] ACPI: Dynamic OEM Table Load:
[    0.350770] ACPI: SSDT 0xFFFF90380739B000 000724 (v02 PmRef  HwpLvt   00003000 INTL 20160422)
[    0.352241] ACPI: Dynamic OEM Table Load:
[    0.352248] ACPI: SSDT 0xFFFF90380739F800 0005FC (v02 PmRef  ApIst    00003000 INTL 20160422)
[    0.353610] ACPI: Dynamic OEM Table Load:
[    0.353616] ACPI: SSDT 0xFFFF903B5E508000 000317 (v02 PmRef  ApHwp    00003000 INTL 20160422)
[    0.354976] ACPI: Dynamic OEM Table Load:
[    0.354982] ACPI: SSDT 0xFFFF903807262000 000AB0 (v02 PmRef  ApPsd    00003000 INTL 20160422)
[    0.356759] ACPI: Dynamic OEM Table Load:
[    0.356765] ACPI: SSDT 0xFFFF903B5E508400 00030A (v02 PmRef  ApCst    00003000 INTL 20160422)
[    0.361875] ACPI: EC: EC started
[    0.361876] ACPI: EC: interrupt blocked
[    0.375674] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.375676] ACPI: \_SB_.PCI0.LPCB.EC0_: Boot DSDT EC used to handle transactions
[    0.375676] ACPI: Interpreter enabled
[    0.375728] ACPI: (supports S0 S3 S4 S5)
[    0.375729] ACPI: Using IOAPIC for interrupt routing
[    0.375768] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.376239] ACPI: Enabled 10 GPEs in block 00 to 7F
[    0.377291] ACPI: Power Resource [PG00] (on)
[    0.380787] ACPI: Power Resource [PUBS] (on)
[    0.381562] ACPI: Power Resource [BTPR] (on)
[    0.381562] ACPI: Power Resource [USBC] (on)
[    0.381562] ACPI: Power Resource [PAUD] (on)
[    0.387002] ACPI: Power Resource [PXP] (off)
[    0.393485] ACPI: Power Resource [PXP] (off)
[    0.394967] ACPI: Power Resource [V0PR] (on)
[    0.395123] ACPI: Power Resource [V1PR] (on)
[    0.395275] ACPI: Power Resource [V2PR] (on)
[    0.396627] ACPI: Power Resource [PXTC] (on)
[    0.396627] ACPI: Power Resource [PXTC] (off)
[    0.399655] ACPI: Power Resource [WRST] (on)
[    0.401462] ACPI: Power Resource [PIN] (off)
[    0.401791] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[    0.401796] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI HPX-Type3]
[    0.405407] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR]
[    0.405408] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[    0.407831] PCI host bridge to bus 0000:00
[    0.407833] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.407834] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.407835] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.407836] pci_bus 0000:00: root bus resource [mem 0x8f800000-0xdfffffff window]
[    0.407837] pci_bus 0000:00: root bus resource [mem 0xfc800000-0xfe7fffff window]
[    0.407838] pci_bus 0000:00: root bus resource [bus 00-fe]
[    0.407847] pci 0000:00:00.0: [8086:3ec4] type 00 class 0x060000
[    0.408809] pci 0000:00:01.0: [8086:1901] type 01 class 0x060400
[    0.409042] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[    0.410072] pci 0000:00:02.0: [8086:3e9b] type 00 class 0x030000
[    0.410100] pci 0000:00:02.0: reg 0x10: [mem 0xb5000000-0xb5ffffff 64bit]
[    0.410109] pci 0000:00:02.0: reg 0x18: [mem 0x90000000-0x9fffffff 64bit pref]
[    0.410112] pci 0000:00:02.0: reg 0x20: [io  0x5000-0x503f]
[    0.410154] pci 0000:00:02.0: BAR 2: assigned to efifb
[    0.411227] pci 0000:00:04.0: [8086:1903] type 00 class 0x118000
[    0.411255] pci 0000:00:04.0: reg 0x10: [mem 0xb4510000-0xb4517fff 64bit]
[    0.412399] pci 0000:00:08.0: [8086:1911] type 00 class 0x088000
[    0.412441] pci 0000:00:08.0: reg 0x10: [mem 0xb4524000-0xb4524fff 64bit]
[    0.413628] pci 0000:00:12.0: [8086:a379] type 00 class 0x118000
[    0.413696] pci 0000:00:12.0: reg 0x10: [mem 0xb4525000-0xb4525fff 64bit]
[    0.414954] pci 0000:00:14.0: [8086:a36d] type 00 class 0x0c0330
[    0.415004] pci 0000:00:14.0: reg 0x10: [mem 0xb4500000-0xb450ffff 64bit]
[    0.415200] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    0.416203] pci 0000:00:14.2: [8086:a36f] type 00 class 0x050000
[    0.416291] pci 0000:00:14.2: reg 0x10: [mem 0xb4520000-0xb4521fff 64bit]
[    0.416347] pci 0000:00:14.2: reg 0x18: [mem 0xb4526000-0xb4526fff 64bit]
[    0.417502] pci 0000:00:14.3: [8086:a370] type 00 class 0x028000
[    0.417727] pci 0000:00:14.3: reg 0x10: [mem 0xb4518000-0xb451bfff 64bit]
[    0.418556] pci 0000:00:14.3: PME# supported from D0 D3hot D3cold
[    0.419762] pci 0000:00:15.0: [8086:a368] type 00 class 0x0c8000
[    0.419830] pci 0000:00:15.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[    0.421031] pci 0000:00:15.1: [8086:a369] type 00 class 0x0c8000
[    0.421101] pci 0000:00:15.1: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[    0.422372] pci 0000:00:16.0: [8086:a360] type 00 class 0x078000
[    0.422441] pci 0000:00:16.0: reg 0x10: [mem 0xb4529000-0xb4529fff 64bit]
[    0.422691] pci 0000:00:16.0: PME# supported from D3hot
[    0.423782] pci 0000:00:17.0: [8086:a353] type 00 class 0x010601
[    0.423845] pci 0000:00:17.0: reg 0x10: [mem 0xb4522000-0xb4523fff]
[    0.423869] pci 0000:00:17.0: reg 0x14: [mem 0xb452e000-0xb452e0ff]
[    0.423893] pci 0000:00:17.0: reg 0x18: [io  0x5080-0x5087]
[    0.423909] pci 0000:00:17.0: reg 0x1c: [io  0x5088-0x508b]
[    0.423925] pci 0000:00:17.0: reg 0x20: [io  0x5060-0x507f]
[    0.423941] pci 0000:00:17.0: reg 0x24: [mem 0xb452d000-0xb452d7ff]
[    0.424060] pci 0000:00:17.0: PME# supported from D3hot
[    0.425129] pci 0000:00:1d.0: [8086:a330] type 01 class 0x060400
[    0.425447] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    0.425569] pci 0000:00:1d.0: PTM enabled (root), 4ns granularity
[    0.426627] pci 0000:00:1d.5: [8086:a335] type 01 class 0x060400
[    0.426950] pci 0000:00:1d.5: PME# supported from D0 D3hot D3cold
[    0.427070] pci 0000:00:1d.5: PTM enabled (root), 4ns granularity
[    0.428109] pci 0000:00:1e.0: [8086:a328] type 00 class 0x078000
[    0.428179] pci 0000:00:1e.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[    0.429451] pci 0000:00:1f.0: [8086:a30d] type 00 class 0x060100
[    0.430867] pci 0000:00:1f.3: [8086:a348] type 00 class 0x040300
[    0.430967] pci 0000:00:1f.3: reg 0x10: [mem 0xb451c000-0xb451ffff 64bit]
[    0.431049] pci 0000:00:1f.3: reg 0x20: [mem 0xb4200000-0xb42fffff 64bit]
[    0.431342] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[    0.432449] pci 0000:00:1f.4: [8086:a323] type 00 class 0x0c0500
[    0.432653] pci 0000:00:1f.4: reg 0x10: [mem 0xb452b000-0xb452b0ff 64bit]
[    0.432885] pci 0000:00:1f.4: reg 0x20: [io  0x5040-0x505f]
[    0.434060] pci 0000:00:1f.5: [8086:a324] type 00 class 0x0c8000
[    0.434104] pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
[    0.435355] pci 0000:01:00.0: [10de:2191] type 00 class 0x030000
[    0.435414] pci 0000:01:00.0: reg 0x10: [mem 0xb3000000-0xb3ffffff]
[    0.435459] pci 0000:01:00.0: reg 0x14: [mem 0xa0000000-0xafffffff 64bit pref]
[    0.435498] pci 0000:01:00.0: reg 0x1c: [mem 0xb0000000-0xb1ffffff 64bit pref]
[    0.435513] pci 0000:01:00.0: reg 0x24: [io  0x4000-0x407f]
[    0.435529] pci 0000:01:00.0: reg 0x30: [mem 0xfff80000-0xffffffff pref]
[    0.435703] pci 0000:01:00.0: PME# supported from D0 D3hot
[    0.435965] pci 0000:01:00.1: [10de:1aeb] type 00 class 0x040300
[    0.435983] pci 0000:01:00.1: reg 0x10: [mem 0xb4000000-0xb4003fff]
[    0.436369] pci 0000:01:00.2: [10de:1aec] type 00 class 0x0c0330
[    0.436397] pci 0000:01:00.2: reg 0x10: [mem 0xb4100000-0xb413ffff 64bit pref]
[    0.436465] pci 0000:01:00.2: reg 0x1c: [mem 0xb4140000-0xb414ffff 64bit pref]
[    0.436607] pci 0000:01:00.2: PME# supported from D0 D3hot
[    0.436762] pci 0000:01:00.3: [10de:1aed] type 00 class 0x0c8000
[    0.436799] pci 0000:01:00.3: reg 0x10: [mem 0xb4004000-0xb4004fff]
[    0.437021] pci 0000:01:00.3: PME# supported from D0 D3hot
[    0.437232] pci 0000:00:01.0: PCI bridge to [bus 01-05]
[    0.437235] pci 0000:00:01.0:   bridge window [io  0x4000-0x4fff]
[    0.437245] pci 0000:00:01.0:   bridge window [mem 0xa0000000-0xb40fffff]
[    0.437259] pci 0000:00:01.0:   bridge window [mem 0xb4100000-0xb41fffff 64bit pref]
[    0.437543] pci 0000:06:00.0: [144d:a808] type 00 class 0x010802
[    0.437631] pci 0000:06:00.0: reg 0x10: [mem 0xb4400000-0xb4403fff 64bit]
[    0.438657] pci 0000:00:1d.0: PCI bridge to [bus 06]
[    0.438670] pci 0000:00:1d.0:   bridge window [mem 0xb4400000-0xb44fffff]
[    0.438796] pci 0000:07:00.0: [10ec:8168] type 00 class 0x020000
[    0.438911] pci 0000:07:00.0: reg 0x10: [io  0x3000-0x30ff]
[    0.439001] pci 0000:07:00.0: reg 0x18: [mem 0xb4304000-0xb4304fff 64bit]
[    0.439041] pci 0000:07:00.0: reg 0x20: [mem 0xb4300000-0xb4303fff 64bit]
[    0.439363] pci 0000:07:00.0: supports D1 D2
[    0.439364] pci 0000:07:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.439867] pci 0000:00:1d.5: PCI bridge to [bus 07]
[    0.439872] pci 0000:00:1d.5:   bridge window [io  0x3000-0x3fff]
[    0.439876] pci 0000:00:1d.5:   bridge window [mem 0xb4300000-0xb43fffff]
[    0.441413] ACPI: EC: interrupt unblocked
[    0.441471] ACPI: EC: event unblocked
[    0.441510] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.441511] ACPI: EC: GPE=0x2
[    0.441512] ACPI: \_SB_.PCI0.LPCB.EC0_: Boot DSDT EC used to handle transactions and events
[    0.441569] iommu: Default domain type: Translated
[    0.441581] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[    0.441581] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.441581] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[    0.441581] pci 0000:00:02.0: vgaarb: no bridge control possible
[    0.441581] pci 0000:01:00.0: vgaarb: bridge control possible
[    0.441581] vgaarb: loaded
[    0.441581] EDAC MC: Ver: 3.0.0
[    0.443628] Registered efivars operations
[    0.443628] PCI: Using ACPI for IRQ routing
[    0.528254] PCI: pci_cache_line_size set to 64 bytes
[    0.528663] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[    0.528664] e820: reserve RAM buffer [mem 0x73d87000-0x73ffffff]
[    0.528665] e820: reserve RAM buffer [mem 0x7ad1b000-0x7bffffff]
[    0.528665] e820: reserve RAM buffer [mem 0x7b474000-0x7bffffff]
[    0.528666] e820: reserve RAM buffer [mem 0x8a89e000-0x8bffffff]
[    0.528667] e820: reserve RAM buffer [mem 0x8bc0f000-0x8bffffff]
[    0.528668] e820: reserve RAM buffer [mem 0x46e800000-0x46fffffff]
[    0.528751] NetLabel: Initializing
[    0.528752] NetLabel:  domain hash size = 128
[    0.528752] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.528764] NetLabel:  unlabeled traffic allowed by default
[    0.529327] clocksource: Switched to clocksource tsc-early
[    0.536712] VFS: Disk quotas dquot_6.6.0
[    0.536727] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.536821] AppArmor: AppArmor Filesystem Enabled
[    0.536833] pnp: PnP ACPI init
[    0.536912] system 00:00: [mem 0x40000000-0x403fffff] could not be reserved
[    0.536916] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.537212] system 00:01: [io  0x1800-0x18fe] has been reserved
[    0.537213] system 00:01: [mem 0xfd000000-0xfd69ffff] has been reserved
[    0.537215] system 00:01: [mem 0xfd6c0000-0xfd6cffff] has been reserved
[    0.537216] system 00:01: [mem 0xfd6f0000-0xfdffffff] has been reserved
[    0.537217] system 00:01: [mem 0xfe000000-0xfe01ffff] could not be reserved
[    0.537218] system 00:01: [mem 0xfe200000-0xfe7fffff] has been reserved
[    0.537219] system 00:01: [mem 0xff000000-0xffffffff] could not be reserved
[    0.537222] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.537508] system 00:02: [io  0x2000-0x20fe] has been reserved
[    0.537511] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.537675] system 00:03: [io  0x0680-0x069f] has been reserved
[    0.537676] system 00:03: [io  0x164e-0x164f] has been reserved
[    0.537679] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.537789] system 00:04: [io  0x1854-0x1857] has been reserved
[    0.537792] system 00:04: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[    0.537826] pnp 00:05: Plug and Play ACPI device, IDs PNP0303 (active)
[    0.538993] system 00:06: [mem 0xfe037000-0xfe037fff] has been reserved
[    0.538994] system 00:06: [mem 0xfe036008-0xfe036fff] has been reserved
[    0.538997] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.539437] system 00:07: [mem 0xfed10000-0xfed17fff] has been reserved
[    0.539439] system 00:07: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.539440] system 00:07: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.539441] system 00:07: [mem 0xe0000000-0xefffffff] has been reserved
[    0.539442] system 00:07: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.539443] system 00:07: [mem 0xfed90000-0xfed93fff] could not be reserved
[    0.539444] system 00:07: [mem 0xfed45000-0xfed8ffff] could not be reserved
[    0.539445] system 00:07: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.539448] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.539612] pnp: PnP ACPI: found 8 devices
[    0.545126] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.545153] pci 0000:01:00.0: can't claim BAR 6 [mem 0xfff80000-0xffffffff pref]: no compatible bridge window
[    0.545164] pci 0000:00:15.0: BAR 0: assigned [mem 0x8f800000-0x8f800fff 64bit]
[    0.545185] pci 0000:00:15.1: BAR 0: assigned [mem 0x8f801000-0x8f801fff 64bit]
[    0.545202] pci 0000:00:1e.0: BAR 0: assigned [mem 0x8f802000-0x8f802fff 64bit]
[    0.545219] pci 0000:01:00.0: BAR 6: assigned [mem 0xb2000000-0xb207ffff pref]
[    0.545220] pci 0000:00:01.0: PCI bridge to [bus 01-05]
[    0.545222] pci 0000:00:01.0:   bridge window [io  0x4000-0x4fff]
[    0.545224] pci 0000:00:01.0:   bridge window [mem 0xa0000000-0xb40fffff]
[    0.545226] pci 0000:00:01.0:   bridge window [mem 0xb4100000-0xb41fffff 64bit pref]
[    0.545229] pci 0000:00:1d.0: PCI bridge to [bus 06]
[    0.545240] pci 0000:00:1d.0:   bridge window [mem 0xb4400000-0xb44fffff]
[    0.545253] pci 0000:00:1d.5: PCI bridge to [bus 07]
[    0.545256] pci 0000:00:1d.5:   bridge window [io  0x3000-0x3fff]
[    0.545263] pci 0000:00:1d.5:   bridge window [mem 0xb4300000-0xb43fffff]
[    0.545276] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.545277] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.545278] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.545279] pci_bus 0000:00: resource 7 [mem 0x8f800000-0xdfffffff window]
[    0.545280] pci_bus 0000:00: resource 8 [mem 0xfc800000-0xfe7fffff window]
[    0.545281] pci_bus 0000:01: resource 0 [io  0x4000-0x4fff]
[    0.545282] pci_bus 0000:01: resource 1 [mem 0xa0000000-0xb40fffff]
[    0.545283] pci_bus 0000:01: resource 2 [mem 0xb4100000-0xb41fffff 64bit pref]
[    0.545284] pci_bus 0000:06: resource 1 [mem 0xb4400000-0xb44fffff]
[    0.545285] pci_bus 0000:07: resource 0 [io  0x3000-0x3fff]
[    0.545286] pci_bus 0000:07: resource 1 [mem 0xb4300000-0xb43fffff]
[    0.545424] NET: Registered protocol family 2
[    0.545537] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    0.545554] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.545676] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.545787] TCP: Hash tables configured (established 131072 bind 65536)
[    0.545816] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.545844] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.545927] NET: Registered protocol family 1
[    0.545931] NET: Registered protocol family 44
[    0.545941] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.547706] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[    0.547745] pci 0000:01:00.2: D0 power state depends on 0000:01:00.0
[    0.548097] pci 0000:01:00.3: D0 power state depends on 0000:01:00.0
[    0.548249] PCI: CLS 64 bytes, default 64
[    0.548301] Trying to unpack rootfs image as initramfs...
[    1.061904] Freeing initrd memory: 32300K
[    1.061936] DMAR: No ATSR found
[    1.061995] DMAR: dmar0: Using Queued invalidation
[    1.061998] DMAR: dmar1: Using Queued invalidation
[    1.062593] pci 0000:00:00.0: Adding to iommu group 0
[    1.062662] pci 0000:00:01.0: Adding to iommu group 1
[    1.066804] pci 0000:00:02.0: Adding to iommu group 2
[    1.067133] pci 0000:00:02.0: Using iommu direct mapping
[    1.067179] pci 0000:00:04.0: Adding to iommu group 3
[    1.067240] pci 0000:00:08.0: Adding to iommu group 4
[    1.067309] pci 0000:00:12.0: Adding to iommu group 5
[    1.067432] pci 0000:00:14.0: Adding to iommu group 6
[    1.067443] pci 0000:00:14.2: Adding to iommu group 6
[    1.067477] pci 0000:00:14.3: Adding to iommu group 6
[    1.067571] pci 0000:00:15.0: Adding to iommu group 7
[    1.067581] pci 0000:00:15.1: Adding to iommu group 7
[    1.067654] pci 0000:00:16.0: Adding to iommu group 8
[    1.067712] pci 0000:00:17.0: Adding to iommu group 9
[    1.067794] pci 0000:00:1d.0: Adding to iommu group 10
[    1.067860] pci 0000:00:1d.5: Adding to iommu group 11
[    1.067930] pci 0000:00:1e.0: Adding to iommu group 12
[    1.069631] pci 0000:00:1f.0: Adding to iommu group 13
[    1.069644] pci 0000:00:1f.3: Adding to iommu group 13
[    1.069654] pci 0000:00:1f.4: Adding to iommu group 13
[    1.069666] pci 0000:00:1f.5: Adding to iommu group 13
[    1.069675] pci 0000:01:00.0: Adding to iommu group 1
[    1.069680] pci 0000:01:00.1: Adding to iommu group 1
[    1.069685] pci 0000:01:00.2: Adding to iommu group 1
[    1.069693] pci 0000:01:00.3: Adding to iommu group 1
[    1.069771] pci 0000:06:00.0: Adding to iommu group 14
[    1.069846] pci 0000:07:00.0: Adding to iommu group 15
[    1.070124] DMAR: Intel(R) Virtualization Technology for Directed I/O
[    1.072000] platform rtc_cmos: registered platform RTC device (no PNP device found)
[    1.072463] Initialise system trusted keyrings
[    1.072476] Key type blacklist registered
[    1.072519] workingset: timestamp_bits=40 max_order=22 bucket_order=0
[    1.073588] zbud: loaded
[    1.073734] Platform Keyring initialized
[    1.073735] Key type asymmetric registered
[    1.073736] Asymmetric key parser 'x509' registered
[    1.073741] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[    1.073787] io scheduler mq-deadline registered
[    1.077844] pcieport 0000:00:01.0: PME: Signaling with IRQ 122
[    1.078133] pcieport 0000:00:1d.0: PME: Signaling with IRQ 123
[    1.078446] pcieport 0000:00:1d.5: PME: Signaling with IRQ 124
[    1.078585] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    1.078598] efifb: probing for efifb
[    1.078608] efifb: framebuffer at 0x90000000, using 8128k, total 8128k
[    1.078609] efifb: mode is 1920x1080x32, linelength=7680, pages=1
[    1.078609] efifb: scrolling: redraw
[    1.078610] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    1.078678] Console: switching to colour frame buffer device 240x67
[    1.082385] fb0: EFI VGA frame buffer device
[    1.082392] intel_idle: MWAIT substates: 0x11142120
[    1.082393] intel_idle: v0.4.1 model 0x9E
[    1.082990] intel_idle: lapic_timer_reliable_states 0xffffffff
[    1.085168] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.085768] hpet_acpi_add: no address or irqs in _CRS
[    1.085797] Linux agpgart interface v0.103
[    1.085855] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[    1.085855] AMD-Vi: AMD IOMMUv2 functionality not available on this system
[    1.086609] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[    1.086610] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[    1.088741] serio: i8042 KBD port at 0x60,0x64 irq 1
[    1.088845] mousedev: PS/2 mouse device common for all mice
[    1.088919] rtc_cmos rtc_cmos: RTC can wake from S4
[    1.089988] rtc_cmos rtc_cmos: registered as rtc0
[    1.090000] rtc_cmos rtc_cmos: alarms up to one month, y3k, 114 bytes nvram
[    1.090005] intel_pstate: Intel P-state driver initializing
[    1.090018] intel_pstate: Disabling energy efficiency optimization
[    1.091191] intel_pstate: HWP enabled
[    1.091327] ledtrig-cpu: registered to indicate activity on CPUs
[    1.091568] drop_monitor: Initializing network drop monitor service
[    1.091708] NET: Registered protocol family 10
[    1.096371] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[    1.100857] Segment Routing with IPv6
[    1.100874] mip6: Mobile IPv6
[    1.100875] NET: Registered protocol family 17
[    1.100900] mpls_gso: MPLS GSO support
[    1.101528] microcode: sig=0x906ea, pf=0x20, revision=0xd6
[    1.101688] microcode: Microcode Update Driver: v2.2.
[    1.101690] IPI shorthand broadcast: enabled
[    1.101696] sched_clock: Marking stable (1088770363, 12689327)->(1114824104, -13364414)
[    1.101932] registered taskstats version 1
[    1.101933] Loading compiled-in X.509 certificates
[    1.132766] Loaded X.509 cert 'Debian Secure Boot CA: 6ccece7e4c6c0d1f6149f3dd27dfcc5cbb419ea1'
[    1.132782] Loaded X.509 cert 'Debian Secure Boot Signer: 00a7468def'
[    1.132800] zswap: loaded using pool lzo/zbud
[    1.133308] Key type ._fscrypt registered
[    1.133309] Key type .fscrypt registered
[    1.133309] Key type fscrypt-provisioning registered
[    1.133371] AppArmor: AppArmor sha1 policy hashing enabled
[    1.135862] integrity: Loading X.509 certificate: UEFI:db
[    1.135894] integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
[    1.135894] integrity: Loading X.509 certificate: UEFI:db
[    1.135914] integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
[    1.135915] integrity: Loading X.509 certificate: UEFI:db
[    1.135917] integrity: Problem loading X.509 certificate -65
[    1.135938] Error adding keys to platform keyring UEFI:db
[    1.139657] rtc_cmos rtc_cmos: setting system clock to 2020-06-14T18:27:40 UTC (1592159260)
[    1.140597] Freeing unused kernel image (initmem) memory: 1612K
[    1.180054] Write protecting the kernel read-only data: 16384k
[    1.181025] Freeing unused kernel image (text/rodata gap) memory: 2044K
[    1.181210] Freeing unused kernel image (rodata/data gap) memory: 120K
[    1.222905] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.222906] x86/mm: Checking user space page tables
[    1.261976] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.261977] Run /init as init process
[    1.261978]   with arguments:
[    1.261978]     /init
[    1.261979]   with environment:
[    1.261979]     HOME=/
[    1.261980]     TERM=linux
[    1.261980]     BOOT_IMAGE=/vmlinuz-5.6.0-2-amd64
[    1.331877] udevd[177]: starting version 3.2.9
[    1.332959] udevd[178]: starting eudev-3.2.9
[    1.346879] wmi_bus wmi_bus-PNP0C14:00: WQ data block query control method not found
[    1.346881] wmi_bus wmi_bus-PNP0C14:00: WQ data block query control method not found
[    1.346882] wmi_bus wmi_bus-PNP0C14:00: WQ data block query control method not found
[    1.346883] wmi_bus wmi_bus-PNP0C14:00: WQ data block query control method not found
[    1.347042] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
[    1.354318] udevd[189]: Error running install command 'modprobe -i nvidia-current ' for module nvidia: retcode 1
[    1.356435] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[    1.356539] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[    1.357206] hid: raw HID events driver (C) Jiri Kosina
[    1.361933] cryptd: max_cpu_qlen set to 1000
[    1.366726] SCSI subsystem initialized
[    1.371064] ACPI: bus type USB registered
[    1.371091] usbcore: registered new interface driver usbfs
[    1.371108] usbcore: registered new interface driver hub
[    1.371153] usbcore: registered new device driver usb
[    1.375778] intel-lpss 0000:00:15.0: enabling device (0000 -> 0002)
[    1.376264] idma64 idma64.0: Found Intel integrated DMA 64-bit
[    1.379486] AVX2 version of gcm_enc/dec engaged.
[    1.379486] AES CTR mode by8 optimization enabled
[    1.382371] intel-lpss 0000:00:15.1: enabling device (0000 -> 0002)
[    1.382782] idma64 idma64.1: Found Intel integrated DMA 64-bit
[    1.384160] r8169 0000:07:00.0: can't disable ASPM; OS doesn't have ASPM control
[    1.384237] libata version 3.00 loaded.
[    1.386172] nvme nvme0: pci function 0000:06:00.0
[    1.388673] ahci 0000:00:17.0: version 3.0
[    1.389927] intel-lpss 0000:00:1e.0: enabling device (0000 -> 0002)
[    1.390374] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.390379] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[    1.390447] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x10 impl SATA mode
[    1.390450] ahci 0000:00:17.0: flags: 64bit ncq sntf pm clo only pio slum part ems deso sadm sds apst
[    1.390623] idma64 idma64.2: Found Intel integrated DMA 64-bit
[    1.390815] dw-apb-uart.2: ttyS0 at MMIO 0x8f802000 (irq = 20, base_baud = 115200) is a 16550A
[    1.391525] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x110 quirks 0x0000000000009810
[    1.391532] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[    1.391580] scsi host0: ahci
[    1.391690] scsi host1: ahci
[    1.391743] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.06
[    1.391744] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.391745] usb usb1: Product: xHCI Host Controller
[    1.391746] usb usb1: Manufacturer: Linux 5.6.0-2-amd64 xhci-hcd
[    1.391747] usb usb1: SerialNumber: 0000:00:14.0
[    1.391786] scsi host2: ahci
[    1.391880] scsi host3: ahci
[    1.391889] hub 1-0:1.0: USB hub found
[    1.391912] hub 1-0:1.0: 16 ports detected
[    1.391953] scsi host4: ahci
[    1.391989] ata1: DUMMY
[    1.391990] ata2: DUMMY
[    1.391990] ata3: DUMMY
[    1.391990] ata4: DUMMY
[    1.391996] ata5: SATA max UDMA/133 abar m2048@0xb452d000 port 0xb452d300 irq 125
[    1.393176] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.393181] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[    1.393184] xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
[    1.393241] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.06
[    1.393243] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.393244] usb usb2: Product: xHCI Host Controller
[    1.393246] usb usb2: Manufacturer: Linux 5.6.0-2-amd64 xhci-hcd
[    1.393247] usb usb2: SerialNumber: 0000:00:14.0
[    1.393377] hub 2-0:1.0: USB hub found
[    1.393400] hub 2-0:1.0: 8 ports detected
[    1.394265] xhci_hcd 0000:01:00.2: xHCI Host Controller
[    1.394270] xhci_hcd 0000:01:00.2: new USB bus registered, assigned bus number 3
[    1.394898] xhci_hcd 0000:01:00.2: hcc params 0x0180ff05 hci version 0x110 quirks 0x0000000000000010
[    1.395002] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.06
[    1.395004] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.395005] usb usb3: Product: xHCI Host Controller
[    1.395005] usb usb3: Manufacturer: Linux 5.6.0-2-amd64 xhci-hcd
[    1.395006] usb usb3: SerialNumber: 0000:01:00.2
[    1.395080] hub 3-0:1.0: USB hub found
[    1.395086] hub 3-0:1.0: 2 ports detected
[    1.395337] xhci_hcd 0000:01:00.2: xHCI Host Controller
[    1.395339] xhci_hcd 0000:01:00.2: new USB bus registered, assigned bus number 4
[    1.395341] xhci_hcd 0000:01:00.2: Host supports USB 3.1 Enhanced SuperSpeed
[    1.395360] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.395374] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.06
[    1.395375] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.395376] usb usb4: Product: xHCI Host Controller
[    1.395376] usb usb4: Manufacturer: Linux 5.6.0-2-amd64 xhci-hcd
[    1.395377] usb usb4: SerialNumber: 0000:01:00.2
[    1.395440] hub 4-0:1.0: USB hub found
[    1.395448] hub 4-0:1.0: 4 ports detected
[    1.405517] libphy: r8169: probed
[    1.405688] r8169 0000:07:00.0 eth0: RTL8168h/8111h, f8:75:a4:a2:7b:db, XID 541, IRQ 129
[    1.405690] r8169 0000:07:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[    1.460287] battery: ACPI: Battery Slot [BAT0] (battery present)
[    1.473664] i2c_hid i2c-MSFT0001:01: i2c-MSFT0001:01 supply vdd not found, using dummy regulator
[    1.473699] i2c_hid i2c-MSFT0001:01: i2c-MSFT0001:01 supply vddl not found, using dummy regulator
[    1.605472] nvme nvme0: missing or invalid SUBNQN field.
[    1.605541] nvme nvme0: Shutdown timeout set to 8 seconds
[    1.676507] nvme nvme0: 12/0/0 default/read/poll queues
[    1.697826]  nvme0n1: p1 p2 < p5 p6 >
[    1.704207] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    1.727683] usb 1-2: new full-speed USB device number 2 using xhci_hcd
[    1.798774] ata5.00: ATA-10: ST2000LM015-2E8174, 0001, max UDMA/133
[    1.798777] ata5.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    1.849648] ata5.00: configured for UDMA/133
[    1.849867] scsi 4:0:0:0: Direct-Access     ATA      ST2000LM015-2E81 0001 PQ: 0 ANSI: 5
[    1.854234] input: MSFT0001:01 04F3:309E Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-MSFT0001:01/0018:04F3:309E.0001/input/input1
[    1.854440] input: MSFT0001:01 04F3:309E Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-MSFT0001:01/0018:04F3:309E.0001/input/input3
[    1.854723] hid-generic 0018:04F3:309E.0001: input,hidraw0: I2C HID v1.00 Mouse [MSFT0001:01 04F3:309E] on i2c-MSFT0001:01
[    1.858039] sd 4:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[    1.858040] sd 4:0:0:0: [sda] 4096-byte physical blocks
[    1.858045] sd 4:0:0:0: [sda] Write Protect is off
[    1.858046] sd 4:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    1.858053] sd 4:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.879803] usb 1-2: New USB device found, idVendor=1bcf, idProduct=0824, bcdDevice= 5.22
[    1.879807] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.879810] usb 1-2: Product: SmartMouse
[    1.879812] usb 1-2: Manufacturer: SunplusIT
[    1.889314] input: SunplusIT SmartMouse as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.0/0003:1BCF:0824.0002/input/input4
[    1.943272]  sda: sda1
[    1.943938] sd 4:0:0:0: [sda] Attached SCSI disk
[    1.947520] sd 4:0:0:0: Attached scsi generic sg0 type 0
[    1.947842] hid-generic 0003:1BCF:0824.0002: input,hidraw1: USB HID v1.00 Keyboard [SunplusIT SmartMouse] on usb-0000:00:14.0-2/input0
[    1.949520] input: SunplusIT SmartMouse as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:1BCF:0824.0003/input/input5
[    1.949644] input: SunplusIT SmartMouse Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:1BCF:0824.0003/input/input6
[    2.007650] usb 1-6: new high-speed USB device number 3 using xhci_hcd
[    2.007830] hid-generic 0003:1BCF:0824.0003: input,hidraw2: USB HID v1.00 Mouse [SunplusIT SmartMouse] on usb-0000:00:14.0-2/input1
[    2.007888] usbcore: registered new interface driver usbhid
[    2.007889] usbhid: USB HID core driver
[    2.079962] tsc: Refined TSC clocksource calibration: 2592.002 MHz
[    2.079975] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x255cb8d7d74, max_idle_ns: 440795265546 ns
[    2.080049] clocksource: Switched to clocksource tsc
[    2.168875] usb 1-6: New USB device found, idVendor=04ca, idProduct=7070, bcdDevice= 0.24
[    2.168878] usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.168880] usb 1-6: Product: Integrated Camera
[    2.168882] usb 1-6: Manufacturer: 8SSC20F27068L1GZ0197DY5
[    2.299674] usb 1-9: new full-speed USB device number 4 using xhci_hcd
[    2.310831] device-mapper: uevent: version 1.0.3
[    2.311018] device-mapper: ioctl: 4.42.0-ioctl (2020-02-27) initialised: dm-devel@redhat.com
[    2.463992] usb 1-9: New USB device found, idVendor=048d, idProduct=c100, bcdDevice= 0.43
[    2.463996] usb 1-9: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.463998] usb 1-9: Product: ITE Device(8910)
[    2.464000] usb 1-9: Manufacturer: ITE Tech. Inc.
[    2.476383] input: ITE Tech. Inc. ITE Device(8910) Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/0003:048D:C100.0004/input/input7
[    2.536239] input: ITE Tech. Inc. ITE Device(8910) Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/0003:048D:C100.0004/input/input8
[    2.536280] input: ITE Tech. Inc. ITE Device(8910) Wireless Radio Control as /devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/0003:048D:C100.0004/input/input9
[    2.536608] hid-generic 0003:048D:C100.0004: input,hiddev0,hidraw3: USB HID v1.10 Keyboard [ITE Tech. Inc. ITE Device(8910)] on usb-0000:00:14.0-9/input0
[    2.664166] usb 1-14: new full-speed USB device number 5 using xhci_hcd
[    2.814917] usb 1-14: New USB device found, idVendor=8087, idProduct=0aaa, bcdDevice= 0.02
[    2.814921] usb 1-14: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[   98.938491] process '/usr/bin/fstype' started with executable stack
[   99.262776] PM: Image not found (code -22)
[   99.369279] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Opts: (null)
[   99.416834] EXT4-fs (dm-2): mounted filesystem with ordered data mode. Opts: (null)
[   99.477696] Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist.
[   99.723358] udevd[695]: starting version 3.2.9
[   99.766581] udevd[695]: starting eudev-3.2.9
[   99.856309] ACPI: AC Adapter [ADP0] (on-line)
[   99.880559] input: Ideapad extra buttons as /devices/pci0000:00/0000:00:1f.0/PNP0C09:00/VPC2004:00/input/input10
[   99.885564] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input11
[   99.885606] ACPI: Lid Switch [LID0]
[   99.886074] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input12
[   99.886128] ACPI: Power Button [PWRB]
[   99.934384] IPMI message handler: version 39.2
[   99.934957] mc: Linux media interface: v0.10
[   99.944350] ipmi device interface
[   99.945446] intel_rapl_common: Found RAPL domain package
[   99.945447] intel_rapl_common: Found RAPL domain dram
[   99.947047] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[   99.947102] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   99.947297] cfg80211: Loaded X.509 cert 'benh@debian.org: 577e021cb980e0e820821ba7b54b4961b8b4fadf'
[   99.947479] cfg80211: Loaded X.509 cert 'romain.perier@gmail.com: 3abbc6ec146e09d1b6016ab9d6cf71dd233f0328'
[   99.947639] videodev: Linux video capture interface: v2.00
[   99.947670] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   99.948281] platform regulatory.0: firmware: direct-loading firmware regulatory.db
[   99.948563] platform regulatory.0: firmware: direct-loading firmware regulatory.db.p7s
[   99.952452] alg: No test for fips(ansi_cprng) (fips_ansi_cprng)
[   99.957720] proc_thermal 0000:00:04.0: Creating sysfs group for PROC_THERMAL_PCI
[   99.961626] Intel(R) Wireless WiFi driver for Linux
[   99.961627] Copyright(c) 2003- 2015 Intel Corporation
[   99.967451] iwlwifi 0000:00:14.3: firmware: direct-loading firmware iwlwifi-9000-pu-b0-jf-b0-46.ucode
[   99.967480] iwlwifi 0000:00:14.3: Found debug destination: EXTERNAL_DRAM
[   99.967481] iwlwifi 0000:00:14.3: Found debug configuration: 0
[   99.967747] iwlwifi 0000:00:14.3: loaded firmware version 46.a41adfe7.0 9000-pu-b0-jf-b0-46.ucode op_mode iwlmvm
[   99.975768] nvidia: loading out-of-tree module taints kernel.
[   99.975777] nvidia: module license 'NVIDIA' taints kernel.
[   99.975778] Disabling lock debugging due to kernel taint
[  100.019793] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[  100.020594] uvcvideo: Found UVC 1.00 device Integrated Camera (04ca:7070)
[  100.033728] input: MSFT0001:01 04F3:309E Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-MSFT0001:01/0018:04F3:309E.0001/input/input13
[  100.033865] input: MSFT0001:01 04F3:309E Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-MSFT0001:01/0018:04F3:309E.0001/input/input15
[  100.033997] hid-multitouch 0018:04F3:309E.0001: input,hidraw0: I2C HID v1.00 Mouse [MSFT0001:01 04F3:309E] on i2c-MSFT0001:01
[  100.038413] uvcvideo 1-6:1.0: Entity type for entity Extension 4 was not initialized!
[  100.038414] uvcvideo 1-6:1.0: Entity type for entity Extension 3 was not initialized!
[  100.038415] uvcvideo 1-6:1.0: Entity type for entity Processing 2 was not initialized!
[  100.038416] uvcvideo 1-6:1.0: Entity type for entity Camera 1 was not initialized!
[  100.038487] input: Integrated Camera: Integrated C as /devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.0/input/input16
[  100.038550] usbcore: registered new interface driver uvcvideo
[  100.038551] USB Video Class driver (1.1.1)
[  100.061618] iTCO_vendor_support: vendor-support=0
[  100.064651] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[  100.064934] iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
[  100.067937] nvidia-nvlink: Nvlink Core is being initialized, major device number 242
[  100.068205] nvidia 0000:01:00.0: enabling device (0006 -> 0007)
[  100.068394] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[  100.068537] EFI Variables Facility v0.08 2004-May-17
[  100.071754] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[  100.072158] snd_hda_intel 0000:01:00.1: Disabling MSI
[  100.072173] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[  100.081664] input: PC Speaker as /devices/platform/pcspkr/input/input17
[  100.095573] Bluetooth: Core ver 2.22
[  100.095584] NET: Registered protocol family 31
[  100.095585] Bluetooth: HCI device and connection manager initialized
[  100.095588] Bluetooth: HCI socket layer initialized
[  100.095590] Bluetooth: L2CAP socket layer initialized
[  100.095597] Bluetooth: SCO socket layer initialized
[  100.102767] r8169 0000:07:00.0: firmware: direct-loading firmware rtl_nic/rtl8168h-2.fw
[  100.102887] Generic FE-GE Realtek PHY r8169-700:00: attached PHY driver [Generic FE-GE Realtek PHY] (mii_bus:phy_addr=r8169-700:00, irq=IGNORE)
[  100.103716] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[  100.107544] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input18
[  100.107587] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input19
[  100.107648] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input20
[  100.107681] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input21
[  100.107714] input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input22
[  100.107749] input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input23
[  100.117602] NVRM: loading NVIDIA UNIX x86_64 Kernel Module  440.82  Wed Apr  1 20:04:33 UTC 2020
[  100.123161] usbcore: registered new interface driver btusb
[  100.124288] Bluetooth: hci0: Bootloader revision 0.1 build 42 week 52 2015
[  100.125274] Bluetooth: hci0: Device revision is 2
[  100.125275] Bluetooth: hci0: Secure boot is enabled
[  100.125276] Bluetooth: hci0: OTP lock is enabled
[  100.125276] Bluetooth: hci0: API lock is enabled
[  100.125277] Bluetooth: hci0: Debug lock is disabled
[  100.125278] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[  100.126543] pstore: Using crash dump compression: deflate
[  100.126554] pstore: Registered efi as persistent store backend
[  100.126743] bluetooth hci0: firmware: direct-loading firmware intel/ibt-17-16-1.sfi
[  100.126745] Bluetooth: hci0: Found device firmware: intel/ibt-17-16-1.sfi
[  100.143946] RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
[  100.143946] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[  100.143947] RAPL PMU: hw unit of domain package 2^-14 Joules
[  100.143947] RAPL PMU: hw unit of domain dram 2^-14 Joules
[  100.143948] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[  100.225315] r8169 0000:07:00.0 eth0: Link is Down
[  100.297746] iwlwifi 0000:00:14.3: Detected Intel(R) Dual Band Wireless AC 9560, REV=0x318
[  100.298935] i915 0000:00:02.0: VT-d active for gfx access
[  100.298938] checking generic (90000000 7f0000) vs hw (b5000000 1000000)
[  100.298939] checking generic (90000000 7f0000) vs hw (90000000 10000000)
[  100.298940] fb0: switching to inteldrmfb from EFI VGA
[  100.299018] Console: switching to colour dummy device 80x25
[  100.299052] i915 0000:00:02.0: vgaarb: deactivate vga console
[  100.301547] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[  100.301548] [drm] Driver supports precise vblank timestamp query.
[  100.302822] i915 0000:00:02.0: firmware: direct-loading firmware i915/kbl_dmc_ver1_04.bin
[  100.302879] [drm:csr_load_work_fn [i915]] *ERROR* DMC firmware has wrong CSS header length (1097158924 bytes)
[  100.302885] i915 0000:00:02.0: Failed to load DMC firmware i915/kbl_dmc_ver1_04.bin. Disabling runtime power management.
[  100.302886] i915 0000:00:02.0: DMC firmware homepage: https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/tree/i915
[  100.306179] iwlwifi 0000:00:14.3: Applying debug destination EXTERNAL_DRAM
[  100.306445] iwlwifi 0000:00:14.3: Allocated 0x00400000 bytes for firmware monitor.
[  100.359611] [drm] Initialized i915 1.6.0 20200114 for 0000:00:02.0 on minor 0
[  100.360178] [Firmware Bug]: ACPI(PEGP) defines _DOD but not _DOS
[  100.360187] ACPI: Video Device [PEGP] (multi-head: yes  rom: yes  post: no)
[  100.360219] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input24
[  100.361641] ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[  100.361812] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input25
[  100.361973] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[  100.363017] fbcon: i915drmfb (fb0) is primary device
[  100.387134] iwlwifi 0000:00:14.3: base HW address: 54:8d:5a:12:93:82
[  100.453579] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[  100.453809] thermal thermal_zone8: failed to read out thermal zone (-61)
[  100.536593] intel_rapl_common: Found RAPL domain package
[  100.536594] intel_rapl_common: Found RAPL domain core
[  100.536597] intel_rapl_common: Found RAPL domain uncore
[  100.536598] intel_rapl_common: Found RAPL domain dram
[  101.660343] Bluetooth: hci0: Waiting for firmware download to complete
[  101.661214] Bluetooth: hci0: Firmware loaded in 1501970 usecs
[  101.661367] Bluetooth: hci0: Waiting for device to boot
[  101.666382] Console: switching to colour frame buffer device 240x67
[  101.674281] Bluetooth: hci0: Device booted in 12696 usecs
[  101.678233] i915 0000:00:02.0: fb0: i915drmfb frame buffer device
[  101.681034] bluetooth hci0: firmware: direct-loading firmware intel/ibt-17-16-1.ddc
[  101.681038] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-17-16-1.ddc
[  101.684362] Bluetooth: hci0: Applying Intel DDC parameters completed
[  101.686246] Bluetooth: hci0: Firmware revision 0.1 build 216 week 27 2019
[  101.837422] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC257: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[  101.837425] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[  101.837428] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[  101.837429] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[  101.837431] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[  101.837433] snd_hda_codec_realtek hdaudioC0D0:      Mic=0x19
[  101.837435] snd_hda_codec_realtek hdaudioC0D0:      Internal Mic=0x12
[  101.891957] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1f.3/sound/card0/input26
[  101.892031] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input27
[  101.892096] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input28
[  101.892141] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input29
[  101.892175] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input30
[  101.892263] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input31
[  101.892372] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input32
[  101.893630] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input33
[  102.267215] EXT4-fs (dm-1): re-mounted. Opts: errors=remount-ro
[  103.882219] r8169 0000:07:00.0 eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[  103.882230] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[  118.962147] lp: driver loaded but no devices found
[  118.970284] ppdev: user-space parallel port driver
[  119.016469] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  440.82  Wed Apr  1 19:41:29 UTC 2020
[  119.034388] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[  119.034390] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 1
[  119.419015] EXT4-fs (dm-2): re-mounted. Opts: (null)
[  119.424427] EXT4-fs (nvme0n1p5): mounted filesystem with ordered data mode. Opts: (null)
[  119.424435] ext4 filesystem being mounted at /boot supports timestamps until 2038 (0x7fffffff)
[  119.525489] EXT4-fs (dm-8): mounted filesystem with ordered data mode. Opts: (null)
[  119.568957] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null)
[  119.572635] EXT4-fs (dm-4): mounted filesystem with ordered data mode. Opts: (null)
[  119.576698] EXT4-fs (dm-3): mounted filesystem with ordered data mode. Opts: (null)
[  119.628123] Adding 15622140k swap on /dev/mapper/vgs-swap.  Priority:-2 extents:1 across:15622140k SSFS
[  119.742903] audit: type=1400 audit(1592159379.080:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-xpdfimport" pid=1768 comm="apparmor_parser"
[  119.743694] audit: type=1400 audit(1592159379.084:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-senddoc" pid=1767 comm="apparmor_parser"
[  119.744432] audit: type=1400 audit(1592159379.084:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=1769 comm="apparmor_parser"
[  119.744936] audit: type=1400 audit(1592159379.084:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=1766 comm="apparmor_parser"
[  119.744939] audit: type=1400 audit(1592159379.084:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=1766 comm="apparmor_parser"
[  119.744991] audit: type=1400 audit(1592159379.084:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-oopslash" pid=1772 comm="apparmor_parser"
[  119.745060] audit: type=1400 audit(1592159379.084:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=1765 comm="apparmor_parser"
[  119.745063] audit: type=1400 audit(1592159379.084:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=1765 comm="apparmor_parser"
[  119.745066] audit: type=1400 audit(1592159379.084:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=1765 comm="apparmor_parser"
[  119.746650] audit: type=1400 audit(1592159379.084:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cups-browsed" pid=1771 comm="apparmor_parser"
[  120.149601] ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20200110/nsarguments-59)
[  120.179977] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[  120.179978] Bluetooth: BNEP filters: protocol multicast
[  120.179982] Bluetooth: BNEP socket layer initialized
I have no sparkling idea where to start looking for that and if that is part of my flickering screen "party". Anyone any ideas?
If you're also experiencing the flicker in the console then it's nothing to do with the compositor or the DDX driver.
FWIW your X.Org log shows that X.Org's builtin modesetting driver is being used for your Intel iGPU.
I really don't know anything about NVIDIA (I would never give money to that company) so I can't help with that, sorry.
Ah, you wanted me to check another window manager. Well yes, I think thats not the root of the cause. And about the discussion AMD vs. Nvidia. I do not really get to deep into it. I had some time doing research of what is best solution for me and for the Intel CPU there is a possible way to remove parts of the management engine. I didn't find something lilke that for AMD CPU's.
Cheers
Walter
#14 2020-06-20 23:02:04
merom
Re: Beowulf and Legion y540
walter wrote:
After that installation I got error messages from nvidia-persistenced both in Synaptic and the console during installation of any package:
nvidia-persistenced failed to initialize. Check syslog for more details
I've got the same message during nvidia-persistenced installation process.
This can be avoided, you can run command in terminal :
sudo dpkg --configure nvidia-persistenced
If nvidia-persistenced runs, check in terminal :
ps aux | grep -i nvidia-persistenced
Possible answer looks like
nvpd      1632  0.0  0.0   4672  1596 ?        Ss   21:03   0:00 /usr/bin/nvidia-persistenced --user nvpd
#15 2020-06-21 10:25:29
Marjorie
I had this problem with nvidia-persistenced back in April when I upgraded to Beowulf-Beta.
It's caused by an error in etc/init.d/nvidia-persistenced that happens when it is started and there is already another copy running.
nvidia-persistenced is not really needed unless you use CUDA.
If you's rather keep it you can patch it so that it doesn't misbehave (with the patch it checks if there is already a copy running and just exits if there is).
See https://dev1galaxy.org/search.php?actio … w_as=posts for details.
My patched version is in post #3, also shown below:
#!/bin/sh -e
# NVIDIA Persistence Daemon Init Script
# Copyright (c) 2013 NVIDIA Corporation
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
# AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
# DEALINGS IN THE SOFTWARE.
# This is a sample System V init script, designed to show how the NVIDIA
# Persistence Daemon can be started.
# This sample does not rely on any init system functions, to ensure the
# widest portability possible.
# chkconfig: 2345 99 01
# description: Starts and stops the NVIDIA Persistence Daemon
# processname: nvidia-persistenced
### BEGIN INIT INFO
# Provides:         nvidia-persistenced
# Required-Start:   $local_fs
# Required-Stop:    $local_fs
# Default-Start:    2 3 4 5
# Default-Stop:     0 1 6
# Short-Description: Starts and stops the NVIDIA Persistence Daemon
# Description:      Starts and stops the NVIDIA Persistence Daemon
### END INIT INFO
NVPD=nvidia-persistenced
NVPD_BIN=/usr/bin/${NVPD}
NVPD_RUNTIME=/var/run/${NVPD}
NVPD_PIDFILE=${NVPD_RUNTIME}/${NVPD}.pid
NVPD_USER=nvpd
NVPD_ACTION=${1}
# Gracefully exit if the package has been removed.
test -x $NVPD_BIN || exit 0
# Get the value of the PID
if [ -f ${NVPD_PIDFILE} ]; then
 read -r NVPD_PID < "${NVPD_PIDFILE}"
# Is the daemon already running?
 if [ "${NVPD_PID}" ] ;then
  if [ -d /proc/${NVPD_PID} ]
# Daemon is running, so stop it then start a new instance
   then
    case "${1}" in
     start)
      echo "NVIDIA Persistence Daemon already running"
      NVPD_ACTION=restart
    esac
# Daemon not running, but there is a stale PID
   else
    echo "NVIDIA Persistence Daemon, stale PID removed"
    unset NVPD_PID
    rm -rf "${NVPD_RUNTIME}"
  fi
 fi
fi
case "${NVPD_ACTION}" in
 start)
  echo "Starting NVIDIA Persistence Daemon"
# Execute the daemon as the intended user
  ${NVPD_BIN} --user ${NVPD_USER}
 stop)
   echo "Stopping NVIDIA Persistence Daemon"
# Stop the daemon - its PID should have been read in
   [ ! -z "${NVPD_PID}" ] && kill ${NVPD_PID} &> /dev/null
  restart)
   $0 stop
   sleep 2
   $0 start
  *) echo "usage: $0 {start|stop|restart}"
esac
exit 0
#16 2020-06-22 19:05:35
walter
Thank you very much merom and Marjorie!
Yeah, I deleted it since I do not need CUDA. Don't think I ever will.
And it seems there was an instance running already and the error came out of a 2nd call.
Again - thank you very much for your time and ideas.
I still have my major problem with the flickering screen. In the meanwhile I tried a Windows10 live release on a pen-drive. No flickering. Thats obscure. I am pretty sure its not a hardware or BIOS issue. Its a driver or a set of configurations which makes the Intel iGPU fuzzy. I am experimenting at the moment to nail it down. But I don't have that much time.
In the meanwhile I can tell the latest Kernel of chimaera is running very well with the machine. I had some manual adjustments which I noted and I will publish it soon.
Happy hacking
Walter
#17 2020-06-22 22:58:52
merom
Hi, you can try create file 20-intel.conf
with content
Section "Device"
   Identifier  "intel Graphics"
   Driver  "intel"
   Option  "TearFree" "true"
   Option  "AccelMethod" "uxa"
EndSection
Create directory in /etc/X11 named xorg.conf.d
And copy as root file 20-intel.conf
to
/etc/X11/xorg.conf.d
restart
#18 2020-06-25 22:51:29
walter
merom wrote:
Hi, you can try create file 20-intel.conf with content
Section "Device"
   Driver  "intel"
EndSection
Create directory in /etc/X11 named xorg.conf.d and copy as root file 20-intel.conf to /etc/X11/xorg.conf.d
I tried it with no luck. But thank you very much for your suggestion.
I like to know the source of your information. Perhaps I can find some more hints or other possible options to use.
By the way, I don't know if the phenomenon the same as "tearing" is.
The display mainly is black and sometimes the display flashes up and content is visible. This flasing moment is not always the same. Sometimes there is text (logon of console screen) only. Sometimes there are additional colourful light streams like smearing down the text which is to be displayed. And then sometimes during the flashes there are very small squares in any coulour on the top third of the display. Maintime the display is dark. I suppose a misinterpretation of the capabilities of the display, so there is a fault in the sync between iGPU and display.  Don't have an idea of how to get deeper into it or to check if this is correct synced or not. I am digging ;-)
thank you
Walter
#19 2020-06-26 22:20:58
merom
Best source is internet search ...
Some good source is maybe:
https://wiki.archlinux.org/index.php/Intel_graphics
or
https://bbs.archlinux.org/search.php?se … 1922492135
But not all things from arch are applicable on different operating system
Best regards...
