#1 2020-06-04 19:14:22
rayburn
Upgrade error
I have followed the instructions on upgrading from ACSII to Beowulf and all appeared to go well. However, when I try to open the menu, (right click in Openbox), I get the following message:
Invalid output from pipe-menu "/usr/bin/obmenu-generator -i"
I have tried running 'obmenu-generator -i' in a terminal and get the following output:
root@miyolinux:/home/mc# obmenu-generator -i
Can't locate Linux/DesktopFiles.pm in @INC (you may need to install the Linux: :DesktopFiles module) (@INC contains: etc/perl usr/local/lib/x86_ 64-linux-gnu/perl/5.28.1 usr/local/share/perl/5.28.1 usr/1ib/X86_64-1inux-gnu/perl5/5.28 usr/share/perl5 usr/lib/x86_64-linux-gnu/perl/5.28 usr/share/perl/5.28 usr/local/lib/site_perl usr/1ib/x86_64-1inux-gnu/perl-base) at usr/bin/obmenu-generator line 35.
BEGIN failed--compilation aborted at usr/bin/obmenu-generator line 35.
Can anyone help me to understand what is going wrong please?
Thanks.
#2 2020-06-04 19:35:32
Re: Upgrade error
The perl modules need updating.
I happen to have a package which supplies the perl modules that you need without relying on cpan:
https://software.opensuse.org//download … sktopfiles
It says it's for Debian but it is compatible with Devuan, the repository only supplies that package and obmenu-generator itself.
"Il semble que la perfection soit atteinte non quand il n'y a plus rien à ajouter, mais quand il n'y a plus rien à retrancher." — Antoine de Saint-Exupéry
#3 2020-06-04 19:57:02
rayburn
Re: Upgrade error
Thank you so much, that was just the advice I needed, and so quickly too!
I followed the instructions, rebooted and I now have an application menu again, I much appreciate your time and advice.
#4 2020-06-04 20:02:55
Re: Upgrade error
You're welcome.
May I ask which version of obmenu-generator you're using?
apt policy obmenu-generator
I had an old version that was linked from the obmenu-generator github page that wasn't very good, the current package (v0.87-3) is much better and should probably be favoured.
#5 2020-06-04 20:35:18
rayburn
Re: Upgrade error
You're welcome.
root@miyolinux:/home/mc# apt policy obmenu-generator
obmenu-generator:
  Installed: (none)
  Candidate: 0.87-3
  Version table:
     0.87-3 500
        500 [url]http://download.opensuse.org/repositories/home:/Head_on_a_Stick:/obmenu-generator/Debian_10[/url]  Packages
Looks like it is the current version.
#6 2020-06-04 20:48:48
Re: Upgrade error
Nice smile
So the error in the OP is actually my fault — the old package wasn't the best. All fixed now though.
EDIT: no, wait, the package isn't installed at all. Not sure what's happening there, perhaps @Miyo can clear things up for us if they notice this thread.
#7 2020-06-04 21:03:59
rayburn
Re: Upgrade error
Nice smile
That is strange, I hadn't noticed that the package isn't installed! I was too focused on the version number....
For the moment I am just relieved that it all seems to be working now, and thanks again.
