#1 2020-05-08 19:37:57
ve1drg
Type size too small
Wondering how I can increase the size of the text on the screen.  Very small.
I am using chimeara/ceres  under release testing/unstable.
It had been the correct size earlier today. But as I made changes and got upgrades/updates etc... suddently I have very small type..
#2 2020-05-08 20:47:36
Re: Type size too small
Ah, the joys of the development branches :-)
Check the reported screen size & DPI:
xdpyinfo|grep -A1 dim
Which desktop environment is this? Check to see which packages were updated.
"Il semble que la perfection soit atteinte non quand il n'y a plus rien à ajouter, mais quand il n'y a plus rien à retrancher." — Antoine de Saint-Exupéry
#3 2020-05-08 21:12:01
ve1drg
The screen size etc  is as follows:
dimensions:    3840x2160 pixels (1016x572 millimeters)
  resolution:    96x96 dots per inch
I will check on desktop enviroment files.  Must be those.,
