#1 2020-04-22 03:34:29
MiyoLinux
[MiyoLinux] miyofetch
If any MiyoLInux users are interested (if there are any MiyoLinux users besides me...  tongue  LOLOLOLOL!!! )...
...miyofetch is now available for beowulf releases. Click the image to enlarge it.
2020-04-21-225135-688x434-scrot.png?1587526063
miyofetch is a utility similar to neofetch and screenfetch; however, it is made specifically for MiyoLinux.
Here is a link to a slide show showing how it looks in all of the various colors...
https://miyolinux.weebly.com/miyofetch.html
Light Blue is the default color that is used in the script that's available for download. If you want to use different colors, you will need to edit the script; however, all of the colors are declared in the script, so it's just a matter of replacing a few numbers.
To use miyofetch...
Place the script in /usr/local/bin/
Make sure that it has been marked as executable.
Open your terminal, and enter the following command...
miyofetch
...and it should appear in your terminal.
To have it appear each time you open your terminal, open your .bashrc file in your home folder, and add...
miyofetch
...to the bottom of the file.
Here is a link to a video showing how to install it and change the colors...
https://youtu.be/P5bl6Na-rwY
Download available here...
https://sourceforge.net/projects/miyoli … miyofetch/
#2 2020-04-22 12:21:12
Re: [MiyoLinux] miyofetch
Very nice, thanks for sharing smile
You might prefer this for the CPU identification:
CPU="$(awk -F':' '/model\ name/{cpu=$2} END{print cpu}' /proc/cpuinfo)"
And perhaps this for the OS line:
OS="$(awk -F'"' '/PRETTY_NAME/{print $2}' /etc/os-release)"
Black Lives Matter
#3 2020-04-22 18:59:11
MiyoLinux
Thanks HoaS. Yeah...seems like I always find a better way for something I've done after I've already done it...whether it's through advice from others (like you) or discovering something I missed myself. tongue
Thanks!
