Pages: 1
Hi
I run Devuan Ceres on amd64 architecture, with Xfce as DE.
$ uname -a
Linux *** 5.5.0-2-amd64 #1 SMP Debian 5.5.17-1 (2020-04-15) x86_64 GNU/LinuxWith the kernel 5.4.0-4, I have not any specific problem; but with the kernels 5.5.0-(1|2), I have this trouble: no sound with firefox (or videoconf, as zoom), egual for VLC.
If I download a video, or one music, I have not sound on the file!
Terrible!
(and, yes, the sound volume is open, at audible level).
But, If I use Audacious, I can hear the music!
I known, it's weird.
PS: FYI, I used since severals years Debian Sid, or *Buntu liked… (or OpenBSD).
Hi
Not using that variant but until you get a better reply....maybe firefox run from a terminal might show some errors?
If none seen....and if you don't mind a little bit of logging into sites
delete the
.cache/mozilla
.mozilla
in case stale files are interfering?
no problem here with MATE DE. you can also check ~/.xsession-errors file for related messages, and also try to run
$ apulse firefox , to see if that works...
lots of related messages in this forum to look more info : https://dev1galaxy.org/search.php?search_id=392925050
OK, I purged .cache/mozilla/firefox.
I Installed apulse. Always no sound!
$ apulse firefox
[apulse] [error] do_connect_pcm: can't get initial hw parameters for playback device "default". Error code 1 (Operation not permitted)
[apulse] [error] do_connect_pcm: failed to open ALSA device. Apulse does no resampling or format conversion, leaving that task to ALSA plugins. Ensure that selected device is capable of playing a particular sample format at a particular rate. They have to be supported by either hardware directly, or by "plug" and "dmix" ALSA plugins which will perform required conversions on CPU.
[Child 3677, MediaDecoderStateMachine #1] WARNING: 7f14f5e89160 OpenCubeb() failed to init cubeb: file /build/firefox-0xX3lf/firefox-75.0/dom/media/AudioStream.cpp, line 328
[Child 3677, MediaDecoderStateMachine #1] WARNING: Decoder=7f14f5ef2800 [OnMediaSinkAudioError]: file /build/firefox-0xX3lf/firefox-75.0/dom/media/MediaDecoderStateMachine.cpp, line 3758With apulse, video on firefox runs, but always without sound!
With VLC:
[0000556633e77470] vlcpulse audio output error: stream connection failure: Oops.
[0000556633e77470] main audio output error: module not functional
[00007fc2cd008b10] main decoder error: failed to create audio output
[apulse] [error] do_connect_pcm: can't open playback device "default". Error code -5 (Erreur d'entrée/sortie)
[00007fc2d0004680] glconv_vaapi_x11 gl error: vaAcquireBufferHandle: invalid VABufferID
[00007fc2cc00a5a0] filesystem stream error: read error: Cannot allocate memory
[h264 @ 0x7fc2ccf94500] get_buffer() failed
[h264 @ 0x7fc2ccf94500] thread_get_buffer() failed
[h264 @ 0x7fc2ccf94500] decode_slice_header error
[h264 @ 0x7fc2ccf94500] no frame!
[h264 @ 0x7fc2ccfa3fc0] get_buffer() failed
[h264 @ 0x7fc2ccfa3fc0] thread_get_buffer() failed
[h264 @ 0x7fc2ccfa3fc0] decode_slice_header error
[h264 @ 0x7fc2ccfa3fc0] no frame!
[00007fc2d40c6ea0] filesystem stream error: read error: Cannot allocate memory
[00007fc2d40c9520] cache_read stream error: cannot pre fill buffer
(...)@xinomilo: you link seems to be fault:
Désolé, aucun résultat n'a été trouvé pour votre recherche
And I repeat, with kernel 5.4.0-x, this run without no problem; sounds and video files are OK!
All run correctly (Firefox, VLC, Zoom, and others)!
Hi
sorry for late reply.
vlc tends to use "default" as the default audio device on next boot up.
If vlc was using pulseaudio then that is what default is....ditto if you used alsa...that is what default is.
Can you try
vlc -> Tools -> Preferences -> Select Audio TAB -> pulldown output and choose Alsa
pulldown device and choose the analog device....I am not sure what your choices are but mine have alsa, surround sound and hdmi
click save
and retest sound
Just FYI: With the new kernel Linux 5.6.0-1-amd64 #1 SMP Debian 5.6.7-1 (2020-04-29) x86_64 GNU/Linux, it seems run correctly!
Amazing!?!
After few weeks, a point to resume this:
If I use audacious, and pause sounds, to launch and view videos. Thoses are blocked until I quit audacious. When I've quitted audacious, videos run.
Otherwise, if I use zoom, I cant use audacious. I have an error message.
Error sndio : error on sio_open()
I need to quit zoom and browser web, if actived, and after I can to be use audacious.
@aus9: I've not change any settings on VLC, or others. It's all on default parameters.
Pages: 1
