Pages: 1
How to upgrade the kernel to the latest via backports sources.
You need to add extra backports sources tou your sources list:
echo "deb http://deb.devuan.org/merged <my_dist>-backports main contrib non-free" >> /etc/apt/sources.listaccording to your OS change <my_dist> with ascii or beowulfapt updateTo know how kernel are installed:
uname -aTo search a newest kernel:
apt search linux-imageIn the output we will see a lot of kernels, but we have interest to the latest, at this time the kernel 5.7:
Lets do it and install the latest kernel:
apt install linux-image-5.7.0-0.bpo.2-amd64 linux-headers-5.7.0-0.bpo.2-amd64 -t buster-backports -yA reboot is needed to boot on the new kernel:
rebootWe can check now:
uname -aThe output:
Linux my-pc 5.7.0-0.bpo.2-amd64 #1 SMP Debian 5.7.10-1~bpo10+1 (2020-07-30) x86_64 GNU/Linuxlet's take it a step further by removing the old kernels, in general it is advisable to keep 2 kernels in case there is a problem with one of them.
To view the installed kernel:
dpkg --list 'linux-image*'In the output you will see how kernel you can purge, in my case i keep the 4.19 and the 5.7 and purge the 5.6.
Example to purge a kernel:
apt autoremove --purge linux-image-5.6.0-0.bpo.2-amd64 linux-headers-5.6.0-0.bpo.2-amd64 -yWe need to upgrade the grub with the changes we made:
update-grub2After an reboot in the boot menu, select advanced options, you can also check the kernels who are usable.
In case if you have a graphic card using open firmwares you'll need to update your kernel with it, just check this tutorial
AMD Ryzen 7 5700X - Gigabyte B550 AORUS ELITE V2 - 32Gb Vengeance Pro RGB White - NVME/SSD 2,5To - RTX4060TI 6Gb White - PSU Corsair 750w White - Case Corsair 5000D AirFlox Case fan x7 White - AIO 240 Corssair RGB White
Daedalus / W11
Pages: 1
