#1 2020-03-31 12:04:32
coyotito
Beowulf
Simple question:
Is Devuan Buster Beta ready for home use now or what?  :=)
Cheers.
#2 2020-03-31 12:18:51
Re: Beowulf
I think it's been ready since December. Read what others are saying:
https://dev1galaxy.org/viewtopic.php?id=3372
#3 2020-03-31 15:01:42
sgage
Re: Beowulf
I've been using Beowulf full-time since January, and on and off for much longer than that. For the parts of the system that I use on a regular (or even occasional) basis, it has proven itself rock solid. I use the MATE DE, fwiw.
#4 2020-04-03 13:45:05
aut0exec
Re: Beowulf
Definitely. Been using it on non-important systems for months. Switch my primary desktop over about 2 weeks ago and the only issue was pulseaudio not starting automatically so one of my shell functions for recording audio wasn't working properly. All is solved now though!
#5 2020-04-04 00:21:27
bgstack15
Re: Beowulf
That was one of my early issues with Devuan Ceres (which was based on Beowulf at the time) as well! I remember making a .desktop file for my xdg autostart to run "pulseaudio -start" I think it was. Nowadays I've moved to alsa and not Xfce, so I have different types of issues now.
#6 2020-04-04 00:56:32
aus9
Re: Beowulf
@bgstack15
Then it is more likely  that aplay -l shows your hdmi getting index=0 or card 0. Use a modprobe config file to swap the index
see link if relevant
http://dev1galaxy.org/viewtopic.php?pid=339#p339
there are other ways of swapping index 2....and assumes you need analog sound.
#7 2020-04-04 14:49:29
aut0exec
Re: Beowulf
I wish I could move solely to alsa but try as I may, simply can't figure out how to record streams with solely alsa on this machine....
#8 2020-04-04 15:04:16
bgstack15
Re: Beowulf
aus9 wrote:
@bgstack15
Alas, sorry, I was trying to sound mysterious and aloof. I have no problems at the moment to troubleshoot. I do use Xfce and pulseaudio on the one system where I'm trying to output audio to HDMI (home theater PC). I guess I'm just a pragmatist because I use dbus everywhere, because I like lightdm which needs dbus and logind, and pulseaudio when I'm lazy.
