#1 2020-03-19 14:23:03
cipher
VMware install Devuan ascii
Tons of problems, the latest being kernel headers 4.9.0-11-amd64
Installed VMware-Workstation-Full-15.5.1-15018445.x86_64.bundle  went well.
Launching VMWare from apps menu fails, from terminal it produces depends error, the latest one being the kernel headers.
Those headers are not in the repo, apt upgrade and update no joy...
No idea what awaits after I solve this, if it is solvable
Info:
Linux devuan 4.9.0-11-amd64 #1 SMP Debian 4.9.189-3+deb9u2 (2019-11-11) x86_64 GNU/Linux
If there is another way to get VMware installed, I would appreciate any clues, thanks...
#2 2020-03-19 14:59:18
Re: VMware install Devuan ascii
Kernel 4.9.0-11 isn#t the latest kernel, that is -12. The following headers are in the repos:
    [ascii-backports] linux-headers-4.9.0-4-common-grsec-4.9.65-2+grsecunoff1~bpo9+1
    [ascii-backports] linux-headers-4.9.0-4-grsec-amd64-4.9.65-2+grsecunoff1~bpo9+1
    [ascii] linux-headers-4.9.0-12-all-4.9.210-1
    [ascii] linux-headers-4.9.0-12-all-amd64-4.9.210-1
    [ascii] linux-headers-4.9.0-12-amd64-4.9.210-1
    [ascii] linux-headers-4.9.0-12-common-4.9.210-1
    [ascii] linux-headers-4.9.0-12-common-rt-4.9.210-1
    [ascii] linux-headers-4.9.0-12-rt-amd64-4.9.210-1
    [ascii-security] linux-headers-4.9.0-11-all-4.9.189-3+deb9u2
    [ascii-security] linux-headers-4.9.0-11-all-amd64-4.9.189-3+deb9u2
    [ascii-security] linux-headers-4.9.0-11-amd64-4.9.189-3+deb9u2
    [ascii-security] linux-headers-4.9.0-11-common-4.9.189-3+deb9u2
    [ascii-security] linux-headers-4.9.0-11-common-rt-4.9.189-3+deb9u2
    [ascii-security] linux-headers-4.9.0-11-rt-amd64-4.9.189-3+deb9u2
#3 2020-03-19 15:29:07
cipher
installed /usr/src/linux-headers-4.9.0-12-amd64
Build environment error! A required application is missing and Modconfig cannot continue. xzCheck the log for more info"
Yes, the "xz" was there, no log specified
No joy...
#4 2020-03-19 18:10:36
Make sure build-essential is installed. (Yes, the package name is singular.)
#5 2020-03-20 00:32:33
cipher
Last piece of my puzzle, solved it, thanks very much!  :-)
#6 2025-01-14 10:24:15
