#1 2020-03-06 04:11:18
Roger
How to download alternate kernels
Forgive my ignorance, but I am having trouble persuading dpkg or apt to download an updated kernel for testing. I simply want to get the beowulf version without changing my sources.list and having apt then want to upgrade everything else. There must be a simple command to download a specific *.deb file from the repository. What is it?
#2 2020-03-06 05:17:08
ToxicExMachina
Re: How to download alternate kernels
Two simple steps:
1. First, you have to add a new repository config into /etc/apt/sources.list.d so you don't need to modify sources.list at all. This is very easy way to add new repository as a separated config.
2. According to "man apt-get" you can use the following command:
apt-get -t beowulf --download-only install package_name
Another ways:
1) You can use custom config for apt-get. The command line key is "-c". In this the config where you can specify configuration files like another sources.list. I think in this case it's inefficient way but it may be a good one for some situations.
2) There is a tool called aptly. You can even mirror a subset of repository with it.
3) Go to any Devuan mirror via web browser and download package manually.
#3 2020-03-06 23:29:38
Roger
Thanks very much. What I was missing was that one can control which parts of sources.list are used with entries in an
/etc/apt/preferences file, and that those preferences can be overridden by a -t flag to apt-get. Of course one also has to run apt-get update to get access to sections added to sources.list
I can now install selected items from the beowulf release into a system running ascii. In principle I am happy to stay with the current stable release, but I am planning for a possible problem with outdated device drivers installing Devuan onto a new computer. I have had problems like that before with ethernet and video. That was several releases ago, and Linux seems much better these days in being up to date with hardware.
