#1 2020-03-01 03:03:40
Kiwi Rider
Append date and time to .bash_history at start of session
Hi there.
Something I'm not up to figuring out ATM...
When I log into a machine I'd like to have the current date and time of the session added to ~/.bash_history.
I don't want it for every command line, just at the start of the session, eg
##Session begin 1 Mar 2020 16:00
cd /etc/apt
tail sources.list
Sometimes when I've been working on something across multiple accounts it'd be nice to be able to start to follow the order a bit easier, so having the date/time I start a session would be quite nice.
I'm sure someone else has done this but I cannot think of the right search terms to find the answer, nor am I familiar enough with the system to work it out myself at the moment. Everything points to sites explaining how to add a timestamp to every command but I don't want that, just session starts.
Session end would be fine as well, as it still separates each day/logon.
Much thanks.
#2 2020-03-01 10:47:30
Re: Append date and time to .bash_history at start of session
Create a file at ~/.bash_profile with this content:
. ~/.profile
echo "##
##Session begin $(date)
##" >> ~/.bash_history
#3 2020-03-22 12:46:45
Tried that and created the .bash_profile in the /root folder of a Beowulf installation in a VM based on the Beta DVD, does not work. I use Mate, the root terminal is started by pkexec mate-terminal.
What can be wrong? Rights?
PS: seems to work when I start the Mate terminal as user and switch to root with su -. How can I make this work via pkexec?
#4 2020-03-22 13:04:09
Don't use pkexec to start a root terminal, that's a silly idea. Why do the MATE devs do that? hmm
Use this to start a root terminal:
x-terminal-emulator -e su -
Create a file at ~/.local/share/applications/root-terminal.desktop to make the action available via the XDG menu sytem:
[Desktop Entry]
Version=1.0
Name=Root Terminal
Comment=Run terminal emulator as root
Type=Application
Exec=x-terminal-emulator -e su -
Categories=System;TerminalEmulator;
#5 2020-03-22 13:56:54
Putting it in ~/.bash_profile didn't work for me. I suppose I have to log out of my desktop session and restart it. Putting it in ~/.bashrc works every time I open a new terminal on the desktop. If I put it in /root/.bashrc, it works every time I do 'su' or 'su -' in a terminal.
#6 2020-03-22 15:08:09
Yes, that's right.
But then you'll have a new "##Session begin" section for every time a terminal is opened, which doesn't appear to be what the OP wants.
#7 2020-03-22 15:21:34
Please can you explain why this is a silly idea?
And its not a MATE devs idea. I put something together about a year ago, related to dropping gksu: https://dev1galaxy.org/viewtopic.php?id=2717
That line works fine as additional entry in the menu.
But: I don't like xterm. The font is ugly and much too small for my eyes, and the window is too small. Mate terminal gives me exactly what I want and need, and offers to increase the window to a width of 132 characters.
There should be a way to achieve this.
#8 2020-03-22 15:29:05
Entering:
. ~/.profile
echo "##
into /root/.bashrc causes a memory access error (Speicherzugriffsfehler in German), no matter if I use Mate with pkexec, su - or xterm. Whats wrong here? Guess I have to use the rescue mode again.
It does not matter if the separator is inserted every time I use the root terminal, I like the idea to have a better feeling for when I did something administering my installations.
BTW: the machine in question is Beowulf Beta from DVD in a VBox with UEFI encrypted with LVM. Rebooting the VM didn't make a difference.
Edit: could fix it via opening the root folder under the Mate file manager with administrative privileges and using geany to remove the modifications from the .bashrc file.
#9 2020-03-22 16:02:04
Because it runs the entire terminal emulator as root. Using my suggested command runs the emulator under the normal user and just runs the shell as root. See also https://en.wikipedia.org/wiki/Principle … _privilege
# update-alternatives --config x-terminal-emulator # then select your favourite emulator
#10 2020-03-22 16:33:10
I am always willing to learn, you got a point there. update-alternatives allows to switch to the mate-terminal-wrapper, I will change my default mode to that proposal. This also fixes the problems with the text in the bash_history.
Thanks, rolfie
#11 2020-06-06 10:21:56
Kiwi Rider
Yes, that's right.
Well. actually that'd be quite good I think . Sometimes I'm switching between normal user and root, and if I come back to something after a while I might see a string of commands in root's history but there was a break where I dropped back to normal user first.
As I said, I wouldn't want it for every single command, but at the start of any shell session is fine and can help a lot to trace things.
Thanks again to for the suggestions guys! It has helped some with keeping on top of some maintenance for a project where I really must work out a script that runs under cron, at least the gruntwork.
