I followed this
https://wiki.debian.org/SynapticsTouchp … n_touchpad
In Devuan ASCII there is already a 40-libinput.conf file:
~$ cat /usr/share/X11/xorg.conf.d/40-libinput.conf
# Match on all types of devices but tablet devices and joysticks
Section "InputClass"
Identifier "libinput pointer catchall"
MatchIsPointer "on"
MatchDevicePath "/dev/input/event*"
Driver "libinput"
Option "Tapping" "True"
EndSection
Identifier "libinput keyboard catchall"
MatchIsKeyboard "on"
Driver "libinput"
EndSection
Identifier "libinput touchpad catchall"
MatchIsTouchpad "on"
Driver "libinput"
EndSection
Identifier "libinput touchscreen catchall"
MatchIsTouchscreen "on"
Driver "libinput"
EndSection
Identifier "libinput tablet catchall"
MatchIsTablet "on"
Driver "libinput"
EndSectionand seems that the tapping option is active. However I tried to change Option "Tapping" "True" to Option "Tapping" "on" but it still doesn't work. Any suggest?
I followed this
No you didn't. That guide advises to create a new file at /etc/X11/xorg.conf.d/40-libinput.conf with the suggested content. But you need to run the commands as root for them to work.
Or with sudo:
sudo mkdir -p /etc/X11/xorg.conf.d
sudo tee /etc/X11/xorg.conf.d/40-libinput.conf <<END
Driver "libinput"
EndSection
ENDYou've added your configuration to the pointer section rather than the touchpad section, which is why it doesn't work. And using /usr/share/X11/xorg.conf.d/40-libinput.conf means your changes will be over-written if the xserver-xorg-input-libinput package is upgraded.
Sorry Head_on_a_Stick you are totally right, my mistake. Now the tapping works perfectly.
Thank you!
