#1 2020-02-11 15:31:17
stecco
SOLVED - Wi-Fi oddity
Every time I turn on my laptop, there is no internet connection.
I have to [Switch On Wi-Fi] pressing the button
then I have to [Refresh]
Only after this i can select my ESSID and connect to my network.
It's the first time I have a problem like this one.
Probably this issue is related rfkill, this is the situation when I tun on my laptop:
~# rfkill list
0: ideapad_wlan: Wireless LAN
	Soft blocked: yes
	Hard blocked: no
1: ideapad_bluetooth: Bluetooth
	Soft blocked: yes
	Hard blocked: no
2: hci0: Bluetooth
	Soft blocked: yes
	Hard blocked: no
3: phy0: Wireless LAN
	Soft blocked: yes
	Hard blocked: no
And this after the [Switch On Wi-Fi] and [Refresh] procedure
~# rfkill list
	Soft blocked: no
	Hard blocked: no
	Soft blocked: yes
	Hard blocked: no
2: hci0: Bluetooth
	Soft blocked: yes
	Hard blocked: no
	Soft blocked: no
	Hard blocked: no
Obviously I already tried
~# rfkill unblock all
and this worked too, but I have to do it every time I turn on my laptop... Super annoynig.
#2 2020-02-11 17:02:21
Re: SOLVED - Wi-Fi oddity
What is the status of the rfkill kernel module?
cat /sys/module/rfkill/parameters/default_state
It should be "1", if it's "0" then change that by creating a file at /etc/modprobe.d/rfkill.conf with this content:
options rfkill default_state=1
"Il semble que la perfection soit atteinte non quand il n'y a plus rien à ajouter, mais quand il n'y a plus rien à retrancher." — Antoine de Saint-Exupéry
#3 2020-02-11 19:21:23
stecco
~$ cat /sys/module/rfkill/parameters/default_state
1
It's 1
#4 2020-02-11 20:04:46
Good.
You can add the rfkill command to /etc/rc.local to get it to run automatically on boot. Or make a custom service to run it if you want more control.
#5 2020-02-12 00:03:35
stecco
I never edited rc.local nor created custom services before. Can you tell me how to do it or at least where I can find any good documentation to do that?
#6 2020-02-12 05:52:15
Just add your rfkill command on a single line at the end of the file at /etc/rc.local
#7 2020-02-14 10:55:09
stecco
Thank you Head_on_a_Stick now finally everything works.
