#1 2020-02-02 06:12:02
phillc54
[SOLVED] ASCII Backports Linux Headers
I am testing Devuan ASCII to see if it is compatible with LinuxCNC http://www.linuxcnc.org/ which requires a realtime kernel.
I added ascii-backports to my repository list and I have successfully installed a realtime linux-image 4.19.67-2+deb10u2~bpo9+1 and it errored while install the matching linux-headers as they are dependent on linux-compiler-gcc-6-x86 4.19.67-2+deb10u2~bpo9+1
According to this page https://pkginfo.devuan.org/cgi-bin/d1pk … ease=ascii it should be available but it doesn't appear in Synaptic Package Manager
Am I looking in the wrong place?
Cheers, Phill.
#2 2020-02-02 09:40:18
Re: [SOLVED] ASCII Backports Linux Headers
Give the root terminal a try. First do an apt update/apt upgrade, then:
apt -t ascii-backports install linux-headers-4.19.0-0.bpo.6-amd64
You will have to replace the 4.19.0-0.bpo.6-amd64 with the correct suffix for your machine. That apt install will pull all the required dependencies for the headers.
Rolfie
#3 2020-02-02 10:42:38
It's better to install the metapackages, they will keep the kernel version updated:
# apt -t ascii-backports install linux-{headers,image}-amd64
#4 2020-02-02 23:26:05
phillc54
Thank you both. I needed RT so I went with:
# apt -t ascii-backports install linux-{headers,image}-rt-amd64
and it worked a treat.
Cheers, Phill
