#1 2020-01-27 06:55:29
3036
Keyboard issues with default Xorg on netinst
Attempting a Devuan netinst... Installed without desktop environment, using US keymap and locale US english.
Installing default Xorg metapackage along with CWM seems to play with my keyboard.
In my cwmrc I have meta (winkey) set to move windows around. Instead alt is the key that responds.
Mousekeys (ctrl + arrows) seems to be enabled by default. For the life of me I cannot figure out how to disable mouse keys and reset the keyboard.
Any suggestions on how to reset everything so nothing has been prebound by X? Thanks in advance.
#2 2020-01-27 09:11:36
3036
Re: Keyboard issues with default Xorg on netinst
Finally figured it out... There is something wrong with the binary in the repos, openbsd-cwm.
Building this https://github.com/leahneukirchen/cwm works perfectly.
Very strange. New to Devuan, where/whom do I report this issue? Thank you.
#3 2020-01-27 14:34:20
HevyDevy
Post up your .cwmrc and ....
RTFM https://www.mankier.com/5/cwmrc
edit: there is no openbsd-cwm package in devuan.
The only packages in devuan are listed here: https://pkginfo.devuan.org/cgi-bin/d1pk … elease=any
[ascii] cwm-5.6-4+b1
    [ascii] swap-cwm-1.2.1-7
    [beowulf] cwm-6.3-1
    [beowulf] swap-cwm-1.2.1-7
    [ceres] cwm-6.3-1
    [jessie] cwm-5.5-1+deb8u1
