#1 2020-01-11 19:07:36
Ron
Is VirtualBox (or alternative) in the repo?
Am I missing it, or is Virtualbox not in the repo? Any alternatives in the repo?
#2 2020-01-11 19:36:28
Ogis1975
Re: Is VirtualBox (or alternative) in the repo?
Hello. Virtualbox is in  ascii-backports - contrib repo. But, for my opinion, it is a crap. I prefer qemu-kvm- QEMU Full virtualization on x86 hardware. It is in ascii - main repo.
            ----+- Peter Kropotkin -+----
#3 2020-01-11 20:14:58
No, it's so shit that the Debian developers removed it from the stable release and won't be backporting it in future.
See https://bugs.debian.org/cgi-bin/bugrepo … bug=794466 for all the gory details.
Ogis1975 wrote:
I prefer qemu-kvm
+1
#4 2020-01-11 22:46:08
Ron
In Synaptic, kvm is described as "QEMU Full virtualization on x86 hardware." My rig is 64 bit. Can I use kvm on it? Also, would a guest 64 bit OS work on it?
#5 2020-01-12 11:10:29
Andre4freedom
Simple answer: YES
You must have (and you have) 64bit Intel or AMD x86 hardware. You can run client-VMs in 64bit and 32bit mode.
Works very well on ASCII.
Just install qemu-kvm and its dependencies from the ascii repos and you are fine.
Don't forget to install virt-manager too! it helps a lot.
Good luck
#6 2020-01-12 11:13:51
The x86 architecture includes both 32-bit and 64-bit versions. It is possible to run a 64-bit or 32-bit guest in a 64-bit host (but you can't run a 64-bit guest in a 32-bit host).
If you don't like GUI management tools see my fdn guide: http://forums.debian.net/viewtopic.php?f=16&t=144775
#7 2020-01-12 13:10:02
Ogis1975
It is exelent guide. This instruction helped me a lot!
#8 2020-01-12 14:49:32
aut0exec
Ogis1975 wrote:
I prefer qemu-kvm
+1
This is where I've been moving as well. Between it and LXC, virtualbox has pretty much gone by the wayside on *nix stations. Sadly still have to use VB on Windoze stations for work but it beats the licensing cost of VMware!
#9 2020-01-12 16:11:06
Ron
Thanks to all for your help. If I have any problems, I'll be back. wink
#10 2020-01-15 06:49:27
ToxicExMachina
If you need VirtualBox, you can install it from official deb packages: https://www.virtualbox.org/wiki/Linux_Downloads
However, I recommend QEMU (+ KVM) with AQEMU GUI:
apt-get install aqemu
QEMU is easy-to-use solution. For example, you can add USB devices into VM out of box without limitations. QEMU also has snapshots support and you don't need to build additional kernel module for virtualization. AQEMU is awesome UI because you can get a command for running configured QEMU without GUI at all ("Show QEMU Arguments" and "Create Shell Script" in right-click menu).
If you need terminal UI you can use this: https://bitbucket.org/PascalRD/nemu/
#11 2021-01-22 16:49:17
jorgericarte
An alternative
apt-get install virt-manager
#12 2021-01-22 18:30:41
Ogis1975 wrote:
I prefer qemu-kvm
+1
Seconded...
Qemu-kvm is awesome.
Virt-maanger, is semi okay...
But, virtualbox has been crap since... well, always really... hmm
Especially when they made it depend on a non-free watcom compiler.
4.1 was the only version I ever liked even a little bit.
QEMU, FTW!
#13 2021-01-23 14:20:23
thierrybo
For all my new vms i use libvirt now but I am too lazy to convert all my previous virtualbox machines to libvirt so I need both for the moment.
If you can use Devuan testing, thankfully virtualbox is in Devuan Ceres. I use this :
/etc/apt/preferences.d/40sid
Package: *
Pin: release a=unstable
Pin-Priority: -1
Package: *
Pin: release a=experimental,n=experimental
Pin-Priority: -1
/etc/apt/preferences.d/90virtualbox-sid
Package: virtualbox*
Pin-Priority: 900
#14 2021-01-23 15:46:27
thierrybo wrote:
i use this
Well done, you have pulled in the libc6 package from sid and prevented it from being subsequently upgraded. Good luck with any future vulnerabilities in that package, your system will be left wide open to them.
@all: don't try this at home.
And just for the record experimental has a pin value of 1 (one) by default so you don't need a preferences entry for that and if you did want to pin a package from ceres (which you don't) then it would only need a pin value of 500 because APT would favour the higher package version automatically.
EDIT: hold on, are you using testing? The above would apply to beowulf users.
#15 2021-01-23 19:45:16
thierrybo
Yes i use testing.
#16 2021-01-24 13:20:52
swarfendor437
I've had an issue with Aqemu in that I am not doing something correct i.e., thinking I had created an installed 'drive' when it starts in live mode again (image). However I found VirtManager (Virtual Machine Manager to give it it's full title) great at importing my VB .vhd into quemu using the qcow2 converter. It is so much nicer not to have to press the right Ctrl key to free the mouse back to the desktop - the mouse can easily move from a VM to the desktop. (I do have 2 monitors I hasten to add!)
#17 2021-02-05 11:15:15
If you want to know how to use qemu to install virtual machines, there is a thread where someone helped me with that...
https://dev1galaxy.org/viewtopic.php?pid=4128#p4128
That is how I do it... wink
"This is what I do:
qemu-img create -f qcow2 name-of.img 100g
In the directory where you made your image put your iso and:
sudo kvm -m (amount of memory for VM, i.e. 2048) -cdrom (name of image, i.e., gnuinos.iso) -boot d name-of.img
To start the image after install do:
sudo kvm -m (amount of memory for VM, i.e. 2048)  name-of.img
HTH"
#18 2021-02-05 15:03:02
Why are you running QEMU with sudo? That's not a good idea — security for virtualised systems isn't the best and elevating the privileges will only make the situation worse.
#19 2021-02-05 18:03:56
Whoops, your right, good eye, I forgot myself that isn't a good idea.
#20 2021-03-13 03:40:50
Actually, I neglected to mention, in my config, it seems I don't have that configuration, so maybe idk, I just forgot to write down my actual config... lol...
It was a quick copy and paste, but more or less its the same, - the dumb sudo... hmm
