#1 2019-12-30 20:31:27
turbo
"Warning": Failed to connect to lvmetad
Hello,
just new to Devuan with a fresh ASCII desktop install. Installation went smooth and after the first reboot I got the following warning message at boot time.
"Warning": Failed to connect to lvmetad. Falling back to internal scanning.
Booting is otherwise fine without any hick-ups. Too new to "try" something to get this message to disappear.
Any suggestions ?
Thank you.
Johannes
#2 2019-12-31 10:45:47
Re: "Warning": Failed to connect to lvmetad
turbo wrote:
Any suggestions ?
I have not come across this and from what I have read, if the system boots without issues, it is just a harmless warning.
Maybe someone else knows better.
Cheers,
#3 2019-12-31 11:52:02
HevyDevy
from reading up on this it sounds like a grub erroneous message. From the gentoo forum its quite possible this is the problem.
https://forums.gentoo.org/viewtopic-t-1 … art-0.html
That's a feature, not a fatal error. Internal scanning will work for some time yet.
When you install grub, it wants to consult /etc/mtab, which is missing in the chroot, since all the mounts happened and were recorded in the /etc/mtab outside the chroot.
/etc/mtab is not usually a file any more, its a symbolic link.
I wonder what the output of /etc/mtab is ?
cat /etc/mtab
and
ls /etc/mtab -l
#4 2019-12-31 14:09:12
/etc/mtab should be a symlink to /proc/self/mounts
If you're not using LVM then remove the package and re-configure GRUB:
# apt purge lvm2
# update-grub
#5 2019-12-31 14:19:02
HevyDevy
# apt purge lvm2
# update-grub
Im not using LVM but have the package installed and do not get this error. Im on Beowulf Refracta though.
I dont believe removing lvm2 is a solution head on a stick.
#6 2019-12-31 14:22:15
Yeah, you're probably right. It was just a stab in the dark tbh.
#7 2019-12-31 14:26:00
HevyDevy
Its probably something t do with os-prober.
#8 2019-12-31 17:32:21
turbo
cat /etc/mtab
the output is
cat /etc/mtab
sysfs /sys sysfs rw,nosuid,nodev,noexec,relatime 0 0
proc /proc proc rw,nosuid,nodev,noexec,relatime 0 0
udev /dev devtmpfs rw,nosuid,relatime,size=2055536k,nr_inodes=209431,mode=755 0 0
devpts /dev/pts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000 0 0
tmpfs /run tmpfs rw,nosuid,noexec,relatime,size=413008k,mode=755 0 0
/dev/mapper/devuan--vg-root / ext4 rw,relatime,errors=remount-ro,data=ordered 0 0
tmpfs /run/lock tmpfs rw,nosuid,nodev,noexec,relatime,size=5120k 0 0
pstore /sys/fs/pstore pstore rw,relatime 0 0
tmpfs /run/shm tmpfs rw,nosuid,nodev,noexec,relatime,size=826000k 0 0
/dev/sda1 /boot ext2 rw,relatime 0 0
/dev/mapper/devuan--vg-home /home ext4 rw,relatime,data=ordered 0 0
/dev/mapper/devuan--vg-tmp /tmp ext4 rw,relatime,data=ordered 0 0
/dev/mapper/devuan--vg-var /var ext4 rw,relatime,data=ordered 0 0
tmpfs /sys/fs/cgroup tmpfs rw,nosuid,nodev,noexec,mode=755 0 0
cgroup /sys/fs/cgroup/elogind cgroup rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/usr/lib/elogind/elogind-cgroups-agent,name=elogind 0 0
tmpfs /run/user/1000 tmpfs rw,nosuid,nodev,relatime,size=413004k,mode=700,uid=1000,gid=1000 0 0
and
ls /etc/mtab -l
ls /etc/mtab -l
lrwxrwxrwx 1 root root 12 Dec 29 16:58 /etc/mtab -> /proc/mounts
As said earlier, this is a fresh install and I chose the LVM option at graphical install. And I finished with my desktop install using the xfce desktop.
Johannes
#9 2020-01-01 06:29:31
HevyDevy
Maybe run update-grub again and see if the message disappears.
sudo update-grub
#10 2020-01-01 12:16:19
turbo wrote:
ls /etc/mtab -l
That's strange, the Refracta beowulf beta also does that.
From my Debian buster system:
empty@E485:~ $ ls -l /etc/mtab
lrwxrwxrwx 1 root root 19 Sep 23 17:11 /etc/mtab -> ../proc/self/mounts
empty@E485:~ $
/proc/mounts is a symlink to /proc/self/mounts so for your system /etc/mtab is symlinked to a symlink, which doesn't sound right.
Does linking it correctly fix things?
cd /etc
# ln -sf ../proc/self/mounts mtab
EDIT: use the force, Luke.
#11 2020-01-01 12:44:01
HevyDevy
Hold on there head on a stick, there must be a good explanation of why /etc/mtab is symlinked to /proc/mounts ?
http://man7.org/linux/man-pages/man5/proc.5.html
#12 2020-01-01 12:49:21
Probably so but that isn't the case for Debian buster and symlinking to another symlink just sounds wrong.
The content would be the same either way.
#13 2020-01-01 12:53:15
HevyDevy
So far all ive been able to understand is that it is easier to have /etc/mtab symlinked to /proc/self/mounts in the case of loop devices / losetup. Debian buster uses systemd, so maybe there is a difference in devuan having these symlinks?
You may be right on this, sorry. Man page says....
/proc/mounts
              Before kernel 2.4.19, this file was a list of all the filesys‐
              tems currently mounted on the system.  With the introduction
              of per-process mount namespaces in Linux 2.4.19 (see
              mount_namespaces(7)), this file became a link to
              /proc/self/mounts, which lists the mount points of the
              process's own mount namespace.  The format of this file is
              documented in fstab(5).
#14 2020-01-01 15:29:43
@OP: as you say you are using a LVM, then the message is normal. As long as the LVM finally is opened, everything is fine.
#15 2020-01-01 19:42:41
turbo
Hey guys,
thank you for your feedback. I think I will leavei t as is for now, as all is running without problems.
Happy New Year to All.
Johannes
