#1 2019-12-10 12:50:22
roluan17
sources.list for bloody germans
I had difficulties running  DVD's on my system so I added:
deb http://us.deb.devuan.org/merged/ ascii main non-free contrib
deb-src http://us.deb.devuan.org/merged/ ascii main non-free contrib
deb http://us.deb.devuan.org/merged/ ascii-security main non-free contrib
deb-src http://us.deb.devuan.org/merged/ ascii-security main non-free contrib
deb http://us.deb.devuan.org/merged/ ascii-updates main non-free contrib
deb-src http://us.deb.devuan.org/merged/ ascii-updates main non-free contrib
to my sources.list (everything is fine now, DVD's are showing)
But shouldn't I use instead of us.deb.devuan.org, the german de.deb.devuan.org?
#deb http://de.deb.devuan.org/merged/ ascii main non-free contrib
#deb-src http://de.deb.devuan.org/merged/ ascii main non-free contrib
#deb http://de.deb.devuan.org/merged/ ascii-security main non-free contrib
#deb-src http://de.deb.devuan.org/merged/ ascii-security main non-free contrib
#deb http://de.deb.devuan.org/merged/ ascii-updates main non-free contrib
#deb-src http://de.deb.devuan.org/merged/ ascii-updates main non-free contrib
I tried that out and got a long list of errors about double entries.
Do not understand the HOW and WHY
Thanks for help
#2 2019-12-10 13:08:23
Re: sources.list for bloody germans
You can drop the country code altogether. It doesn't really do anything - you just get redirected to a nearby mirror. (e.g. I'm in the US and I frequently get Italian or German mirrors. There is no US mirror.)
If you want to use a specific mirror, choose one from the list here: https://devuan.org/get-devuan
#3 2019-12-10 13:29:39
roluan17
That was quick, thank you!
What's your local time?
#4 2019-12-12 18:13:18
Hi roluan17,
I'm from Germany also. I have dropped all tries to add a country code or a specific mirror. I simply use:
deb http://deb.devuan.org/merged ascii main contrib non-free
deb http://deb.devuan.org/merged ascii-security main contrib non-free
deb http://deb.devuan.org/merged ascii-updates main contrib non-free
deb http://deb.devuan.org/merged ascii-backports main contrib non-free
This works fine.
Regards, rolfie
#5 2019-12-12 19:58:40
UTC -0500  (East coast US)
#6 2019-12-12 20:07:23
Ozi
rolfie wrote:
Hi roluan17,
This works fine.
Regards, rolfie
I'm +11 atm, summer time here. And I see no advantage in country codes either, just use the same as above.
#7 2019-12-28 11:43:19
thierrybo
rolfie wrote:
Hi roluan17,
This works fine.
Regards, rolfie
+1
