#1 2016-12-05 12:21:55
jessie-backports
Someone posted in #devuan a couple hours ago that they ran into trouble with jessie-backports. This is the same problem I had a while ago. If you have jessie-backports enabled in your sources, and you run an update and upgrade, your system will get spammed with backports versions of everything possible. I reported this issue, and someone recently posted a possible fix - https://git.devuan.org/devuan/devuan-pr … #note_8046
Until then, you can prevent this from happening by pinning backports to a lower priority. Put the following into /etc/apt/preferences.d/00backports
Package: *
Pin: release a=jessie-backports
Pin-Priority: 100
This is a lot easier to prevent than it is to fix it. I don't recall exactly what I did to downgrade all the packages I got grom backports, but it may have involved uninstalling a bunch of stuff (including xorg) and then reinstalling. You can see what you have installed from backports with
dpkg -l | grep bpo
#2 2016-12-05 13:06:25
chillfan
Re: jessie-backports
dpkg -l | grep bpo
I had the same problem with the system being spammed full of backports.
After checking for packages named bpo as above and disabling the backports repository I did the following:
apt-cache show pkgname|grep Vers
From here I just chose the latest version that did not include "bpo" and used apt-get to downgrade the packages individually.
apt-get install pkgname=pkgversion
Where pkgname is the package you want and pkgversion is the latest one returned by the previous command. Where possible I removed and reinstalled packages that wouldn't clobber the system and downgraded the rest. It's a little time consuming, but everything turned out OK.
#3 2016-12-06 08:56:31
dj_papeles
Thank you very much! Pin priority did the trick, it worked like in wheezy.
#4 2017-03-12 16:21:01
more...
https://lists.dyne.org/lurker/message/2 … 61.en.html
Author: Adam Borowski
Date: 2017-01-28 05:08 -500
To: dng
Subject: Re: [DNG] Backports priority
(snip)...
Temporarily bump the priority of stable above 1000, it will downgrade
everything to that release.
