#1 2019-11-21 20:53:30
kapqa
(building handbrake) error with pkg-config
Hello ,
i try to build Handbrake from source on Devuan Ascii.
the following error occurs during ./config :
ERROR: minimum required pkg-config version is 0.29.1 and /usr/bin/pkg-config is 0.29
however
sudo apt install pkg-config
Building dependency tree
pkg-config is already the newest version (0.29-4+b1).
#2 2019-11-22 20:21:22
bgstack15
Re: (building handbrake) error with pkg-config
Ah, the way package version tends to work is the application upstream chooses a version string. In this case, the upstream version number is "0.29" without quotes. The package has its own versioning, which is "4+b1" which means it is the fourth attempt to package this application version, with the additional value "+b1" which could mean anything you want it to mean. I see lots of "+devuan2.1" and similar at the end of the package version.
So, you put the application version and package version together with a dash, to get "0.29-4+b1" which unfortunately is lower than the application version "0.29.1".
The Handbrake upstream must follow the upstream pkg-config more aggressively than Devuan (probably Debian) does. Perhaps they base their dpkg on Ubuntu which uses a higher version of pkg-config, or something, at this very moment.
Turns out pkg-config is a freedesktop.org thing. (That explains a few things...) The current version as of this post is 0.29.2
