#1 2019-10-03 02:28:43
bgstack15
[SOLVED] Devuan snapshot repos, like Debian?
An alternate title is: Devuan ceres libldb2 and its reverse dependencies
Pardon me, as I'm still learning the debianized way to do things.
Tonight, I was running OS updates on a Devuan ceres installation, and it removed freeipa-client, because sssd appears to be dependent on libldb1 but other parts of freeipa-client depend on libldb2, and those packages are conflicting. Yes, of course I know this is the rolling release "unstable" release.
My errors are this:
[bgstack15-local@ltb-013|/home/bgstack15-local/dev]$ sudo apt-get install freeipa-client sssd-ad-common sssd sssd-ad sssd-ipa samba-libs libsmbclient libldb2
Building dependency tree
 freeipa-client : Depends: python3-sss but it is not going to be installed
 sssd : Depends: python3-sss (= 2.2.2-1) but it is not going to be installed
        Depends: sssd-common (= 2.2.2-1) but it is not going to be installed
        Depends: sssd-krb5 (= 2.2.2-1) but it is not going to be installed
        Depends: sssd-ldap (= 2.2.2-1) but it is not going to be installed
        Depends: sssd-proxy (= 2.2.2-1) but it is not going to be installed
 sssd-ad : Depends: sssd-common (= 2.2.2-1) but it is not going to be installed
           Depends: sssd-krb5-common (= 2.2.2-1) but it is not going to be installed
           Depends: libldb1 (>= 0.9.21) but it is not going to be installed
 sssd-ad-common : Depends: sssd-common (= 2.2.2-1) but it is not going to be installed
 sssd-ipa : Depends: sssd-common (= 2.2.2-1) but it is not going to be installed
Boiling it down even further, I got to the real problem:
[bgstack15-local@ltb-013|/home/bgstack15-local/dev]$ sudo apt-get install freeipa-client sssd-ad-common sssd sssd-ad sssd-ipa samba-libs libsmbclient libldb2 python3-sss sssd-common sssd-krb5 sssd-ldap sssd-proxy sssd-krb5-common libldb1
 libldb2 : Breaks: libldb1 (< 2:2~) but 2:1.5.5-2 is to be installed
Is it possible to use a Devuan snapshot repository, like I have read about for Debian?
Or is there a way I can help whoever is responsible for libldb1 so that ew can get 2:2 version published so I can log back into my system with my domain account?
#2 2019-10-03 03:08:27
bgstack15
Re: [SOLVED] Devuan snapshot repos, like Debian?
Answered my own question!
This is what I get for doing unattended upgrades in a rolling release. I realize it's entirely my fault.
I have successfully downgraded components necessary so I can get a running sssd client and I can getent passwd bgstack15 again. Thankfully, these components do not require the custom rebuilt packages for devuan. I'm not entirely sure what I would have done in that case.
# set this source:
deb   https://snapshot.debian.org/archive/debian/20190901T043449Z/ unstable main
Run commands
sudo apt-get -o Acquire::Check-Valid-Until=false update
sudo apt-get install freeipa-client=4.7.2-3 freeipa-common=4.7.2-3 python-ipaclient=4.7.2-3 sssd=2.2.0-4 python3-sss=2.2.0-4 sssd-ad=2.2.0-4 sssd-common=2.2.0-4 sssd-ipa=2.2.0-4 sssd-krb5=2.2.0-4 sssd-ldap=2.2.0-4 sssd-proxy=2.2.0-4 libsss-idmap0=2.2.0-4 sssd-ad-common=2.2.0-4 sssd-krb5-common=2.2.0-4 libipa-hbac0=2.2.0-4 libsmbclient=2:4.9.11+dfsg-1 samba-libs=2:4.9.11+dfsg-1 libwbclient0=2:4.9.11+dfsg-1
References
https://unix.stackexchange.com/question … cal-mirror
https://duckduckgo.com/?q=debian+releas … is+expired
#3 2025-01-14 16:54:21
mirrortokyo
How do I find and download libavahi-glib1_0.8-15devuan1_amd64.deb which was in Ceres a while back but isn't found when searching https://pkginfo.devuan.org/cgi-bin/policy-query.html
#4 2025-01-15 09:43:22
mirrortokyo
Answering my own question, thanks to the #devuan irc channel,
https://git.devuan.org/devuan/avahi/src … -15devuan1, then selecting tags had a link to a source tarball for each of the versions, and I built version 0.8-15devuan1 myself using dpkg-buildpackage -b.
