#1 2019-09-22 10:59:52
rahalver
poor sound quality - scratchy
Hi.  I have now successfully installed "devuan ascii _2.0.0_amd64 desktop-live.iso" on an iMac.
Everything works great, except the sound quality is so-so.
The sound worked before on the imac, so I think it is not a hardware problem.
It is a 64 bit system.
3.06 GHz Intel Core 2 Duo processor.
Model:  A1225
24" - seems to be from 2007.
Question:  What might I do to improve the scratchy sound?  It is present with Youtube (through various browsers) and Xine, and VLC.
Thanks for ideas/guidance.
#2 2019-09-22 13:53:12
HevyDevy
Re: poor sound quality - scratchy
what is your audio?
lspci -knn | grep "Audio"
#3 2019-09-22 22:32:14
rahalver
Hi.  Thanks for the reply.  I am in a different time zone, so I may not respond to your answer right away.  Not sure what your meaning is..
Should I run [lspci -knn | grep "Audio"] in terminal mode (command line) to determine what my audio is?
#4 2019-09-23 08:13:39
ToxicExMachina
Try to remove pulseaudio. At least it worked for me.
#5 2019-09-23 10:01:45
HevyDevy
yes
#6 2019-09-23 13:22:12
rahalver
My audio seems to be 00:08.0 Audio device [0403]: NVIDIA Corporation MCP79 High Definition Audio [10de:0ac0]
Now what?
#7 2019-09-23 13:43:12
HevyDevy
sudo apt-get remove --purge pulseaudio
sudo apt-get install alsa-utils
#8 2019-09-24 12:30:57
SJW for hire, usual rates apply
#9 2019-09-24 13:18:18
rahalver
Thanks y'all.
I tried this, and it didn't work:
I will now try the wiki archlinux ideas and let you know later.
