#1 2019-09-08 21:02:03
oui
I search for experiments trying to build linux from Devuan sources
I search for experiments trying to build some absolutely minimal linux environment (but with some graphic ability!!!) from Devuan sources
- without use of some system"x" or other "boxes"
- with minimal dev environment
- if possible with integrated dpkg + apt + debootstrap + apt-build
(example of such an old realisation? yes: the 1th stable release of SliTaz until the stage named "justX"!)
are such experiments or going derivatives known?
#2 2019-09-08 21:03:38
oui
Re: I search for experiments trying to build linux from Devuan sources
ok! SliTaz 1.0 did use boxes, and I find it is to avoid if possible...
#3 2019-09-08 21:08:01
oui
how to download directly sources packages from Devuan with wget? can the Devuan packages list (Ceres rolling) at Distrowatch be used for this purpose?
#4 2019-09-08 21:10:35
oui
would the most actual SliTaz dev environment (select the subdir "iso" or use an old ISO-cd with SliTaz to active the netstart of one actual version of SliTaz without some installation or install within your actual Devuan installation for ex. in /var/slitaz as proposed in http://doc.slitaz.org/en:guides:uncommo … filesystem !) be enough to start with such an experiment?
