#1 2019-09-05 09:03:20
nomorelogic
[solved] vpgrp/devuan docker image
hi all
I'm new with devuan and I'd like to make my custom devuan docker image.
The docker image I use to start my customization is vpgrp/devuan but I've some problems
1) unable to install wget:
root@311049c9574d:/home# apt-get install wget
E: Unable to locate package wget
2) unable to install libgtk2.0-dev
apt-get install libgtk2.0-dev
E: Unable to locate package libgtk2.0-dev
E: Couldn't find any package by glob 'libgtk2.0-dev'
E: Couldn't find any package by regex 'libgtk2.0-dev'
Can anyone help me?
Thanks in advance
nomorelogic
#2 2019-09-05 12:21:42
bgstack15
Re: [solved] vpgrp/devuan docker image
Can you show us the contents of /etc/apt/sources.list and any files underneath /etc/apt/sources.list.d/ ?
#3 2019-09-05 22:17:21
nomorelogic
hi bgstack15
follow file contents
deb http://mirror.vpgrp.io/devuan ascii main
deb http://mirror.vpgrp.io/devuan ascii-updates main
deb http://mirror.vpgrp.io/devuan ascii-backports main
deb http://mirror.vpgrp.io/devuan ascii-security main
in /etc/apt/sources.list.d/ I can't find any file
nomorelogic
#4 2019-09-06 13:39:56
bgstack15
And another reality check: you did run an apt-get update before trying to install any packages?
What does apt-cache policy get you?
You can go visit that main url from sources.list, and check if the packages exist. However, they are using amprolla just like the main Devuan repos, so they are proxying all the Debian contents that don't need to be customized for our distro.
#5 2019-09-06 14:10:41
nomorelogic
after apt-get update I've a new error but I think the cause is the same
root@4281eb6b4506:/# apt-get update
Get:1 http://mirror.vpgrp.io/devuan ascii InRelease [439 kB]
Get:2 http://mirror.vpgrp.io/devuan ascii-updates InRelease [150 kB]
Get:3 http://mirror.vpgrp.io/devuan ascii-backports InRelease [150 kB]
Get:4 http://mirror.vpgrp.io/devuan ascii-security InRelease [143 kB]
Get:5 http://mirror.vpgrp.io/devuan ascii/main amd64 Packages [80.9 kB]
Get:6 http://mirror.vpgrp.io/devuan ascii-updates/main amd64 Packages [2000 B]
Get:7 http://mirror.vpgrp.io/devuan ascii-backports/main amd64 Packages [2604 B]
Get:8 http://mirror.vpgrp.io/devuan ascii-security/main amd64 Packages [6928 B]
Fetched 974 kB in 1s (599 kB/s)
root@4281eb6b4506:/# apt-get install wget
Package wget is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'wget' has no installation candidate
follow apt-cache policy output
root@4281eb6b4506:/# apt-cache policy
Package files:
 100 /var/lib/dpkg/status
     release a=now
 500 http://mirror.vpgrp.io/devuan ascii-security/main amd64 Packages
     release v=2.0,o=None,a=ascii-security,n=None,l=None,c=main,b=amd64
     origin mirror.vpgrp.io
 100 http://mirror.vpgrp.io/devuan ascii-backports/main amd64 Packages
     release v=2.0.0,o=Devuan,a=ascii-backports,n=ascii,l=ascii-backports,c=main,b=amd64
 500 http://mirror.vpgrp.io/devuan ascii-updates/main amd64 Packages
     release v=2.0.0,o=Devuan,a=ascii-updates,n=ascii,l=ascii-updates,c=main,b=amd64
 500 http://mirror.vpgrp.io/devuan ascii/main amd64 Packages
     release v=2.0.0,o=Devuan,a=ascii,n=ascii,l=ascii,c=main,b=amd64
Pinned packages:
after that, I executed
echo deb http://deb.devuan.org/merged ascii          main >>/etc/apt/sources.list
apt-get update
now wget and libgtk2.0-dev are correctly installed
I don't know if replacing the content of /etc/apt/sources.list with
deb http://deb.devuan.org/merged ascii-updates  main
deb http://deb.devuan.org/merged ascii-security main
is a good or a bad idea...
I've another question: does exists an official devuan docker image?
