#1 2019-08-28 07:03:31
cunotj
Pi Zero W - How to connect over usb?
Good day to you all. First time poster here.
Does anyone have experience with the pi zero w? I've been trying to get it up and running, but so far nothing has worked out.
I couldn't get the wifi going, so decided to try ssh over usb. I followed the instructions for raspbian, no luck. The pi doesn't even
show up in dmesg.
#2 2019-08-28 08:28:20
Dutch_Master
Re: Pi Zero W - How to connect over usb?
I've unsuccessfully attempted to use the Devuan RPi images for the RPi1 several times, so I ended up using Raspbian-lite instead. As I'm using this particular RPi in headless mode, systemd is not a overly annoying issue. Using a GUI is rather not recommended though roll
#3 2019-08-28 22:26:43
czeekaj
I installed the Rasbian Devuan Image for arm on a Raspi 3.
I just used dd to the SD card on my laptop and it booted up fine.
Although I filled the SD card now I am getting some errors even after freeing some space.
I'll probably have to re-flash it at some point.
It was an ascii image.
I used it to mess around on systems wink
#4 2019-08-30 14:59:38
crankypuss
Only recently did i discover what "Raspberry pi" meant; go figure, i'm old and stupid.  Anyway, it sounds as though you are running out of storage on the SD card, which you recognize.  What you might *not* be aware of, is how abysmally lame linux is when it runs out of storage.  It's like, okay, so we're out of storage, what are we gonna do about it? We'll just run this tool like... oh, baobab maybe, (and i like baobab for what it's worth).  But the tool needs resources and they're all gone.  Catch-22, bigtime; if you haven't been there before.
linux needs to have a user-settable configuration parameter that specifies "how proactive do you want the system to be when storage is running low?"
Yeah, i know, why don't i build one. <g>  About the best i could do to help within my time constraints is to write some half-assed PHP utility to deal with it through a text-mode interface.  If that's potentially useful, let me know.  Otherwise, good luck, really; i think there's a chinese phrase that describes the lands we move into when resources run low, "qi-qi-gui-gui" if i've remembered it right, anyway it means "when strange things happen".
#5 2019-10-05 14:56:52
alphalpha
as far as i know you cannot use the micro-usb port to connect to your pc
but you can connect a serial cable to the gpio pins and use putty to connect via com port
see this tutorial
