#1 2019-07-16 04:01:26
spinlock
Raspberry Pi VideoCore userland build/install (/opt/vc)
Doing this for the second time in 6 months, so I thought I'd better document it here.
The Raspbian images contain some userland libraries, code examples etc. for the VideoCore of the raspberry pi. They usually live in /opt/vc. Building the software from the official github repo directly on the raspberry pi, seems to be the cleanest way to install it on devuan. This worked on a rpi3 (running 32-bit), and most recently on a pi zero.
On a pi zero the build takes about 45 minutes (<10 minutes on the rpi3).
The required packages are:
$ sudo apt install build-essential pkg-config cmake
Building locally in a 128MB ramdisk works nicely (gpu_mem=32 initially, adjusted later):
$ mkdir /tmp/ramdisk
$ sudo mount -t tmpfs -o size=128M tmpfs /tmp/ramdisk
$ cd /tmp/ramdisk
Fetch the code:
git clone https://github.com/raspberrypi/userland
Start the build:
$ cd userland
$ ./buildme
This should install everything in /opt/vc.
Change memory split in /boot/config.txt:
## memory shared with the GPU
gpu_mem=128
More to follow.
#2 2019-07-17 04:29:35
spinlock
Re: Raspberry Pi VideoCore userland build/install (/opt/vc)
Add login username to /etc/group for audio, video:
audio:x:29:username
video:x:44:username
Create '/etc/udev/rules.d/10-local-rpi.rules', to set VC device group and permissions:
SUBSYSTEM=="vchiq", GROUP="video", MODE="0660"
SUBSYSTEM=="vc-sm", GROUP="video", MODE="0660"
SUBSYSTEM=="bcm2708_vcio", GROUP="video", MODE="0660"
Time to reboot:
$ sudo reboot
#3 2019-07-17 04:41:41
spinlock
Testing.
Compile demos:
$ sudo apt install libfreetype6-dev
$ cd /opt/vc/src/hello_pi
$ sudo sh rebuild.sh
Set library path:
$ export LD_LIBRARY_PATH=/opt/vc/lib
Run e.g. tiger demo:
$ ./hello_tiger/hello_tiger.bin
