#1 2019-07-13 14:01:59
erdos
Long Delayed boot time on ascii
hi, my ascii installation has an unusually long boot time.
it always stuck at two places by looking at onscreen boot log:
1.  configuration network interfaces..ifup: wait for lock on /run/network/ifstate.wlan0
2.  starting MTA
I started the wifi connection by issuing the following command once loggin into icewm WM,
root@t60:/home/erdos# wpa_supplicant -B -iwlan0 -c/etc/wpa_supplicant.conf -Dwext
Successfully initialized wpa_supplicant
ioctl[SIOCSIWENCODEEXT]: Invalid argument
root@t60:/home/erdos# dhclient wlan0
#2 2019-07-13 17:09:49
Re: Long Delayed boot time on ascii
^ Those commands are correct and the OP says it works.
2.  starting MTA
Can we please see the content of /etc/network/interfaces and the output of ip link, thanks!
Fabricando fit faber
#3 2019-07-13 19:27:59
erdos
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
#auto lo
#iface lo inet loopback
auto wlan0
allow-hotplug wlan0
iface wlan0 inet dhcp
    wireless-essid asd
ip link
erdos@t60:~$ ip link
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
    link/ether 00:15:58:82:f6:94 brd ff:ff:ff:ff:ff:ff
3: irda0: <NOARP> mtu 2048 qdisc noop state DOWN mode DEFAULT group default qlen 8
    link/irda 00:00:00:00 brd ff:ff:ff:ff
4: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DORMANT group default qlen 1000
    link/ether 00:19:d2:c5:0a:41 brd ff:ff:ff:ff:ff:ff
#4 2019-07-13 20:16:41
Try commenting out auto wlan0, if that doesn't fix things then un-comment it and comment out allow-hotplug wlan0 instead.
#5 2019-07-13 23:10:11
dxrobertson
I have had this issue on several installs, but with eth0.  This has been discussed here:
https://dev1galaxy.org/viewtopic.php?id=1688
CREDIT: ralph.ronnquist
The fix seems to be to not have /etc/network/interfaces do anything, except for lo, the file contents should be:
auto lo
This will get rid of the boot delay and allow you network manager (wicd, network-manager, whatever) to control the network connection.  If you do not use a network manager, then you probably just need to do an ifconfig wlan0 up prior to your other manual connection commands.
My problem with this was with ethernet, hopefully the resolution for your wireless is the same, as posted.
The MTA delay probably has to do with exim4 now being installed by default.  You may want a mail transport agent, I personally find it not needed on my system.  You can purge exim4 and all associates if you do not want the mail transport, this will get rid of that delay.
#6 2019-07-14 12:55:00
That's not a fix, it's a workaround. NetworkManager is a bloated, buggy pile of crap and it should be possible to use ifupdown in Devuan.
The linked thread shows that allow-hotplug seemed to be causing the problem so the OP can try removing that line.
FWIW, I experience a 5 second delay with ifupdown in my Debian buster system compared to my usual custom unit file for systemd.
#7 2019-07-14 16:41:45
dxrobertson
Go around often mis-quoting people?
Good for you and your il-informed personal opinion.  NM works fine here, cant recall experiencing bugs.
If you would exercise a little civility in your responses, useless posts like this one would not be needed.
#8 2019-07-14 18:31:27
I have a habit of only quoting the relevant sections so as to keep the reply short and the lo exception is irrelevant in respect of the objection I raised.
Absence of evidence is not evidence of absence and the OP's problem is about boot delays caused by ifupdown so switching to NM does not solve that particular problem in any way, it just conceals it.
stfu
#9 2019-07-14 20:32:53
dxrobertson
stfu
Southern Tenant Farmers Union?
https://en.wikipedia.org/wiki/Southern_ … mers_Union
Probably not.  I'll post it here, you dont have to hide behind your cute little acronym.
https://www.urbandictionary.com/define.php?term=stfu
#10 2019-07-22 17:44:23
erdos
auto lo
After I deleted lines in /etc/network/interfaces about 'wlan0', it seems delays caused by both network interface and MTA are gone.
thanks!
#11 2019-08-21 17:25:48
Jafa
My solution was to set the primary interface to "manual" instead of "dhcp" in /etc/network/interfaces. Boots like lightning.
This allows Wicd to wrangle networking after booting ..
