#1 2019-06-11 22:20:13
Mr.Bean
I lost my desktop after editing conky
After installing conky and editing it in /etc/conky/conky.conf., I lost my desktop as a normal user... I use Fluxbox as a window manager and I can log in aka the mouse cursor appears but I can't do anything else, no right-click to access to the menu, no conky...
However, as a root user, I still can access to my desktop... with Fluxbox
So how I can get back to my desktop in non root user ?
Thanks !
#2 2019-06-12 10:51:08
Re: I lost my desktop after editing conky
That's a really bad idea, use ~/.conkyrc instead.
Restore the file with
# apt reinstall conky
That's an even worse idea, don't do that. Ever.
Fabricando fit faber
#3 2019-06-12 13:43:33
Mr.Bean
There is no ~/.conkyrc file, only /etc/conky/conky.conf. and /etc/conky/conky_no_x11.conf instead
Did it but again, I can only access to my desktop as a root user and in normal user, it didn't solve my problem: desktop with only mouse pointer but nothing else, no conky, no plank nor right-click either.
Strange thing, from there, I can launch any app except Firefox.
#4 2019-06-12 14:02:22
Create a new user and then log in as that user to see if it works. That will tell you if fluxbox is working or not. There may be something in your current user's configs causing the problem.
adduser mrbean2
Then give it a new password and just press Enter for the rest of the questions.
I don't think you get ~/.conkyrc automatically. You have to create it. (see the man page and look for examples on the web)
#5 2019-06-12 14:04:56
Well make one then:
cp /etc/conky/conky.conf ~/.conkyrc && editor ~/.conkyrc
Ooops, sorry, that's a dummy package.
Try
# apt reinstall conky-std # or conky-cli or conky-all if you have those version instead
If things still won't work then try deleting ~/.Xauthority and if that doesn't fix it then check for root-owned files in $HOME:
find ~ -user root
#6 2019-06-12 17:49:44
Mr.Bean
adduser mrbean2
Yess it works !
So what's next ?
find ~ -user root
Sorry but I supposed to check what in $Home ? There is no Xauthority file...
#7 2019-06-12 19:18:44
Note the dot in .Xauthority. That makes it a hidden file.
ls -la
Will show you all your files in home as well as who owns them.
Try removing .Xauthority first. If that doesn't fix it, you can start deleting user configs. Those can be found in a hidden directory - ~/.config. The nuclear option is to delete all of .config, and then you'd be logging in like a new user. (i.e. any of your custom desktop settings or desktop-application settings would be lost.)
#8 2019-06-13 21:32:35
Mr.Bean
It did not work even the nuclear option ! yikes
No new user created... ie, I still cannot access as a normal user, only in root...
#9 2019-06-14 00:06:12
Is your home partition full?
df -h
#10 2019-06-14 07:11:04
Mr.Bean
No, it's a fresh install...
#11 2019-06-15 00:19:34
I'm confused. In one post it looks like you said you created a new user and it worked, and in another post you said you didn't create a new user.
Anyway, maybe you should take a look in both root and user's command history to review what you actually did when you edited the conky config.
#12 2019-06-18 21:47:00
Mr.Bean
I want to recover my normal user account ===>mrbean1. You said, try to add new user (mrbean2); well, everything was fine there but it didn't solve my problem. Also, deleting Xauthority file or all user config. doesn't help either.
#13 2019-06-19 00:15:43
Since it works for the other user, it's not a problem with fluxbox or xorg. It's a problem with the first user account. It could be some other hidden file in that user's home or it could be something to do with permissions or authentication for that user. Did you change anything in pam or polkit configs? Something else?
I don't think editing the conky configs could do what happened. Something else had to happen around the same time. That's why I suggested looking in the command histories. Maybe you did something that you don't recall right now. (I do that all the time.) Just run history as root and as user, and look at the commands around when you edited conky.
