#1 2019-04-22 13:05:18
guioQ
error when installing task-xfce-desktop in beowulf
E: Failed to fetch http://deb.debian.org/debian/pool/main/ … _amd64.deb  404  Not Found [IP: 151.101.12.204 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
running sudo apt update --fix-missing doesn't help
Hello, I've encountered this issue while installing task-xfce-desktop, how do I fix this issue? Also, why does neofetch say
OS: Devuan GNU/Linux beowulf/ceres x86_64, should it say just beowulf? Sorry I'm a noob.
Thanks a lot.
#2 2019-04-22 14:29:21
Re: error when installing task-xfce-desktop in beowulf
guioQ wrote:
E: Failed to fetch http://deb.debian.org/debian/pool/main/w/webkit2gtk/libjavascriptcoregtk-4.0-18_2.22.7-1_amd64.deb 404  Not Found [IP: 151.101.12.204 80]
Why is your Devuan system attempting to download stuff from Debian's repositories?
guioQ wrote:
why does neofetch say OS: Devuan GNU/Linux beowulf/ceres x86_64
https://github.com/dylanaraps/neofetch/ … fetch#L926
#3 2019-04-22 14:52:23
guioQ
I have no idea, that's my sources.list file
deb http://deb.devuan.org/merged beowulf main non-free contrib
deb-src http://deb.devuan.org/merged beowulf main non-free contrib
deb http://deb.devuan.org/merged beowulf-security main non-free contrib
deb-src http://deb.devuan.org/merged beowulf-security main non-free contrib
deb http://deb.devuan.org/merged beowulf-updates main non-free contrib
deb-src http://deb.devuan.org/merged beowulf-updates main non-free contrib
And this is what I get if trying to install libjavascriptcoregtk-4.0-18
sudo apt install libjavascriptcoregtk-4.0-18 -y
Building dependency tree
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 4,530 kB of archives.
After this operation, 18.8 MB of additional disk space will be used.
Err:1 http://deb.devuan.org//merged beowulf/main amd64 libjavascriptcoregtk-4.0-18 amd64 2.22.7-1
  404  Not Found [IP: 151.101.112.204 80]
E: Failed to fetch http://deb.debian.org/debian/pool/main/w/webkit2gtk/libjavascriptcoregtk-4.0-18_2.22.7-1_amd64.deb  404  Not Found [IP: 151.101.112.204 80]
to me these double slashes look strange (the ones before the word "merged"): Err:1 http://deb.devuan.org//merged from the above output.
Thank you!
#4 2019-04-22 16:39:20
The sources.list looks fine to me. The double // before merged are a bit strange, but I wouldn't care as long as the sources is correct.
That the webkit is redirected to Debian is possible.
Looks like there currently is an issue with fetching packages from the server, see also https://dev1galaxy.org/viewtopic.php?id=2800.
Rolf
#5 2019-04-22 16:42:19
Can we see
apt policy
The Devuan merged repositories seem to have problems at the moment (as rolfie notes) so perhaps your system is falling back to the Debian repositories.
#6 2019-04-22 19:16:06
guioQ
Rolf
Thanks.
Can we see
apt policy
apt policy
Package files:
 100 /var/lib/dpkg/status
     release a=now
 500 http://deb.devuan.org/merged beowulf-security/main i386 Packages
     release v=3.0.0,o=Devuan,a=testing-security,n=beowulf-security,l=Devuan-Security,c=main,b=i386
     origin deb.devuan.org
 500 http://deb.devuan.org/merged beowulf-security/main amd64 Packages
     release v=3.0.0,o=Devuan,a=testing-security,n=beowulf-security,l=Devuan-Security,c=main,b=amd64
 500 http://deb.devuan.org/merged beowulf/contrib i386 Packages
     release v=3.0,o=Devuan,a=testing,n=beowulf,l=Devuan,c=contrib,b=i386
 500 http://deb.devuan.org/merged beowulf/contrib amd64 Packages
     release v=3.0,o=Devuan,a=testing,n=beowulf,l=Devuan,c=contrib,b=amd64
 500 http://deb.devuan.org/merged beowulf/non-free i386 Packages
     release v=3.0,o=Devuan,a=testing,n=beowulf,l=Devuan,c=non-free,b=i386
 500 http://deb.devuan.org/merged beowulf/non-free amd64 Packages
     release v=3.0,o=Devuan,a=testing,n=beowulf,l=Devuan,c=non-free,b=amd64
 500 http://deb.devuan.org/merged beowulf/main i386 Packages
     release v=3.0,o=Devuan,a=testing,n=beowulf,l=Devuan,c=main,b=i386
 500 http://deb.devuan.org/merged beowulf/main amd64 Packages
     release v=3.0,o=Devuan,a=testing,n=beowulf,l=Devuan,c=main,b=amd64
#7 2019-04-24 17:43:36
Just did an update of 2 VMs, one with ASCII, one with Beowulf. Both updates worked fine.
A word from one of the admins would have been desirable.
Rolf
