#1 2019-02-18 09:31:25
MiyoLinux
Beowulf: Link sbin
After my latest stab at building a basic Openbox system on the Beowulf .iso, everything is working wonderfully. smile
I have one question, and I know that this is rather vague...
During the installation, there was an option to link sbin to bin (?). I can't remember exactly what it said...sorry. I'm bad about not reading things. LOL! tongue
Anyway...I chose the default answer of No. Later on, after setting everything up and adding a desktop-grub.png image, I tried to run update-grub and received an error in the terminal that the update-grub command wasn't found. Grrrrrr...
So...I opened the file manager as root, went to the sbin folder, and sure enough...update-grub was there. So I opened the terminal in that folder and ran update-grub successfully.
So my question is...despite the default answer of no, should sbin be linked to bin (or whatever that option was) in Beowulf? I just don't have it in me to go through another installation right now in order to read that message during the installation. sad  tongue
#2 2019-02-18 09:52:19
Geoff 42
Re: Beowulf: Link sbin
There is some discussion about merging some of the bins on the mailing list. I think it is /usr/bin and /bin as well as /usr/sbin and /sbin
https://lists.dyne.org/lurker/message/2 … fe.en.html
Geoff
#3 2019-02-18 15:44:47
Panopticon
^ probably a bad idea, what would the need be to symlink all that? Has to be something to do with systemd.
From "man hier"
/bin   This  directory  contains executable programs which are needed in single user mode and to bring
              the system up or repair it.
       /sbin  Like  /bin,  this directory holds commands needed to boot the system, but which are usually not
              executed by normal users.
       /usr/bin
              This is the primary directory for executable programs.  Most programs executed by normal  users
              which  are  not  needed  for  booting  or  for repairing the system and which are not installed
              locally should be placed in this directory.
#4 2019-02-18 15:49:39
Geoff 42
Its a bit <tl;dr> and I was rather lazily hoping that someone would post the executive summary for us! I did try and work my way through it, but failed.
Geoff
#5 2019-02-18 15:54:59
Panopticon
^ I see, im not familiar with that message board but found more replies to the original message. Bit of light reading ahead maybe.
#6 2019-02-18 16:23:10
PedroReina
I dont think so. Just remember the history of the split:
http://lists.busybox.net/pipermail/busy … 74114.html
#7 2019-02-18 18:11:14
The problem you're running into is the change in root's path when you run su in a terminal. That path no longer contains the sbins. If you use su - instead, you'll get the root path that you're used to. But then you won't be able to start graphical apps as root from that terminal. For that, you're supposed to use pkexec. When you figure all that out, I'll read your posts. Until then, or until someone gives me good reasons not to do this, I'm working around the problem.
# grep PATH /root/.bashrc
export PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin"
Oh yeah, the other workaround is to use the full path for commands.
/sbin/blkid
/usr/sbin/update-grub
#8 2019-02-18 20:07:52
PedroReina
I use an old trick for that:
cp /home/user/.Xauthority /root/
#9 2019-02-18 20:16:35
I tried copying .Xauthority and that didn't work for me in beowulf. Are you using that in beowulf now?
I also tried xhost + and that didn't work, either.
#10 2019-02-18 22:06:22
MiyoLinux
/sbin/blkid
Thanks fsr. The "full path" answer is what I thought of after doing it the way that I did. I wasn't aware of su -. Thanks.
As for opening items with pkexec, I have a couple of apps in the "MiyoLinux Accessories" that run as root. PCManFM and Lxappearance. The way that I solved that was to add a file for both of them in /usr/share/policykit-1/actions/
I just used one of the existing ones as a template and changed each instance of the original application's name in the existing file to the appropriate name of the application that I wanted to use it for in the file I was creating; such as, if I were using the synaptic file as an example, I replaced every instance of synaptic with lxapppearance...hope that makes sense. Also, I changed the icon used and named both files similarly to how the existing files are named.
Anyway, I can now open both PCManFM (as root) and Customize Look and Feel (as root) from the menu using pkexec. smile
#11 2019-02-19 04:29:56
stanz
MiyoLinux wrote:
update-grub ...
...file manager as root,
Yep ~ I donno reasons either, but always & still working is ..sudo update-grub.
Oh shoot, I'm in miyo-xtra/beowulf partition! ...better reboot to beowulf and check tongue
miyoisomix.i2p
#12 2019-02-19 12:50:11
PedroReina
No, in Beowulf no.
#13 2019-02-20 21:57:24
guuml.dev1
Just for the records, it may be off topic: I'm watching the testing of beowulf, but in the not to far future I want to distribute a stable operating system to others which I have to maintain!  Quoting my 2nd post to dev1galaxy:
guuml.dev1 wrote:
... minimalistic devuan/jessie with xfce ... You should remember that su - is your friend. BTW: the last few years on LMDE2 betsy I was used to type sudo su. Unfortunately some time ago a guy (new to GNU/Linux but interested to learn) asked me about the differences about su and sudo and why both packages are needed. My answer was not very helpful to him because it was much too detailed ...
#1: Devuan does the right thing: During installation you have to  give two passwords for two accounts. One for root and one for yourself (UID=1000). And there are two home directories, see /etc/passwd.
#2: Since decades i'm used to type su - and the right password to gain a root shell, where I can do everything. YES, including shot me knee and break every toe afterwards. You're warned.
#3: On the other hand sudo ... asks for confirmation with my own password. Just to remember that UID=1000 is able to ruin compromise the system, too.
Back to topic: IMHO there should be a link from /sbin/ to /usr/sbin/ (just in case the merge is done:-(
BTW: Some people are mounting the /usr via network, aka remote. And then mounting /usr/local from local?
PS: Should root be able to interact with user's X-server? I've had never heard about pkexec up to now but looks like policy-kit. I'm going RTFM ...
#14 2020-05-14 07:12:44
PedroReina
PedroReina wrote:
No, in Beowulf no.
I'm working with Beowulf beta3 for a couple of days. Coping .Xauthority to the root home works for me. I can start X Window programs as root: bare user -> su - -> program. YMMV. Mine is lightdm, webkit2 greeter and KDE without much further tinkering.
#15 2020-05-14 16:21:21
Good to know, thanks. My current preferred method to revert to the old behavior is to add
ALWAYS_SET_PATH yes
to /etc/default/su. This is documented in 'man su'.  You can put the line in /etc/login.defs instead, but then you get an error message when you log in.
#16 2020-05-14 16:45:17
PedroReina
ALWAYS_SET_PATH yes
to /etc/default/su.
There are a few methods. Years ago I decided to change almost all the configuration files of Bash of my systems. Now, with Devuan my modifications work well.
