#1 2019-02-13 12:09:21
[Solved] Stuck with Beowulf netinstall
After successfully installing native Beowulf in a VM, I thought I might give Beowulf a try on my secondary PC. Now I am facing some problems: after reboot I end up in the grub shell. When I enter boot grub tells me the kernel is not loaded.
Boundary conditions: EFI mode, amd64, installation from USB stick, system encrypted. The VM had no EFI, was installed from the iso directly, no encryption.
Tried to fix with the rescue mode: reinstalled grub, went into shell with the encrypted root, update-grub from there, update-initramfs from there, no change. Also burned the iso on a CD and tried again, no help. Isn't the shell offered a fully working chroot environment?
I am no sure if there is an issue with the netinstall iso, or if my detours have contributed (initially I had some other drives and an USB card reader connected, so the SSD for Beowulf was sdi).
Is there a way to fix the installation?
Thanks, Rolf
#2 2019-02-13 12:42:25
Re: [Solved] Stuck with Beowulf netinstall
Either boot from grub command line or go into chroot and remove grub-efi-amd64-signed. Then run grub-install and update-grub.
#3 2019-02-13 16:23:31
Thanks for the feedback, still no step further. I can't get along with the grub command line. I have looked at some stuff from Ubuntuusers, that was of limited use. I learned how to navigate in the uefi shell, but grub is sealed for me.
Booted my favorite life system Knoppix, and could not find any grub-efi-amd64-signed file wherever. grub-install in efi mode was noit possible since Knoppix does not boot in efi mode. Maybe I have to download an ASCII or Stretch life system.
Thanks, Rolf
Note: tried in a VBox: no encryption, efi with sysvinit and open-rc, both end in the grub command line. The efi installer is broken.
#4 2019-02-13 20:00:02
Go into rescue mode and get a shell in the installed system. Run dpkg -l | grep grub and if a package named grub-efi-amd64-signed is installed, remove it.
If that's not possible, try grub-install --bootloader-id=debian and see if that fixes it.
Note: I had the same problem with an encrypted install of beowulf, and I was able to fix it with either of the methods I described. If neither of these can help, post the contents of /etc/fstab, /etc/crypttab and /boot/grub/grub.cfg, and the output of the following comands:
fdisk -l
df -h
blkid
#5 2019-02-13 21:28:10
Thank you, that description contains the amount of detail I needed. The grub-efi-amd64-signed really was installed, I must have overlooked that fact in my previous searches.
Then I did grub-install --bootloader-id=debian followed by an update-grub.
Now I have got a non-working devuan efi entry, and a working debian efi entry. In any case, now I am logged in as root on my secondary PC.
I think I spend a grub-install --bootloader-id=devuan later.
Thank you for your help, Rolf
#6 2019-02-13 22:40:29
You did both fixes and only needed to do one. With the *-signed package removed, you can just run grub-install and it will make (re-make) the devuan entry and set it be the first bootloader. (It should do that, anyway. Not all uefi systems act the same.)
#7 2019-02-14 21:01:25
Tested your proposal on my faulty VBox Beowulf on efi. Works, removing  grub-efi-amd64-signed followed by a  grub-install does the job.
Maybe this post will help others.
Have a nice evening, thank you again, Rolf
BTW: my secondary PC now is on Beowulf. Some questions remain for other threads.
