After figuring out how to get the Tor Project repository working and installing apt-transport-tor, I am still not able to use the onion repositories.
$ sudo -e /etc/apt/sources.list
deb http://deb.devuan.org/merged ascii main non-free contrib
deb-src http://deb.devuan.org/merged ascii main non-free contrib
deb http://deb.devuan.org/merged ascii-updates main non-free contrib
deb-src http://deb.devuan.org/merged ascii-updates main non-free contrib
deb http://deb.devuan.org/merged ascii-security main non-free contrib
deb-src http://deb.devuan.org/merged ascii-security main non-free contrib
deb http://deb.devuan.org/merged ascii-backports main non-free contrib
deb-src http://deb.devuan.org/merged ascii-backports main non-free contrib
$ sudo apt update
$ sudo apt install apt-transport-https curl devuan-keyring
$ sudo -e /etc/apt/sources.list.d/tor.list
deb https://deb.torproject.org/torproject.org stretch main
deb-src https://deb.torproject.org/torproject.org stretch main
$ curl https://deb.torproject.org/torproject.o … 6DDD89.asc | gpg --import
$ gpg --export A3C4F0F979CAA22CDBA8F512EE8CBC9E886DDD89 | sudo apt-key add -
$ sudo apt update
$ sudo apt install apt-transport-tor tor deb.torproject.org-keyring
deb tor+http://devuanfwojg73k6r.onion/merged ascii main non-free contrib
deb-src tor+http://devuanfwojg73k6r.onion/merged ascii main non-free contrib
deb tor+http://devuanfwojg73k6r.onion/merged ascii-updates main non-free contrib
deb-src tor+http://devuanfwojg73k6r.onion/merged ascii-updates main non-free contrib
deb tor+http://devuanfwojg73k6r.onion/merged ascii-security main non-free contrib
deb-src tor+http://devuanfwojg73k6r.onion/merged ascii-security main non-free contrib
deb tor+http://devuanfwojg73k6r.onion/merged ascii-backports main non-free contrib
deb-src tor+http://devuanfwojg73k6r.onion/merged ascii-backports main non-free contrib
deb tor+http://sdscoq7snqtznauu.onion/torproject.org stretch main
deb-src tor+http://sdscoq7snqtznauu.onion/torproject.org stretch main
$ sudo apt update
0% [Connecting to SOCKS5h proxy (socks5h://localhost:9050)]$ sudo apt upgrade
0% [Connecting to SOCKS5h proxy (socks5h://localhost:9050)]$ sudo apt dist-upgrade --auto-remove --purge
0% [Connecting to SOCKS5h proxy (socks5h://localhost:9050)]It won't go any further after this point. Can anyone help me to figure this out or know why this is happening?
works fine here. is tor running on port 9050?
check tor daemon messages.
