I did a migration upgrade to Devuan Jessie from Debian Wheezy. I have XFCE but gdm seems unhealthy. gdmgreeter goes <defunct> immediately after logging in and all I see is the desktop backgound.
From https://devuan.org/os/documentation/dev … -to-jessie, The instructions say to "Choose slim" if prompted during the upgrade. But I was not prompted.
Should I try installing LightDM (what I am used to in Xubuntu) or the one used in Devuan by default (Not sure which). Or is there something I need to fix regardless of which DM is logging me in?
EDIT
Asked in IRC, got a quick answer ![]()
I disabled and stopped gdm, and then installed slim. It worked properly out-of-the-box.
I also learned to pay attention to the recommended display manager for desktop environments running on Devuan Ascii (probably applies to Jessie too but I will be continuing on to upgrade to Ascii first)
