#1 2019-01-28 19:58:27
xuserx
Difference between DE during installation from dvd installer
What the difference between these 2 desktop environments? Are the same or not?
#2 2019-01-28 20:57:13
ChuangTzu
Re: Difference between DE during installation from dvd installer
Xfce is the default, so if you leave that unticked and do not choose a DE then Xfce will be installed.  The top option is for task which brings in lots of desktop goodies that most people will want.  So unless you really like minimal installs and you know exactly what you want/need, then leave those checked.
PS: LXQt is also a very nice option.  wink
PSS: If you do want minimal then untick everything except the last option and you will reboot to console, where you can login as root and apt install whatever you need, keep in mind that includes needing to add Xorg, etc...
#3 2019-01-30 10:17:18
Duke Nukem
I was puzzled by this screen too. For a moment I thought that Devuan had developed its own graphical desktop environment [DE]! But I took it to mean that the top tick box meant whether you wanted a graphical DE or not, and the next five chose which specific type of DE you wanted. So I ticked the top box and also KDE, with the other four DE boxes blank - that worked for me.
It seemed to me that the top box was redundant because if you ticked one of the five specific DEs then of course you wanted a DE.  The five specific DE lines might have been indented like subheadings. I don't know what would happen if you ticked one of the five DEs but not the top box :-S
That's how I interpreted it - does anyone kow better?
#4 2019-01-30 12:32:17
If you check just the first box, you should get xfce, because it's the first of the three desktops recommended by task-desktop.
If you check just the xfce box, you'll get task-desktop because xfce depends on it.
So, checking first box only, second box only, or first and second box should all give the same result. (I haven't tested this.)
$ apt-cache depends task-desktop
task-desktop
  Depends: tasksel
  Depends: xorg
  Depends: xserver-xorg-video-all
  Depends: xserver-xorg-input-all
  Depends: desktop-base
 |Recommends: task-xfce-desktop
 |Recommends: task-lxde-desktop
  Recommends: task-mate-desktop
  Recommends: xdg-utils
  Recommends: avahi-daemon
    avahi-daemon:i386
  Recommends: libnss-mdns
  Recommends: anacron
    systemd-cron
  Recommends: eject
    eject:i386
  Recommends: iw
    iw:i386
  Recommends: alsa-utils
    alsa-utils:i386
$ apt-cache depends task-xfce-desktop
task-xfce-desktop
  Depends: tasksel
  Depends: task-desktop
  Depends: xfce4
  Depends: slim
  Recommends: xfce4-goodies
  Recommends: xfce4-power-manager
  Recommends: xfce4-mixer
  Recommends: xfce4-terminal
  Recommends: mousepad
  Recommends: orage
  Recommends: libreoffice-gtk
  Recommends: dbus-x11
    dbus-x11:i386
  Recommends: xsane
    xsane:i386
  Recommends: vlc
  Recommends: quodlibet
 |Recommends: evince-gtk
  Recommends: evince
  Recommends: tango-icon-theme
  Recommends: wicd
  Recommends: synaptic
  Recommends: iceweasel
  Recommends: libreoffice-help-en-us
  Recommends: mythes-en-us
  Recommends: hunspell-en-us
  Recommends: hyphen-en-us
  Recommends: system-config-printer
  Recommends: gnome-orca
#5 2019-01-30 15:07:52
Panopticon
fsmith and changtzu summed it up very well but i will add you might want to check the console productivity as it has some really cool little games included in it and is not a very big download smile
#6 2019-01-30 15:17:58
xuserx
Thanks for all answers, i think better to choose desktop that do you want explicitly.
#7 2019-01-30 16:13:42
Panopticon
If you want the full Devuan experience with xfce4 then choose devuan desktop only, i have found that if you choose devuan desktop along with any others will give you a very complete desktop environment also.
