#1 2018-12-26 03:22:37
aut0exec
Displaying NEF (RAW) files in Devuan
Been switching systems over to Devuan and had a need to view thumbnails of Nikon RAW images (NEF). Some quick research turned up a solution. Wanted to document it just in case anyone else runs into the issue.
System: Devuan Beowulf running Cinnamon using nemo as the file explorer
First install ufraw and libraw19 ( Not completely sure if this is needed but it is also used by shotwell and gimp so it's likely already installed )
# apt install ufraw ufraw-batch libraw19
Then create the thumbnailer file /usr/share/thumbnailers/ufraw.thumbnailer and place the following into the file (place other file types in the MimeType as needed):
[Thumbnailer Entry]
Exec=/usr/bin/ufraw-batch --silent --noexif --embedded-image --out-type=png --size=%s %u --overwrite --output=%o
MimeType=image/x-nef;image/x-nikon-nef;
Nemo should start showing the thumbnails for the RAW images now! Depending on the size of the RAW images the initial thumbnail creation may take some time.
