Hy! My english is not good, I'm from Argentina, but I'll try to do my best. Some day, not far away, devuan will be common in spanish people!. For me Devuan is the future, and systemd will fall, as a big gigant...a big fall.
Now, my big problem: my soundcard is not recognized. i'm urged cos my 4 childs needs theirs games. Their father (me) always said that devuan is the best distro...and now...I what resolve this before they knows the problem, haha!.
I am in Ascii. From specifications, I know that my card is
VT8237R Plus integrated VIA AC'97 audio controller
Realtek ALC655 AC'97 audio codec
AC'97 2.3 compliant
but ...
aplay -l
aplay: device_list:272: no soundcards found...
root@devuan:/home/hemallaim# lspci
00:00.0 Host bridge: VIA Technologies, Inc. CN700/VN800/P4M800CE/Pro Host Bridge
00:00.1 Host bridge: VIA Technologies, Inc. CN700/VN800/P4M800CE/Pro Host Bridge
00:00.2 Host bridge: VIA Technologies, Inc. CN700/VN800/P4M800CE/Pro Host Bridge
00:00.3 Host bridge: VIA Technologies, Inc. PT890 Host Bridge
00:00.4 Host bridge: VIA Technologies, Inc. CN700/VN800/P4M800CE/Pro Host Bridge
00:00.7 Host bridge: VIA Technologies, Inc. CN700/VN800/P4M800CE/Pro Host Bridge
00:01.0 PCI bridge: VIA Technologies, Inc. VT8237/VX700 PCI Bridge
00:0f.0 RAID bus controller: VIA Technologies, Inc. VIA VT6420 SATA RAID Controller (rev 80)
00:0f.1 IDE interface: VIA Technologies, Inc. VT82C586A/B/VT82C686/A/B/VT823x/A/C PIPC Bus Master IDE (rev 06)
00:10.0 USB controller: VIA Technologies, Inc. VT82xx/62xx UHCI USB 1.1 Controller (rev 81)
00:10.1 USB controller: VIA Technologies, Inc. VT82xx/62xx UHCI USB 1.1 Controller (rev 81)
00:10.2 USB controller: VIA Technologies, Inc. VT82xx/62xx UHCI USB 1.1 Controller (rev 81)
00:10.3 USB controller: VIA Technologies, Inc. VT82xx/62xx UHCI USB 1.1 Controller (rev 81)
00:10.4 USB controller: VIA Technologies, Inc. USB 2.0 (rev 86)
00:11.0 ISA bridge: VIA Technologies, Inc. VT8237 ISA bridge [KT600/K8T800/K8T890 South]
00:12.0 Ethernet controller: VIA Technologies, Inc. VT6102/VT6103 [Rhine-II] (rev 78)
01:00.0 VGA compatible controller: VIA Technologies, Inc. CN700/P4M800 Pro/P4M800 CE/VN800 Graphics [S3 UniChrome Pro] (rev 01)
root@devuan:/home/hemallaim# cat /proc/asound/cards
cat: /proc/asound/cards: No existe el fichero o el directorio
root@devuan:/home/hemallaim# alsactl init
alsactl: init:1757: No soundcards found...
I read all post about this here, but nothing helps. Someone here could resolve this issue updating kernel. I did the same, now is linux-imga 4.19 (from ceres)--- but without results.
Please, some sugestions will be very apreciated, cos I'm staked. All other things, policykit, automount and go on are going perfect! only sound for my childs (is their computer) rest. Thank you very much People Of Devuan!
Perhaps, run alsamixer F6 to select soundcard?
"The obstacle is the path."
Thanks for reply!
root@devuan:/home/hemallaim# apt-get install alsamixer
Leyendo lista de paquetes... Hecho
Creando árbol de dependencias
Leyendo la información de estado... Hecho
E: No se ha podido localizar el paquete alsamixer (-> alsamixer is not more present in devuan repositories...)
sources.list =
#ASCII
# deb cdrom:[devuan_ascii_2.0.0_i386_netinst]/ ascii main non-free
deb http://deb.devuan.org/merged/ ascii main non-free contrib
deb-src http://deb.devuan.org/merged/ ascii main non-free contrib
deb http://deb.devuan.org/merged/ ascii-security main non-free contrib
deb-src http://deb.devuan.org/merged/ ascii-security main non-free contrib
deb http://deb.devuan.org/merged/ ascii-updates main non-free contrib
deb-src http://deb.devuan.org/merged/ ascii-updates main non-free contrib
#CERES
#deb http://deb.devuan.org/merged/ ceres contrib non-free main
#deb-src http://deb.devuan.org/merged/ ceres contrib non-free main
#deb http://deb.devuan.org/merged/ ceres-security contrib non-free main
#deb-src http://deb.devuan.org/merged/ ceres-security contrib non-free main
#deb http://deb.devuan.org/merged/ ceres-updates contrib non-free main
#deb-src http://deb.devuan.org/merged/ ceres-updates contrib non-free main
but I have done yesterday this that you said, and the only card that appear is "pulseaudio".
I had uninstalled pulseudio too, without results. Now is installed as in Ascii defaults.
I found here someone with similar problem...without answers....
No sound from VT1708 Analog on Devuan Ascii -> http://dev1galaxy.org/viewtopic.php?id=2383
thank you 4 your suggestion !
Problem persist.
Hello, did you try https://wiki.debian.org/ALSA
or
https://wiki.debian.org/CategorySound
Thaks u all of u, for your suggestions! Finally I could probate that is a hardware fail. Sound card is broken. ![]()
Solved.
Solved.
hola, .. . por curiosidad.. y porque tengo una toshiba satellite "viejita" que tiene un tarjeta de sonido que también es realtek y que igualmente no suena ...
- . . .y que también es para juegos de críos !!! / yes-- to play video games all over the day!!
¿cómo sabés que está rota? ¿how do you know you sound card is broken?
he econtrado discusiones sobre necesitar un driver de realtek, que sólo funciona con kernels por debajo del 3.6
a buscarle pué!! ![]()
satellite mestizo
