#1 2018-09-24 07:16:29
cheslavic
No sound from VT1708 Analog on Devuan Ascii
Hello guys,
I've been searching Internet for few hours now how to force soundcard to play some tunes, but without success. I've checked alsamixer already. PulseAudio and HDA VIA VT82xx is unmuted. Please find output of alsa-info.sh below. Thank you in advance for any hints to make this garbage works.
upload=true&script=true&cardinfo=
!!ALSA Information Script v 0.4.64
!!Script ran on: Mon Sep 24 07:01:52 UTC 2018
!!Linux Distribution
ID_LIKE=debian
!!DMI Information
Manufacturer:      FUJITSU SIEMENS
Product Name:      AMILO La1703
Product Version:   1.0
Firmware Version:  8.8-0023-M008
Board Vendor:      Inventec
Board Name:        E25
!!ACPI Device Status Information
/sys/bus/acpi/devices/ACPI0003:00/status 	 15
/sys/bus/acpi/devices/LNXPOWER:01/status 	 1
/sys/bus/acpi/devices/PNP0000:00/status 	 15
/sys/bus/acpi/devices/PNP0100:00/status 	 15
/sys/bus/acpi/devices/PNP0200:00/status 	 15
/sys/bus/acpi/devices/PNP0303:00/status 	 15
/sys/bus/acpi/devices/PNP0800:00/status 	 15
/sys/bus/acpi/devices/PNP0A03:00/status 	 15
/sys/bus/acpi/devices/PNP0B00:00/status 	 15
/sys/bus/acpi/devices/PNP0C01:00/status 	 15
/sys/bus/acpi/devices/PNP0C02:00/status 	 15
/sys/bus/acpi/devices/PNP0C04:00/status 	 15
/sys/bus/acpi/devices/PNP0C0A:00/status 	 31
/sys/bus/acpi/devices/PNP0C0C:00/status 	 11
/sys/bus/acpi/devices/PNP0C0F:00/status 	 9
/sys/bus/acpi/devices/PNP0C0F:01/status 	 9
/sys/bus/acpi/devices/PNP0C0F:02/status 	 9
/sys/bus/acpi/devices/PNP0C0F:03/status 	 9
/sys/bus/acpi/devices/PNP0C0F:04/status 	 9
/sys/bus/acpi/devices/PNP0C0F:05/status 	 9
/sys/bus/acpi/devices/PNP0C0F:06/status 	 9
/sys/bus/acpi/devices/PNP0C0F:07/status 	 9
/sys/bus/acpi/devices/PNP0C0F:08/status 	 9
/sys/bus/acpi/devices/PNP0C0F:09/status 	 9
/sys/bus/acpi/devices/PNP0C0F:0a/status 	 9
/sys/bus/acpi/devices/PNP0C0F:0b/status 	 9
/sys/bus/acpi/devices/SYN1907:00/status 	 15
/sys/bus/acpi/devices/device:01/status 	 11
/sys/bus/acpi/devices/device:0b/status 	 15
/sys/bus/acpi/devices/device:0c/status 	 15
/sys/bus/acpi/devices/device:0d/status 	 15
/sys/bus/acpi/devices/device:0e/status 	 15
/sys/bus/acpi/devices/device:0f/status 	 15
/sys/bus/acpi/devices/device:12/status 	 15
/sys/bus/acpi/devices/device:13/status 	 15
/sys/bus/acpi/devices/device:16/status 	 15
/sys/bus/acpi/devices/device:17/status 	 15
!!Kernel Information
Kernel release:    4.9.0-6-amd64
Operating System:  GNU/Linux
Architecture:      x86_64
Processor:         unknown
SMP Enabled:       Yes
!!ALSA Version
Driver version:     k4.9.0-6-amd64
Library version:    1.1.3
Utilities version:  1.1.3
!!Loaded ALSA modules
snd_hda_intel
!!Sound Servers on this system
Pulseaudio:
      Installed - Yes (/usr/bin/pulseaudio)
      Running - Yes
!!Soundcards recognised by ALSA
 0 [VT82xx         ]: HDA-Intel - HDA VIA VT82xx
                      HDA VIA VT82xx at 0xd9000000 irq 17
!!PCI Soundcards installed in the system
04:01.0 Audio device: VIA Technologies, Inc. VT8237A/VT8251 HDA Controller (rev 10)
!!Advanced information - PCI Vendor/Device/Subsystem ID's
04:01.0 0403: 1106:3288 (rev 10)
	Subsystem: 1734:10d9
!!Modprobe options (Sound related)
snd_pcsp: index=-2
snd_usb_audio: index=-2
snd_atiixp_modem: index=-2
snd_intel8x0m: index=-2
snd_via82xx_modem: index=-2
!!Loaded sound module options
!!Module: snd_hda_intel
	align_buffer_size : -1
	bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	beep_mode : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
	enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
	enable_msi : -1
	id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	power_save : 0
	power_save_controller : Y
	probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	single_cmd : N
	snoop : -1
!!HDA-Intel Codec information
--startcollapse--
Codec: VIA VT1708
Address: 0
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x11061708
Subsystem Id: 0x173410d9
Revision Id: 0x100700
No Modem Function Group found
Default PCM:
    rates [0x0]:
    bits [0x0]:
    formats [0x0]:
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
  Power states:  D0 D1 D2 D3
  Power: setting=D0, actual=D0
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x10 [Audio Output] wcaps 0x411: Stereo
  Device: name="VT1708 Analog", type="Audio", device=0
  Converter: stream=5, channel=0
  PCM:
    rates [0x7e0]: 44100 48000 88200 96000 176400 192000
    bits [0xa]: 16 24
    formats [0x1]: PCM
  Power states:  D0 D1
Node 0x11 [Audio Output] wcaps 0x411: Stereo
  Converter: stream=0, channel=0
  PCM:
    bits [0xa]: 16 24
    formats [0x1]: PCM
  Power states:  D0 D1
Node 0x12 [Audio Output] wcaps 0x411: Stereo
  PCM:
    bits [0xa]: 16 24
    formats [0x1]: PCM
  Power states:  D0 D1
Node 0x13 [Audio Output] wcaps 0x411: Stereo
  PCM:
    bits [0xa]: 16 24
    formats [0x1]: PCM
  Power states:  D0 D1
Node 0x14 [Audio Output] wcaps 0x211: Stereo Digital
  Digital:
  Digital category: 0x0
  IEC Coding Type: 0x0
  PCM:
    bits [0xa]: 16 24
    formats [0x5]: PCM AC3
Node 0x15 [Audio Input] wcaps 0x10051b: Stereo Amp-In
  Control: name="Capture Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=0, ofs=0
  Control: name="Capture Switch", index=0, device=0
  Amp-In caps: ofs=0x00, nsteps=0x14, stepsize=0x06, mute=1
  Amp-In vals:  [0x14 0x14]
  Converter: stream=1, channel=0
  SDI-Select: 0
  PCM:
    rates [0x440]: 48000 192000
    bits [0xa]: 16 24
    formats [0x1]: PCM
  Power states:  D0 D1
  Connection: 1
     0x18
Node 0x16 [Audio Input] wcaps 0x100311: Stereo Digital
  SDI-Select: 0
  Digital: Validity
  PCM:
    rates [0x1f0]: 32000 44100 48000 88200 96000
    bits [0xa]: 16 24
  Connection: 1
     0x26
Node 0x17 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Control: name="Mic Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=2, ofs=0
  Control: name="Mic Playback Switch", index=0, device=0
  Amp-In caps: ofs=0x17, nsteps=0x1f, stepsize=0x06, mute=1
  Amp-In vals:  [0x17 0x17] [0x80 0x80] [0x1d 0x1d] [0x80 0x80] [0x80 0x80] [0x17 0x17]
  Connection: 6
     0x10 0x24 0x1d 0x1e 0x21 0x13
Node 0x18 [Audio Selector] wcaps 0x300101: Stereo
  Connection: 5
     0x17 0x24 0x1d* 0x1e 0x21
Node 0x19 [Audio Selector] wcaps 0x30010d: Stereo Amp-Out
  Amp-Out caps: ofs=0x1b, nsteps=0x1b, stepsize=0x06, mute=1
  Amp-Out vals:  [0x80 0x80]
  Connection: 1
     0x11
Node 0x1a [Audio Selector] wcaps 0x30010d: Stereo Amp-Out
  Connection: 1
     0x12
Node 0x1b [Audio Selector] wcaps 0x30010d: Stereo Amp-Out
  Connection: 1
     0x13
Node 0x1c [Pin Complex] wcaps 0x40010d: Stereo Amp-Out
  Amp-Out caps: N/A
  Amp-Out vals:  [0x00 0x00]
  Pincap 0x0000001c: OUT HP Detect
  Pin Default 0x410110f2: [N/A] Line Out at Ext Rear
    Conn = 1/8, Color = Black
    DefAssociation = 0xf, Sequence = 0x2
  Pin-ctls: 0x00:
  Connection: 1
     0x19
Node 0x1d [Pin Complex] wcaps 0x400101: Stereo
  Pincap 0x00000334: IN OUT Detect
    Vref caps: HIZ 50
  Pin Default 0x01a190f0: [Jack] Mic at Ext Rear
    Conn = 1/8, Color = Pink
    DefAssociation = 0xf, Sequence = 0x0
  Pin-ctls: 0x21: IN VREF_50
  Connection: 1
     0x1a
Node 0x1e [Pin Complex] wcaps 0x400101: Stereo
    Vref caps: HIZ 50
  Pin Default 0x418130fe: [N/A] Line In at Ext Rear
    Conn = 1/8, Color = Blue
    DefAssociation = 0xf, Sequence = 0xe
  Pin-ctls: 0x00: VREF_HIZ
  Connection: 1
     0x19
Node 0x1f [Pin Complex] wcaps 0x40010d: Stereo Amp-Out
  Control: name="Line Out Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=Out, idx=0, ofs=0
  Control: name="Line Out Playback Switch", index=0, device=0
  Amp-Out vals:  [0x19 0x19]
  Pin Default 0x110140f0: [Jack] Line Out at Int Rear
    Conn = 1/8, Color = Green
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x17
Node 0x20 [Pin Complex] wcaps 0x40010d: Stereo Amp-Out
  Control: name="Headphone Playback Volume", index=0, device=0
  Control: name="Headphone Playback Switch", index=0, device=0
  Amp-Out vals:  [0x1b 0x1b]
  Pin Default 0x022140f0: [Jack] HP Out at Ext Front
  Pin-ctls: 0xc0: OUT HP
  Connection: 1
     0x17
Node 0x21 [Pin Complex] wcaps 0x400101: Stereo
    Vref caps: HIZ 50
  Pin Default 0x42a190f0: [N/A] Mic at Ext Front
  Connection: 1
     0x1b
Node 0x22 [Pin Complex] wcaps 0x400101: Stereo
  Pincap 0x00000014: OUT Detect
  Pin Default 0x410160f1: [N/A] Line Out at Ext Rear
    Conn = 1/8, Color = Orange
    DefAssociation = 0xf, Sequence = 0x1
  Pin-ctls: 0x00:
  Connection: 1
     0x1a
Node 0x23 [Pin Complex] wcaps 0x400101: Stereo
  Pin Default 0x410120f4: [N/A] Line Out at Ext Rear
    Conn = 1/8, Color = Grey
    DefAssociation = 0xf, Sequence = 0x4
  Pin-ctls: 0x00:
  Connection: 1
     0x1b
Node 0x24 [Pin Complex] wcaps 0x400001: Stereo
  Pincap 0x00000020: IN
  Pin Default 0x593301f7: [N/A] CD at Int ATAPI
    Conn = ATAPI, Color = Unknown
    DefAssociation = 0xf, Sequence = 0x7
    Misc = NO_PRESENCE
  Pin-ctls: 0x00:
Node 0x25 [Pin Complex] wcaps 0x400301: Stereo Digital
  Pincap 0x00000010: OUT
  Pin Default 0x474411f0: [N/A] SPDIF Out at Ext Rear Panel
    Conn = RCA, Color = Black
    Misc = NO_PRESENCE
  Pin-ctls: 0x00:
  Connection: 1
     0x14
Node 0x26 [Pin Complex] wcaps 0x400201: Stereo Digital
  Pincap 0x00010030: IN OUT EAPD
  EAPD 0x0:
  Pin Default 0x47c421f0: [N/A] SPDIF In at Ext Rear Panel
    Conn = RCA, Color = Grey
    Misc = NO_PRESENCE
  Pin-ctls: 0x00:
Node 0x27 [Audio Input] wcaps 0x10051b: Stereo Amp-In
  Amp-In vals:  [0x80 0x80]
  SDI-Select: 0
  PCM:
    bits [0xa]: 16 24
    formats [0x1]: PCM
  Power states:  D0 D1
  Connection: 1
     0x21
Codec: Motorola Si3054
Address: 1
MFG Function Id: 0x2 (unsol 1)
Vendor Id: 0x10573055
Subsystem Id: 0x10573055
Modem Function Group: 0x1
--endcollapse--
!!ALSA Device nodes
crw-rw----+ 1 root audio 116,  2 Sep 24 08:57 /dev/snd/controlC0
crw-rw----+ 1 root audio 116,  7 Sep 24 08:57 /dev/snd/hwC0D0
crw-rw----+ 1 root audio 116,  8 Sep 24 08:57 /dev/snd/hwC0D1
crw-rw----+ 1 root audio 116,  4 Sep 24 08:59 /dev/snd/pcmC0D0c
crw-rw----+ 1 root audio 116,  3 Sep 24 09:01 /dev/snd/pcmC0D0p
crw-rw----+ 1 root audio 116,  6 Sep 24 08:57 /dev/snd/pcmC0D6c
crw-rw----+ 1 root audio 116,  5 Sep 24 08:57 /dev/snd/pcmC0D6p
crw-rw----+ 1 root audio 116,  1 Sep 24 08:57 /dev/snd/seq
crw-rw----+ 1 root audio 116, 33 Sep 24 08:57 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root  60 Sep 24 08:57 .
drwxr-xr-x 3 root root 240 Sep 24 08:57 ..
lrwxrwxrwx 1 root root  12 Sep 24 08:57 pci-0000:04:01.0 -> ../controlC0
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: VT82xx [HDA VIA VT82xx], device 0: VT1708 Analog [VT1708 Analog]
  Subdevices: 0/1
  Subdevice #0: subdevice #0
card 0: VT82xx [HDA VIA VT82xx], device 6: Si3054 Modem [Si3054 Modem]
  Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
  Subdevices: 1/1
  Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card 0 [VT82xx]
Card hw:0 'VT82xx'/'HDA VIA VT82xx at 0xd9000000 irq 17'
  Mixer name	: 'VIA VT1708'
  Components	: 'HDA:11061708,173410d9,00100700 HDA:10573055,10573055,00100700'
  Controls      : 24
  Simple ctrls  : 12
Simple mixer control 'Master',0
  Capabilities: pvolume pvolume-joined pswitch pswitch-joined
  Playback channels: Mono
  Limits: Playback 0 - 27
  Mono: Playback 27 [100%] [0.00dB] [on]
Simple mixer control 'Headphone',0
  Capabilities: pvolume pswitch
  Playback channels: Front Left - Front Right
  Mono:
  Front Left: Playback 27 [100%] [0.00dB] [on]
  Front Right: Playback 27 [100%] [0.00dB] [on]
Simple mixer control 'PCM',0
  Limits: Playback 0 - 255
  Mono:
  Front Left: Playback 255 [100%] [0.00dB]
  Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Line Out',0
  Mono:
  Front Left: Playback 25 [93%] [-3.50dB] [on]
  Front Right: Playback 25 [93%] [-3.50dB] [on]
Simple mixer control 'Mic',0
  Limits: Playback 0 - 31
  Mono:
  Front Left: Playback 29 [94%] [10.50dB] [on]
  Front Right: Playback 29 [94%] [10.50dB] [on]
Simple mixer control 'Capture',0
  Capabilities: cvolume cswitch
  Capture channels: Front Left - Front Right
  Limits: Capture 0 - 20
  Front Left: Capture 20 [100%] [35.00dB] [on]
  Front Right: Capture 20 [100%] [35.00dB] [on]
Simple mixer control 'Auto-Mute Mode',0
  Capabilities: enum
  Items: 'Disabled' 'Enabled'
  Item0: 'Disabled'
Simple mixer control 'Caller ID',0
  Capabilities: pswitch pswitch-joined
  Mono: Playback [on]
Simple mixer control 'Dynamic Power-Control',0
  Capabilities: enum
  Item0: 'Disabled'
Simple mixer control 'Jack Detect',0
  Mono: Playback [on]
Simple mixer control 'Loopback Mixing',0
  Capabilities: enum
  Item0: 'Disabled'
Simple mixer control 'Off-hook',0
  Mono: Playback [on]
!!Alsactl output
--startcollapse--
state.VT82xx {
	control.1 {
		iface MIXER
		name 'Line Out Playback Volume'
		value.0 25
		value.1 25
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 27'
			dbmin -4725
			dbmax 0
			dbvalue.0 -350
			dbvalue.1 -350
	control.2 {
		iface MIXER
		name 'Line Out Playback Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.3 {
		iface MIXER
		name 'Headphone Playback Volume'
		value.0 27
		value.1 27
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 27'
			dbmin -4725
			dbmax 0
			dbvalue.0 0
			dbvalue.1 0
	control.4 {
		iface MIXER
		name 'Headphone Playback Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.5 {
		iface MIXER
		name 'Loopback Mixing'
		value Disabled
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 Disabled
			item.1 Enabled
	control.6 {
		iface MIXER
		name 'Mic Playback Volume'
		value.0 29
		value.1 29
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -4025
			dbmax 1400
			dbvalue.0 1050
			dbvalue.1 1050
	control.7 {
		iface MIXER
		name 'Mic Playback Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.8 {
		iface MIXER
		name 'Auto-Mute Mode'
		value Disabled
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 Disabled
			item.1 Enabled
	control.9 {
		iface MIXER
		name 'Capture Volume'
		value.0 20
		value.1 20
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 20'
			dbmin 0
			dbmax 3500
			dbvalue.0 3500
			dbvalue.1 3500
	control.10 {
		iface MIXER
		name 'Capture Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.11 {
		iface MIXER
		name 'Master Playback Volume'
		value 27
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 27'
			dbmin -4725
			dbmax 0
			dbvalue.0 0
	control.12 {
		iface MIXER
		name 'Master Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.13 {
		iface CARD
		name 'Mic Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.14 {
		iface CARD
		name 'Speaker Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.15 {
		iface CARD
		name 'Front Headphone Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.16 {
		iface MIXER
		name 'Jack Detect'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.17 {
		iface MIXER
		name 'Dynamic Power-Control'
		value Disabled
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 Disabled
			item.1 Enabled
	control.18 {
		iface PCM
		name 'Playback Channel Map'
		value.0 3
		value.1 4
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.19 {
		iface PCM
		name 'Capture Channel Map'
		value.0 0
		value.1 0
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.20 {
		iface MIXER
		name 'Off-hook Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.21 {
		iface MIXER
		name 'Caller ID Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.22 {
		iface PCM
		device 6
		value 0
		comment {
			access read
			type INTEGER
			count 1
			range '0 - 36'
	control.23 {
		iface PCM
		device 6
		value 0
		comment {
			access read
			type INTEGER
			count 1
			range '0 - 36'
	control.24 {
		iface MIXER
		name 'PCM Playback Volume'
		value.0 255
		value.1 255
		comment {
			access 'read write user'
			type INTEGER
			count 2
			range '0 - 255'
			tlv '0000000100000008ffffec1400000014'
			dbmin -5100
			dbmax 0
			dbvalue.0 0
			dbvalue.1 0
--endcollapse--
!!All Loaded Modules
Module
appletalk
ax25
ipx
p8023
p8022
psnap
llc
bnep
bluetooth
rfkill
rndis_host
cdc_ether
usbnet
snd_hda_codec_si3054
evdev
snd_hda_codec_via
snd_hda_codec_generic
snd_hda_intel
powernow_k8
snd_hda_codec
snd_hda_core
edac_mce_amd
snd_hwdep
snd_pcm
edac_core
snd_timer
pcspkr
snd
joydev
serio_raw
soundcore
k8temp
video
battery
shpchp
ac
button
ext4
crc16
jbd2
crc32c_generic
fscrypto
ecb
glue_helper
lrw
gf128mul
ablk_helper
cryptd
aes_x86_64
mbcache
dm_mod
uas
usb_storage
sg
sr_mod
cdrom
sd_mod
ata_generic
psmouse
sata_via
pata_via
via_rhine
mii
i2c_viapro
ehci_pci
uhci_hcd
ehci_hcd
usbcore
usb_common
libata
scsi_mod
fan
thermal
!!Sysfs Files
/sys/class/sound/hwC0D0/init_pin_configs:
0x1c 0x410110f2
0x1d 0x01a190f0
0x1e 0x418130fe
0x1f 0x110140f0
0x20 0x022140f0
0x21 0x42a190f0
0x22 0x410160f1
0x23 0x410120f4
0x24 0x593301f7
0x25 0x474411f0
0x26 0x47c421f0
/sys/class/sound/hwC0D0/driver_pin_configs:
/sys/class/sound/hwC0D0/user_pin_configs:
/sys/class/sound/hwC0D0/init_verbs:
/sys/class/sound/hwC0D0/hints:
/sys/class/sound/hwC0D1/init_pin_configs:
/sys/class/sound/hwC0D1/driver_pin_configs:
/sys/class/sound/hwC0D1/user_pin_configs:
/sys/class/sound/hwC0D1/init_verbs:
/sys/class/sound/hwC0D1/hints:
!!ALSA/HDA dmesg
[    6.574204] powernow_k8: Found 1 Mobile AMD Sempron(tm) Processor 3600+ (1 cpu cores) (version 2.20.00)
[    6.601987] snd_hda_intel 0000:04:01.0: PCI: Disallowing DAC for device
[    6.607791] snd_hda_intel 0000:04:01.0: CORB reset timeout#1, CORBRP = 0
[    6.816281] tsc: Marking TSC unstable due to cpufreq changes
[    6.822689] ACPI: Battery Slot [BAT0] (battery present)
[    6.923403] snd_hda_codec_via hdaudioC0D0: autoconfig for VT1708: line_outs=1 (0x1f/0x0/0x0/0x0/0x0) type:line
[    6.923416] snd_hda_codec_via hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    6.923422] snd_hda_codec_via hdaudioC0D0:    hp_outs=1 (0x20/0x0/0x0/0x0/0x0)
[    6.923427] snd_hda_codec_via hdaudioC0D0:    mono: mono_out=0x0
[    6.923431] snd_hda_codec_via hdaudioC0D0:    inputs:
[    6.923436] snd_hda_codec_via hdaudioC0D0:      Mic=0x1d
[    7.362010] input: HDA VIA VT82xx Mic as /devices/pci0000:00/0000:00:13.0/0000:04:01.0/sound/card0/input15
[    7.362850] input: HDA VIA VT82xx Speaker as /devices/pci0000:00/0000:00:13.0/0000:04:01.0/sound/card0/input16
[    7.363329] input: HDA VIA VT82xx Front Headphone as /devices/pci0000:00/0000:00:13.0/0000:04:01.0/sound/card0/input17
[    7.457131] usbcore: registered new interface driver cdc_ether
